23rd July 2017, 13:20 | #8382 | Link | |
I am always a bit suspicious if it is not from the official download page and this seems to be: http://opus-codec.org/downloads/ |
23rd July 2017, 13:46 | #8383 | Link |
As I told you: I did that, straight from the official sources, using
https://github.com/jb-alvarado/media-autobuild_suite If you don't trust me, build it yourself. For my x265 builds, I use XhmikosR's slightly older MSYS (32b) package; MABS uses MSYS2 (64b) and updates itself regularly, instead. Last edited by LigH; 23rd July 2017 at 13:53. |
26th July 2017, 11:51 | #8386 | Link | ||
28th July 2017, 13:16 | #8387 | Link | |
Keeping it as it is, but making it look like a button would give it a more clickable appearance, or even an arrow pointing down next to the text to indicate it opens a list, maybe something similar to the method for selecting a frame rate in the bitrate calculator. It's obviously clickable. |
2nd August 2017, 03:15 | #8389 | Link |
I just updated to 2768 and when MeGUI restarted it crashed my computer to a blue screen of death. I was able to reboot and change the megui.exe to the BU file but when I started the program ALL my configuration settings were GONE...this is disaster. I finally got it restarted but it was the stable version,2715, not from the Development Updater site. Is there anywhere I can download the 2767 .exe file?
Humanity does more than rhyme with insanity...it defines it. |
2nd August 2017, 08:55 | #8390 | Link |
I'm still running 2767.
[@To all users Please report any trouble or success changing to 2768. Because Zathor holidays maybe we can stay at 2767 untill there are success reports. I don't know the 2768 changelog.] EDIT: Forget that, seems a problem not related with MeGUI 2768. @HOB Please inform about your OS, AviSynth version, etc. Check if you have already ...\megui\update_cache\_obsolete_megui-core-2767-32.7z If not I can upload it.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 2nd August 2017 at 17:37. Reason: remove warning |
2nd August 2017, 13:44 | #8391 | Link | ||
Just updated from 2755 to 2768, no problems (not yet tried encode).
WinXP32 SP3 Quote:
2768 [x264] improved custom command line parameter detection 2767 [L-SMASH Indexer] fixed some issues (regression of 2757) 2766 [OneClick] fixed an issue if the input audio codec cannot be used for direct muxing (regression of 2759). bug #890 2765 [Video Preview] aligned the total time and frame count in the title bar with the Info() output 2764 [OneClick] fixed external audio file handling (regression of 2759). bug #889 2763 [Audio Encoder] ignore a requested sample rate change if source and target are identical 2762 [Audio Encoder] fixed "NicAudio" not being saved as preferred decoder (regression of 2693) 2761 [OneClick] + [AVS SC] select AviSource() or DirectShowSource() only if suitable 2760 [OneClick] cosmetics 2759 [OneClick] improved handling of audio tracks: - FLAC encodings use the HD track instead of the core if possible. Feature request #610 - fixed demux of multiple audio tracks using the same input track (eac3to only) - fixed handling of TrueHD+AC3 tracks if using an intermediate MKV file 2758 [Muxer] removed dtshd and dtsma file extension and added eac3 and thd+ac3 file extension where suitable [MediaInfo] improved audio codec/type detection 2757 [L-SMASH Indexer] improved error handling 2756 [Chapter] added a workaround for MediaInfo sometimes not detecting all chapters in MPLS files (regression of 2753) 2755 [AutoEncode] fixed a crash if trying to add additional content (regression of 2753) improved logging 2754 [MKV Info] switched to the JSON format as the old switch is deprecated (requires mkvmerge 9.7+) 2753 [Chapter] improved chapter handling all MediaInfo supported files and TXT/XML files can be used as chapter files !!! existing jobs have to be recreated as otherwise the chapter information will not be added !!! [Muxer] use chapter information from the input video file if available [Muxer] + [OneClick] disable/enable the chapter selection box based upon the selected container and device type 2752 [MKV Muxer] ignore invalid subtitle files 2751 [HD Streams Extractor] improved