8th March 2020, 18:57 | #5201 | Link |
We dropped VS2008 ages ago. stdint and stdbool are part of C99, which Microsoft wasn't sufficiently compliant with until VS2013 (2015 added more support for C99). That's probably the earliest for plugins (although the core requires at leastı VS 2015).
ıstd::filesystem is a C++17 feature, but it looks like VS 2015 might have added it early. |
8th March 2020, 19:10 | #5202 | Link | |
So plugins also will not compile now with avs+ headers and older compiler, guess that means loads of plugins
will now revert to avs Std headers. [EDIT: Ones that only support v2.60 std colorspaces anyway, and that is most plugins] EDIT: One plugin (by someone else) that I fixed up (maybe Watermark plugin not sure) used stdint.h and simply adding that to include directory worked just fine, I have not as yet found the (M$) stdbool.h and dont know if adding that to include would cause any problems, I do have VS2015, VS2017 community and also 2019, I guess I could get stdbool from any one of them, but have no idea if would work properly for vs2008. I have not really used either 2015, or 2017 or 2019, did not like the telemetry and need to register thing [I also like the ability to compile on XP on occasion, hence VS2008]. Quote:
EDIT: If avs+ headers are supposed to be compatible with avs std, then would not stdtype.h and stdbool.h only be needed by the core and not for [any/most] plugins ???
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th March 2020 at 19:51. |
8th March 2020, 20:03 | #5203 | Link | |
typedef __int16 int16_t; typedef unsigned __int16 uint16_t; typedef __int32 int32_t; typedef unsigned __int32 uint32_t; typedef __int64 int64_t; typedef unsigned __int64 uint64_t; |
8th March 2020, 20:05 | #5204 | Link |
What is it that is required from stdbool.h, similar easy fix ?
[also need edit avs+ types.h whenever updated]
8th March 2020, 20:15 | #5205 | Link |
Dunno, probably I put a check in the header against compiler version and define those types if compiler is Microsoft and compiler version is below a specific value. (A conditional ifdef'd section for typedefing the new types mentioned above)
8th March 2020, 20:17 | #5206 | Link |
Cheers P.
EDIT: Maybe stdbool.h for C interface, C does not have bool.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th March 2020 at 20:24. |
8th March 2020, 20:17 | #5207 | Link |
Considering that a refusal to update from outdated compilers was one of the main reasons AviSynth+ was started in the first place, I don't consider that a convincing argument. Requiring C99 is not an unreasonable baseline in any way, shape, or form.
VS2013 is 7 years old at this point (the C99 standard itself is 21 years old), and systems that can't run at least that version are in a very small minority. That's not 'the runtime of vc2013', required to use stuff it produces, that's the compiler itself. Most devs interested in keeping their plugins up-to-date with AviSynth+ are not on Pentium IIIs running Windows XP. The alternatives are Clang-cl, use the MSVC Build Tools without the IDE or in conjunction with non-branded VSCode (probably; still requires a newer CPU/OS, though), or switch the plugin to the C interface and build with GCC. C++17 features aren't used in the headers, no. |
8th March 2020, 21:08 | #5208 | Link |
I understand that Avs+ core requires recent compiler and have no problem with that.
But seems that one should require later version compiler for plugins, for no other reason than "it is hip" to do so, I dont wanna update just because it is fashionable. I mainly now use VS2008 on W7x64 Q9550, sometimes use XPx64 on quad core Q6600, got rid of my PIII's some time ago, I have one P4 XP32. I also on occasion use VS2008 x86 on W10x86(Baytrail) Tablet/Laptop 2_in_1 thingy, with only 2GB RAM, 32GB storage, no way I am gonna use 2015, 2017 or 2019 on that. [I also have x64 4GB RAM 64GB storage CherryTrail W10, dont want to swamp that with 2015/17/19 either] EDIT: Of course the worst thing is that existing plugin source will no longer compile using the compilers that they were developed with (unless you switch to avs 2.60 std header, making all of the avs+ compatible header stuff a pointless exercise). EDIT: OK, reverted to older Avs+ headers, can compile again.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th March 2020 at 22:01. |
8th March 2020, 23:02 | #5209 | Link | |
It'd be something like this: Code:
#include "config.h" // Define all types necessary for interfacing with avisynth.dll #if defined(AVS_WINDOWS) #if _MSC_VER >= 1800 // C99 stdint.h is only supported by MSVC 2013 or higher #include <stdint.h> #include <stdbool.h> #endif #else // AVS_POSIX #include <stdint.h> #include <stdbool.h> #endif |
10th March 2020, 05:26 | #5210 | Link |
I'm currently just about done with mod to DDigit metrics text renderer for plugin devs, implemented for all Avs+ colorspaces.
