10th January 2020, 13:01 | #781 | Link | |
Formerly davidh*****
10th January 2020, 13:18 | #782 | Link |
Can you elaborate? I'm not sure if I understand your point.
Groucho's Avisynth Stuff |
10th January 2020, 13:44 | #783 | Link |
Yep, M$ has their own unique [patent pending] way of keeping I.T. guys in work, the system/system32/SysWOW64 conundrum is not the only one of its kind.
EDIT: My own favourite is, "The system drive is the drive you boot to, and the boot drive is the one your system is on".
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th January 2020 at 13:46. |
10th January 2020, 14:18 | #785 | Link | |
https://stackoverflow.com/questions/...23671#37823671
15th January 2020, 09:56 | #786 | Link | |
https://forum.doom9.org/showthread.p...79#post1891279 |
17th January 2020, 17:51 | #787 | Link |
I'm also running into issues with v210 10bit input through QTGMC, and would like to ask for any pointers that you guys could give me.
I have a recent and clean installation of VirtualDub2, AviSynth+ and QTGMC. All 64bit working in a Windows10 environment. My simple Avisynth script works well with 8bit (uncompressed) input, but fails with 10bit v210 (uncompressed) input, giving the following error: Code:
--------------------------- File open error --------------------------- Avisynth open failure: TemporalSoften: Scenechange not available on RGB32/64 (D:/Program Files (x86)/AviSynth+/plugins64+/QTGMC.avsi, line 468) (D:\Users\miket\Videos\Process VHS Tapes\Files De-Interlaced\10bit Test 01.avs, line 10) --------------------------- OK --------------------------- Code:
AviSource("D:\Users\miket\Videos\Process VHS Tapes\Files Capture\10bit Test 01.avi") # #Settings for use of de-interlacing using QTGMC via AviSynth # #Version() SetFilterMTMode("QTGMC",2) # Put QTGMC into multithreading mode 2 #ConvertToYUY2() AssumeTFF() # Top Frame First or BFF QTGMC(Preset="Slower", Edithreads=2) Prefetch(threads=6) Code:
AVSMeter 2.9.7 (x64), 2012-2019, Groucho2004 VersionString: AviSynth+ 3.4 (r2923, 3.4, x86_64) VersionNumber: 2.60 File / Product version: 3.4.0.0 / 3.4.0.0 Interface Version: 6 Multi-threading support: Yes Avisynth.dll location: C:\WINDOWS\SYSTEM32\avisynth.dll Avisynth.dll time stamp: 2019-10-20, 13:58:12 (UTC) PluginDir2_5 (HKLM, x64): D:\Program Files (x86)\AviSynth+\plugins64 PluginDir+ (HKLM, x64): D:\Program Files (x86)\AviSynth+\plugins64+ [CPP 2.6 Plugins (64 Bit)] [Version, Time stamp] D:\Program Files (x86)\AviSynth+\plugins64+\ConvertStacked.dll [x.x.x.x, 2019-10-20] D:\Program Files (x86)\AviSynth+\plugins64+\DirectShowSource.dll [x.x.x.x, 2019-10-20] D:\Program Files (x86)\AviSynth+\plugins64+\ffms2.dll [x.x.x.x, 2016-12-29] D:\Program Files (x86)\AviSynth+\plugins64+\ImageSeq.dll [x.x.x.x, 2019-10-20] D:\Program Files (x86)\AviSynth+\plugins64+\masktools2.dll [2.2.18.0, 2018-09-05] D:\Program Files (x86)\AviSynth+\plugins64+\mvtools2.dll [2.7.41.0, 2019-05-02] D:\Program Files (x86)\AviSynth+\plugins64+\nnedi3.dll [0.9.4.53, 2019-06-06] D:\Program Files (x86)\AviSynth+\plugins64+\RgTools.dll [0.98.0.0, 2019-06-03] D:\Program Files (x86)\AviSynth+\plugins64+\Shibatch.dll [x.x.x.x, 2019-10-20] D:\Program Files (x86)\AviSynth+\plugins64+\TimeStretch.dll [x.x.x.x, 2019-10-20] D:\Program Files (x86)\AviSynth+\plugins64+\VDubFilter.dll [x.x.x.x, 2019-10-20] [Scripts (AVSI)] [Time stamp] D:\Program Files (x86)\AviSynth+\plugins64+\AnimeIVTC.avsi [2020-01-05] D:\Program Files (x86)\AviSynth+\plugins64+\colors_rgb.avsi [2019-10-20] D:\Program Files (x86)\AviSynth+\plugins64+\QTGMC.avsi [2020-01-05] D:\Program Files (x86)\AviSynth+\plugins64+\smdegrain.avsi [2020-01-05] [Uncategorized files] [Time stamp] D:\Program Files (x86)\AviSynth+\plugins64+\colors_rgb.txt [2019-10-20] Any help would be gratefully received. |
15th March 2020, 11:18 | #788 | Link | |
partially-informed layman
HOW TO DEAL WITH ZOOMS?
