28th March 2021, 05:20 | #61362 | Link | |
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
29th March 2021, 05:23 | #61364 | Link |
Troubleshooter
Orange dots appearing in videos.
Anyone know what may be causing lots of very small orange dots to appear in videos?
Has anyone had this start occurring on their systems recently where it didn't occur before? I thought it might be noise but I've tried changing dithering and noise settings in the dithering options in MadVR, but that didn't stop or significantly change it. I see it occurring in and around multiple colors on screen, but perhaps most heavily near light browns (skins), red objects, and orange objects. I tried to take a screen shot, but the issue doesn't display in screen shots. I have an optimus system, but since the last major Windows 10 update (20H2) I've been unable to use the Nvidia GPU (GTX 680M), its software, nor Optimus for anything, and am stuck using the Intel HD Graphics 4000 for everything (including watching any videos). If anyone has any settings you want me to check or test let me know.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
29th March 2021, 15:03 | #61365 | Link | |
When you enable LAN access on madVR you will see all running instances of madVR in your home network in each madVR tray tool list. To control madVR like you said from a phone or tablet would requite an app. I tried to make a madVR control app before, but I found out that the madVR command API only affects the madVR settings on disk, and not the live, running instance of madVR. Meaning you needed to close and re-open madVR to see any changes that you made to the madVR config via remote control. So ultimately I gave up on that idea. The other way you can control some madVR options is to set up hotkeys in the madVR hotkeys screen and you can use some remote control app on your phone or tablet that lets you simulate hotkeys on your PC. |
29th March 2021, 18:38 | #61366 | Link | |
I guess if it's bad one can always try to get a 3rd party cooler which I actually did, but haven't installed cause I found I didn't really need to, plus I found out the 3070FE is a PITA to do cause it has proprietary fan leads.
29th March 2021, 22:23 | #61367 | Link | |
The wisdom of this choice will be revealed when my new PC is delivered on 23 April. I doubt if I will be disappointed, as it will be replacing a machine that is rather long in the tooth (rather like me) |
29th March 2021, 23:44 | #61368 | Link | |
31st March 2021, 14:48 | #61369 | Link |
What version of madVR (that doesn't expire) let me choose an HDR measurement file? I tried with madVRhdrMeasure113 and 128 but they don't seem to show the folder selection icon.
Also is there a way to load madVR profiles per title? Maybe copying settings.bin to the movie folder or something like that? Edit: looks like beta 85 broke the measurement file support. Last edited by Dogway; 31st March 2021 at 15:16. |
31st March 2021, 15:38 | #61370 | Link |
In the newer test builds, the measurements folder config is under configuration => files & folders
I never got them to work starting from some build around 90-something. Anyway, the live method in v113 and newer is better than the measurement files. You can select profiles depending on what's in the file name using the condition filename="whatever" but you'd have to create a different profile for every one of your movies. If your problem is adapting the tone mapping settings to different types of movies (maybe depending on the mastering data?), I'd do something like renaming the movies this way: "movie title [hdr_profile1].mkv" and then use filename="*[hdr_profile1]*" to map them to just a few different profiles.
31st March 2021, 16:07 | #61371 | Link |
Thanks for the help. I used v113 before and it was ok, now in v130 it triggers HDR mode on my display so I will test with the measurement files, I fail to see how a live algo can predict peak brightness so far ahead if not relying on a measurement file.
The per movie profile was only to adjust the gamma, some 3D movies have brightness pumped it up to compensate for the glasses. |
31st March 2021, 16:14 | #61372 | Link |
Use profiles if you want to edit settings per movie.
Make like a "3D gamma" profile and then in the profile selection rules have something like; if the file name contains X, then select profile "3D gamma". Then come up with some special word for X to add to your movie filenames that you want to be gamma adjusted. |
1st April 2021, 06:21 | #61373 | Link | |
if (3D) "3D" else if (HDR) "HDR" else "SDR" Last edited by Bo.; 1st April 2021 at 06:24. |
1st April 2021, 15:03 | #61374 | Link |
Yes, it's actually 3D to 2D titles to leverage the open matte of some 3D releases. I already set it up and it works, but the gamma only goes up to 2.60, it would need to be 2.84 to mimic the 2D release... for the time being I lower brightness to -15. Better than nothing.
1st April 2021, 18:41 | #61375 | Link |
Perhaps a silly question, but how can I not get dropped frames in madVR OSD if I get sometimes max stats of 34 ms for rendering for a 60p AV1 8K HDR video? I watched carefully but I don't see dropped frames, stutters or anything like that.
1st April 2021, 19:08 | #61376 | Link |
The important is the present step. As long as the render queue is filled high enough to feed the present queue, you can have one frame (or even many) that takes more time to render and it won't have an impact on presentation as the queue is there to hide the variations in render times.
2nd April 2021, 01:43 | #61377 | Link | |
but except for the blower cards i have not seen a single GPU test where the FE edition isn't stomped into the ground by board partner cards including temps, clock rate and noise. |
2nd April 2021, 02:20 | #61378 | Link |
Need some help figuring something out:
Had been using a 980 Ti for a few years, outputing 24hz to a panasonic plasma. Never had any issues. Upgraded to a 3080, and now i get weird stuttering, but only if im at 24hz and trying to play sdr content. If i play a UHD remux, I dont get the stutters. The weird part is that im not showing any dropped frames, even though that's exactly what it feels like is happening. messed with every setting i could think of with the same results. Anyone have any ideas? |
2nd April 2021, 05:57 | #61379 | Link |
So there's no way to play this file using madVR and MPC-HC without the image looking all green?
https://pastebin.com/7Tk6DXne My config is still old... monitor: W2452V, video card Radeon R7 265, Windows 10-64 bit, Core i7 4770... and yet this is the first time I try playing a 4K video and it doesn't show correctly. What about this Dolby Vision support? I only found this thread about this issue: https://www.avsforum.com/threads/doe...ision.2980754/ >>>>>>> Does Windows 10 and MadVR support Dolby Vision? |
2nd April 2021, 12:57 | #61380 | Link |
Profile 5 Dolby Vision is non-backward compatible which means the player itself has to decode it, and madVR doesn't. Dolby Vision is proprietary and there is no indication of when or if unlicensed playback will be possible.