I'de just like to check if I'm doin' it right, in particular the chroma calcs. where, output 32 bit float result required. c1 is YUV-Y in 0->255 range [EDIT: Text color as YUV 8 bit] c2 is YUV-U in 0->255 range c3 is YUV-V in 0->255 range Code:
const float cxy =(float)(c1/255.0); const float cxu =(float)((c2-127.5)/255.0); # mid 127.5 rather than 128 (seems right for -0.5 to +0.5) const float cxv =(float)((c3-127.5)/255.0); Or Maybe const float cxy =(float)(c1/255.0); const float cxu =(float)((c2-128)/255.0); # mid 128, possible (but unlikely) lob sided out of -0.5, 0.5 range const float cxv =(float)((c3-128)/255.0); Or Limit const float cxy =(float)(c1/255.0); const float cxu =(float)(max(c2-128,-127)/255.0); # mid 128, limited const float cxv =(float)(max(c3-128,-127)/255.0); Thanx in advance. EDIT: And for 8 bit BYTE RGB to 16 bit RGB48 Code:
int cx1=(c1<<8)|c1 int cx2=(c2<<8)|c2 int cx3=(c3<<8)|c3 Code:
int cls=Bpc-8,crs=8-cls; int cx1=(c1<<cls)|(c1>>crs); int cx2=(c2<<cls)|(c2>>crs); int cx3=(c3<<cls)|(c3>>crs); Code:
int cxy =c1<<(Bpc-8) int cxu =c2<<(Bpc-8); int cxv =c3<<(Bpc-8);
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th March 2020 at 07:22. |
10th March 2020, 10:23 | #5211 | Link | ||
RGB is always full scale, the ranges should be stretched like
x_new = x_old * target_max / source_max Quote:
This python script is showing that this approximation differs only by 1 from the ideal result. The integer mul-add-rounder-div is giving the same results as doing all as float (no difference). This latter method is not too fast, it has an integer division (which can be replaced by multiply using magic-number tricks but using float for precison is better) When you are using this approximation for font colors, it's more than enough. Code:
sourcebits=10 targetbits=16 sourcemax = (1 << sourcebits) - 1 half_for_rounding = sourcemax // 2 cls = targetbits - sourcebits crs = sourcebits - cls targetmax = (1 << targetbits) - 1 errcount_approx = 0 errcount_intmuldiv = 0 maxdiff = 0 for x in range(0, sourcemax): # reference: float float32 = int(float(x) * targetmax / sourcemax + 0.5) approx = (x << cls) | (x >> crs) intmuldiv = (x * targetmax + half_for_rounding) // sourcemax intmuldiv_no_round = (x * targetmax) // sourcemax if approx != float32: print("FLT_APPROX_DIFF x = {0} approx = {1} exact = {2} intround = {3} intnoround = {4} ".format(x, approx, float32, intmuldiv, intmuldiv_no_round)) errcount_approx = errcount_approx + 1 diff = abs(approx - float32) if diff > maxdiff: maxdiff = diff if float32 != intmuldiv : # or approx != intmuldiv_no_round''': print("FLT_INT_DIFF x = {0} approx = {1} exact = {2} intround = {3} intnoround = {4} ".format(x, approx, float32, intmuldiv, intmuldiv_no_round)) errcount_intmuldiv = errcount_intmuldiv + 1 print("Difference count (approx): {0}, maxdiff: {1}".format(errcount_approx, maxdiff)) print("Difference count (intmuldiv): {0}".format(errcount_intmuldiv)) # from-to # of differences # 8->10 42 # 8->12 56 # 8->14 42 # 8->16 0 #10->12 170 #10->14 234 #10->16 234 O.K. YUV is always bit-shifting |
10th March 2020, 11:36 | #5212 | Link | |
Either you are using 32 bit float format with a simple division For 8 bits: Y' = Y / 255.0 U' = (U - 128) / 255.0 (replace 255 with the acture max_bit_depth_value) Internally 8 bit colors (historically we can pass only 8 bit colors using integer parameters e.g. text color or BlankClip) are converted by using this method. Or you can keep the convention that float formas are always full scale and map Y 16-235 to 0..1.0 and U,V 16-240 to -0.5..0.5 I'm planning rechecking all such occurences when YUV 32 bit floats are used in such a mixed bit depth environment, incl. Colorbars. My opinion that 32 bit float YUV should be treated always as full scale Y=0 to 1 and U/V=-0.5 to +0.5 |
10th March 2020, 15:27 | #5213 | Link |
Thanks P, I've taken snap of both posts for posterity, not really that important (I dont think) that absolutely correct, is only for metrics
and colornames chosen (from Colors_Rgb.avsi) were really only so I would not end up making up my own names, eg FishFinger_Orange or Putrid_Puce. I'll try get as close as I can to optimum, but might just do close to best if it will impact speed too much. I'm surprised that it was so easy to do the mod, only started it two days ago, still some tinkering to do. IanB did a re-factor of Info.h where optionally len of text could be given rather than hunting nul term sentinel, this allowed me to write the utility partner header InfoF.h which allows Info.h metrics text to have embedded control codes eg '\n' and '\r', perhaps a similar arrangment could be used with your Text() filter (AKA SimpeText class), might also allow for color control codes so that plug progger could use multi-line anti-aliased Text() with better control of text rendering, and eg sprintf type insertion of variables into strings, as used in eg RT_String(). For this to work properley, would ideally be implemented as a frame renderer rather than a filter [requiring MakeWriteable already done by caller], so as to be able to control text placement, or maybe the InfoF.h style control with additional sprintf style var to string substitution could be done internally and so the interface would need be implemented with varidaic args [think thats what them there things are called, same as RT_string(), RT_DebugF(), RT_Subtitle() and a few more]. As currently implemented as a filter, Text() would not be ideal where placement of multiple strings in different frame positions is needed. I implemented similar in thread "Avisynth CPP interface for C Proggers":- https://forum.doom9.org/showthread.p...57#post1538557 Some excerpts from that thread. Code:
