Old 6th February 2023, 00:40   #1661  |  Link
Janusz
Originally Posted by Nikse555 View Post
@von Suppé/Janusz: Strange... is this better: https://github.com/SubtitleEdit/subt...leEditBeta.zip ?
Yes. Seems to work fine,
but i have a question related to selecting text.
With the [Settings/Appearance/Use syntax coloring] option selected, double-clicking on the word "Line" in "Line one", for example, selects the word "Line" + additional space behind it. Otherwise, the word "Line" itself is selected.
Second note: double-clicking outside the "Line one" text in the empty area of the line selects the invisible LF and CR characters.
Is this action correct?
Sorry for my mistakes - I'm using a translator.
Janusz is offline   Reply With Quote
Old 6th February 2023, 10:00   #1662  |  Link
von Suppé
von Suppé's Avatar
@Janusz: Thank you for taking the time to check and confirming.
@Nikse555: Yes, latest beta seems to work ok again. Also the drag-select seems ok. Thanks for the fix.
After a quick & dirty test I can confirm the behaviour from Janus'z last post. Version 3.6.10 (portable) also shows this difference btw.
Thank you, guys
Old 6th February 2023, 19:40   #1663  |  Link
Nikse555
This is the default behavior of the "Rich text box control", but I've tried to change the double-click behavior here: https://github.com/SubtitleEdit/subt...leEditBeta.zip
Should be more like the normal text box... hopefully
Old 6th February 2023, 23:39   #1664  |  Link
Janusz
@Nikse, Thanks for the fix.
However with the [Settings/Appearance/Use syntax coloring] option selected double clicking on a word still doesn't work properly, example:
line one one
line two two
line tree tree
line four four
While in lines 1 and 4 double-clicking on the last word in the line selects the whole word "one" and "four"
it is in lines 2 and 3, in the last words of the line, that the words without the last letter "o" and "e" are marked.
Old 7th February 2023, 11:52   #1665  |  Link
von Suppé
von Suppé's Avatar
When "Use syntax coloring" is enabled, I'm still noticing unwanted behaviour for selecting parts of text in case there's a space between words.
Example:
In first line, place cursor between the "o" and "n" of the word "one" and try to select from that point to the left. As soon as the cursor is over the space between "line" and "one", both words get fully selected.
Old 7th February 2023, 20:04   #1666  |  Link
Nikse555
Thx for testing
New beta upped: https://github.com/SubtitleEdit/subt...leEditBeta.zip
Better?
Old 7th February 2023, 23:53   #1667  |  Link
Janusz
@Nikse, thanks for the fix.
For my purposes, selecting in a Text box now works properly.
For precise text selection (character by character) I use Shift + left/right arrows.
Old 8th February 2023, 10:43   #1668  |  Link
von Suppé
von Suppé's Avatar
Sadly with mouse (often quicker for me) the unproper selecting behaviour is still there. See my previous post.
Old 22nd February 2023, 00:03   #1669  |  Link
Atlantis
I just discovered something! After you OCR a subtitle and close the OCR window, if you hit Spell Check you see images of the sup file to compare to the text line.
The problem is you have to do this before saving the file. As soon as you save, you don't get that functionality while spell checking!
So the question is, is there anyway to link an open srt file to a sup file so when you spell check, you can see the original images?
Atlantis is offline   Reply With Quote
Old 22nd February 2023, 18:50   #1670  |  Link
Nikse555
@Atlantis: if you, in spell check, right-click in the "Full text" text box... you can choose "Open image based subtitle..."
Old 22nd February 2023, 19:11   #1671  |  Link
Atlantis
Thank you so much. I never thought you could right click there!
Why is this hidden like this?! You should put a button for this and another to show the right click options.
It's better not to hide the functionalities of your hard work!
Old 22nd February 2023, 19:26   #1672  |  Link
longiloquence
Wow, this changes everything. Thanks for the info!
longiloquence is offline   Reply With Quote
Old 22nd February 2023, 20:46   #1673  |  Link
Atlantis
Exactly, don't hide such an important functionality!
Old 23rd February 2023, 00:48   #1674  |  Link
Atlantis
How can I remove a word from an official dictionary?
Old 23rd February 2023, 15:04   #1675  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Handediting. I suggest notepad++
Go to <SubtitleEdit>\Dictionaries\
load the offending file and delete the offending entry.
Example for English (US)
en_US_se.xml
en_names.xml
eng_OCRFixReplaceList.xml
The same for .aff and .dic
Old 23rd February 2023, 17:06   #1676  |  Link
Atlantis
Thank you so much. Opened fr_FR.dic
Removed the offending entry: li
Can't believe they added that!
There is a huge problem in OCRing L and I, especially if they are in italic.
For example Il (I+L) in italic is OCRed to LI.
Old 25th February 2023, 13:20   #1677  |  Link
Atlantis
When spell checking and you choose "Open image based subtitle..." and open an idx/sub, it chooses the first subtitle in the stream.
You can't change. idx/sub can have several subtitles in them.
Old 27th February 2023, 02:01   #1678  |  Link
Atlantis
What is the file en_US_se.xml ?
And why it has the word favourite in it which is the British spelling!?
Old 27th February 2023, 08:45   #1679  |  Link
varekai
varekai's Avatar
Oh man... how hard can it be...
Just edit the en_US_se.xml and change the word and be done with it... :/
Favorite
Favorite and favourite are both correct spellings, depending on whether you use American or British spelling standards.
Favorite is preferred in American English, while favourite is preferred in British English.
Old 27th February 2023, 12:11   #1680  |  Link
Atlantis
You did not answer anything useful. Just a waste of your time. Please ignore posts where you can't handle them and get easily upset over nothing.
These posts are not for people who don't want to help and have no temper. Please go do something else and useful.
Yes I know I can easily edit any file and remove anything. That is not the question. I'm trying to learn how this works so I can use it correctly.
So first I want to learn what the file en_US_se.xml is and who adds words to it and what words should be in it.
