2nd May 2018, 12:13 | #50563 | Link | |
how do you get the (extra) detailed rendering stats ? in your view , it looks like they unfold to show more , i don't see an option for that , neither in Options explained page TIA, Sven |
2nd May 2018, 12:17 | #50564 | Link | |
Here you go:
2nd May 2018, 12:18 | #50565 | Link |
it is in the option explained thread and it should not be used by default. as you can easily see it is no bug free at all.
you need to go to the madVR folder and create an empty folder called: ShowRenderSteps just to give oyu an idea this was slowing down render with NGU in past and not only a little bit so don't use this regularly there has to be a good reason this is not a normal option. |
2nd May 2018, 12:40 | #50566 | Link | |
2nd May 2018, 18:07 | #50569 | Link |
Is this for real?
So no others here with the same issue with MadVr and Win10 1803 with low queues and dropped frames? I'm considering buying a Win 8.1 OEM lisence in order to have something that work and won't be broken with an OS update...
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED |
2nd May 2018, 19:58 | #50571 | Link | |
chroma NGU sharp (high) luma NGU sharp (high) < SSim1D100 LL AR chroma > Bicubic60 AR Upload queue is fine, but render queue 2-3/8, present queue 0-2/6. Avg stats: rendering 9.16ms If I lower it to NGU sharp (medium), queues goes back to normal. Avg stats: rendering 5.83ms. Before the 1803 update, everything worked fine. If I overclock my GPU, the render queue is 'slightly' better, but still not normal. I tried DDU and clean install the drivers. I have not yet tried a fresh windows install. Only thing I tried so far is turning off all the "Focus Assist" options, as I heard it makes alt-tabbing from a game to a browser can take a few seconds if ON. |
2nd May 2018, 20:05 | #50572 | Link | |
I don't remember seeing that when I upgraded either of my computers. Were you using something other than 100% scaling?
Still, I also do not recommend it for everyone.
madVR options explained |
2nd May 2018, 21:13 | #50573 | Link |
I use MSI afterburner to monitor my GPU > remoteserver > android app. Anyway, non-overclocked GTX 980 using 720p60 > 1080p upscaling (1.5x) then reduce using SSIM1D:
GPU : 75% Power : 99% (I've increased the max to 125% power limit) tons of frame drops When I overclock: GPU : 69% Power : 104% frame drops when render queue goes to 0-2 instead of 1-3 momentarily NGU Sharp (med) + no-overclock: GPU : 56% Power : 71% no frame drops and all queues normal I tried changing some RCA settings and dithering settings to increase load from NGU Sharp (med), and the queue problems seems to trigger at around >75% GPU load and >90% Power load. One thing that's strange is the Task Manager GPU load is always higher than MSI GPU load by about 6%. EDIT: I was wrong, I can't trigger the queue problem with 23.976fps videos, only 60fps. I tried NGU sharp (very high) and GPU load 90%, power 104%, no queue problems. Could it be my CPU? 2500k @ 4.2 Ghz. Last edited by Crimson Wolf; 2nd May 2018 at 21:19. |
2nd May 2018, 21:55 | #50575 | Link | |
2nd May 2018, 21:58 | #50576 | Link |
I just wanted them to know performance isn't a big problem now but it is still not for those who simply want a set and forget configuration.
2nd May 2018, 22:16 | #50577 | Link |
Ditto on the weird queue behavior and the FSE freezing mentioned. I upgraded 2 machines to 1803 and they're both like that now. One's a laptop on R9 270x, the other an RX480. One day prior, they were both fine.
I've noticed that on FSE the queues fill normally, but on non-FSE they never fill to full unless the GPU load is extremely small. However FSE is unusable because of significant stuttering on maximizing. |
2nd May 2018, 22:18 | #50578 | Link | |
I don't know why Microsoft thinks this is a good idea and why nvidia doesn't care that this is happening every damn time. Anyway, short story even shorter you need to reinstall the nvidia drivers after every major update. |
2nd May 2018, 22:18 | #50579 | Link |
Is this for real?
I reverted back to an older MadVr build here, version 0.92.4, and used NNEDI3 128 settings. My render and present queues are normal here, and that is with stats that is around ~30 ms too. I tested with SG-1 episodes again (480p) same as my previous screens. So... NGU problem with Win10 1803 build, or some other funky stuff?
3rd May 2018, 00:02 | #50580 | Link | |
Fortunately there are simple ways to add it: https://www.tenforums.com/tutorials/...a.html#option1 |