#include "Info.h" // Plugin text rendering header from Avisynth v2.6, (Use Version of 17 April 2011, or later, bugs fixed, OK for v2.5+) // Provides white only horizontal print at pixel coordinates, no formatting of any kind. // Obtainable here (look for 'Info.h'):- // http://avisynth2.cvs.sourceforge.net/viewvc/avisynth2/avisynth/src/core/ #include "InfoF.h" // New in v0.2 // A companion to Info.h, provides screen formatted printing via embedded control codes. // Also provides stubs for character coord printing as well as pixel coordinates. // Formatting control codes:- // '\n', Newline, positioning cursor 1 line down and at left edge of screen. // '\r', Newline Special, moves 1 line down and positions cursor at on-entry X position. // '\b', Backspace, obvious, not sure how useful this will be. // '\f', Forward Space, again obvious, re-uses formfeed code for this. Again, maybe not so useful. // '\t', Tab, @ character positions, every 4 characters.(relative screen LHS). // // DDigit() from which this header originates, provides horizontal & vertical print at both pixel // and character coords, 16 color printing and screen formatting (eg '\n') control codes together // with color control codes. Control codes, vertical print and colorspace code are all controlled // via compiler directives and so can be excluded from the binary if not required. // Code:
// DrawFStr() Draw a Formatted string of text at character position, a user defined member function. // As with all class members defined outside of the class, it is preceded by the class name and scope operator. void __stdcall INTERNALNAME::DrawFStr(PVideoFrame &dst,int x,int y,const char *format, ...) { // This member function added in v0.2, adds BOTH string and screen formatting, eg '%f' for string and '\n' for screen. // Firstly, string formatting, into the buffer implemented in the class instance, formatted_buf[FMT_BUFSZ]. va_list args; va_start(args, format); _vsnprintf(formatted_buf,FMT_BUFSZ-1, format, args); va_end(args); // The DrawFStrXXX fn's are implemented in the InfoF.h file and provide screen formatting, eg '\'n and '\t'. // As string formatting has already been done above (eg floats etc turned to character strings), and the below // DrawFStrXXX functions provide screen formatting, so full formatting is achieved on the video frame. // // Formatting control codes (as provided by InfoF.h):- // '\n', Newline, positioning cursor 1 line down and at left edge of screen. // '\r', Newline Special, moves 1 line down and positions cursor at on-entry X position. // '\b', Backspace, obvious, not sure how useful this will be. // '\f', Forward Space, again obvious, re-uses formfeed code for this. Again, maybe not so useful. // '\t', Tab, @ character positions, every 4 characters.(relative screen LHS). // if(vi.IsPlanar()) DrawFStrPlanar(dst,x,y,formatted_buf); else if(vi.IsYUY2()) DrawFStrYUY2(dst,x,y,formatted_buf); else if(vi.IsRGB32()) DrawFStrRGB32(dst,x,y,formatted_buf); else if(vi.IsRGB24()) DrawFStrRGB24(dst,x,y,formatted_buf); } Code:
void __stdcall DrawFStringPlanar(PVideoFrame &dst,int x,int y,const char *s,bool pix = true) { // Draw formatted string at pixel or character coords, pix == false = character coords if(pix == false) {x *= 10; y *= 20;} // To Chars int in_x = x; // REM x for '\r' const unsigned char *se=(unsigned char*)s; // unsigned while(*se) { // while, some to do int n; for(s=(char*)se; n = *se, n>=' ' && n <= 223; ++se); // Find end+1 of printable int len = (int)((char*)se - s); // Len of printable if (len) { // Some to print DrawStringPlanar(dst,x,y,s,len); // do the biz x += len * 10; // update x coord } else { // Ctrl code OR nonsense; if(n == '\n') { x = 0; y+=20; // Newline, down 1, LHS } else if (n == '\r') { x = in_x; y +=20; // Newline Special, Down 1, orig x coord } else if(n == '\b') { x -= 10; // Backward Space } else if (n == '\f') { x += 10; // Forward Space } else if (n == '\t') { x+= ((4*10)-(x%(4*10))); // H-Tab (step 4) } ++se; // skip ctrl code (and unknowns, outer loop detects nul sentinel) } } } void __stdcall DrawFStrPlanar(PVideoFrame &dst,int x,int y,const char *s) { // Formatted Print @ character coords DrawFStringPlanar(dst,x,y,s,false); } Using plain white only text using Info.h with InfoF.h layout control and sprintf style arg substitution as from above function. A few frames from current DDigitTest dll
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th March 2020 at 15:36. |
10th March 2020, 15:51 | #5214 | Link |
So positioning is done like left-right-down joystick movements between prints?
