19th March 2016, 02:47 | #3681 | Link |
3d and other issues
Hi
I'm trying to set up a machine which is able to Play back 3d-mvc (without PowerDVD or StereoscopicPlayer, which both do work)... Since for this, one needs madVR and LAV, I had to change the set-up of MPC-BE... out of this, two questions arise : - MPC-BE does not remember anymore the last Video Position if the playback is interrupted/stopped; how do I re-enable this Feature with LAV/madVR ? - it would be nice, if MPC-BE would provide LAV and madVR as internal filters with Basic Settings, which would enable "out of the box" Standard playbach but also 3d... because I was not able to make it work for 3d (Standard 2d-1080p works but 3d only with but extrem stuttering/droped Frames) Thanks Last edited by arrgh; 19th March 2016 at 02:52. |
19th March 2016, 05:20 | #3682 | Link |
Update Japanese translation
Hello.
This is a latest mplayerc.ja.rc.txt. It's based on [r1260]. http://www84.zippyshare.com/v/5EubAJS2/file.html |
19th March 2016, 07:29 | #3684 | Link |
No - it's impossible.
19th March 2016, 11:12 | #3685 | Link |
@Socket774
Thanks. Updated in r1278.
19th March 2016, 18:19 | #3686 | Link |
https://drive.google.com/file/d/0B4y...ew?usp=sharing
MPC-BE can't play this file -> I get so sound. VLC media player can play it. |
19th March 2016, 20:03 | #3687 | Link |
Just use Tee on stdin. That should work.
Roelofs Coaching |
19th March 2016, 21:57 | #3688 | Link |
@Klaus1189
Fixed in r1286.
21st March 2016, 11:06 | #3689 | Link |
Thank you
I updated german translation based on r1291: https://drive.google.com/file/d/0B4y...ew?usp=sharing I found a menu which is a bit too small for almost all strings in dropdownlist: https://drive.google.com/file/d/0B4y...ew?usp=sharing Can you increase the size somehow, so the strings are not cut off? |
21st March 2016, 12:27 | #3690 | Link | |
21st March 2016, 19:39 | #3692 | Link | |
Nevcairiel confirmed that LAV will never do transcoding, so I will need also in future the MPC-BE internal filters to transcode aac-5.1 on the fly to ac3-5.1... So, there remains only the issue that MPC-BE does not remember anymore (with LAV+madVR) the last playback position of the played videos... thanks |
22nd March 2016, 07:46 | #3694 | Link | |
22nd March 2016, 08:45 | #3695 | Link |
Can you please increase the size of the drop down lists to the left, there should be some space also for other languages, so the strings aren't cut off when the longest ones are selected. |
22nd March 2016, 09:45 | #3696 | Link |
For me it's working fine, position remember and restore.
24th March 2016, 15:16 | #3697 | Link | |
I use SPDIF; since the AV-Receiver is not able to decode AAC, I need to decode in the Player; with PCM I'm limited to Stereo; therefore the internal MPC-BE Decoder is set to pass through DD and DTS and to transcode everything else to AC3 which gives me 5.1... in general I want to keep things simple : not install more codecs than necessary; LAV and madVR makes it already complicated enough... therefore I hoped that LAV could do it, so would not need to look in two places...but no such luck... |
26th March 2016, 07:57 | #3698 | Link |
Cannot play properly this 3840x2160 UHD 60.000p file with internal Filters. LAV Filters are fine.
http://distribution.bbb3d.renderfarm...fps_normal.mp4 |
26th March 2016, 12:48 | #3700 | Link |
Look at display stats the red and green line should be parallel when using the Standard refresh rate of 60 Hz, but they don't. And you already see that the framerate is at about 28 fps, way too low. The videoengine is at about 98 %.
If I use external LAV Filters you see that the picture is played smooth at 60 Hz. The video engine is at very low load. Perfect playback. When testing be sure to disable every external filter. Only use the internal ones of 1298. I used that version too. |
