Old 20th September 2019, 10:14   #901  |  Link
sneaker_ger
You would increase all of them. (Usually you would keep the factors between them constant.)
P.S.: It seems you cannot select e.g. --vbrhq 0 --vbr-quality <float> in StaxRip. It always sets --vbrhq 7677.
sneaker_ger is offline
Old 20th September 2019, 10:22   #902  |  Link
JKyle
App Digger
JKyle's Avatar
I already brought up that issue, and I guess Stax or Revan has a plan for that in the future.
See this.
JKyle is offline
Old 20th September 2019, 10:27   #903  |  Link
Patman
Patman's Avatar
I pm'ed Wolfberry but I don't know when he will fix it.
I sent Wolfberry pm too. But no reaction till now.
BTW, your version of ffmpeg is very slim compared to the Wolfberry built ffmpeg, which is more than 90MiB in size.
Can you please explain what makes the big difference?
Wolfberry's build have a lot of external libraries included. My version based on zeranoe builds + openal, opencl, opengl, vapoursynth and cuda-nvcc. Final size of my build is about 65 MB. After compiling i compress my files with upx, so the filesizes are like now. You can also see it by the filesize of x264 and x265. Until now, i had no problems with the compressed files during my encodes/decodes.
Patman is offline
Old 20th September 2019, 10:45   #904  |  Link
stax76
stax76's Avatar
See this.
I've bookmarked it, it looks like there is more than one issue and likely they are not easy to solve.
stax76 is offline
Old 20th September 2019, 10:59   #905  |  Link
ZeroCool22
ZeroCool22's Avatar
Thank you.
I tried VBR, it's good to get low size, but i notice pixelation in fast movement scenes.
So i just keep with CQP.
ZeroCool22 is offline
Old 20th September 2019, 20:48   #906  |  Link
JKyle
App Digger
JKyle's Avatar
Awesome! I'll be using your builds instead of the default Wolfberry builds, and see if I can provide any feedback for you.
Thank you again.
JKyle is offline
Old 21st September 2019, 10:53   #907  |  Link
Atlantis
I encoded an HDR mp4 and it seems the HDR flags are not passed.
This is the original file
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom)
File size                                : 724 MiB
Duration                                 : 1 min 23 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 73.1 Mb/s
Encoded date                             : UTC 2016-10-24 05:40:14
Tagged date                              : UTC 2016-10-24 05:40:14
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hvc1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 72.9 Mb/s
Maximum bit rate                         : 94.2 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Frame rate                               : 59.940 (60000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.147
Stream size                              : 722 MiB (100%)
Encoded date                             : UTC 2016-10-24 06:37:11
Tagged date                              : UTC 2016-10-24 05:40:23
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : R: x=1.000000 y=1.000000, G: x=1.000000 y=1.000000, B: x=1.000000 y=1.000000, White point: x=1.000000 y=1.000000
Mastering display luminance              : min: 0.1000 cd/m2, max: 1 cd/m2
Codec configuration box                  : hvcC
This is what Staxrip 2.0.4 gives
ormat                                   : Matroska
Format version                           : Version 4
File size                                : 253 MiB
Overall bit rate                         : 25.5 Mb/s
Encoded date                             : UTC 2019-09-21 09:45:52
Writing application                      : mkvmerge v37.0.0 ('Leave It') 64-bit
Writing library                          : libebml v1.3.9 + libmatroska v1.5.2
Writing frontend                         : StaxRip v2.0.4.0
Video
Format                                   : HEVC
Format profile                           : Main 10@L5.1@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 25.3 Mb/s
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.051
Stream size                              : 251 MiB (99%)
Writing library                          : x265 3.1+11-de920e0a3183:[Windows][GCC 9.1.1][64 bit] 10bit
Encoding settings                        : rc=crf / crf=18.0000 / qcomp=0.60 / qpstep=4 / qpmax=69 / qpmin=0 / no-lossless / no-cu-lossless / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / psy-rd=2.00 / psy-rdoq=0.00 / rdoq-level=0 / cbqpoffs=0 / crqpoffs=0 / ctu=64 / min-cu-size=8 / ref=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / no-hme / rd=3 / no-rd-refine / no-ssim-rd / rdpenalty=0 / deblock=0:0 / min-keyint=25 / keyint=250 / bframes=4 / bframe-bias=0 / b-adapt=2 / b-intra / b-pyramid / cutree / max-merge=3 / no-fades / weightp / no-weightb / no-rect / no-amp / sao / no-limit-sao / no-sao-non-deblock / early-skip / no-splitrd-skip / rskip / no-tskip / no-tskip-fast / no-fast-intra / scenecut=40 / scenecut-bias=0.05 / rc-lookahead=20 / gop-lookahead=0 / lookahead-slices=8 / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / qg-size=32 / radl=0 / open-gop / no-hevc-aq / no-aq-motion / no-dynamic-refine / dynamic-rd=0.00 / nr-intra=0 / nr-inter=0 / strong-intra-smoothing / no-constrained-intra / no-strict-cbr / no-const-vbv / no-rc-grain / wpp / no-pmode / no-pme / no-psnr / no-ssim / signhide / stats-write=0 / stats-read=0 / zone-count=0 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=4980 / frame-threads=3 / level-idc=0 / high-tier=1 / uhd-bd=0 / no-analyze-src-pics / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / temporal-mvp / no-temporal-layers / no-splice / no-intra-refresh / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / no-opt-cu-delta-qp / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / refine-analysis-type=0 / ctu-info=0 / copy-pic=1 / max-ausize-factor=1.0 / no-single-sei / no-svt / no-field / no-lowpass-dct / cpuid=1111039 / numa-pools=8 / log-level=2 / qp-adaptation-range=1.00
Atlantis is offline
Old 21st September 2019, 11:24   #908  |  Link
Atlantis
Here is the original file:
https://uhdsample.com/43-download-so...emo-video.html
Atlantis is offline
Old 21st September 2019, 12:02   #909  |  Link
NikosD
I've updated my builds of MP4Box, x265 and ffmpeg (with dxva2 support). For these who are intresteted.