handling of audio tracks with unknown parameters 2750 [Worker] fixed rare invisible progress window (regression of 2743) 2749 [Update] fixed a rare crash when a restart is required and MeGUI is already closed 2748 [HD Streams Extractor] added detection of "core/embedded" tracks removed the DTSHD "extract as" option added the DTS_CORE "extract as" option added settings menu: - added option to select by default the (non-)HD tracks (defaults to non-HD) - moved the language track selection option from the global settings into the new menu - added settings to inlcude the encoding and/or all demuxer "extract as" options AAC encoding is only available if neroaacenc.exe is found in the eac3to directory 2747 [Worker] improved handling of multiple worker instances. part II 2746 [Worker] improved handling of multiple worker instances 2745 [Main] added option to extend logging 2744 [Worker] improved child process priority handling. part II 2743 [Worker] improved child process priority handling 2742 [Main] improved OS detection 2741 [MediaInfo] fixed chapter detection prevent MediaInfo from locking the GUI 2740 [OneClick] disable controls while input detection is ongoing 2739 [MediaInfo] removed the external dependency to MediaInfoWrapper.dll 2738 [OneClick] fixed detection of audio track names 2737 [Muxer] + [OneClick] removed unnecessary "X" buttons 2736 [Update] x64: fixed detection of the DGIndexIM package 2735 [MP4 Muxer] write always aspect ratio information to preserve anamorphic information. Bug #837 2734 [Profile] removed redundant second warning when changing a profile which should be saved to the scratchpad. Feature request #606 2733 [OneClick] added button to clear the working directory path and the chapters file [AVS Script Creator] added button to clear the subtitle file [Muxer] added button to clear the chapter file 2732 [OneClick] fixed OneClick startup error (regression of 2631) 2731 [OneClick] added aspect ratio selection to the OneClick profile input aspect ratio can always be selected if an input aspect ratio will be selected this will be forced the aspect ratio will not be forced by the muxer if the video track has been encoded cosmetics 2730 [AutoEncode] do not force the aspect ratio to be written by the muxer as it is available in the video stream 2729 [Muxer] added/improved aspect ratio writing (all muxers except the AVI muxer) for the M2TS muxer only some input video types are supported improved logging 2728 [VideoEncoder] forced aspect ratio to be written to the encoding if not available in the job the avs aspect ratio information will be used 2727 [Worker] priority changes will also be applied to child processes. Feature request #615 2726 [OneClick] removed the "Anamorph Output" option in the OneClick profile. Please use the anamorphic encoding options in the AviSynth profile instead. 2725 [Main] fixed wrong AR of a "video encoding" queued job in rare cases (regression of 2610) 2724 [OneClick] cosmetic fix as sometimes even with "don't encode video" some video processing options were not disabled 2723 [OneClick] improved error handling of invalid AviSynth scripts 2722 [Main] if not at least AviSynth 2.6 is installed the portable build will be used improved AviSynth logging 2720 [AviSynth Wrapper] added functions to detect AviSynth details 2719 [AviSynth Wrapper] updated wrapper to interface 3 2718 [FFMS Indexer] enabled AVI file handling 2717 [AviSynth Wrapper] improved error handling 2716 [VideoEncoder] extended avs log information Changelog 2624 --> 2715 Features/Changes: [AudioEncoder] default to LWLibavAudioSource()/LSMASHAudioSource() [AviSynth] replaced Yadif by Yadifmod2 [FileIndexer] added title selector for DVD sources incl. multi-angle support [Update] improved updater to download appropriate architecture packages (can be deselected in the options) [VobSubber] The VobSubber has been enhanced - to support demux of forced subtitles - to select if the subtitles should be extracted to multiple files - with improved speed as the source will only be indexed once for multiple tracks - to detect DVD sources incl. multi-angle suppor [x265 Encoder] x265 is now always enabled Enhancements/Fixes: [AudioEncoder] added downmix option to 5.1 [FileIndexer] added IFO as supported input file type [Haali Media Splitter] if the Haali Media Splitter is needed by the HD Streams Extractor it will be installed (administrative permissions are required) [HD Streams Extractor] Unknown or not supported tracks cannot be selected [OneClick] added MPLS as supported input files [Title Selector] improved DVD/Blu-ray support & added option to change the minimum title length also in the global settings [Various] where appropriate for DVD/Blu-ray sources a prefix and suffix is attached to the output file name Changelog 2525 --> 2624 Features/Changes: [Aften Encoder] The Aften AC-3 encoder has been removed. Please switch to FFmpeg AC-3. [DGAVCIndex Indexer] DGAVCIndexer has been removed. Please use another indexer. [DGIndexIM Indexer] DGIndexIM has been added. It is disabled by default and has to be enabled in the settings. The new default indexer order is: DGIndexNV, DGIndexIM, DGIndex, L-SMASH, FFMS [Main] .NET 4.0 is now required for MeGUI [Main] The support for Windows XP has been dropped [x265 Encoder] Added n-pass support [Xvid Encoder] Added support for Xvid 1.3. An additional automated step is required as the output file must be prepared with FFmpeg. Enhancements/Fixes: [FFMS Indexer] disabled AVI file handling as FFMS may cause jittery motion [HD Streams Extractor] + [MediaInfo] if a language cannot be detected or matched the default MeGUI language will be used [HD Streams Extractor] improved feature selection & handling of unsupported tracks [Main] added ~300 additional languages to select based upon ISO 639-2 [Muxer] + [OneClick] improved language detection based on the file name [Profile] profiles will be saved to disk also when a profile is changed. additionally "Load Defaults" resets now the selected profile (before it was the scratchpad one). [Update] clean package directory during update Changelog 2507 --> 2525 Features/Changes: [Audio Encoder] added custom command line support [Chapter Creator] added option to sort the title list by chapter count [FDK-AAC Encoder] added FDK-AAC encoder support due to the FDK-AAC license the encoder will not be available in the online updater Enhancements/Fixes: [Chapter Creator] cosmetics [Chapter Creator] improved error handling [HD Streams Extractor] cosmetics [OneClick] better support for Blu-ray playlist where eac3to and mediainfo report different track information [OneClick] fixed removing the wrong subtitle track when using the DEL key [Update] get update server configuration data from the update server itself [Update] if an outdated package is enabled the update will be downloaded automatically (if auto update is not disabled) [VobSubber] improved error handling [x265] adjusted command line for recent avs4x265 Known Problems: - Windows XP and older is not supported - Unicode is not supported - non default DPI values are not supported - M2TS bitrate calculator does not calculate correct values as the specifications are unknown Full changelog: http://sourceforge.net/p/megui/code/HEAD/tree/megui/trunk/Changelog_full.txt?format=raw Quote:
These were updated:-
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th May 2020 at 15:11. |
2nd August 2017, 13:50 | #8392 | Link |
Hello tebasuna51
Thanks for replying so quickly. YES I do have that file, which I was unaware of until you pointed it out thank you. I was able to use a Windows 7 System Restore point to return my computer to the state it was in the day before I upgraded to 2768 so I'm back to 2767 and will leave it like that until Zathor returns...GOOD advice! I lost my configuration settings so it went back to default, might there be a backup for that file? If not I think I've got it back to the way it was, I tested it last night on a movie I just worked on recently and the results looked just fine. Once again thanks for your quick response it was most helpful, I'll make a note of where those files are in case I ever need them again. Hi StainlessS Just saw your post, glad to hear it worked for you. I just checked my updates with the ones in your screen grab and mine are all the same versions.
Humanity does more than rhyme with insanity...it defines it. Last edited by HOB; 2nd August 2017 at 13:57. Reason: correct mistakes |
2nd August 2017, 14:10 | #8393 | Link | |
Did an x264 encode and here is the (successful) log:- http://www.mediafire.com/file/al9k5y...2_13-49-55.zip
EDIT: Quote:
Also, you could retry, eg Make copy of MeGUI folder, Execute MeGUI update. If crash, restore from copy and retry one update at a time till crash. Report what happened. Here log of x265 encode on same file/script. http://www.mediafire.com/file/01sv2b...2_14-14-39.zip x265 seems to have improved nicely, last time I tried it I think I got about 0.2 FPS on StdDef (with similar-ish script), with Core2Duo 2.4GHz CPU. Today, Core2Quad 2.4GHz, x264 (CRF 21.5, SLOW preset), getting 6.75 FPS encode, CPU @ ~72%. x265, Same settings, 1.46FPS and CPU @ 100.0% most of the time. (Encode clip output 1280x720@25FPS, reasonably heavy processing script including MCDegrainSharp and FFT3DFilter-ing). Think I might sometimes use x265 now
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd August 2017 at 15:19. |
2nd August 2017, 15:04 | #8394 | Link |
StainlessS
I notice you're using WinXP, I wonder if that might have something to do with it? I'm using Windows 7. Also...your Changelog reference to 2768 says "custom command line parameter detection", I can imagine any mistake accessing a command line might cause a Blue Screen Crash and perhaps as you are using XP and I'm using 7 that might explain the difference? Glad it's working for you...
2nd August 2017, 15:16 | #8395 | Link | |
HOB, See EDIT.
All Changelog stuff between your current and 2768 is pertinent, and I think your ref to custom command line would only be relevant when update success and using MeGUI to call x264. Quote:
2749 [Update] fixed a rare crash when a restart is required and MeGUI is already closed 2736 [Update] x64: fixed detection of the DGIndexIM package Kinda curious about below Code:
Changelog 2624 --> 2715 [Update] improved updater to download appropriate architecture packages (can be deselected in the options) EDIT: Arh In Update, for MediaInfo, when trying to Enable, option is disabled, but allows "Ignore Updates" and "Force Reinstall". MediaInfo [EDIT: update] must now not be usable in XP (lovely to have that Zathor, Thanx).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 3rd August 2017 at 16:58. |
2nd August 2017, 15:23 | #8396 | Link |
StainlessS
Thanks for the feedback, I guess I'll just stick with 2767 till Zathor gets backs and has a look at things. After the Blue Screen appeared, just after updating from 2767, I rebooted into Windows 7 and tried to start MeGUI 2768 once again at which point it went straight to the blue screen. I've got a system with XP on it, when I get the time I'll try and update it to 2768 and see what happens. Back again... I updated to 2768 on my XP with no Blue Screen so there may be something going on that's specific to Windows 7 in general or my computer in particular.
Humanity does more than rhyme with insanity...it defines it. Last edited by HOB; 2nd August 2017 at 15:57. |
2nd August 2017, 17:33 | #8397 | Link | |
Thanks for your info StainlessS.
And yes, the change: Quote:
I upgrade to 2768 (W 7) without problems, seems a problem in HOB system not related with MeGUI.
2nd August 2017, 21:11 | #8398 | Link |
Hello tebasuna51
After seeing that you successfully upgraded to 2768 in Win 7 it encouraged me to keep working on the problem. I had a BU folder of MeGUI and tried updating it to 2768 and it worked. Out of curiosity I tried once again to update MeGUI from that original WORKING folder with the same BLUE SCREEN results. So there is something going on in that folder that is the cause of the problem...what it could be is beyond me and not that important as I've been able to update MeGUI from my BU folder. Thanks to both you and StainlessS for your help...
3rd August 2017, 01:08 | #8400 | Link |
How does MeGUI pipe AviSynth output to external audio encoders?
How can it be done directly on the commandline? For example, here's what's executed thru MeGUI: Code:
fdkaac.exe --ignorelength -m 5 -p 2 - -o output.m4a |
megui |
