Old 3rd March 2023, 07:20   #1681  |  Link
varekai
varekai's Avatar
Originally Posted by Atlantis View Post
Just a waste of your time.
How hard can it be... No Time To Waste...
Old 9th March 2023, 21:13   #1682  |  Link
Janusz
Test files to load.
The following bug in the "compare" command has been present in several recent versions of Subtitle Edit.
1. I load the srt file containing text formatting (color) into the left window,
2. I load an srt file with the same content to the right, but without text formatting,
As a result I get:
And that's OK.
After enabling [ignore formatting] I get:
Here the result obtained contains errors and is incorrect.
File Type: zip files.zip (439 Bytes, 27 views)
Sorry for my mistakes - I'm using a translator.
Janusz is offline   Reply With Quote
Old 10th April 2023, 07:30   #1683  |  Link
dbtayag
I'm trying to nOCR some subtitles. Some subtitles are like this:
nOCR sees the first image like this:
I just don't...
Mind looking after Rosette?
Because it's two different characters speaking is there an option to make it look like this:
- I just don't...
- Mind looking after Rosette?
Or do I have to manually go line by line to change it like the latter?
dbtayag is offline   Reply With Quote
Old 14th April 2023, 16:48   #1684  |  Link
speedy
I just don't...
- I just don't...
I've been wondering about the same thing for a while now. It would be great if someone knows of a way to handle subtitles like these.
speedy is offline   Reply With Quote
Old 14th May 2023, 14:59   #1685  |  Link
Nikse555
Subtitle Edit 3.6.13 is out now
https://github.com/SubtitleEdit/subtitleedit/releases
Video -> Audio to text via Whisper now supports 5 different implementations:
@Janusz: The compare issue is hopefully fixed.
Old 14th May 2023, 16:22   #1686  |  Link
oniiz86
@Nikse555 Thanks so much for the update, the title thread has to be updated to 3.6.13, perhaps a mod could oblige @tebasuna51
oniiz86 is offline   Reply With Quote
Old 14th May 2023, 18:57   #1687  |  Link
locotus
Seems to me that the change in "find" is not right. Before as the search of the file get to the last line, if you push de "find" botton
again the progran ask to if should start from first line. This is the way it should be because you may start searching in the middle
of the file, going back with previous one by one is certainly tedious.
locotus is offline   Reply With Quote
Old 15th May 2023, 19:12   #1688  |  Link
Janusz
Unfortunately, the error I described still persists.
Old 15th June 2023, 11:02   #1689  |  Link
varekai
varekai's Avatar
about "Fix common errors" "What to fix"
Hello and thanks for Subtitle Edit!
In "Fix common errors" how do I add in "What to fix" missing space - (dash) at start of every new line.
Like this:
‐Oh, remember?
‐Yeah.
Fix to this:
‐ Oh, remember?
‐ Yeah.
I think it was found in the "Fix common errors" "What to fix" in previous versions?
Edit:
Found it.
Options->Settings->Dialog style->Dash both lines with space
It does not catch all but close enough for me.
In text like this where empty lines are removed it doesn't catch:
(Empty line removed)
‐Nope.
Thanks and best regards,
varekai
Old 15th June 2023, 12:29   #1690  |  Link
tormento
Acid fr0g
tormento's Avatar
Is there any way that the anime community can convince you to have SE able to split upper and lower PGS and proceed with OCR indipendently?
You can't imagine what a PITA is to have to edit timings and subs after having OCRed an anime with overlapping timings.
@turment on Telegram
Old 15th June 2023, 12:37   #1691  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
To ease the PITA:
#upper half
crop(0,0,0,height/2)
#lower half
crop(0,height/2,0,0)
Old 16th June 2023, 08:22   #1692  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Emulgator View Post
To ease the PITA
And how can it have any sort of effect on PGS?
I neeed to split the subs not the video.
Old 16th June 2023, 08:51   #1693  |  Link
Emulgator
Emulgator's Avatar
Ah, I see, PGS it was, sorry for the confusion.
Old 3rd August 2023, 15:54   #1694  |  Link
Lucius Snow
Hi all,
Is it possible to disallow a placement of an insert before/after a scene change, according to a length set.
I don't know if my request is clear
Lucius Snow is offline   Reply With Quote
Old 18th August 2023, 08:38   #1695  |  Link
von Suppé
von Suppé's Avatar
Hi Nikse
Did I find a little bug in one of the "Fix common errors" functions?
Take for example these two lines:
'Line 1.'
- Line 2.
Note that line 1 is between ' and '
When "Remove dialog dashes in single lines" is checked, the result window prompts to delete the dash of line 2. Where it isn't wished for.
I'm on v3.6.13
[EDIT] I think it's because it ends with '
Because
Line 1.'
- Line 2.
also gives that result
Old 22nd August 2023, 09:57   #1696  |  Link
nautilus7
nautilus7's Avatar
Hi, is there a bug in blu-ray sup creation regarding shadow transparency? I am trying to create a sup with a non transparent shadow, but I can't seem to make it happen.
In the attached picture, you can see the shadow is transparent, although I set its alpha to 255 when creating the subtitle.
nautilus7 is offline   Reply With Quote
Old 23rd August 2023, 22:34   #1697  |  Link
locotus
Is there any way in spell check to let the user change words with hyphens as separator instead of comma, like in what-what, he-he, D-did, H-Harry to what, what, etc?
Old 29th August 2023, 14:16   #1698  |  Link
draupert
Hi all. I have two .stl subtitle files for the same video - one is exported as EBU STL open subtitling, one is exported as EBU STL teletext with "double height for text" activated.
My client wants me to deliver these two subtitle tracks as one mixed mode .xif file. Whenever I try to merge the two files (Tools > Join subtitles), the teletext properties are lost and I just have a .xif file with all open titles.
I have also tried exporting both as .xif and then merging, but still the closed captioning turns into open subtitling.
Any way to mitigate this with Subtitle Edit or any other software?
draupert is offline   Reply With Quote
Old 2nd September 2023, 04:45   #1699  |  Link
GMJCZP
GMJCZP's Avatar
Is there any possibility to use Whisper on W7 32 bit with this program?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 5th September 2023, 07:07   #1700  |  Link
Zetti
Thanks for new release:
https://github.com/SubtitleEdit/subt...ases/tag/4.0.0
