10th March 2021, 14:16 | #18981 | Link |
I afraid I don't understand. I'm trying to create the files using RB. The sub file as not being converted correctly with bdsup2sub++. It would consume all memory and just crash, or it would consume 12+GB of memory and finish but it would be an empty file. Kodi really has no bearing yet since I did not have a video file to play.
12th March 2021, 00:22 | #18984 | Link |
Open manually //[your_host_pc]/ripbot264temp/chunks/1.avs in mpc-hc on not working pc. I suspect some error from avisynth.
12th March 2021, 07:25 | #18986 | Link |
hevc better at lower crf?
hevc encodes seem marginally less detailed than avc at the same crf. is it common to up the quality, (lower the crf #) for hevc (vs. avc)?
perhaps crf 18 for hevc vs 20 for avc. |
12th March 2021, 08:29 | #18987 | Link | |
There are strategies to reduce the loss, the most radical is disabling SAO, others are related to tuning psycho-visual features. _ Regarding your encoding issue: Do you even have AviSynth installed and working on the remote PC where the conversion shall run? Last edited by LigH; 12th March 2021 at 08:31. |
12th March 2021, 08:54 | #18988 | Link | |
RB and supporting software are installed on all computers. host pc has DE on and IP addresses. mac addresses auto-populated. not sure if DE on/off and settings matter on non-host computers. i start EncodingServer on the non host computers and then start an RB job on the host. DE seems to be in a connection loop; jumping between encoding and idle with no progress. |
12th March 2021, 09:47 | #18990 | Link |
Grumpy Old Man.
I doubt that you can half it.
Setting #1 is:- video=KNLMeansCL(video,d=0, a=2, s=4, h=4 Setting #3 is:- video=KNLMeansCL(video,d=1, a=2, s=4, h=4 Setting #5 is :- video=KNLMeansCL(video,d=2, a=2, s=4, h=4 the ONLY change seems to be the "d" value, so if you know how to half "0", go right ahead, and I doubt that you could use -1. Try MDeGrain's instead
12th March 2021, 09:49 | #18991 | Link | |
Grumpy Old Man.
Why didn't you update the "non-host's" to 3.7.0 ?? The only way to reduce the load is to reduce the servers enabled, or don't use them at all, until you get the cooling sussed !!!!
12th March 2021, 09:51 | #18992 | Link |
Sample Adaptive Offset loopfilter ... has been mocked as "Smooth All Out" in earlier versions of the x265 encoder development. Current versions have several options to tune, limit, and even disable its use.
It is useful for the efficiency of FullHD and UHD resolution encodes. But its detail loss can become more obvious when you upscale the encodes of lower resolutions. |
12th March 2021, 09:59 | #18993 | Link | |
12th March 2021, 11:05 | #18994 | Link |
Copy Video Stream Option?
I just ran across a situation where it would be convinient to leave the video stream as it is and just recode the audio streams and remuxing the subtitles for a couple of the files being processed. Is there a "copy video" option? I thught I once did see one, but now I canīt find it. |
12th March 2021, 11:18 | #18995 | Link | |
12th March 2021, 12:26 | #18996 | Link |
whats the best setup if i have a GPU?
i have an i5 10th gen and an Nvidia 1650 GPU.
im not after outright speed but more quality. currently im using CPU for 4K HDR encodes. im wondering if i should be using some sort of combination of GPU and CPU or will i loose quality? |
13th March 2021, 01:21 | #18998 | Link | |
Grumpy Old Man.
13th March 2021, 12:42 | #19000 | Link |
IT does what it's says on the tin
