Old 26th April 2019, 21:31   #55961  |  Link
@Tpain145
if you send UHD then you avoid the scaler in the TV.
personal advise don't get a vizio.
Old 26th April 2019, 21:58   #55962  |  Link
Tpain145
@Tpain145
Thanks. It's such a shame that vizio has never fix this issue with their tv's. They offer great bang for your buck.
Tpain145 is offline   Reply With Quote
Old 26th April 2019, 23:03   #55963  |  Link
just to make sure.
you can send any source resolution to the TV at UHD.
Old 26th April 2019, 23:19   #55964  |  Link
Originally Posted by oldpainlesskodi View Post
Hope it helps.
I'm on 1920x1080, thanks though. Anyone else on this resolution with an Nvidia card on newer drivers that have some settings I can try?
I'll keep trying the various options that madVR offers.
No luck unfortunately with both madVR and CRU. I noted some of the recommended settings madVR gave me (various back porch changes to the main 23Hz mode) which I used CRU to try a few of but I still get one frame repeat every 12 mins or so regardless of what I change. This custom 23hz mode is showing in the detailed settings window and I reboot afterwards so I expect that's all I need to do to get this working, but it doesn't appear to be changing anything. Anyone with some serious experience with CRU/Nvidia able to give a hand, maybe in private? Either I get this working or it's back to 385.28 and avoid Windows 1903 as a result.
Old 27th April 2019, 01:30   #55965  |  Link
toki
I wish you hadn't mentioned anything about the 720 and sd on a vizio. I went in to test those and they don't look as pronounced as 1080 or 4k, but now I'm getting stuttering again on 4k after doing it. don't do this to me!!!!!
toki is offline   Reply With Quote
Old 27th April 2019, 05:22   #55966  |  Link
suanm
Is there anyone who took a blu-ray player named oppo203 cracked version 60? My question is which has better video quality between MadVR NGU sharp(high) exclusive mode and oppo203?
I'm gonna buy an oppo203 cracked version 60 if the oppo203 makes me see better video quality than MadVR NGU sharp(high) exclusive mode does.
Thanks in advance for your reply if you would like to reply to my question.
suanm is offline   Reply With Quote
Old 27th April 2019, 06:08   #55967  |  Link
End of the day it's your judgment to make what you prefer the look of, from a technical standpoint no other video processing equipment AFAIA offers the same processing capabilities.
Old 27th April 2019, 06:23   #55968  |  Link
suanm
So that means it's better than oppo203 to use madvr in order to get better video quality? By the way,what does the AFAIA mean?
Old 27th April 2019, 07:29   #55969  |  Link
hotripper
As Far As I Am Aware
3700X - RTX2070 - 970EVO - EVGA Supernova 750W Gold - Sony KD55X720E
hotripper is offline   Reply With Quote
Old 27th April 2019, 07:32   #55970  |  Link
suanm
Ah,Got it.Thanks a lot
Old 27th April 2019, 08:43   #55971  |  Link
There isn't any DVD/Blu-ray player on the market that can compare with what madVR does, it's just a question of what you feel is good enough.
Old 27th April 2019, 08:57   #55972  |  Link
suanm
Thank you again,i got it.I abandon the idea to buy an oppo203 blu-ray player after i take you.r advice.I will keep using madvr as my only renderer
Old 27th April 2019, 10:12   #55973  |  Link
tabari
Cpu for the best image quality for 1080p to 2160p upscale
Hello everyone,
I currently have an i5 4670k and a 1080 ti.
I want to get the best possible image quality with MPC-HC + Madvr both for native 2160p videos and also for 1080p to 2160p upscale. I will watch them on a quite large 4k Samsung TV. Which CPU would You recommend for this purpose ?
Budget is not an issue, but I don't want to throw away my hard earned money either. Do I really need an i7 8700 ? Or can I get the same best results also with an i7 7700 ?
I have no experience with overclocking, so I prefer a non-K intel cpu.
Last but not the least, please let me know if my gpu 1080 ti is not enough for the same purpose.
Thanks in advance for the replies.
tabari is offline   Reply With Quote
Old 27th April 2019, 10:56   #55974  |  Link
You honestly don't need to change anything to get the "best" image quality. A 1080Ti offers plenty of performance for your required task. To make the most of it you will need profiles, start with Asmodians Max Quality settings profile found at the bottom of this post here and edit to suit the slightly lower performance of the 1080Ti.
Old 27th April 2019, 12:41   #55975  |  Link
Charky
Don't buy anything.
Your i5 is fine and CPU is (mostly) irrelevant for HTPC-related video decoding/processing as most of the work is done by the GPU. I use a cheap i3 6100k in my HTPC (which is 1/3 less powerful than your current CPU) with a GTX 1070 and everything runs smoothly.
Your current setup is more than enough to achieve great PQ.
Charky is offline   Reply With Quote
Old 27th April 2019, 13:49   #55976  |  Link
TechnoPeasant
Hey guys, I'm running into an issue attempting to output 10-bit from MadVR, despite having native display bitdepth set to 10-bit or higher. As you can see in the screenshot below, I have my nvidia driver set to 12-bit as well. I'm aware that setting everything to 8-bit w/ dithering might be the optimal choice, but I decided to do some experimenting. Is there some way I can determine why MadVR is outputting at 8-bit, and not 10-bit as I have it set? Thanks!
TechnoPeasant is offline   Reply With Quote
Old 27th April 2019, 14:37   #55977  |  Link
giulianoprs
@ TechnoPeasant test FSE fullscreen exclusive mode .
How did you set the LAV filter?
giulianoprs is offline   Reply With Quote
Old 27th April 2019, 14:47   #55978  |  Link
Charky
Have you tried rebooting Windows ?
I know it seems stupid but i run into this issue quite often (madvr unable to switch to "D3D11 exclusive (10 bits)" and sticking to "D3D11 fullscreen windowed (8 bits)") even with FSE enabled, and a reboot always fixes it...
Hijacking the topic to ask...
Why would that be ?
Old 27th April 2019, 15:30   #55979  |  Link
chros
chros's Avatar
What's your OS? Win8 only supports FSE, FSW only available in Win10.
Old 27th April 2019, 17:24   #55980  |  Link
chrisssj2
Fullscreen windowed is not working for me in Windows10 latest update.
ONLY fullscreen exclusive gives me HDR logo on my LGOLED TV.
chrisssj2 is offline   Reply With Quote
