Old 9th June 2018, 21:26   #15861  |  Link
pacaveli420
BluRay Compliant Profile
Hey - someone (I think it was Atak) helped me build a bluray compliant profile for x264....years ago. I've read through a lot of the documentation and forums on the options for x265, but there are a lot of options. Can someone assist in setting up something similar for x265?
x264 BluRay Profile:
--level 4.1 --aud --nal-hrd vbr --vbv-bufsize 50000 --vbv-maxrate 50000 --filter 0,0 --ref 4 --min-keyint 1 --keyint 24 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh
My Attempt at x265:
--profile main10 --level 5.1 --output-depth 10 --hrd --vbv-bufsize 100000 --vbv-maxrate 100000 --ref 4 --min-keyint 1 --keyint 24 --bframes 4 --b-adapt 2 --no-b-pyramid --subme 3 --me umh --no-open-gop --aud --repeat-headers
I think some of these may not be needed as RipBot automatically sets some of them (b-adapt?). I'm also assuming that I don't need to flag any colormatrix/colorprim or related options as RipBot has the option in the GUI for 709/2020. Or, at least it did, I don't see those now. Maybe it auto detects now?
pacaveli420 is offline   Reply With Quote
Old 10th June 2018, 00:31   #15862  |  Link
byteshare
ByteShare
byteshare's Avatar
My Attempt at x265:
RipBot uses the medium present unless defined as something else:
http://x265.readthedocs.io/en/default/presets.html
Have you seen this thread: https://forum.doom9.org/showthread.php?t=174491
Has examples that are supposed to work.
Old 10th June 2018, 02:45   #15863  |  Link
Jake802
Originally Posted by varekai View Post
Not shure what you mean with JAVA installed?
Renaming Install.cmd to Install.cmd.bak will prevent RipBot to auto update, if you at some point want to update RipBot just remove .bak
I have JAVA Installed and when I go to run the program it tells me its not installed.
Jake802 is offline   Reply With Quote
Old 10th June 2018, 08:39   #15864  |  Link
varekai
I believe RipBot requires Java 32bit.
Perhaps Atak can confirm that?
Old 10th June 2018, 09:06   #15865  |  Link
Jake802
Thanks that dd the trick!
Old 11th June 2018, 07:45   #15866  |  Link
byteshare
ByteShare
byteshare's Avatar
Having an issue with color space on a 10bit x264:
https://imgur.com/a/V1GswgQ
Link to the file:
https://mega.nz/#F!I0QjVRBQ!sXl7gbM-ZfspEdwvrezNlA
I think it has to do with the Chroma subsampling being 4:4:4 and not 4:2:0, but not 100%
Anyone know a work around?
http://avisynth.nl/index.php/Convert
Not sure which convert string to use in this case.
Old 11th June 2018, 16:47   #15867  |  Link
byteshare
ByteShare
byteshare's Avatar
I saw there was an update to the detectborders, anything we should be looking for to give feedback?
Old 11th June 2018, 20:50   #15868  |  Link
byteshare
ByteShare
byteshare's Avatar
Updated RipBot and seems to be working now. Thank you.
Old 12th June 2018, 06:11   #15869  |  Link
thezfunk
I have the same problem and updating 32 bit Java did not do the trick. It still says it is not installed. Appears that Ripbot is 1.23.0
thezfunk is offline   Reply With Quote
Old 12th June 2018, 17:32   #15870  |  Link
byteshare
ByteShare
byteshare's Avatar
Have you tried removing Java completely and then reinstalling? I've had to do that in the past.
Old 14th June 2018, 01:37   #15871  |  Link
iSeries
Feature request, being able to select a preferred language in settings, so that only audio/subs in the preferred language get demuxed, rather than all of them
Old 16th June 2018, 13:14   #15872  |  Link
activoice
Java not detected
Same here Ripbot 1.23 is not detecting Java on one of my PCs... Works fine on 3 others.
I have tried uninstalling and deleting folders, deleted the old registry keys as well before reinstalling just 32 bit java, and it still won't detect it.
I think I saw that ripbot looks for a registry key to detect if java is installed, and that key is there on this PC and as far as I can tell what's in that registry key matches the registry of the PC's it works fine on..
activoice is offline   Reply With Quote
Old 16th June 2018, 15:50   #15873  |  Link
byteshare
ByteShare
byteshare's Avatar
If you haven't make sure you go through this guide for reg keys:
https://java.com/en/download/help/manual_regedit.xml
I found a tool once for removing old java installs that helped me but I can't seem to find it again, sorry.
Old 16th June 2018, 17:08   #15874  |  Link
activoice
Yup I have tried uninstalling and verified that Registry keys were deleted with the uninstall, then reinstalled both the 64 bit and 32 bit versions.
I also made sure that I have the registry keys that I think Ripbot uses to detect that Java is installed:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\JavaSoft\Java Runtime Environment
Old 18th June 2018, 02:58   #15875  |  Link
thezfunk
Still having problems myself. I might have discovered something. When I delete Ripbot and reinstall it, it starts with version 1.22 and then works...for the first run. After I close it and open it again it checks for updates and installs 1.23 and then I get the Java can't be found message. I think this is repeatable, at least, it has been every time I have tried it.
Old 18th June 2018, 11:35   #15876  |  Link
run in cmd
java.exe -version 2> %TEMP%\java_version.txt
show me what you get in java_version.txt file
Old 20th June 2018, 05:06   #15877  |  Link
activoice
run in cmd
This is what I get
java version "1.8.0_172"
Java(TM) SE Runtime Environment (build 1.8.0_172-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.172-b11, mixed mode)
This problem only started happening after the update to 1.23, before that it detected Java fine.
Old 23rd June 2018, 17:56   #15878  |  Link
mparade
"Automatic HDR information retention while encoding to HEVC format". Can this readout be considered reliable?
I have a lot of HDR movies willing to encode while maintaining the original HDR metadata.
Is it possible to keep more than 2 audio streams from the source? Is it allowed to replace encoders used by Ripbot with newer versions?
Thanks for the reply.
Old 23rd June 2018, 18:56   #15879  |  Link
This data is taken from mediainfo so It should be reliable. I do not see any complaints so far.
yes.
Old 23rd June 2018, 19:46   #15880  |  Link
mparade
I was asking just because of this statement: "due to the changes in mediainfo for Master-Display will not auto-load anymore. Since mediainfo removed the color coordinates. It only shows the colorspace now."
and this statement at forum of StaxRip: "The old version gave bad data readouts when it came to HDR10."
I have to embed the metadata correctly into the reencodes. I did not know that Ripbot is using the same program to read them out.
