Old 13th May 2020, 07:47   #581  |  Link
darksen
Originally Posted by hubblec4 View Post
cE uses it's own database. I have copied the chapters from ChapterDB. You can upload to cE's database, this works!
Cool! Thanks for this!
Now, I wonder, why I can't upload no chapters?
I have an account and I'm logged in and when I try to upload it asks me if everything is correct, I click to confirm it is and... nothing happens. Nothing, nada.
Can you please confirm it works? Maybe my account has some problem or something?
darksen is offline   Reply With Quote
Old 13th May 2020, 08:05   #582  |  Link
hubblec4
Matroska find' ich toll
mmh, strange. for a while I have uploaded chapters but now it do not work.
Thanks for this hint, I will have a look.
Old 13th May 2020, 08:41   #583  |  Link
darksen
No problem. Thank you for taking the time to look into this.
Old 13th May 2020, 08:54   #584  |  Link
hubblec4
I found the issue, and I will try to make a new rev in the next couple of hours.
Old 13th May 2020, 09:39   #585  |  Link
hubblec4
chapterEditor(cE) rev1.23 is available.
Windows
Linux
Important bugfix for the chapter database because the upload no longer worked.
Change chapterEditor
added    &
fixed    *
improved #
changed  %
rev1.23 2020-05-13
// chapterEditor
& Support for BSPlayer .chf files
# OGG/OGM.txt files from ChapterDB Webside
  - "Next line" is only displayed with one character
// Matroska Chapters
* Missing translation for "Edition entry"
  - when loading simple chapter files
  - new Disc2mkv chapters
  - Multi chapters
// Multi chapters
* insert chapters after the selected chapter does not work if there is no next chapter (only Matroska)
// Chapter database
* Uploading chapters no longer worked
@tormento
I have started to implement multi selection of chapters but it is not so easy and not included in this rev.
Old 13th May 2020, 20:04   #586  |  Link
darksen
Thanks!! I just tested it and it is working well now.
Edit: I want to request something regarding the chapter database. Is it possible you could allow us to choose more than one language for the chapter?
I have some chapters with multiple languages but I can only pick one when uploading them. Thanks!
Old 13th May 2020, 23:50   #587  |  Link
hubblec4
Hi darksen
Many thanks for uploading the Avengers chapters.
Multiple languages for the chapters DB
I don't know if this so easy possible. I will have a look but to change the database design is maybe not possible.
Old 26th May 2020, 13:57   #588  |  Link
tormento
Acid fr0g
tormento's Avatar
Under Special tools -> Chapter naming, the chapter name is the first time with capital letter (Chapter) and other times with lowercase (chapter).
Me only?
@turment on Telegram
Old 26th May 2020, 15:55   #589  |  Link
hubblec4
Yeah, that causes by a translation(used only one time at start if the cE language is not german) which uses Chapter, but in the combo-box list the entry use chapter.
What do you prefer? I can change the entries from the combo-box list.
Old 26th May 2020, 16:46   #590  |  Link
tormento
Acid fr0g
tormento's Avatar
To me, Chapter (and translations) is ok.
Old 26th May 2020, 20:00   #591  |  Link
hubblec4
OK, I will change the list entries. It makes more sense to start with a capital letter.
Old 2nd June 2020, 12:30   #592  |  Link
tormento
Acid fr0g
tormento's Avatar
When are you going to release?
Old 2nd June 2020, 22:46   #593  |  Link
hubblec4
Hi tormento
I have not much time currently to work on cE, but here is a Windows 1.24 branch for testing.
The chapter names in the combo-box have now capital letters.
Old 3rd June 2020, 00:49   #594  |  Link
tormento
Acid fr0g
tormento's Avatar
Old 23rd June 2020, 21:03   #595  |  Link
darksen
I've been using cE to remux some Blu-rays and DVDs and so far so good but there are some things I would like to request.
1- An option to hide the duplicate entries/playlists would be great. There were some times where there have been two or more playlists that pointed to the same file/s (m2ts) so the duration and the tracks where exactly the same, in those cases would be great if cE could hide all but one of them and only show that one. There are some cases where the segments differ (like in Disney's Blu-rays where they combine different segments according to the language one chooses or multi cut releases) and in those cases cE should obviously show all those playlists.
2- An option to automatically clean the temp folders after remuxing. This mostly applies to DVD2mkv as cE copies the entire files to the temp folder to process, but would also be handy for BD2mkv as I for one don't have any use for the job files and the other stuff.
3- Automatically replace illegal characters from the filename when remuxing. Otherwise we get errors and everything "hangs" until we close and reopen cE. Like if (in Windows) we put "AAAAA: AAAA BBBBB" as the filename and start remuxing the application will show an error on the log and, after finishing the batch, cE wouldn't start any other operation, all of this because it couldn't create the file with the ":" character on the filename.
I think I had one additional request but I forgot lol.
Thanks for all your work!
Old 24th June 2020, 13:10   #596  |  Link
hubblec4
Hi darksen
1.)
That's maybe not so easy for me. To find all the correct mpls files I use the output of eac3to which selects only the important mpls titles. If MTX is the analysis part in the chain then all mpls files are shown.
I have not much knowledge about the index.bdmv to parse it by my self.
I personally trust eac3to fully.
Sometimes there are duplicated mpls titles and one of them have chapters and the other not, I know.
You can send me a chunk of the disc if you like. You can use my DiscShare tool for that.
2.)
Ok, I will think about it. Could be useful.
3.) <-- fixed
Oops, that's an ugly bug, I will fix it.
The strange thing is that MTX does its job as if everything is OK(sends progress numbers and reported all done fine), but there isn't really an output file.
Old 30th June 2020, 15:06   #597  |  Link
darksen
Hi darksen
1.)
2.)
3.) <-- fixed
Hey, thanks for your time. Don't worry about the number 1, would have been nice to have if not much work should be needed. My ignorant self (I don't know much or anything about this) thought that maybe this be easy to implement. And thanks again for fixing number 3 and considering number 2. cE is great and more than just a chapter editor .
Old 2nd July 2020, 16:11   #598  |  Link
hubblec4
Hi darksen
Here is a new test rev1.24 branch (Windows exe only).
The fix of point 3. is included and also the new feature delete temp folder (2.).
Automatically delete temp folder (settings)
   - MKV file must not be created in the temp folder
   - if there were errors when muxing, the temp folder is not deleted
   - Gray state of the checkbox: the temp folder is only deleted if there was no warning
Point 1.
You can set a minimum of chapters(settings) for a playlist, this should hide chapterless playlists.
Old 8th July 2020, 06:57   #599  |  Link
darksen
Thank you hubblec4, I tested it and everything is working great.
Just one thing, I saw you now don't allow special chars on the "file name" box but we still can input double quotes (") which -at least in Windows- are invalid for filenames. Can you please also add that character to the blacklist?
Old 8th July 2020, 12:32   #600  |  Link
hubblec4
Thanks for testing.
Yes I will add double quotes to the blacklist. Thanks for this hint, I never realized that.
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag
