5th July 2013, 14:55 | #262 | Link | |||
Software Developer
It seems you already solved your problem this time, but next time you may need a debug build, just grab MinGW + MSYS and then in the MSYS terminal do the following: Code:
git clone git://git.videolan.org/x264.git x264-src cd x264-src ./configure --enable-win32thread --enable-debug make (Your mileage may vary) Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th July 2013 at 18:02. |
24th September 2013, 05:11 | #264 | Link |
Huh?
I'm currently trying to use JEEB's 32bit r2245 x264 build to encode a fairly resource-intensive script. For the third time, the encode seems to stop at about 66%. The process does not get hung and it does not crash, but the progress indicator just stops increasing. What could be the cause of this? I am using AVISynth v 2.60a4 and SEt's v2.6MT.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
24th September 2013, 07:21 | #265 | Link | |
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
24th September 2013, 13:28 | #266 | Link |
Huh?
Yes. Should I try eliminating all related lines, or just the Distributor() one?
24th September 2013, 13:48 | #267 | Link | |
- Don't use Distibutor() in the script - How much memory does Avisynth use with your script? - Post your x264 command line
Groucho's Avisynth Stuff |
24th September 2013, 15:47 | #268 | Link |
Huh?
Yeah, my bad. Here's the script:
SetMemoryMax(900) SetMTMode(5,4) Plugin loading MPEG2Source("x:\wherever\somevideo.d2v") SetMTMode(2) TComb(fthreshL=6,fthreshC=7,othreshL=7,othreshC=8) source=last out1=source.Checkmate() out2=source.checkmate(tthr2=0) out2.mergechroma(out1) FFT3DFilter(sigma=10,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16,interlaced=true) Interp = nnedi3() Deinted=TDeint(type=1,edeint=Interp,emask=TMM()) TFM(d2v="x:\wherever\somevideo.d2v",mode=6,PP=7,slow=2,mChroma=true,Clip2=Deinted) vinverse() TDecimate(mode=1) RemoveGrain(mode=5) p=last a=p.Trim(0,32578) b=p.Trim(32579,32654).ConvertToYUY2().SpatialSoften(11,0,700).SpatialSoften(11,0,700).ConvertToYV12().ChubbyRain2().FFT3DFilter(sigma=16,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) c=p.Trim(32655,0) a+b+c q=last d=q.Trim(0,34603).Crop(6,2,704,478,align=true) e=q.Trim(34604,0).ConvertToRGB().Crop(7,2,703,478,align=true).Spline36Resize(704,478).ConvertToYV12() d+e source=last preNR=source.dfttest(sigma=1.25,tbsize=3).FFT3DFilter(sigma=10,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) preNR_super=preNR.MSuper(pel=2, sharp=1) source_super=source.MSuper(pel=2, sharp=1) backward_vec3 = MAnalyse(preNR_super,isb = true, delta = 3, overlap=4) backward_vec2 = MAnalyse(preNR_super,isb = true, delta = 2, overlap=4) backward_vec1 = MAnalyse(preNR_super,isb = true, delta = 1, overlap=4) forward_vec1 = MAnalyse(preNR_super,isb = false, delta = 1, overlap=4) forward_vec2 = MAnalyse(preNR_super,isb = false, delta = 2, overlap=4) forward_vec3 = MAnalyse(preNR_super,isb = false, delta = 3, overlap=4) source.MDegrain3(source_super,backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3,thSAD=350) RemoveGrain(mode=5) Spline36Resize(704,480) aWarpSharp2(depth=16,chroma=4) dull=last sharp=last.LimitedSharpenFaster(SMode=4,Strength=150) Soothe(sharp,dull,25) Tweak(sat=1.1) GradFunkMirror(1.51) Code:
x264-10bit --preset placebo --tune animation --bframes 16 --crf 18 --keyint 240 --no-dct-decimate --no-fast-pskip --output d:\result.mp4 d:\wherever\sauce.avs
24th September 2013, 16:16 | #269 | Link |
Woah. With that script, Avisynth MT and the placebo preset it's no surprise that it locks up.
