Old 21st December 2017, 22:39   #2761  |  Link
Micheal813
I've tried over and over. Nothing I do is working. Same error anytime mClean is added. All other filters work fine.
-------------------------- System Environment --------------------------
StaxRip    : 1.7.0.0
Windows    : Windows 10 Home 1709
Language   : English (United States)
CPU        : AMD Athlon(tm) II X2 215 Processor
GPU        : NVIDIA GeForce 6150SE nForce 430
Resolution : 1920 x 1080
DPI        : 96
------------------------ MediaInfo Source File ------------------------
F:\Capture\Testing.avi
General
Complete name                : F:\Capture\Testing.avi
Format                       : AVI
Format/Info                  : Audio Video Interleave
File size                    : 394 MiB
Duration                     : 1 min 1 s
Overall bit rate             : 53.8 Mb/s
Writing library              : VirtualDub build 40717/release
Video
Format                       : Lagarith
Codec ID                     : LAGS
Bit rate                     : 52.3 Mb/s
Width                        : 640 pixels
Height                       : 480 pixels
Display aspect ratio         : 4:3
Frame rate                   : 29.970 (30000/1001) FPS
Color space                  : YUV
Chroma subsampling           : 4:2:2
Bit depth                    : 8 bits
Bits/(Pixel*Frame)           : 5.678
Stream size                  : 383 MiB (97%)
Audio
Format                       : PCM
Format settings              : Little / Signed
Format, Endianness           : Little
Format, Sign                 : Signed
Codec ID                     : 1
Bit rate mode                : Constant
Bit rate                     : 1 536 kb/s
Channel(s)                   : 2 channels
Sampling rate                : 48.0 kHz
Bit depth                    : 16 bits
Stream size                  : 11.3 MiB (3%)
Alignment                    : Aligned on interleaves
Interleave, duration         : 34  ms (1.01 video frame)
Interleave, preload duration : 500  ms
----------------------- Indexing using ffmsindex -----------------------
F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\both\ffms2\ffmsindex.exe F:\Capture\Testing.avi F:\Capture\Testing_temp\Testing.ffindex
Writing index... done.
Start:    4:35:48 PM
End:      4:35:51 PM
Duration: 00:00:02
--------------------------- AviSynth Script ---------------------------
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\DCTFilter\DCTFilter.dll")
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\FFT3DFilter\fft3dfilter.dll")
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\masktools2\masktools2.dll")
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\modPlus\modPlus.dll")
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\mvtools2\mvtools2.dll")
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\RgTools\RgTools.dll")
LoadPlugin("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\both\ffms2\ffms2.dll")
Import("F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\avs\mClean\mClean.avsi")
FFVideoSource("F:\Capture\Testing.avi", colorspace = "YV12", \
              cachefile = "F:\Capture\Testing_temp\Testing.ffindex")
ConvertToYV12()
mClean()
-------------------------- Script Properties --------------------------
Source Frame Count : 1842
Source Frame Rate  : 29.970030
Source Duration    : 00:01:01.4610000
Target Frame Count : 1842
Target Frame Rate  : 29.970030
Target Duration    : 00:01:01.4610000
----------- Error Video encoding using x264 0.150.2851 8-Bit -----------
Video encoding using x264 0.150.2851 8-Bit failed with exit code: -1073741795 (0xC000001D)
The exit code might be a system error code: {EXCEPTION}
Illegal Instruction
An attempt was made to execute an illegal instruction.
-------------- Video encoding using x264 0.150.2851 8-Bit --------------
F:\Programs\StaxRip-x64-1.7.0.0-stable\Apps\x264\x264.exe --crf 20 --output F:\Capture\Testing_temp\Testing_out.h264 F:\Capture\Testing_temp\Testing.avs
Start:    4:36:19 PM
End:      4:36:28 PM
Duration: 00:00:09
Micheal813 is offline   Reply With Quote
Old 22nd December 2017, 07:07   #2762  |  Link
Micheal813
I'm also getting an error when trying to use the latest QTGMC on Windows 10. Both with the stable build and test build.
"Cannot load file .....\KNLMeansCL.dll" Platform returned code 127. The specified procedure could not be found."
Is there some way to fix? If not, is there some way to stop a plugin from trying to load? I only use the default preset for QTGMC and don't think I need KNLMeansCL.
Old 22nd December 2017, 09:38   #2763  |  Link
Groucho2004
@Micheal813
Run "AVSMeter64 -avsinfo".
Groucho's Avisynth Stuff
Old 22nd December 2017, 09:43   #2764  |  Link
Groucho2004
Remove the "yadifmod2_avx2.dll" and see if it works. If not, run your script with AVSMeter.
