26th September 2018, 16:36 | #6381 | Link | |
Yes, the -cp?offs ARE the chroma offsets. I don’t recall the exact math; it was based on an IEEE paper a couple years back. But it is adaptive based on luma, and so is going to be better than just fixed offsets. |
26th September 2018, 16:44 | #6382 | Link | |
Those are what I know about. When using —no-slow-firstpass you probably want to make sure to set the number of ref and b-frames to match the second pass. The first pass is less useful as a reference without those, which will hurt quality a bit, and might slow encoding. That said, the multi-pass options and no-slow-firstpass might be incompatible in practice, since x265 can’t refine stuff that the first pass didn’t do. Or at least, some parameter fine-tuning might be required to make sure the 1st pass is a good reference. |
26th September 2018, 17:04 | #6383 | Link | |
I just got my budget Chinese tablet with MediaTek MT6797 (Xelio X20) inside - a 2016 SoC It supports in hardware MPEG2, VC-1/ WMV3, VP8, VP9 (8bit/10bit), H.264 (8bit/10bit), H.265 (8bit/10bit) Also, my Sony is an ATV2 with MediaTek MT5891 SoC inside and supports H.264 10bit too. End of OT.
26th September 2018, 18:06 | #6384 | Link | |
I would keep options 2 and 3, and add --no-strong-intra-smoothing --no-sao --multi-pass-opt-rps for some speedups as well. |
26th September 2018, 18:47 | #6385 | Link | |
I'll leave --c*qpoffs at default for HDR ecndoes then and set --hdr-opt instead. |
27th September 2018, 16:35 | #6386 | Link |
x265 v2.8+74-fd517ae68f93 (32 & 64-bit 8/10/12bit Multilib Windows Binaries)
https://bitbucket.org/multicoreware/x265/commits/branch/default |
6th October 2018, 13:50 | #6388 | Link |
Pig on the wing
Apart from the required bitrate to encode a frame, is the only real difference between --rd 4 and --rd 6 just the amount of effort required by the encoder? So I could switch to using --rd 4 if I'm ready to accept that it will probably produce a bigger file but take much less time? The presets don't seem to change the setting at all from the default 3, but 4 is the one where the other settings related to RDO kick in.
6th October 2018, 15:48 | #6389 | Link |
x265 v2.9+1-169e76b6bbcc (32 & 64-bit 8/10/12bit Multilib Windows Binaries)
https://bitbucket.org/multicoreware/x265/commits/all |
8th October 2018, 17:17 | #6393 | Link | |
I don’t know if it’d be THAT much less time, but it’ll help. |
10th October 2018, 15:12 | #6394 | Link |
Thanks for providing builds for v2.9, guys!
I just always wonder - how to tell which cpu capabilities a build is using (AVX? AVX2? None?). As far as I can tell x265.exe -V is misleadingly saying "using CPU capabilities X Y Z" but in fact it is actually just listing MY CPU's capabilities. Is that right? |
10th October 2018, 15:22 | #6395 | Link | ||
Herr
10th October 2018, 15:25 | #6396 | Link | |
Some people try to get a tiny bit of extra performance by allowing the C/C++ compiler to use those instructions sets to optimize the code, however one should know that compilers are limited in what they can do, and the majority of the "hot" (ie. important) code is manually optimized and unaffected by the compilers choices. In my experience, the differences between a generic build with just the ASM enabled that the x265 developers wrote, and a build that allows the compiler to additionally use AVX/AVX2 to optimize the remaining code is relatively small, probably low single digits percentages.
10th October 2018, 20:05 | #6398 | Link |
Artem S. Tashkinov
Version 2.9
Release date - 05/10/2018 New features
10th October 2018, 20:14 | #6399 | Link |
@Forteen88:
Thanks, man. That's where I'm usually grabbing my builds from. But no 2.9 yet. But there are cool guys here too, providing builds. @nevcairiel: Moin nevcairiel, thanks for the insights! Huh. The x265.exe --V output made me think that there are some AVX2 optimizations in the project's code itself. That's why I'm asking. But you're saying it's just about compiler optimizations. Hm. |
