Old 13th December 2019, 10:34   #7261  |  Link
markiemarcus
Originally Posted by RainyDog View Post
Qg-size is still a bit of ahead scratcher for me. In theory, 8 should yield bigger size encodes with the most detail retention but at the expense of more artifacting. Yet everytime I've tested at the same settings and CRF, qg-size 16 comes out the biggest, size 8 by far the smallest with 32 sat somewhere in between! So I usually just leave it at the default of 32.
If you restore limit-tu , tu-intra-depth and tu-inter-depth to the default, I suspect things will start behaving like you'd expect with the filesize.
markiemarcus is offline   Reply With Quote
Old 13th December 2019, 12:53   #7262  |  Link
_kermit
Sure, the below is always my starting point then I tweak from there if necessary with a dial or two down on --aq-strength and/or a notch or two up on --psy-rd. This is for a broad range of film sources at 1080p resolution.
thanks, I'll give that a try.
Can anyone provide something like that for UHD/HDR?
_kermit is offline   Reply With Quote
Old 13th December 2019, 14:25   #7263  |  Link
RainyDog
I use the same template for HDR encodes just with the additional required HDR knobs (hdr-opt etc.) turned on. CRF needs to be bumped down a couple of notches for HDR though ie. CRF 17 for SDR = CRF 15 for HDR.
Again, this is all at 1080p resolution. For UHD all I'd probably change is CTU 32 > 64, me-range 40 > 57 and possibly qg-size 32 > 64.
RainyDog is offline   Reply With Quote
Old 13th December 2019, 14:33   #7264  |  Link
RainyDog
I'll have a look at that then.
I've never really seen much difference in quality or size between tu-intra-depth inter-depth and limit-tu all set to 4 versus 1, 1 and 0 anyway. I only really use the former as it's a buffed setting with minor performance hit.
I think the gains from increasing tu-intra and inter-depth are probably only really seen without using limit-tu. But the speed decrease is pretty severe then.
Old 13th December 2019, 20:04   #7265  |  Link
markiemarcus
I don't really understand them to be perfectly honest lol. But I have found instances where tu-intra and tu-inter being set to 4, with limit-tu 0, causes grain freezing and huge blocks on flat textures. It spooked me so I've dodged them since.
Old 13th December 2019, 21:57   #7266  |  Link
fauxreaper
Without limit-tu, higher values of tu-intra and tu-inter only increase compression, not visual quality. limit-tu 1 + tu-inter 4 + tu-intra 4 should give better quality than using limit-tu 0.
fauxreaper is offline   Reply With Quote
Old 13th December 2019, 22:09   #7267  |  Link
markiemarcus
That makes sense. I've also observed less severe versions of the issue with limit-tu 4 + tu-inter 4 + tu-intra 4. Would limit-tu 1 + tu-inter 4 + tu-intra 4 be higher quality?
Edit: Nope. After some more testing I prefer the results with limit-tu 4 + tu-inter 3 + tu-intra 3.
Old 14th December 2019, 23:47   #7268  |  Link
vpupkind
I use rdLevel 4 and almost exclusively --limit-refs 1. If the performance impact weren't so dramatic, I'd use rdLevel 6. It's just better, there's no getting around that, but it is awfully slow.
Try --dynamic-rd, it typically provides a pretty decent quality boost over rd-level=4
vpupkind is offline   Reply With Quote
Old 16th December 2019, 13:31   #7269  |  Link
markiemarcus
Cheers for the suggestion. How would one go about using this reliably in CRF mode? Seems to rely on VBV.
Old 16th December 2019, 14:23   #7270  |  Link
l00t
Where's my loot?
Over? According to the manual it should be helpful at 4 and below...
Originally Posted by x265 read the docs
--dynamic-rd <0..4>
Increases the RD level at points where quality drops due to VBV rate control enforcement. The number of CUs for which the RD is reconfigured is determined based on the strength. Strength 1 gives the best FPS, strength 4 gives the best SSIM. Strength 0 switches this feature off. Default: 0.
Effective for RD levels 4 and below.
l00t is offline   Reply With Quote
Old 16th December 2019, 14:33   #7271  |  Link
markiemarcus
"By comparison to" I assume.
Old 16th December 2019, 14:43   #7272  |  Link
Yanak
answering to myself about this, apparently the problem is there since a while now :
Found out this
https://bitbucket.org/multicoreware/...cpp-when-using
It fixes the cli if you make it with a single lib, but trying to make a multilib exe you end up with this :
https://bitbucket.org/multicoreware/...indicator_init
Then in the end i found the full fix needed for the code, it's this :
https://github.com/msg7086/x265-Yuuk...35c659d71beac9
Multilib 8+10+12Bit compiles correctly now with ICC 1910 from latest Intel System Studio 2020 integrated in VS2019 .
Posting it in case it helps someone else, spent a few days banging my head on this thing...
Yanak is offline   Reply With Quote
Old 18th December 2019, 07:05   #7273  |  Link
vpupkind
Quality-wise, it can give you (combined with rd-level=4) quality improvement getting you closer to rd-level=6 performance.
We've seen 3% BD-SSIM improvement from using it.
Old 18th December 2019, 07:22   #7274  |  Link
Boulder
Pig on the wing
Boulder's Avatar
According to the manual, it applies only to VBV capped encodes in special situations in the material. I think quite many of us don't use VBV constraints in personal encodes.
Old 18th December 2019, 08:12   #7275  |  Link
Barough
Barough's Avatar
x265 v3.2+22-a8a2c4c37267 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Old 18th December 2019, 16:26   #7276  |  Link
alexantr
alexantr's Avatar
Did anybody notice enabled b-intra makes more blur artifacts in motion?
alexantr is offline   Reply With Quote
Old 20th December 2019, 22:59   #7277  |  Link
bjoker
I'm basically into CLI stuff. I have no issues running ffmpeg with x265 10-bit using CRF with any x265 parameter value but can't figure out 2-pass encoding which fails in the 2nd pass. Could any one please guide me where I am doing wrong? @Selur please
Microsoft Windows [Version 10.0.18362.535]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\admin\Desktop\REMUX>ffmpeg -y -i "Testing-1min.mkv" -c:v libx265 -b:v 5000k -preset slow -pix_fmt yuv420p10le -x265-params "pass=1:aq-mode=3:bframes=8:sao=0:sar=0:selective-sao=0" -an -f mp4 NUL
ffmpeg version git-2019-12-19-99f505d Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 9.2.1 (GCC) 20191125
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf
libavutil 56. 36.101 / 56. 36.101
libavcodec 58. 65.100 / 58. 65.100
libavformat 58. 35.101 / 58. 35.101
libavdevice 58. 9.101 / 58. 9.101
libavfilter 7. 69.101 / 7. 69.101
libswscale 5. 6.100 / 5. 6.100
libswresample 3. 6.100 / 3. 6.100
libpostproc 55. 6.100 / 55. 6.100
[matroska,webm @ 0000015de81d9d80] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[matroska,webm @ 0000015de81d9d80] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 0000015de81d9d80] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Input #0, matroska,webm, from 'Testing-1min.mkv':
Metadata:
title : testing clip
encoder : libebml v1.3.9 + libmatroska v1.5.2
creation_time : 2019-12-18T23:24:19.000000Z
Duration: 00:01:00.02, start: 0.000000, bitrate: 23880 kb/s
Chapter #0:0: start 0.000000, end 12.012208
Metadata:
title : Chapter 09
Chapter #0:1: start 12.012208, end 60.008000
Metadata:
title : Chapter 10
Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Metadata:
BPS-eng : 22031553
DURATION-eng : 00:00:59.977000000
NUMBER_OF_FRAMES-eng: 1438
NUMBER_OF_BYTES-eng: 165173310
_STATISTICS_WRITING_APP-eng: mkvmerge v41.0.0 ('Smarra') 64-bit
_STATISTICS_WRITING_DATE_UTC-eng: 2019-12-18 23:24:19
_STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream #0:1(por): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), s16p (default)
Metadata:
title : Surround 5.1
BPS-eng : 1787265
DURATION-eng : 00:01:00.011000000
NUMBER_OF_FRAMES-eng: 5626
NUMBER_OF_BYTES-eng: 13406948
Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle (default)
Metadata:
BPS-eng : 55145
DURATION-eng : 00:00:55.535000000
NUMBER_OF_FRAMES-eng: 24
NUMBER_OF_BYTES-eng: 382812
Stream #0:3(chi): Subtitle: hdmv_pgs_subtitle
Metadata:
BPS-eng : 40979
NUMBER_OF_BYTES-eng: 284474
Stream #0:4(chi): Subtitle: hdmv_pgs_subtitle
Metadata:
BPS-eng : 42596
NUMBER_OF_BYTES-eng: 295697
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> hevc (libx265))
Press [q] to stop, [?] for help
x265 [info]: HEVC encoder version 3.2+15-04db2bfee5d6
x265 [info]: build info [Windows][GCC 9.2.1][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main 10 profile, Level-4 (Main tier)
x265 [info]: Thread pool 0 using 32 threads on numa nodes 0
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 5 / wpp(17 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3
x265 [info]: Keyframe min / max / scenecut / bias: 23 / 250 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 25 / 8 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
x265 [info]: References / ref-limit cu / depth : 4 / on / on
x265 [info]: AQ: mode / str / qg-size / cu-tree : 3 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : ABR-5000 kbps / 0.60
x265 [info]: tools: rect limit-modes rd=4 psy-rd=2.00 rdoq=2 psy-rdoq=1.00
x265 [info]: tools: rskip signhide tmvp strong-intra-smoothing lslices=4
x265 [info]: tools: deblock stats-write
Output #0, mp4, to 'NUL':
Metadata:
encoder : Lavf58.35.101
Metadata:
title : Chapter 09
Metadata:
title : Chapter 10
Stream #0:0(eng): Video: hevc (libx265) (hev1 / 0x31766568), yuv420p10le, 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 5000 kb/s, 23.98 fps, 24k tbn, 23.98 tbc
Metadata:
BPS-eng : 22031553
encoder : Lavc58.65.100 libx265
Side data:
cpb: bitrate max/min/avg: 0/0/5000000 buffer size: 0 vbv_delay: N/A
frame= 1438 fps=9.9 q=-0.0 Lsize= 38964kB time=00:00:59.85 bitrate=5333.1kbits/s speed=0.412x
video:38945kB audio:0kB subtitle:0kB other streams:0kB global headers:2kB muxing overhead: 0.050550%
x265 [info]: frame I: 12, Avg QP:19.99 kb/s: 27830.30
x265 [info]: frame P: 268, Avg QP:20.89 kb/s: 16318.63
x265 [info]: frame B: 1158, Avg QP:26.00 kb/s: 2539.48
x265 [info]: Weighted P-Frames: Y:0.4% UV:0.4%
x265 [info]: consecutive B-frames: 4.3% 0.7% 2.1% 52.9% 5.0% 6.1% 5.0% 21.8% 2.1%
encoded 1438 frames in 145.06s (9.91 fps), 5318.55 kb/s, Avg QP:25.00
C:\Users\admin\Desktop\REMUX>ffmpeg -i "Testing-1min.mkv" -c:v libx265 -b:v 5000k -preset slow -pix_fmt yuv420p10le -x265-params "pass=2:aq-mode=3:bframes=8:sao=0:sar=0:selective-sao=0" -an -f mp4 Testing-1min-2pass.mp4
[matroska,webm @ 00000198d82d9cc0] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 00000198d82d9cc0] Could not find codec parameters for stream 3 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 00000198d82d9cc0] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Metadata:
Metadata:
title : Chapter 09
Metadata:
title : Chapter 10
Metadata:
BPS-eng : 22031553
Metadata:
BPS-eng : 1787265
Metadata:
BPS-eng : 55145
Metadata:
BPS-eng : 40979
Metadata:
BPS-eng : 42596
Stream mapping:
x265 [error]: different scenecut setting than first pass (40 vs 40)
[libx265 @ 00000198d8356500] Cannot open libx265 encoder.
Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Conversion failed!
bjoker is offline   Reply With Quote
Old 20th December 2019, 23:34   #7278  |  Link
Selur
Selur's Avatar
try '-pix_fmt yuv420p10le -strict -1' instead of just '-pix_fmt yuv420p10le'
Old 21st December 2019, 00:31   #7279  |  Link
bjoker
Thank you Selur
Now it throws: (pasted last few lines)
[libx265 @ 000001bb8d550300] Cannot open libx265 encoder.
Conversion failed!
I ran 2 commands (for 2 passes separately) like this: (First pass goes fine but 2nd one fails)
ffmpeg -y -i "Testing-1min.mkv" -c:v libx265  -b:v 5000k -preset slow -pix_fmt yuv420p10le -strict -1 -x265-params "pass=1:aq-mode=3:bframes=8:sao=0:sar=0:selective-sao=0"  -an -f mp4 NUL
ffmpeg -i "Testing-1min.mkv" -c:v libx265 -b:v 5000k -preset slow -pix_fmt yuv420p10le -strict -1 -x265-params "pass=2:aq-mode=3:bframes=8:sao=0:sar=0:selective-sao=0" -an -f mp4 Testing-1min-2pass.mp4
Old 21st December 2019, 01:33   #7280  |  Link
Greenhorn
Originally Posted by bjoker View Post
Thank you Selur
Conversion failed!
The "different scenecut" error is caused by a bug in x265 builds 3.2+15 through 3.2+17; selur brought it up here a couple/three weeks ago, and it should be fixed if you can upgrade to a build (in or out of FFMPEG) that's 3.2+18 or later.
Greenhorn is offline   Reply With Quote
