27th September 2017, 18:50 | #4681 | Link | |
madVR - zoom control: - x disable scaling if image size changes by only: ... 25 lines or less - x move subtitles: ... to bottom of the screen/window - x auto detect hard coded black bars - x notify media player about cropped black bars: ... no more than once every 2 sec - x keep bars visible if they contain subtitles: ... forever - x crop black bars MPC-BE - Options: - Subtitles: -- Subtitle renderer: internal subtitle renderer -- x Prefer external subtitles over embedded subtitles -- x Use Subresync (this is an amazing feature from Gabest!) - Subtitles - Rendering: -- disable here: "Override placement" -- Sub pictures to buffer: 10 -- Max texture resolution: Desktop -- x Allow dropping some subpictures if the queue is running late - Subtitles - Default Style: -- Screen Alignement & Margins: --- bottom middle --- Left, Top, Right: 20 --- Bottom: 9 --- disable here: "Position subtitles relative to the video frame" -- Border style: Opaque box, border width: 2, Shadow width: 3 -- Colors & Transparency: --- Primary, Secondary: ~90% ; Outline: ~60% ; Shadow: ~50% --- disable here: "Link alpha channels" -- Font: Arial, size: 16 (depends on the size of the screen) I think it works OK (using external LAV filters (copyback direct mode) and madVR), I saw once when LAV reported that copyback is used and MPC-BE didn't display GPU icon: with Ducks.Take.Off.2160p.QHD.CRF25.x264
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 27th September 2017 at 18:55. |
27th September 2017, 20:41 | #4682 | Link | |
Can you explain to me what the option you use does? MadVR configuration is not so clear too. If it's not lot of bother Thanks!!
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 27th September 2017 at 20:50. |
28th September 2017, 04:40 | #4683 | Link | |
MPC-BE 1.5.1 (build 2960) beta, LAV Video Decoder 0.70.2.74-git.
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
28th September 2017, 19:02 | #4684 | Link | |||
- VSFilter is equal to the internal subtitle renderer! - and the reason is the mentioned SubResync ! (View->SubResync (CTRL+6)) Quote:
madVr: - x disable scaling if image size changes by only: ... 25 lines or less ---- it doesn't turn on the scaling algorithms for small size changes, e.g.: if your display is 1920x1080 and your video file 1904x1064 (e.g. with web-dls) - x keep bars visible if they contain subtitles: ... forever ---- this is for hardcoded subs in black bar MPC-BE: -- x Prefer external subtitles over embedded subtitles ---- it will always select first the external sub (srt) if it exist and you have set a preferred language at "Options -> Playback -> Default track preference; Sub: 'hu hun en eng' " -- Max texture resolution: Desktop ---- renders the sub at desktop resolution: it will be more finer --- disable here: "Position subtitles relative to the video frame" ---- since we cropped the possible black bars in madVR it's important to disable this: it will always position relative to the window of the player this way So, the important settings were to achieve what you wanted: madVR - zoom control: - x move subtitles: ... to bottom of the screen/window - x auto detect hard coded black bars - x notify media player about cropped black bars: ... no more than once every 2 sec - x keep bars visible if they contain subtitles: ... forever - x crop black bars MPC-BE - Options: -- Subtitle renderer: internal subtitle renderer - Subtitles - Rendering: -- disable here: "Override placement" -- Screen Alignement & Margins: --- Bottom: 9 --- disable here: "Position subtitles relative to the video frame"
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 28th September 2017 at 19:05. |
28th September 2017, 20:07 | #4685 | Link | |
So I effectively need to crop the black bars in the madvr settings? And there is the other command to keep them visible if there are subs. What this is about? If I want always the black bars instead? My doubt is because black bars are cropped only if i select the option 'if there are big black bars', so i can delete the bars completely, so what's the use of the option 'crop black bars'? i can't see difference if i disable it. And, can i use these settings with LAV Splitter installed and active? Hope it's clear :P Thanks again and again Inviato dal mio ASUS_Z00LD utilizzando Tapatalk
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 28th September 2017 at 20:55. |
1st October 2017, 12:56 | #4687 | Link | |
Well, the idea behind cropping black bars is that video card has less amount of data to deal with. If it's not an issue for you then you don't need this feature in madvr.
Can you ask the rest of the question in madvr thread since they're not mpc-be related?
1st October 2017, 13:42 | #4688 | Link | |
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
2nd October 2017, 11:24 | #4689 | Link |
Good to hear it, enjoy!
2nd October 2017, 17:43 | #4690 | Link |
If I use madvr and enable "delay playback until renderer is full" the taskbar indicator (is it called that way?) displays pause and yellow color progress of file. Is that something that can be fixed? In MPC-BE or madvr?
4th October 2017, 04:26 | #4693 | Link | |
No.
4th October 2017, 04:27 | #4694 | Link |
Yeah, I was wanting something a bit tidier than that. Prefer to stay in fullscreen and just use tasteful OSD display rather than have some window come up over the video, plus you need to scroll..
Will you consider? |
6th October 2017, 04:05 | #4695 | Link |
@ryrynz
I do not understand your problem. But on the basis of what I understood, my answer is no.
6th October 2017, 07:11 | #4696 | Link |
I want without breaking out of full screen mode to tell what the audio output is. This way I can set the receiver to Stereo x7 if the audio is stereo rather than some surround mode. ATM I have to use properties (as you said) and scroll or come out of full screen to click the AUD button. A simple OSD message showing the audio track information is neat and quick. Perhaps along with show name of media file we can include audio info video info as well when file first loads rather than just title only?
Example. Last edited by ryrynz; 6th October 2017 at 08:08. |
6th October 2017, 08:21 | #4697 | Link | |
8th October 2017, 16:07 | #4698 | Link |
Is there a way to start the program with a preset directory where my media files would be found? I tried to do it by starting the program using a shortcut, but it didn't make any difference. File Open File/URL... defaults to Documents on C drive, but I would prefer it to point to a different directory.
8th October 2017, 18:19 | #4699 | Link |
@Zinglar
Open any file in the desired folder.