Builds
@stax76
Hello @Patman.
I replied earlier that ffmpeg DXVA2 worked like a charm and indeed, using my GTX 1660, the performance and CPU usage of ffmpeg DXVA2 was like NVEnc Hardware.
But using my older Haswell system with no discrete card, just the iGPU, both "ffmpeg Intel" and "ffmpeg DXVA2" options inside StaxRip give me very bad results using both versions of ffmpeg (65MB and 20MB)
The ffmpeg Intel option has 25% CPU usage for ffmpeg.exe + 10% CPU usage for QSVEncC = 35% CPU with highest CPU clock and 80% slower FPS than "QSVEnc Hardware" option.
The ffmpeg DXVA2 options has 25% CPU usage for ffmpeg.exe + 25% CPU usage for QSVEncC = 50% CPU with highest clock and 40% slower FPS than QSVEnc Hardware option
I think both ffmpeg Intel and DXVA2 use DXVA2 copy-back mode instead of DXVA2 native and that could be the reason of very high CPU usage and slow FPS performance.
QSVEnc Hardware has lowest CPU clock during encoding and very low total CPU usage ~8% which is normal for DXVA2 native mode, along with highest FPS performance of course.
@Patman
Could you check if there is an option during compilation of ffmpeg for Intel hardware decoding regarding DXVA2 mode ?
Thanks!
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 21st September 2019, 20:10   #910  |  Link
JKyle
App Digger
JKyle's Avatar
AFAIK, the default x265 encoder included with 2.0.4 is Wolfberry's build and it's already reported to rearrange the order of 'Encoding Settings' metadata in the video stream.
See here.
My guess is that the HDR flags are missing in the course of tweaking the metadata.
Why don't you try Patman's x265 and see if the same problem occurs?
See here.
JKyle is offline
Old 21st September 2019, 20:15   #911  |  Link
JKyle
App Digger
JKyle's Avatar
Maybe rigaya is in full gear these days.
It's only three days since he released 4.49 but today he released 4.50 again.
JKyle is offline
Old 21st September 2019, 22:21   #912  |  Link
Atlantis
I like the order of the new stuff
rc=crf / crf=17.0000 / qcomp=0.60 / qpstep=4 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / ...
CRF at the beginning is great because it's the most important parameter that you might want to check and now I can see it at the beginning. I remember it was like this once before too.
Maybe it was Staxrip 2.0.2 or some other previous version.
Atlantis is offline
Old 21st September 2019, 23:39   #913  |  Link
JKyle
App Digger
JKyle's Avatar
Hi @ all,
Builds
Unfortunately, your build of MP4Box seems to generate the same unnecessary 'Title' metadata for the final video stream.
Now I highly suspect that it is an issue inherent in the MP4Box source.
JKyle is offline
Old 21st September 2019, 23:44   #914  |  Link
JKyle
App Digger
JKyle's Avatar
I agree. As long as it does not make any mess or omission in the metadata, of course.
JKyle is offline
Old 22nd September 2019, 12:09   #915  |  Link
Patman
Patman's Avatar
Hi JKyle,
that issue is related to mp4box. It's standard if no Tracktitle is set. I've run the mux process in command line with the parameter 'name:00009' after videoinput file and these is written to the title info.
The container options for MP4Box must be adapted like those for mkv and webm.
Patman is offline
Old 22nd September 2019, 14:55   #916  |  Link
imhh11
probably because your HDR10 source got incomplete/incorrect metadata.
never seen metadata like this on any of the HDR10 file I have.
you file should still trigger HDR10 since PQ is still there (--transfer smpte2084)
imhh11 is offline
Old 22nd September 2019, 16:35   #917  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Enter this Line in your CUSTOM Section, for Display P3 D65 HDR10:
--hdr --output-depth 10 --hdr-opt --max-cll "1000,400" --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)"
EDIT:
L(10000000,1)
You can see this values with "MediaInfo" from your source file.
With my little HDR Parser tool u must use this settings:
--hdr --output-depth 10 --hdr-opt --master-display "G(50000,50000)B(50000,50000)R(50000,50000)WP(50000,50000)L(5000,1000)"
-QfG- is offline
Old 22nd September 2019, 16:47   #918  |  Link
sneaker_ger
He can't see these exact values for his speficic source file because like imhh11 said this file's ("Sony Bravia OLED 4K Demo.mp4") mastering display color primaries and luminance metadata values are bogus. (Though this does not yet explain why StaxRip didn't transfer the metadata to the output.)
Old 22nd September 2019, 17:04   #919  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Problem with the filename (the tool is in beta). Renaming and working, correct values now in the post.
-QfG- is offline
Old 22nd September 2019, 18:10   #920  |  Link
Atlantis
Yes it does trigger the HDR in players. I just don't see it in MediaInfo.
I need it to be recognized as HDR in MediaInfo. For easy checking and organization of my files on PC.
Atlantis is offline