I'm working on further Text filter features which were in my mind but were omitted in the final rush of making linux version work. Such cursor movements can probably be easily added without much speed penalty. (Though I'm sure that it's not this filter which is the bottleneck, I did some profiling and check of the generated asm code just for couriosity) You noticed well that I have removed the string length argument, because it was of no use actually. |
10th March 2020, 16:09 | #5215 | Link | ||
I particularly like the ability to return to 'on-entry' X position, so can if required format text with a horizontal Offset to all lines (either pixel or char position). EDIT: You can use only '\r' n/l special and change on-entry X position and, move the whole damn lot over left or right and maintain all layout. I also use '\a' as color control code with additional chr code for color, but left one ctrl code free for any future expansion, (8=\b=backspace, 9=\t=tab, 10=\n=newline, 11=free['\v' I think, cant remember, maybe vertical tab], 12='\f'=forward space, 13=\r=NewLineSpecialOnEntry-X) Quote:
EDIT: From DDigitTest Code:
if(!mono) { char *ahi=(a1>235||a2>235||a3>235)?"\aA":"\aB"; char *blo=(b1<16||b2<16||b3<16)?"\a6":"\aB"; sprintf(buf, "\b\b\b\b\f\bTesting Control & Color Codes:-\n\n\r" "Frame: %-7u( \a2Red\a- / \a4Green\a- / \a1Blue\a- )\r" " \a8Fred: (%7.2f /%7.2f /%7.2f )\r" " Ted: (%7.2f /%7.2f /%7.2f )\r" " Bill: ( %3d / %3d / %3d )\r" " Ben: ( %3d / %3d / %3d )\r" " %sJack\aB: ( %s%3d\aB / %s%3d\aB / %s%3d\aB )\r" " %sJill\aB: ( %s%3d\aB / %s%3d\aB / %s%3d\aB )\r" "\n\n\a-EVERYTHING VISIBLE (incl this) is 1 single printed string\n" "\t\t\t\t\aEDATA is RANDOM ONLY" ,n, rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX, rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX, rand()&255,rand()&255,rand()&255,rand()&255,rand()&255,rand()&255, ahi,(a1>235)?ahi:"\aB",a1,(a2>235)?ahi:"\aB",a2,(a3>235)?ahi:"\aB",a3, blo,(b1<16)?blo:"\aB",b1,(b2<16)?blo:"\aB",b2,(b3<16)?blo:"\aB",b3 ); } else { char *ahi=(a1>235||a2>235||a3>235)?"\aV":"\aO"; char *blo=(b1<16||b2<16||b3<16)?"\aV":"\aO"; sprintf(buf, "\b\b\b\b\f\bTesting Control & Mono Codes:-\n\n\r" "Frame: %-7u( \aQBob\a- / \aQAlice\a- / \aQDave\a- )\r" " \aTFred: (%7.2f /%7.2f /%7.2f )\r" " Ted: (%7.2f /%7.2f /%7.2f )\r" " Bill: ( %3d / %3d / %3d )\r" " Ben: ( %3d / %3d / %3d )\r" " %sJack\aO: ( %s%3d\aO / %s%3d\aO / %s%3d\aO )\r" " %sJill\aO: ( %s%3d\aO / %s%3d\aO / %s%3d\aO )\r" "\n\n\a-EVERYTHING VISIBLE (incl this) is 1 single printed string\n" "\t\t\t\t\aODATA is RANDOM ONLY" ,n, rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX, rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX,rand()*255.0/RAND_MAX, rand()&255,rand()&255,rand()&255,rand()&255,rand()&255,rand()&255, ahi,(a1>235)?ahi:"\aO",a1,(a2>235)?ahi:"\aO",a2,(a3>235)?ahi:"\aO",a3, blo,(b1<16)?blo:"\aO",b1,(b2<16)?blo:"\aO",b2,(b3<16)?blo:"\aO",b3 ); } AStr(dst, 4, 0, buf); DDigit / RT_Subtitle(), also has 16 shades of grey, but I'm not altogether happy with the dark ones on eg black background, trying to figure out a way to brighten background for those, and with little overhead and hopefully no additional code path. Here is code for RGBPS and RGBAPS Code:
} else if(ComponentSize==4) { if (RGB && Planar) { #if (defined DDIGIT_ENABLE_SUPPORT_RGB && defined DDIGIT_ENABLE_SUPPORT_PLANAR) const int pitch = PitchArr[0]; const float cx1=(float)(c1/255.0); const float cx2=(float)(c2/255.0); const float cx3=(float)(c3/255.0); const float cxArr[3]={cx2,cx3,cx1}; for(int pln=0;pln<=2;++pln) { BYTE *dp=WrPtrArr[pln] + xx*4 + yy*pitch; const float cx = cxArr[pln]; for (int ty = tytop; ty < tybot;++ty,dp += pitch) { float* rp = (float*)dp; unsigned int fbm= FontNum[ty] << txlft; for (int tx = txlft; tx < txrgt; ++tx,++rp, fbm<<=1) { if (fbm & 0x8000) { // Character Foreground SET Pixel ? rp[0] = cx; // Set Luma Foreground Pixel } else { DD4_BGF_RGB(rp[0]); // fade background } } } } #endif // (defined DDIGIT_ENABLE_SUPPORT_RGB && defined DDIGIT_ENABLE_SUPPORT_PLANAR) Code:
