3rd July 2010, 02:04 | #8682 | Link | |
Attempting to get full backup of "White Ribbon", none of BDR settings touched from the normal.
Getting the following: Quote:
Three attempts so far, all stops at 19.59% complete. Any suggestions? |
3rd July 2010, 02:04 | #8683 | Link | |
Hookahice
I'm looking at the comparison of woah!'s capture and it shows the files as MPEG-2 Transport stream while yours are listed as AVCHD video for the same files, and assuming it's the same movie why are there so many discrepancies? This might explain part of your problem. Perhaps you could enlighten us?
"Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep." Scott Adams Last edited by Sophocles; 3rd July 2010 at 17:07. |
3rd July 2010, 03:32 | #8684 | Link |
Hi guys,
just used BD-Rebuilder yesterday nite for the first time - thank you jdobbs for this wonderful app !!! I ripped "3:10 to Yuma" to HD via AnyDVD HD then down converted the Blu-Ray structure via BD-Rebuilder to 25GB size. Original size folder: 44.6 GB output size folder: 21.6 GB Original size main movie file: 27.9 GB output size main movie file: 11.9 GB Original video bitrate: 24.3 Mbps output video bitrate: 7 265 Kbps (max. bitrate 35 Mbps) So by the look of the numbers it seems like extras & menus got down converted by ca. 42% but the video file got down converted by ca. 58% ... Here are my questions regarding the usage of this app: (1.) Is 21.6 GB the maximum disc space available on a single layer BD ? If not, why does the app not use the max disc space available ? (2.) Is it possible to specify a desired (minimum) bitrate ? (3.) Is it possible to strip content (such as extras, audio tracks etc.) from the Blu-Ray structure ? (4.) Is it possible to define a lower bitrate setting for un-important content (such as extras, menus etc.) ? My intention is to keep as much as possible av quality (of the main movie) to fit on a 25GB single layer BD by keeping the Blu-Ray structure. Thanx for your advise in advance ! - M |
3rd July 2010, 09:07 | #8687 | Link | |
Any clues/advice on what I might be doing wrong to draw the following error?
It did all the re-encoding and failed at mkvmerge - what could I be doing wrong? Quote:
3rd July 2010, 11:55 | #8688 | Link | |
4th July 2010, 01:13 | #8689 | Link |
I'm sure SparKeyD has a valid point to some degree, but I've had out of sync issues too, on Dexter Season 2 Disk 1 and 2. I'm sure its not my machine specs as I have a Quad Core 2.4GHz processor with 8GB DDR2 RAM and all my HDD's are 7200 RPM. I'm sure my sync issue had more to do with using the PC while it was doing a backup or my media or bad burn. I'm redoing the First disk tonight to see if it happens (these were done some time ago on an old version of BD-RB).
4th July 2010, 12:45 | #8690 | Link |
Problem with main feature video playback (Star Trek IV)
Hi jdobbs,
Been finding I have problems with backing up one of the Star Trek (Blu-Ray) movie series. Namely Star Trek IV. I am ripping with DVDFab 7.0.7.0. With Star Trek IV the main feature .m2ts is unplayable with MPC (audio only playback) and file thumbnails are not created by the Haali/Makstroka splitter. However all the titles in the ripped BluRay disk playback with A/V just fine in Cyberlink PowerDVD 10. Also the .m2ts file plays back fine (w/ video) in Windows Media Player. I enclose the "MediaInfo" files for the (main feature) video stream in Star Trek III (which works with BD-RB just fine) and Star Trek IV (which doesn't play ball). I have followed your guidance on what version of FFDShow and Makstroka splitter to use... Any thoughts what is going wrong? Thanks Bob Star Trek III: Code:
General ID : 0 Complete name : F:\BD-R DL (folders)\(03) Star Trek III (BD-R DL)\BDMV\STREAM\00004.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 28.3 GiB Duration : 1h 45mn Overall bit rate : 38.6 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 1h 45mn Bit rate mode : Variable Maximum bit rate : 33.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Code:
General ID : 0 Complete name : F:\BD-R DL (folders)\(04) Star Trek IV (BD-R DL)\BDMV\STREAM\00004.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 31.9 GiB Duration : 1h 58mn Overall bit rate : 38.4 Mbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Duration : 1h 58mn Nominal bit rate : 27.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.560 Writing library : x264 core 67 Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=8 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=2 / wpredb=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=abr / bitrate=27841 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00:10.00 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Last edited by Bob Wya; 4th July 2010 at 13:02. |
4th July 2010, 13:37 | #8691 | Link |
Just as an FYI for anyone else that comes up with this problem.
I have had no problems with BD Rebuilder until about 2 days ago. It would load up and everything would act as it should, untill I told it to start the backup. It would start to run (getting as far as extracting the audio) and then freeze. The extraction would be stuck at 0.00%. After a few tests on my system and uninstalling BD Rebuilder and all it's necessary components, I found that txmuxer was what was freezing up. I found this via task manager. Once I stopped it from running, BD Rebuilder would then give an error and run again. After searching my machine for viruses and what not, it hit me, the anti-virus software. I use Kaspersky Internet Suite and it auto updates itself. So I decided to add BD Rebuilder as an exception so that it wouldn't scan it or anything it runs. Sure enough, I've got BD Rebuilder running again. So if anyone out there is running Kaspersky and BD Rebuilder looks like it's frozen like mine was, add it to the exception list and all should be working again. I hope this helps someone out there. |
4th July 2010, 15:57 | #8692 | Link | |
4th July 2010, 16:00 | #8693 | Link |
I use the newest version.
And are using the outout to MKV feature. And all of the movies I have done all comes out in much bigger size than I expected. Should be around DVD duallayer, but always get 10-12G files. Also for some reasons it selects the first Sound track as a default, and if I change it and safe the project and load the project file again, then it goes back to default? Very strange? My settings are shown below: [Options] MODE=1 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 MOVIEONLY_TYPE=5 ALTCRF=20 TARGET_SIZE=7910 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=dan;eng; SD_CONVERT=0 COLOR_BOOST=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=1 FULL_AVCHD=0 REMOVE_OUTPUT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 <--- Does this mean that it ignores the "Target size DVD-9" selection when using MKV? PRIORITY_CLASS=0 ENCODER=0 [Paths] SOURCE_PATH=L:\ WORKING_PATH=D:\WORKING_3\ |
4th July 2010, 16:53 | #8695 | Link |
Thanks for the quick reply...
So even if I use the 2 Pass option I can not get it to fit a DVD-9 in MKV. Only if I make a BD "copy" then it will limit the size. I have been using DVD rebuilder for years and was so familiar with the GUI that I just thought it worked the same way. (-; To bad I really wanted to be able to copy my MKV files to DVD-9 discs. |
4th July 2010, 17:24 | #8696 | Link | |
Aging Video Hobbyist
4th July 2010, 17:27 | #8697 | Link | |
Sorry, a simple reboot of my machine solved the problem. Do that so rarely, machine's on usually 24/7, I forgot the obvious. Thanks anyway, great product, sorry I muddled it up with my faux pas. |
4th July 2010, 17:31 | #8698 | Link | |
4th July 2010, 17:40 | #8699 | Link |
These have been rare for me, , but I was able to make a full backup to BD5 of a Universal title, and the audio works and is heard for the main title during playback on my Sony S360!
The movie is Leap Year, and though it does not have PiP or many other features, it is a successful full movie backup to DVD media of a Universal title! |
4th July 2010, 18:03 | #8700 | Link |
Not sure if anyone is having this issue, maybe its just me, backed up Dexter Season 2 Disk 1,Boondock Saints, and Sherlock Holmes. Getting really bad artifacting and blocks.. I uninstalled/reinstalled FFDSHow and the inspect and everything came up ok. The previous encode I did for dexter had spot on quality but the audio was out of sync.
