18th May 2010, 01:48 | #8221 | Link |
Gran Torino out of sync issue at Chapter 18. The backup of the original Blu-Ray doesn't exhibit this issue. It goes to a sky-blue screen, before the chapter starts, throwing the audio out of sync.
This is a movie-only backup, BD5, using highest quality settings. Code:
----------------------- [09:25:25] BD Rebuilder v0.33.07 (beta) - Source: GRAN_TORINO - Input BD size: 27.67 GB - Approximate total content: [01:56:34.779] - Target BD size: 4.27 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [09:25:25] PHASE ONE, Encoding - [09:25:25] Extracting A/V streams [VID_00004] - [09:33:41] Reencoding: VID_00004 (1 of 1) - [09:33:41] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 167,707 frames - Bitrate: 4,119 Kbs - [09:33:41] Reencoding: VID_00004, Pass 1 of 2 - [11:00:39] Reencoding: VID_00004, Pass 2 of 2 - [13:49:18] Video Encode complete - [13:49:18] Reencoding audio tracks (if req'd) - [13:50:34] Multiplexing M2TS [13:52:05]PHASE ONE complete [13:52:05]PHASE TWO - Rebuild Started - [13:52:05] Rebuilding AVCHD file Structure [13:54:55] - Encode and Rebuild complete [13:54:56]JOB: GRAN_TORINO finished. ----------------------- Code:
- Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.33.0.7, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
18th May 2010, 02:37 | #8222 | Link |
cnote
Pete, I believe that the problem is actually in your rip of Gran Torino. I had the same issue with I Am Legend. I could see that during the exact timing of my audio lag, there was a minor flicker during a frame change in the original. For some reason it happens so fast in the original that the sequencing stays in tact. But, when I tried to encode it again the same issue happened. So I backed up a different copy of I Am Legend and it works fine. Hope it helps.
18th May 2010, 02:55 | #8223 | Link | |
18th May 2010, 05:09 | #8225 | Link | |
I've successfully backed up the US version of "Gran Torino". Last edited by jdobbs; 18th May 2010 at 05:17. |
18th May 2010, 16:12 | #8226 | Link | |
18th May 2010, 16:43 | #8227 | Link |
Issue with x264 - check attachment and log
I use to encode my BD manually with FFmpeg but thanks to Dark Shikari I decided to give try to this solution, sadly I found that for some reason x264.exe is crashing on my sistem, I'm using Win7 x64 v6.1.7600 with exactly the software recomended on the post, here is my log on the error (see the picture):
----------------------- [09:34:46] BD Rebuilder v0.33.07 (beta) - Source: MYHDMOVIE - Input BD size: 41.73 GB - Approximate total content: [04:33:35.740] - Target BD size: 7.72 GB - Windows Version: 6.1 [7600] - Auto Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [09:34:46] PHASE ONE, Encoding - [09:34:46] Extracting A/V streams [VID_00345] - [09:34:46] Reencoding: VID_00345 (1 of 70) - [09:34:46] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 240 frames - [09:34:46] Reencoding: VID_00345, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.33.07 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [09:35:04] - Failed video encode, aborted |
18th May 2010, 17:04 | #8229 | Link |
Haven't used BD-Rb for a while as I started backing up to hard drives, so not constrained by BD5/9 sizes. Excited to see jdobbs added MKV output. Wondering what CRF setting people are using for backups to MKV. In RibBot264, I'm using CQ18, which is single-pass. I'm interested in good quality obviously (as I use a large front projection system), but fast encoding is also important. Thanks in advance for any recommendations.
18th May 2010, 21:55 | #8232 | Link | |
The only thing missing is the ability to add DTS tracks to the MKV output. Today I remux the MKV with DTS for the movies where I want to use DTS. |
18th May 2010, 22:38 | #8233 | Link |
Just did a full movie backup to BD5 of The Punisher, region A, and tested with both software players PowerDVD and TMT3 as well as burned to DVD+RW for playback on my Sony S360.
The backup completes successfully, however the two initial menu buttons are not present on the backup. The original disc and rip work correctly. When you first insert the disc and it starts, there is a brief intro Lionsgate advert followed by a menu tutorial, how to use your remote control, etc.. There is also two buttons available at this time to play the movie or go to the main menu, which allow you to skip this tutorial. If you don't choose, the movie just starts after the tutorial, approx. 30 seconds later. These two buttons are not there on the BD-RB backup. The movie does start and play properly after the intro ends, and does return to the main menu when the movie finishes, but for some reason these menu buttons are left off/not present at the beginning. |
18th May 2010, 23:08 | #8235 | Link | |
19th May 2010, 00:20 | #8236 | Link |
cnote
That is the thing, I believe you will get the same results when you rip that same original of Gran Torino. You need to acquire a different copy of Gran Torino. I would be shocked if you didn't get the results you are looking for then. I too successfully backed up my US version of Gran Torino.