Old 22nd December 2017, 09:51   #2765  |  Link
Micheal813
AVSMeter 2.6.6 (x64) - Copyright (c) 2012-2017, Groucho2004
VersionString:              AviSynth+ 0.1 (r2544, MT, x86_64)
VersionNumber:              2.60
File / Product version:     0.1.0.0 / 0.1.0.0
Interface Version:          6
Multi-threading support:    Yes
Avisynth.dll location:      C:\Windows\SYSTEM32\avisynth.dll
Avisynth.dll time stamp:    2017-11-15, 22:16:02 (UTC)
PluginDir2_5 (HKLM, x64):   C:\Program Files (x86)\AviSynth+\plugins64
PluginDir+   (HKLM, x64):   C:\Program Files (x86)\AviSynth+\plugins64+
[CPP 2.5 / 64 Bit Plugins]
C:\Program Files (x86)\AviSynth+\plugins64\AddGrainC.dll  [1.7.1.0]
C:\Program Files (x86)\AviSynth+\plugins64\dfttest.dll  [1.9.4.0]
C:\Program Files (x86)\AviSynth+\plugins64\TDeinterlace.dll  [1.1.0.0]
[CPP 2.6 / 64 Bit Plugins]
C:\Program Files (x86)\AviSynth+\plugins64+\ConvertStacked.dll
C:\Program Files (x86)\AviSynth+\plugins64+\DirectShowSource.dll
C:\Program Files (x86)\AviSynth+\plugins64+\ImageSeq.dll
C:\Program Files (x86)\AviSynth+\plugins64+\Shibatch.dll
C:\Program Files (x86)\AviSynth+\plugins64+\TimeStretch.dll
C:\Program Files (x86)\AviSynth+\plugins64+\VDubFilter.dll
C:\Program Files (x86)\AviSynth+\plugins64\DCTFilter.dll  [0.5.0.0]
C:\Program Files (x86)\AviSynth+\plugins64\DePan.dll  [2.13.1.3]
C:\Program Files (x86)\AviSynth+\plugins64\DePanEstimate.dll  [2.10.0.2]
C:\Program Files (x86)\AviSynth+\plugins64\EEDI2.dll  [0.9.2.0]
C:\Program Files (x86)\AviSynth+\plugins64\eedi3.dll  [0.9.2.1]
C:\Program Files (x86)\AviSynth+\plugins64\fft3dfilter.dll  [2.4.0.0]
C:\Program Files (x86)\AviSynth+\plugins64\masktools2.dll  [2.2.10.0]
C:\Program Files (x86)\AviSynth+\plugins64\mvtools2.dll  [2.7.24.0]
C:\Program Files (x86)\AviSynth+\plugins64\nnedi3.dll  [0.9.4.48]
C:\Program Files (x86)\AviSynth+\plugins64\PlanarTools.dll
C:\Program Files (x86)\AviSynth+\plugins64\RgTools.dll  [0.96.0.0]
C:\Program Files (x86)\AviSynth+\plugins64\yadifmod2.dll
C:\Program Files (x86)\AviSynth+\plugins64\yadifmod2_avx2.dll
[Scripts / AVSI]
C:\Program Files (x86)\AviSynth+\plugins64\AnimeIVTC.avsi
C:\Program Files (x86)\AviSynth+\plugins64\mClean.avsi
C:\Program Files (x86)\AviSynth+\plugins64\QTGMC.avsi
C:\Program Files (x86)\AviSynth+\plugins64\SMDegrain.avsi
AviSynth+ 0.1 (r2544, MT, x86_64) (0.1.0.0)
Cannot load file 'F:/Programs/StaxRip-x64-1.7.0.4-test/Apps/Plugins/both/KNLMeansCL/KNLMeansCL.dll'. Platform returned code 127:
(F:\Capture\Testing_temp\Testing.avs, line 5)
Old 22nd December 2017, 10:05   #2766  |  Link
Groucho2004
"NVIDIA GeForce 6150SE nForce 430". I don't think this card supports OpenCL at all. Remove KNLMeansCL and try again.
Old 22nd December 2017, 10:12   #2767  |  Link
Micheal813
If I delete KNLMeansCL and try to load a video, the apps window opens wanting me to find the KNLMeans.dll. If I close the window, it will not load the video. Is there a way to stop it from trying to load KNLMeans after it is deleted?
Old 22nd December 2017, 10:17   #2768  |  Link
Groucho2004
No idea. You'll have to ask the author or maybe one of the users knows.
Old 22nd December 2017, 10:24   #2769  |  Link
Micheal813
OK. Thanks for the help.
Old 22nd December 2017, 10:30   #2770  |  Link
Groucho2004
You could try replacing KNLMeansCL with a dummy. I'll post one in a minute.
Old 22nd December 2017, 10:35   #2771  |  Link
Groucho2004
Here you go.
Old 22nd December 2017, 10:48   #2772  |  Link
Micheal813
Here you go.
QTGMC now works. Thanks for your time. Now if I could just get mClean to work.
Old 22nd December 2017, 10:58   #2773  |  Link
Groucho2004
What's the problem there? Did you run it with AVSMeter?
Old 22nd December 2017, 11:08   #2774  |  Link
Micheal813
https://forum.doom9.org/showpost.php...postcount=2761
When I run it with AVSMETER:
Exception 0xC000001D [STATUS_ILLEGAL_INSTRUCTION]
Module: C:\Windows\SYSTEM32\avisynth.DLL
Address: 0x00007FFA2B51FB6E
Old 22nd December 2017, 11:44   #2775  |  Link
Groucho2004
Hm, I'm pretty sure it's one the plugins even though the exception occurs in avisynth.dll. Remove all the ones you don't need for this script and try again with AVSMeter. Possible candidates:
yadifmod2_avx2.dll
Old 22nd December 2017, 11:53   #2776  |  Link
Micheal813
yadifmod2_avx2.dll
Same thing with those removed. I even deleted all the filters except those required for mClean.
Old 22nd December 2017, 12:00   #2777  |  Link
Groucho2004
Well, consider me stumped.
At this point I don't know what else to suggest except to remove all unnecessary filters.
Old 22nd December 2017, 12:06   #2778  |  Link
Micheal813
Already tried that.
Old 22nd December 2017, 12:15   #2779  |  Link
pinterf
What instruction set is Athlon missing? In an earlier mvtools there was a bug when sse4 was used w/o checking, but that issue was fixed already.
pinterf is offline   Reply With Quote
Old 22nd December 2017, 12:17   #2780  |  Link
Groucho2004
Already tried that.
Let's try to exclude the source and source filter. Try this simple script with AVSMeter:
colorbars(width = 1920, height = 1080, pixel_type = "yv12").killaudio().assumefps(50, 1).trim(0, 499)
mclean()