I'm re-ripping Dexter now, going to run it through agian tonight. Its gotta be something with my system right? Inspect Code: Code:
- Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.2, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok Code:
[21:15:34] BD Rebuilder v0.34.02 (beta) - Source: DEXTER_SEASON_2 - Input BD size: 43.07 GB - Approximate total content: [03:35:53.607] - Target BD size: 22.90 GB - Windows Version: 6.1 [7600] - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [21:15:34] PHASE ONE, Encoding - [21:15:34] Extracting A/V streams [VID_00000] - [21:24:23] Reencoding: VID_00000 (1 of 6) - [21:24:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 75,384 frames - Bitrate: 8,666 Kbs - [21:24:23] Reencoding: VID_00000, Pass 1 of 2 - [22:29:05] Reencoding: VID_00000, Pass 2 of 2 - [00:30:27] Video Encode complete - [00:30:27] Reencoding audio tracks (if req'd) - [00:30:27] Multiplexing M2TS - [00:35:04] Extracting A/V streams [VID_00003] - [00:44:14] Reencoding: VID_00003 (2 of 6) - [00:44:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 76,248 frames - Bitrate: 8,773 Kbs - [00:44:14] Reencoding: VID_00003, Pass 1 of 2 - [01:47:00] Reencoding: VID_00003, Pass 2 of 2 - [03:42:56] Video Encode complete - [03:42:56] Reencoding audio tracks (if req'd) - [03:42:56] Multiplexing M2TS - [03:47:54] Extracting A/V streams [VID_00004] - [03:59:25] Reencoding: VID_00004 (3 of 6) - [03:59:25] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 76,728 frames - Bitrate: 8,724 Kbs - [03:59:25] Reencoding: VID_00004, Pass 1 of 2 - [05:01:18] Reencoding: VID_00004, Pass 2 of 2 - [06:56:19] Video Encode complete - [06:56:19] Reencoding audio tracks (if req'd) - [06:56:20] Multiplexing M2TS - [07:01:21] Extracting A/V streams [VID_00005] - [07:11:14] Reencoding: VID_00005 (4 of 6) - [07:11:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 80,352 frames - Bitrate: 8,892 Kbs - [07:11:14] Reencoding: VID_00005, Pass 1 of 2 - [08:16:27] Reencoding: VID_00005, Pass 2 of 2 - [10:17:37] Video Encode complete - [10:17:37] Reencoding audio tracks (if req'd) - [10:17:37] Multiplexing M2TS - [10:23:06] Extracting A/V streams [VID_00100] - [10:23:14] Reencoding: VID_00100 (5 of 6) - [10:23:14] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,079 frames - Bitrate: 13,057 Kbs - [10:23:14] Reencoding: VID_00100, Pass 1 of 2 - [10:24:06] Reencoding: VID_00100, Pass 2 of 2 - [10:25:48] Video Encode complete - [10:25:48] Reencoding audio tracks (if req'd) - [10:25:48] Multiplexing M2TS - [10:25:51] Extracting A/V streams [VID_00101] - [10:25:57] Reencoding: VID_00101 (6 of 6) - [10:25:57] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 785 frames - Bitrate: 13,035 Kbs - [10:25:57] Reencoding: VID_00101, Pass 1 of 2 - [10:26:34] Reencoding: VID_00101, Pass 2 of 2 - [10:27:49] Video Encode complete - [10:27:49] Reencoding audio tracks (if req'd) - [10:27:49] Multiplexing M2TS [10:27:51]PHASE ONE complete [10:27:51]PHASE TWO - Rebuild Started - [10:27:51] Rebuilding BD file Structure [10:27:55] - Encode and Rebuild complete - WORKFILES folder removed. [10:27:56]JOB: DEXTER_SEASON_2 finished. Last edited by Kakashi Sensei; 4th July 2010 at 18:05. |