19th May 2010, 01:04 | #8237 | Link | |
19th May 2010, 02:37 | #8238 | Link | |
No Shutdown in v0.33.07
----------------------- [22:30:53] BD Rebuilder v0.33.07 (beta) - Source: 007_DR_NO - Input BD size: 36.97 GB - Approximate total content: [03:21:28.726] - Target BD size: 7.91 GB - Windows Version: 6.1 [7600] - SHUTDOWN at completion enabled - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=448 [22:30:53] PHASE ONE, Encoding - [22:30:53] Extracting A/V streams [VID_00001] - [22:47:53] Reencoding: VID_00001 (1 of 10) - [22:47:53] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 158,013 frames - Bitrate: 6,175 Kbs - [22:47:53] Reencoding: VID_00001, Pass 1 of 2 - [00:18:44] Reencoding: VID_00001, Pass 2 of 2 - [04:16:34] Video Encode complete - [04:16:34] Reencoding audio tracks (if req'd) - [04:20:20] Multiplexing M2TS - [04:27:23] Extracting A/V streams [VID_00025] - [04:27:32] Reencoding: VID_00025 (2 of 10) - [04:27:32] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 9,200 frames - Bitrate: 1,164 Kbs - [04:27:33] Reencoding: VID_00025, Pass 1 of 2 - [04:28:26] Reencoding: VID_00025, Pass 2 of 2 - [04:31:17] Video Encode complete - [04:31:17] Reencoding audio tracks (if req'd) - [04:31:19] Multiplexing M2TS - [04:31:21] Extracting A/V streams [VID_00026] - [04:31:46] Reencoding: VID_00026 (3 of 10) - [04:31:46] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 23,676 frames - Bitrate: 1,221 Kbs - [04:31:46] Reencoding: VID_00026, Pass 1 of 2 - [04:33:57] Reencoding: VID_00026, Pass 2 of 2 - [04:41:50] Video Encode complete - [04:41:50] Reencoding audio tracks (if req'd) - [04:41:54] Multiplexing M2TS - [04:42:01] Extracting A/V streams [VID_00029] - [04:42:13] Reencoding: VID_00029 (4 of 10) - [04:42:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,776 frames - Bitrate: 3,519 Kbs - [04:42:13] Reencoding: VID_00029, Pass 1 of 2 - [04:44:13] Reencoding: VID_00029, Pass 2 of 2 - [04:48:35] Video Encode complete - [04:48:35] Reencoding audio tracks (if req'd) - [04:48:37] Multiplexing M2TS - [04:48:40] Extracting A/V streams [VID_00030] - [04:51:45] Reencoding: VID_00030 (5 of 10) - [04:51:45] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 75,845 frames - Bitrate: 3,260 Kbs - [04:51:45] Reencoding: VID_00030, Pass 1 of 2 - [05:33:49] Reencoding: VID_00030, Pass 2 of 2 - [07:14:41] Video Encode complete - [07:14:41] Reencoding audio tracks (if req'd) - [07:14:53] Multiplexing M2TS - [07:15:33] Extracting A/V streams [VID_00031] - [07:16:56] Reencoding: VID_00031 (6 of 10) - [07:16:56] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 32,282 frames - Bitrate: 3,519 Kbs - [07:16:56] Reencoding: VID_00031, Pass 1 of 2 - [07:33:53] Reencoding: VID_00031, Pass 2 of 2 - [08:16:53] Video Encode complete - [08:16:53] Reencoding audio tracks (if req'd) - [08:16:58] Multiplexing M2TS - [08:17:17] Extracting A/V streams [VID_00054] - [08:17:34] Reencoding: VID_00054 (7 of 10) - [08:17:34] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29.970fps, 15,614 frames - Bitrate: 1,221 Kbs - [08:17:34] Reencoding: VID_00054, Pass 1 of 2 - [08:19:02] Reencoding: VID_00054, Pass 2 of 2 - [08:24:46] Video Encode complete - [08:24:46] Reencoding audio tracks (if req'd) - [08:24:49] Multiplexing M2TS - [08:24:54] Extracting A/V streams [VID_00057] - [08:24:59] Reencoding: VID_00057 (8 of 10) - [08:24:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,379 frames - Bitrate: 3,333 Kbs - [08:24:59] Reencoding: VID_00057, Pass 1 of 2 - [08:25:43] Reencoding: VID_00057, Pass 2 of 2 - [08:27:19] Video Encode complete - [08:27:19] Reencoding audio tracks (if req'd) - [08:27:19] Multiplexing M2TS - [08:27:23] Extracting A/V streams [VID_00058] - [08:27:26] Reencoding: VID_00058 (9 of 10) - [08:27:26] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 708 frames - Bitrate: 3,325 Kbs - [08:27:26] Reencoding: VID_00058, Pass 1 of 2 - [08:27:49] Reencoding: VID_00058, Pass 2 of 2 - [08:28:38] Video Encode complete - [08:28:38] Reencoding audio tracks (if req'd) - [08:28:38] Multiplexing M2TS - [08:28:40] Extracting A/V streams [VID_00089] - [08:28:43] Reencoding: VID_00089 (10 of 10) - [08:28:43] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 670 frames - Bitrate: 3,715 Kbs - [08:28:43] Reencoding: VID_00089, Pass 1 of 2 - [08:29:04] Reencoding: VID_00089, Pass 2 of 2 - [08:30:01] Video Encode complete - [08:30:01] Reencoding audio tracks (if req'd) - [08:30:01] Multiplexing M2TS [08:30:02]PHASE ONE complete [08:30:02]PHASE TWO - Rebuild Started - [08:30:02] Rebuilding BD file Structure [08:30:06] - Encode and Rebuild complete - WORKFILES folder removed. - Computer SHUTDOWN initiated. |