#elif (DDIGIT_BACKGROUNDFADE == 1) // Multiply background by 3/4 #if(0) // Old 8 bit before simplify #define DD_BGF_Y(dat) (dat)=(unsigned char) (((((dat)-16)*3)>>2)+16) #define DD_BGF_C(dat) (dat)=(unsigned char) (((((dat)-128)*3)>>2)+128) #define DD_BGF_RGB(dat) (dat)=(unsigned char) (((dat)*3)>>2) #else // ComponentSize=1 (8 bit) // (dat*3>>2)-(16*3>>2)+16 == (dat*3>>2)+4 #define DD_BGF_Y(dat) (dat)=(unsigned char) ((((dat)*3)>>2)+4) // (dat*3>>2)-(128*3>>2)+128 == (dat*3>>2)+32 #define DD_BGF_C(dat) (dat)=(unsigned char) ((((dat)*3)>>2)+32) #define DD_BGF_RGB(dat) (dat)=(unsigned char) (((dat)*3)>>2) // ComponentSize=2 // (dat*3>>2)-(64 *3>>2)+ 64 == (dat*3>>2)+ 16 10 bit // (dat*3>>2)-(256 *3>>2)+ 256 == (dat*3>>2)+ 64 12 bit // (dat*3>>2)-(1024*3>>2)+1024 == (dat*3>>2)+ 256 14 bit // (dat*3>>2)-(4096*3>>2)+4096 == (dat*3>>2)+1024 16 bit #define DD2_BGF_Yadd(bpc) (4<<((bpc)-8)) // Precalc add = (4<<(BitsPerComponent-8)) #define DD2_BGF_Y(dat,add) (dat)=(unsigned short) (((dat)*3>>2)+(add)) // Precalc add = (4<<(BitsPerComponent-8)) // (dat*3>>2)-( 512 *3>>2)+ 512 == (dat*3>>2)+ 128 10 bit // (dat*3>>2)-( 2048 *3>>2)+ 2048 == (dat*3>>2)+ 512 12 bit // (dat*3>>2)-( 8192 *3>>2)+ 8192 == (dat*3>>2)+ 2048 14 bit // (dat*3>>2)-(32768 *3>>2)+ 32768 == (dat*3>>2)+ 8192 16 bit #define DD2_BGF_Cadd(bpc) (32<<((bpc)-8)) // Precalc add = (32<<(BitsPerComponent-8)) #define DD2_BGF_C(dat,add) (dat)=(unsigned short) (((dat)*3>>2)+(add)) // Precalc add = (32<<(BitsPerComponent-8)) #define DD2_BGF_RGB(dat) (dat)=(unsigned short) ((dat)*3>>2) // ComponentSize=4 #define DD4_BGF_Y(dat) (dat)=(float)((dat)*(3.0/4.0)) #define DD4_BGF_C(dat) (dat)=(float)((dat)*(3.0/4.0)) #define DD4_BGF_RGB(dat) (dat)=(float)((dat)*(3.0/4.0)) #endif #elif (DDIGIT_BACKGROUNDFADE == 2)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th March 2020 at 16:39. |
10th March 2020, 17:05 | #5217 | Link |
EDIT:
Yep, the centering thing would upset things Here my code in DDigit, uses actual codes, RT_Subtitle (If I remember correctly) will take either real control code or human visible eg "\n" or "\a0" and converts to real control codes "\n" to Chr(10) and then "\a0" to Chr(7)+Chr(48), for DDigit, also RT_Subtitle() does sprintf style arg substitution, and detects whether not will be wholly off frame (misses call to DDigit when so, DDigit can do that itself, but RT_Subtitle is parsing anyways so avoids duplicate parsing when not necessary). Only on frame subs will be processed by DDigit via RT_Subtitle. I have script that scroll quite long texts and in real time upwards, downwards, or Kareoke style, and DDigit only gets the valid on frame text to bother with. some ctrl code stuff Code:
for (int s_ix=0;s_ix<length ;++s_ix) { num=((unsigned char*)s)[s_ix]; // Cast to speed up ctrl code detect #ifdef DDIGIT_ENABLE_SUPPORT_CONTROL_CODES if(num <= '\r' && num >= '\a' && (ctrl)) { // Control Character ? if(num == '\a') { // Color control character ? int cc=s[s_ix+1]; if(cc >= 'a' && cc <= 'v') cc -= ('a' - 'A'); // Upper Case char *colstr="0123456789ABCDEFGHIJKLMNOPQRSTUV-!*"; char * ccp=colstr; while(*ccp && *ccp != cc) ++ccp; if(*ccp) { ++s_ix; // Color control code parsed with valid arg, skip ctrl code.('\a') cc=int(ccp - colstr); if(cc>31) { if(cc==32) { // '-' = ddigit default color cc = CMapdef[cmapix][0]; // Default } else if(cc==33) { // '!' = ddigit hilite cc = CMapdef[cmapix][1]; // Hilite } else if(cc==34) { // '*' = Original starting color cc=color; } } c1=(RGB) ? DDigit_Cmap_RGB[cc] : DDigit_Cmap_YUV[cc]; c3=c1 & 0xFF; c1>>=8U; c2=c1 & 0xFF; c1>>=8U; c1 &= 0xFF; continue; } } else if (!vert) { // Horizontal switch(num) { case '\n': // NewLine x = 0; // Screen left y += DDIGIT_CHAR_HEIGHT; // Next line down continue; case '\r': // 1 line down and back to original X position x = in_x; // Below starting X input postion y += DDIGIT_CHAR_HEIGHT; // Next line down continue; case '\t': // Horizontal Tab x+= ((DDIGIT_TABCNT*DDIGIT_CHAR_WIDTH)-(x%(DDIGIT_TABCNT*DDIGIT_CHAR_WIDTH))); continue; case '\f': // Forward Space x += DDIGIT_CHAR_WIDTH; // 1 char right continue; case '\b': // BackSpace x -= DDIGIT_CHAR_WIDTH; // 1 char left continue; } } else { // Vertical Code:
