8th July 2014, 14:05 | #223 | Link |
The output won't have a video stream, only tools which can handle audio-only AviSynth output as their input (e.g. avs2wav / wavi / avs2pipemod, and MeGUI's audio conversion part) may accept it.
And yes, keeping the same architecture is a prerequisite. |
28th July 2014, 10:03 | #226 | Link |
And GCC binaries of L-Smash (muxer, remuser, etc) which will run on XP as well, since they seem not to be available from http://otsukemono.blogspot.jp anymore and the Google drive he used is down
I wonder why it's so hard to find binaries of this project. |
30th July 2014, 22:27 | #227 | Link |
When I try using LSMASHVideoSource I get "System Exception - Access Violation". This is the case for both x86 and x64 builds. LWLibavVideoSource, which uses the lilbavformat as the demuxer, works fine. This is using the r278 build from the links above. Any ideas why this is? Does this have anything to do with the msvcr120.dll included in the package? Am I supposed to place that in the System32 directory? Looks as though I already have msvcr120.dll in both System32 and SysWOW64
31st July 2014, 08:38 | #228 | Link |
LSMASHVideoSource is only suitable for MP4 and similar ISO-MOV based container sources. Do not use it with any other container format.
Do not rely on any included MSVCR*.DLL; instead, rather install the Microsoft Visual C++ Runtime for 32 bit (and possibly also for 64 bit if you have a 64 bit Windows 7+), this will ensure that the appropriate version of several DLLs will be installed to the matching version of the system32 directory (depending on 32 or 64 bit runtime, and 32 or 64 bit OS; furthermore, MSVCR###.DLL is not the only required DLL). Last edited by LigH; 1st August 2014 at 09:17. |
1st August 2014, 01:20 | #230 | Link | ||
1st August 2014, 09:14 | #233 | Link |
Well, yes, sorry, I always forget that "MP4" is a too strict restriction. But I take MOV not much more serious than AVI for personal reasons, would always recommend the "intentionally best matching container for the content"...
1st August 2014, 12:33 | #235 | Link |
Unfortunately without up to date and properly compiled binaries (ones that aren't slow), L-SMASH Works could end up 'dying' like so many other great projects. Why you may ask? Well, quite simply if people can't download it they can't use it! Also, many are turned away if there is a significant time between builds. Realistically it needs a 'daily' build, like MPC-HC gets. Sure, there may be a week or two between commits, but that doesn't matter, the nightly build only needs updating when new commits are made. The same probably can be said for FFMpegSource, since they, in many ways, compliment each other.
1st August 2014, 12:46 | #236 | Link | |
Swallowed in the Sea
- l-smash x64 |
