Old 2nd June 2023, 08:38   #64101  |  Link
Originally Posted by JordanKietsu View Post
It's a 4k 60hz monitor from LG. Other renderers play at the video's native fps so why can't madvr?
because it is.
madVR can't play a file outside the original FPS.
so make a screen of the OSD.
Old 4th June 2023, 11:16   #64102  |  Link
ashlar42
Anyone knows of a practical solution to use madVR with HLG high dynamic range content?
LG 77C1 - Denon AVC-X3800H - Windows 10 Pro 22H2 - Kodi DSPlayer (LAV Filters, xySubFilter, madVR, Sanear) - RTX 4070 - Ryzen 5 3600 - 16GB RAM
Old 4th June 2023, 12:29   #64103  |  Link
the current "solution" is intended behaviour.
if you want to use HLG use something else pretty much everything does it better.
Old 4th June 2023, 13:18   #64104  |  Link
blecap
hi what is best setting to make it similar like dmitrirenderer? i download madvr but its so many settings to play with.
blecap is offline   Reply With Quote
Old 4th June 2023, 14:16   #64105  |  Link
they have nothing todo with each other.
demitri renderer is not a video renderer.
they don't do the same things.
Old 4th June 2023, 14:37   #64106  |  Link
blecap
my bad. is there an alternative like dmitri renderer that u can recommend?
Old 4th June 2023, 15:09   #64107  |  Link
it may work with madVR else svp.
Old 4th June 2023, 15:24   #64108  |  Link
ashlar42
I...
I'm not sure I understand what you mean. What is the current "solution"? It seems to me HLG material is played back in SDR.
Old 4th June 2023, 18:44   #64109  |  Link
yes SDR fallback is madVR solution HLG playback.
i ask about it and the answer to HLG to HDR10 and HLG tone mapping was no this is correct.
Old 5th June 2023, 18:01   #64110  |  Link
SirMaster
HLG plays fine in SDR for me. I am not sure why it needs another solution. The format itself was intended to be able to be played in SDR.
SirMaster is offline   Reply With Quote
Old 5th June 2023, 18:21   #64111  |  Link
because you could play it back correctly.
why tone map with madVR when your end device can do it too. same reason and more.
Old 5th June 2023, 23:25   #64112  |  Link
Playing back HLG in SDR is lower quality then an actual SDR file, or playing it in HDR.
The "intended" compatibility is a last-resort kind of thing so that something happens that doesn't look overly wrong.
People expecting to play content in the intended high quality is not all that confusing.
Old 6th June 2023, 01:00   #64113  |  Link
does HLG have different rules for tone mapping or is converted HLG to HDR10 with 1000 nit flag a relative save way to display HLG accurately forever?
Old 6th June 2023, 15:21   #64114  |  Link
SirMaster
Weird. HLG looks really great in SDR for me. I saw no issues with lower quality on my projector. It looked as good as good SDR or HDR tone-mapped. I watched all of "His Dark Materials" this way.
Old 6th June 2023, 15:35   #64115  |  Link
it is mastered for a 1000 nits.
it like HDR10 100 nits with very very basic tonemapping applied when played in SDR.
highlights are just a washed out joke.
Old 6th June 2023, 15:36   #64116  |  Link
ashlar42
?!? Because it's an HDR format too. And if one plays back HLG content on an HDR screen, I don't think it's an unreasonable expectation to get HDR results...
Old 15th June 2023, 00:30   #64117  |  Link
djsolidsnake86
a question: if windows hdr is off, how enable hdr only when seeying a movie in mpc? actually i can enable it only with windows hdr on
djsolidsnake86 is offline   Reply With Quote
Old 15th June 2023, 01:18   #64118  |  Link
what GPU are you using madVR has some condition on none madVR GPUs to enter HDR passthrough.
Old 15th June 2023, 01:41   #64119  |  Link
djsolidsnake86
4070ti
and lav filters of klite codec pack
Old 15th June 2023, 01:43   #64120  |  Link
the only reason madVR shouldn'T be able to trigger HDR should be a broken HDR page try the newest beta if this doesn'T fix it a screen of the OSD may help.