avi = RT_FSelOpen("Please select an AVI file",Filt="*.AVI|*.AVI") Assert(avi.IsString,"RT_FSelOpen: Error="+String(avi)) AVISource(AVI) txt = RT_FSelOpen("And now select a Text file",Filt="*.txt|*.txt") Assert(txt.IsString,"RT_FSelOpen: Error="+String(txt)) Txt=RT_ReadTxtFromFile(txt) Lines=RT_TxtQueryLines(Txt) # config DELAY=100 ALIGN=1 # As Numeric KeyPad SCROLL=0 # 0 = Upwards : 1 = Downwards : 2 = Right to Left : 3 = Left to right : 4 = Karaoke # ORG=Last Last=(SCROLL==4)? ORG.Blankclip(height=80) : Last CMD_0 = """RT_Subtitle("%s",Txt,align=ALIGN,y=height+DELAY-current_frame,expx=true,expy=true)""" CMD_1 = """RT_Subtitle("%s",Txt,align=ALIGN,y=-(Lines*20+DELAY) + current_frame,expx=true,expy=true)""" CMD_2 = """RT_Subtitle("%s",Txt,align=ALIGN,x=width+DELAY-current_frame,expx=true,vcent=true)""" CMD_3 = """RT_Subtitle("%s",Txt,align=ALIGN,x=-(width+DELAY)+current_frame,expx=true,vcent=true)""" CMD_4 = """RT_Subtitle("%s",Txt,align=ALIGN,y=height+DELAY-current_frame,expx=true,expy=true)""" CMD_5 = """RT_Subtitle("BAD SCROLL COMMAND (0->4)")""" CMD = (SCROLL<0 || SCROLL>4) ? CMD_5 : Select(Scroll,CMD_0,CMD_1,CMD_2,CMD_3,CMD_4) ScriptClip(CMD) Return (SCROLL==4)? StackVertical(ORG,Last) : Last EDIT: Also take peek at this:- https://forum.doom9.org/showthread.php?t=177366 EDIT: Code:
RT_Subtitle(clip source,string format,dat1,...,datn,int "align",int "x","y",bool "vcent"=false,bool "expx"=false,bool "expy"=false,int "esc"=1) Standard filter function. This function is a standard filter graph function, not a runtime/compile time function. v2.5 plugin dll limited to v2.58 colorspaces. Prints formatted text to clip frame using Avisynth Info.h source font (monospaced) and DDigit font renderer, faster than using Subtitle system fonts. The unnamed 'format' string and optional unnamed 'dat' args are used to construct the text string that is printed on frame, uses C/CPP printf() style formatting. The args 'align', 'x', and 'y', work in a similar fashion to Avisynth Subtitle() expx and expy control whether x and y are same as in SubTitle when eg y = -1 (vertical centered) or y=height (bottom aligned), or as explicit coords when expy = true. esc int, default 1. (0 -> 2). Escape code processing eg '\n' converted to NewLine. 0 = No Escape code processing. 1 = Esc codes processed only in format string. (Default) 2 = Esc codes processed in both format and data strings. RT_Subtitle(c,"Hello there %s and %s.\nGoodbye %d.","Fred","Ted",2013,align=4,x=100,vcent=true) would print Hello there Fred and Ted. Goodbye 2013. at x pixel position 100 and y pixel position centered, the vcent=true will vertical center a block of text (align=4 or 5 or 6), whereas Subtitle() starts at centred position and prints downwards from there (as default vcent=false). Align, default = 7 ie top left (as on numeric keypad). x and y allow modification of alignment, eg x= -1, centers x at mid point, x=width, would right align, y=height would align at bottom of frame. It is necessary to specify the optional arg names of x,y,align and vcent etc, as the dat args can take 0 or more variables of any type, so Avisynth cannot tell when the list of dat args ends and the named optional args begins. I did try to use the dat args last but Avisynth seems to get confused when you use dat= etc, it throws an error saying something like "dat arg specified more than once", even if it was not. printf Format spec here:- http://msdn.microsoft.com/en-us/library/56e442dc%28v=vs.71%29.aspx NOTE, the only support for printing Bool variables is %s as string, ie prints "True" or "False". To print only 1st letter of type bool:- ColorBars.KillAudio.RT_Subtitle("%.1s",true) prints 'T' Formatting supported %[flags] [width] [.precision] type flags, one of "-,+,0, ,#" width, integer, "*" supported (width supplied via dat arg). Precision, integer, "*" supported (precision supplied via dat arg). type, "c,C,d,i,o,u,x,X", Integer type, c,C=character, d,i=signed, o,u,x,X=unsigned. "e,E,f,g,G", Floating point type "s,S", String type (also Bool). eg colorbars.killaudio FMT="%d ] \a%cCurrent_Frame=\a-%d" ALPHA="0123456789ABCDEFGHIJKLMNOPQRSTUV-!" ScriptClip(""" RT_Subtitle(FMT,current_frame,RT_Ord(ALPHA,(current_frame/25)%32+1),current_frame,align=5) """) return last In the above example you see the sequence "\a%c" where %c is replaced with a character from ALPHA, "\a0" selects color 0, "\aV" selects the last color (31). "\a-" selects the default color, and "\a!" selects the hilite color. You can in Scriptclip() select colors programmatically, perhap selecting red to show an error or bad metrics condition. The initially selected color will always be the default