The script alone with Avisynth MT probably needs already 2 G which leaves nothing for the encoder. I'd start by tuning the script so it runs with reasonable speed and not too much memory. Use MDegrain2 instead of 3. Play with SetMemoryMax(). Use AVSMeter to monitor the memory usage and speed. The Distributor() call is only necessary for some piping tools and ffdshow. x264 invokes the call itself. Edit: Your problem is most likely related to Avisynth(MT) so maybe this should moved to the appropriate thread. Last edited by Groucho2004; 24th September 2013 at 16:34. |
27th September 2013, 15:26 | #270 | Link |
Indeed your script is very heavy (cascade of temporal filters). Does the 66 % correspond to a Trim in your script (frame 32579, 34604...)? You probably have a new filter chain suddenly kicking in and generally the AVS-MT cache doesn't like that, outputing a frame every minute or so if you’re lucky.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
25th July 2018, 03:52 | #271 | Link |
Win7-64
x264 x86 Win32 versions: 2851, 2893, 2901 Downloaded from: x264.nl Problem: when using 2893, or 2901, with AVISynth, x264 complains that it "failed to load avisynth." 2851 works without any issues. When running the --version option, I notice that 2851 has the --bit-depth=8 configuration option, while 2893 and 2901 do not. Is that the reason why neither version can find avisynth, even though it is there? Can the next x264 Win32 binary release get fixed so that it will again work with AVISynth? Update: I've discovered another location for a 2901 download: LigH's x264 (https://www.mediafire.com/?bxvu1vvld31k1) It too doesn't contain the --bit-depth=8 configuration option, but it works. Any particular reason why the x264.nl versions fail and the LigH's version works?
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 25th July 2018 at 04:19. |
25th July 2018, 05:33 | #272 | Link |
Do official builds from videolan works? For me both win32 and win64 builds work without problems with AviSynth demuxer. Also check which version of AviSynth you have (original or AviSynth+ and which revision) and that you use have both 32-bit and 64-bit AviSynth installed i.e. you not trying to run win64 x264 build with win32 AviSynth or vice versa. Try to run both win32 and win64 builds.
25th July 2018, 07:18 | #273 | Link |
My mistake, in that I said the builds were from x264.nl. Those three were from the videolan repository. So no, they did not work.
AVISynth is 32bit 2.6 version. The version also required for BDRB. I can't test the Win64 build at the moment, as I have a compile currently running. Update: The videolan 2901 x64 version had the same result.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 25th July 2018 at 13:38. |
25th July 2018, 12:50 | #274 | Link |
I can't replicate it here with:
Windows 7 64-bit x264-r2901-7d0ff22.exe CRC32: A262BDF6 MD5: CC70693AD3E613ECBEEE178B578BCDFE AviSynth_260.exe CRC32: D510D65E MD5: 7299618CCDFA57A2302381FD104234D6 Make sure that you run 32-bit x264 which have size of 20803584 bytes and not 64-bit x264 with same name but size of 22505472 bytes. Also I would recommend switch to AviSynth+ (as only developed/maintained fork) instead of AviSynth 2.6 |
25th July 2018, 14:29 | #275 | Link |
Thanks. Making me recheck the files determined that all of the name changing (the long x264 binary name to x264.exe) and then renaming the x264.exe to x264-2901-x86.exe and x264-2901-x64.exe resulted in the x264-2901-x86.exe file actually being the x64 version. I do not know how I managed to screw this up when transferring the files from the storage area on the NAS. Unfortunately, running the programs with --help or --version results in no information about the binary being 32bit or 64bit. It didn't even dawn on me that the two files were the same size. I've since run "file" on each one (I have Cygwin installed) and see the result. That is now fixed.
As for the 2893 version, I somehow managed to download the x64 version and not the x86 version. As for running AviSynth+, I can't do that. AFAIK, BDRB will not work with the + release. Jdobbs' thread only recommends installing the 2.60 version. |
