Old 20th July 2020, 19:45   #21  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Metafier is a proprietary tool from Dolby for working with Dolby Vision metadata files. It's not free or public AFAIK, tho surely most tools that work with Dolby Vison processing include it.
Old 20th July 2020, 22:12   #22  |  Link
Nico8583
Ok thank you, so I understand why I don't find it. I will try to search another tool to extract metadata from DV source.
Nico8583 is offline   Reply With Quote
Old 3rd March 2021, 10:53   #23  |  Link
Balling
Originally Posted by Blue_MiSfit View Post
Really? I had no idea. That would surprise me because it would only play on a BD player with DoVi support.
I suppose the player could convert back to YCbCr and tone map for an HDR10 or SDR TV but you still need a UHD BD player with DoVi support and that's not all of them. Xbox One S/X being by far the most prevelant!
No, profile 5 can also use not IPTPQc2 and be marked as compatible with HDR10. Example: https://sylvan.apple.com/Aerials/2x/...K_HDR_HEVC.mov IPTPQ c2 profile is also marked as full range per Dolby.
Balling is offline   Reply With Quote