color (white). Ripped from DDigit source code: // Color control codes as strings. ASCII Code of Final char #define DDIGIT_CC_DARKGRAY "\a0" // 48 #define DDIGIT_CC_DODGERBLUE "\a1" // 49 #define DDIGIT_CC_ORANGERED "\a2" // 50 #define DDIGIT_CC_ORCHID "\a3" // 51 #define DDIGIT_CC_LIME "\a4" // 52 #define DDIGIT_CC_AQUAMARINE "\a5" // 53 #define DDIGIT_CC_YELLOW "\a6" // 54 #define DDIGIT_CC_WHITE "\a7" // 55 #define DDIGIT_CC_SILVER "\a8" // 56 #define DDIGIT_CC_CORNFLOWERBLUE "\a9" // 57 #define DDIGIT_CC_ORANGE "\aA" // 65 #define DDIGIT_CC_PLUM "\aB" // 66 #define DDIGIT_CC_CHARTREUSE "\aC" // 67 #define DDIGIT_CC_POWDERBLUE "\aD" // 68 #define DDIGIT_CC_GOLD "\aE" // 69 #define DDIGIT_CC_GAINSBORO "\aF" // 70 #define DDIGIT_CC_Y_0 "\aG" // 71 #define DDIGIT_CC_Y_1 "\aH" // 72 #define DDIGIT_CC_Y_2 "\aI" // 73 #define DDIGIT_CC_Y_3 "\aJ" // 74 #define DDIGIT_CC_Y_4 "\aK" // 75 #define DDIGIT_CC_Y_5 "\aL" // 76 #define DDIGIT_CC_Y_6 "\aM" // 77 #define DDIGIT_CC_Y_7 "\aN" // 78 #define DDIGIT_CC_Y_8 "\aO" // 79 #define DDIGIT_CC_Y_9 "\aP" // 80 #define DDIGIT_CC_Y_A "\aQ" // 81 #define DDIGIT_CC_Y_B "\aR" // 82 #define DDIGIT_CC_Y_C "\aS" // 83 #define DDIGIT_CC_Y_D "\aT" // 84 #define DDIGIT_CC_Y_E "\aU" // 85 #define DDIGIT_CC_Y_F "\aV" // 86 #define DDIGIT_CC_HILITE "\a!" // 33 #define DDIGIT_CC_DEFAULT "\a-" // 45 In color codes eg "\aV", the 'a' is strictly case sensitive however the color number ('V') can be upper ot lower case. In addition to color control codes, the filter will accept "\n" (NOT "\N", strictly case sensitive) or "\r" as newline, and "\f" as forward space (move 1 right without printing anything), no other control codes are supported. "\t" and TAB control codes are converted to a single space, I could think of no sensible way to handle tab when center or right aligned, if there is a demand, I could maybe handle tab for left alignment only and replace with single space for other alignment. To embed a single BackSplash ("\") into the format string or even an argument dat (when esc=2) string you must insert a double BackSlash ie "\\". To embed a single percent character ("%") into a format string, you must embed a double percent sequence ie "%%". Reason is that such characters are used for formatting eg "%f" flags a float arg to embed into the string and eg "\n" would mean insert newline into string. Note, the colored text is not great in YV12 and quite awful in YV411, try to avoid YV411 at all times, tis truly nasty. To Print contents of multiline text file on frame: AVISource("D:\AVS\TEST.AVI") S=RT_ReadTxtFromFile("test.txt") Scriptclip("""RT_Subtitle("%s",S,align=5,vcent=True)""") return last As can be seen from above example, you can also use eg Chr(10) (in the file) instead of "\n" or Chr(13), or Chr(13)+Chr(10) instead of "\r\n" with identical results, CR, NL and CR/NL pairs are internally replaced by a single Chr(10). To Print contents of multiline text file on frame, Scrolling upwards as for end credits: AVISource("D:\AVS\TEST.AVI").ConvertToRGB32() S=RT_ReadTxtFromFile("D:\avs\avi\test.txt") DELAY=100 Scriptclip("""RT_Subtitle("%s",S,align=5,y=height+DELAY-current_frame,expy=true)""") The above example uses the "expy" arg, which tells the filter to NOT interpret y == -1 as screen vertical center align and to NOT interpret y=height as bottom aligned. ExpX does the same for the x arg. If you change above to ExpY=false, as the text scrolls on screen and again when text scrolls off top of frame, there will be a single frame where y==height OR y==-1, will align the text an cause a glitch in the video clip. You could also embed eg color control codes into any above such scrolling text file for your amusement, eg embedding "\a!" into the text file would switch on Hi-Lite-ed text. [needs esc=2 for esc codes in data strings] If you want you can run above script with this text file as "test.txt" and because it has color control codes embedded into it (eg the ripped DDigit source code earlier) so it will show the file, some lines of which will be colored. This text file has NOT been prepared for that particular reason but may demo the embedded color codes. RT_Subtitle() has the advantage of not requiring string memory as the string is created internally and released on plugin destruction, whereas SubTitle() within