I am deinterlacing 1440x1080-25i HDV with QTGMC 3.364. I am having problems deinterlacing one clip that includes a fairly rapid zoom. Here's a short sample. Below is the type of script I'm using (in reality I'm frameserving AVI and using AviSource but DirectShowSource works directly on the sample clip): Quote:
Is there any way to deal with this? As a workaround I threw half the frames away with fpsdivisor=2 and then doubled the framerate with MFlowFps but the result isn't great. |
15th March 2020, 12:00 | #789 | Link | |
Also, Directshowsource would not be my first choice as a source filter (in fact, it should be a last resort). DGIndex/DGDecode work just fine with this source. By the way, your underwater videos are amazing.
Groucho's Avisynth Stuff Last edited by Groucho2004; 15th March 2020 at 14:10. |
15th March 2020, 19:35 | #790 | Link |
Does anybody know if i7-3770K supports AVX2 and if any of the following plugins might crash using this CPU?
AddGrainC.dll Average.dll Decomb.dll dfttest.dll dither.dll EEDI2.dll EEDI3.dll ffms2.dll fft3dfilter.dll KNLMeansCL.dll LSMASHSource.dll masktools2.dll modPlus.dll MPEG2DecPlus.dll mvtools2.dll Plugins_JPSDR.dll RgTools.dll TDeint.dll yadifmod2.dll Problem is somebody with Core i7-3770K gets 1114/0x45a ERROR_DLL_INIT_FAILED trying to use QTGMC. Timestamps and versions are listed here: https://docs.google.com/spreadsheets...it?usp=sharing Github Issue is here: https://github.com/staxrip/staxrip/issues/125 There have been minimum 5 bug reports with some terrible dfttest.dll error in recent months: https://www.google.com/search?q=stax...hrome&ie=UTF-8 StaxRip isn't particular smart when it tries to figure out which plugins need to be loaded, it analyzes the script code for function names and loads all plugins a script supports and not only the ones the filter configuration will actually use.
16th March 2020, 12:43 | #793 | Link | |||
The original HDV is TFF (I hope, as I've been using AssumeTFF with it for 10 years!), it was rendered in VEGAS as TFF, and MediaInfo reports TFF. I'm wondering whether the problem is simply related to the rate of zoom of the clip somehow making the fields seem reversed Quote:
16th March 2020, 13:15 | #794 | Link | |
Script: Code:
Import("E:\Apps\VideoTools\AVSPlugins\QTGMC.avsi") LoadPlugin("E:\Apps\VideoTools\DGDec\DGDecode.dll") MPEG2Source("F:\HDV-zoom-sample.d2v") AssumeBFF() QTGMC(preset = "Slow") Spline36Resize(1920,1080) AssumeFPS(50000, 1000) https://www.mediafire.com/file/swdxg...ample.mkv/file
16th March 2020, 13:58 | #795 | Link |
@pinterf
Thanks, one user could make it run by replacing Plugins_JPSDR as suggested by another user, I had the avx2 version included and replaced it now with the avx version. The other user did not reply yet. I don't have a particular interest in CPUs otherwise I would have avoided the issue or found the solution myself.
17th March 2020, 18:35 | #796 | Link | |
@Groucho2004
That file is indeed BFF and I have absolutely no idea why. I checked others in my archive, including clips in the same sequence, and they are TFF, as they should be for HDV. I fixed it with the following script: Quote:
Thanks very much for your help. |
17th March 2020, 21:07 | #797 | Link |
Nick, it's always nice to hear from you again. I miss all of our discussions in the old Vegas forum.
FWIW, whenever I have any problem, either with my own video or something someone gives me, I always first open it with this script: AssumeTFF() Separatefields() and walk through it one field at a time. If I see a problem, I change to BFF and try again. The number of videos out there with unexpected field order is enormous. In this country I still see video, every single day, that has field reversal, which gives you that funny, "juddery" look on any sort of fast movement. |
18th March 2020, 04:55 | #798 | Link |
@johnmeyer Hi John, nice to see you. Your old posts came up frequently whilst I was troubleshooting this.
I did suspect a field order problem before posting here, and did try BFF. But unfortunately, being out of the habit of using DGIndex/DGDecode, I chose to use DirectShowSource just for the purpose of getting the .m2t file open in AviSynth for troubleshooting. But DirectShowSource gets it totally wrong; it gives a weird and incorrect result for both TFF and BFF when stepping through the file at 50p; for example on that zooming clip, instead of "IN > OUT > IN > OUT etc" it goes "IN > DIFFERENT BUT NEITHER IN NOR OUT > OUT A BIT > IN > etc.". |
18th March 2020, 08:32 | #799 | Link | |
Edit: ffprobe (ffmpeg) also reports the field order like 'field_order=tt'. Apparently the mpeg2 TFF flag is set but in fact the field order has been reversed . Don't know how this can happen. Last edited by Sharc; 18th March 2020 at 09:41. |
18th March 2020, 09:38 | #800 | Link |
DirectShowSource can only be trusted as far as you actively control the selection of filters ... which many users may not be able to achieve. There might be a Telecine you are not aware of, or frame skips due to performance, whatever.
But even the material might be a mess. There are norm conversions of the worst kind, and the most pervert is content stuffing to achieve more time for ads (in case of TV broadcasts). Try to use a source filter one can trust. DG*Decode are among these, as well as FFMS2 or L-SMASH Works (with exceptions in rare cases, depending on the release). |
