Old 20th April 2014, 18:45   #2041  |  Link
bejita7
Why lossless webp is being saved with webpll extension? Chrome can't open this and IrfanView is saying that's not a correct extension. Why not just save it with normal webp extension?
Sure, I can rename webpll files to webp but I'm just asking out of curiosity.
bejita7 is offline   Reply With Quote
Old 22nd April 2014, 20:44   #2042  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4823 Dev.:
MPC-BE 1.4.3.4823 Dev (sourceforge.net)
MPC-BE 1.4.3.4823 Dev (dev.mpc-next.ru)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 22nd April 2014, 22:10   #2043  |  Link
Luyten
Can't use latest devs posted here on my notebook connected to tv using hdmi: selecting hdmi out on windows audio control panel, files plays accelerated (like at 2 or 3x); selecting notebook built-in speakers everyting work fine.
Last working dev is MPC-BE 1.4.3.4783
Notebook HP HDX16-1040el (Intel Core 2 Duo p8400, 4GB DDR2, nvidia GeForce 9600M GT 512MB, windows 7 x64, 16" 1080p dual-back-light lcd display)
Luyten is offline   Reply With Quote
Old 23rd April 2014, 00:08   #2044  |  Link
Reino
Reino's Avatar
Aleksoid1978, I don't have many wmv-files, but I noticed VC1 (DXVA) doesn't work anymore (at least on my WinXP pc) starting from r4486. r4461 still works, so I guess r4473 is the culprit. Coincidentally the revision that fixed my previous problem with H.264 (DXVA1).
My hobby website
Reino is offline   Reply With Quote
Old 23rd April 2014, 04:09   #2045  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Try this build - http://aleksoid.voserver.net/MPC-BE/mpc-be.exe_Audio.7z
Old 23rd April 2014, 04:43   #2046  |  Link
Aleksoid1978
Can you test on other PC with WinXP. Because on russian tester's PC with WinXP + ATI - DXVA work for VC1/WMV
Old 23rd April 2014, 11:20   #2047  |  Link
Luyten
Originally Posted by Aleksoid1978 View Post
Thanks, fixed!
Old 23rd April 2014, 22:08   #2048  |  Link
Reino
Reino's Avatar
I can't test on another pc with WinXP, because I only have 1. I can tell you though that with VC-1 (DXVA) as well as WMV3 (DXVA) MPC-BE doesn't crash, but simply doesn't start playing. The video does load okay, the video-resolution is properly initialized, but I get a black screen and the timer stays at 0:00.
2 samples:
sunrise (WVC1).wmv
Pinball (WMF9).wmv
One issue I noticed not only on my WinXP pc, but on a Win7 pc as well(!): To use MPC-BE's Video Decoder for VC-1 (DXVA) and WMV3 (DXVA), enabling these 2 in Options -> Internal Filters somehow isn't enough, because "VC-1 (FFmpeg)" and "WMV1/2/3" also need to be enabled, which is rather strange if you ask me.
So playing a VC1 or WMV3 video with only VC-1 (DXVA) and WMV3 (DXVA) enabled loads LAV Filters (or any other DS filter) instead! Only when you enable all 4 decoders will get you playback with DXVA.
My hobby website
Old 24th April 2014, 02:08   #2049  |  Link
Aleksoid1978
CoRoNe
1 - on Win7/Win8 all good with VC1/WMV3 DXVA.(also if "VC-1 (FFmpeg)" & "WMV1/2/3" is disabled/unchecked)
2 - i can't test on WinXP. If don't work at you PC - try use old standalone filters.
Old 24th April 2014, 18:14   #2050  |  Link
Reino
Reino's Avatar
Okay, no problem.
My hobby website
Old 24th April 2014, 19:46   #2051  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4831 Dev.:
MPC-BE 1.4.3.4831 Dev (sourceforge.net)
MPC-BE 1.4.3.4831 Dev (dev.mpc-next.ru)
Old 27th April 2014, 19:37   #2052  |  Link
Casshern
Great work on this branch. Nice that you can move DVD/Bluray PGS subtitles with SHIT-CTRL-UP/DOWN-ARROW. But to reset the subtitle position I first tried "reset" under Pan & Scan. But this only resets the video position. "Reload Subtitles" did the trick and also resetted the subtitle position.
Is there any way to position the seekbar at the top of the screen instead of the bottom (or move it up higher)? Or if not, will there be such an option in the foreseeable future? That's the only damn reason i still use Zoomplayer, as in my setup the bottom of the screen gets masked in the screens cache.
Casshern is offline   Reply With Quote
Old 28th April 2014, 01:19   #2053  |  Link
Aleksoid1978
No way to change Seekbar position.
Old 28th April 2014, 15:12   #2054  |  Link
SamKook
You can try to enable something else like the info panel(I don't have it in front of me so I don't know the terms) for example, it might make the seekbar show up higher if its position is under it, it might be a good enough "fix" for you.
AMD Ryzen 9 5950X and EVGA RTX 3080 with G.skill 64Gb 3600 (2 16x2 kit) on Asrock X570 Taichi with Samsung 980 Pro 500Gb NVMe SSD running Win10 x64 on LG 34GN850-B 34.0" 3440 x 1440 160 Hz
SamKook is offline   Reply With Quote
Old 29th April 2014, 13:02   #2055  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4843 Dev.:
MPC-BE 1.4.3.4843 Dev (sourceforge.net)
MPC-BE 1.4.3.4843 Dev (dev.mpc-next.ru)
Old 30th April 2014, 01:44   #2056  |  Link
ibbeebee
selecting Audio device
I have 2 Dacs attached to my computer a Teralink for SPDIF output & a dragonfly for phones but I can't control which one is selected by MPC-BE.
Both of then appear in the output/Audio Renderer there are various entries for both devices in the list as either Direct sound or SPDIF for the Teralink
Changing the settings Doesn't seem to have any effect & neither does changing the windows settings.
Most of the time either the dragonfly gets the nod or I get no sound at all any help would be appreciated Regards Beebee
ibbeebee is offline   Reply With Quote
Old 1st May 2014, 12:44   #2057  |  Link
Nico8583
Thanks for your work, very good player
A little question : is it possible to hide playlist in full screen mode ? Or it is necessary to uncheck playlist in menu ?
Edit : Do you think it is possible to add more informations on MP3 player (album, genre, year...) ? And do you think it is possible to add tag MKV support ? Thanks !
Nico8583 is offline   Reply With Quote
Old 2nd May 2014, 07:28   #2058  |  Link
Originally Posted by Nico8583 View Post
Is it possible to hide playlist in full screen mode ? Or it is necessary to uncheck playlist in menu ?
Right click inside playlist 'Hide in Fullscreen' That what you're after?
Old 2nd May 2014, 11:22   #2059  |  Link
Nico8583
Yes, it was what I have searched thanks !!
Old 6th May 2014, 09:50   #2060  |  Link
THX-UltraII
Is there a way to change the position of the OSD? I want it permanently in the middle/center.
THX-UltraII is offline   Reply With Quote