ScriptClip will keep accumulating string memory which is not released until Avisynth closes. Of course any eg concatenated strings supplied to RT_Subtitle will be accumulated unless eg assigned to string variable external to Scriptclip. The RT_Subtitle filter is intended to be used in providing on-frame metrics in a script, and not for final output, use SubTitle() for that. For any script using standard Subtitle() for metrics, it would not be at all surprising if that script were to double (or more) in speed when replaced by RT_Subtitle, it really is quite light weight in comparison. DDigit handles as described, but RT_Subtitle converts to Chr(10) before it gets there.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 10th March 2020 at 19:00. |
11th March 2020, 19:46 | #5218 | Link |
I get slightly different result from Avs conversion of your (pinterf post #5211) Python script. [assuming that 10->16 234 was correct]
I have added an alternative method of the muldiv whotsit (It dont seem any better than muldiv, at least with the numbers tried, it should though be better occasionally). Hope I did conversion from Python right. Code:
/* Python AVS script results # from-to # of differences approx intmuldiv altmuldiv # 8->10 42 42 0 0 # 8->12 56 56 0 0 # 8->14 42 42 0 0 # 8->16 0 0 0 0 #10->12 170 170 0 0 #10->14 234 234 0 0 #10->16 234 233 1 1 10 -> 16 FLT_APPROX_DIFF x = 818 ALT = 52402 approx = 52403 exact = 52402.000000 intround = 52402 intnoround = 52402 FLT_APPROX_DIFF x = 819 ALT = 52466 approx = 52467 exact = 52466.000000 intround = 52466 intnoround = 52466 *ALT_APPROX_DIFF x = 820 ALT = 52530 approx = 52531 exact = 52531.000000 intround = 52530 intnoround = 52530 *** !FLT_INT_DIFF x = 820 ALT = 52530 approx = 52531 exact = 52531.000000 intround = 52530 intnoround = 52530 !!! Altmuldiv and muldiv both wrong above, but approx gets it right FLT_APPROX_DIFF x = 832 ALT = 53299 approx = 53300 exact = 53299.000000 intround = 53299 intnoround = 53299 FLT_APPROX_DIFF x = 833 ALT = 53363 approx = 53364 exact = 53363.000000 intround = 53363 intnoround = 53363 Difference count (approx): 233, maxdiff: 1 Difference count (intmuldiv): 1 Difference count (altmuldiv): 1 maxdiff 1 */ sourcebits=10 targetbits=16 sourcemax = BitLShift(1 , sourcebits) - 1 half_for_rounding = sourcemax / 2 cls = targetbits - sourcebits crs = sourcebits - cls targetmax = BitLShift(1,targetbits) - 1 errcount_alt = 0 errcount_approx = 0 errcount_intmuldiv = 0 maxdiff = 0 maxdiffalt = 0 for(x=0, sourcemax) { # reference: float float32 = int(float(x) * targetmax / sourcemax + 0.5) approx = BitOr( BitLShift(x,cls) , BitRShiftL(x,crs)) intmuldiv = (x * targetmax + half_for_rounding) / sourcemax intmuldiv_no_round = (x * targetmax) / sourcemax altmuldiv = (x * targetmax * 2 + sourcemax) / (sourcemax*2) # new # EDIT: This ALWAYS produces exact same result as intmuldiv, ie no use at all. if(altmuldiv != float32) { RT_DebugF("*ALT_APPROX_DIFF x = %d ALT = %d approx = %d exact = %f intround = %d intnoround = %d ***",x,altmuldiv, approx, float32, intmuldiv, intmuldiv_no_round) errcount_alt = errcount_alt + 1 diff = abs(altmuldiv - float32) if (diff > maxdiffalt) { maxdiffalt = diff } } if(approx != float32) { RT_DebugF(" FLT_APPROX_DIFF x = %d ALT = %d approx = %d exact = %f intround = %d intnoround = %d ",x,altmuldiv, approx, float32, intmuldiv, intmuldiv_no_round) errcount_approx = errcount_approx + 1 diff = abs(approx - float32) if (diff > maxdiff) { maxdiff = diff } } if(float32 != intmuldiv) { # or approx != intmuldiv_no_round''': RT_DebugF("!FLT_INT_DIFF x = %d ALT = %d approx = %d exact = %f intround = %d intnoround = %d !!!",x, altmuldiv, approx, float32, intmuldiv, intmuldiv_no_round) errcount_intmuldiv = errcount_intmuldiv + 1 } } RT_DebugF("Difference count (approx): %d, maxdiff: %d",errcount_approx, maxdiff) RT_DebugF("Difference count (intmuldiv): %d",errcount_intmuldiv) RT_DebugF("Difference count (altmuldiv): %d maxdiff %d",errcount_alt,maxdiffalt) Return MessageClip("Done")
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th March 2020 at 17:32. |
11th March 2020, 22:32 | #5220 | Link |
Aint that exactly the same where two integers involved ???
EDIT: All these are int Code:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th March 2020 at 22:42. |
