22nd February 2019, 03:44 | #54941 | Link |
X Cinema Projectionist NZ
I use black bar detection and think its a great thing as it lowers the rending times, however Ive had it trip up a number of titles and can go crazy at times...
e.g. On "oz the great and powerful" its a scope film but the start 15mins or so is B&W and meant to be 4.3, then when it changes colour the sides open to scope 2.35 If I dont have black bar detection ON, it works perfectly 4:3 > 2.35 in the right place. if I have black bar detection turned on which i like to ue, on this title the start zooms up to 16:9 when it should be 4.3, then as it widens to scope after 15 mins the image jumps in and out, the zooming gets muddled and its a mess until the sides reach the scope borders..... Black bar detection works great on most titles but not on anything that the ratios change. I have tried and tested every tick box but I just cant get it working acuratley on this title and some others that are similar. I have some other files that the ratios change 4.3, 1.66, 16.9, 1.85 and scope, on these that change often black bar detection gets muddled, again Ive tried making changes, read change every 45secs, 20secs etc etc, it still doesnt correct the zooming in and out. Maybe there is a way that i dont know of to make black bar detection work for all unusual titles without jumping round.... For a film thats static its fantastic, maybe these other titles with mixed ratios it just cant cope... |
22nd February 2019, 15:11 | #54942 | Link | |
22nd February 2019, 18:14 | #54943 | Link | |
NM I found it.. It doesn't seem to be lowering rendering times.. How much should it lower rendering times ? OKOKOK, on 2.39:1 film, I looked more closely.. ~ 0.4-0.6 ms, Is that the correct behavior everyone else is getting. This is on 1060 @ 2088mhz, 9ghz memory
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 22nd February 2019 at 18:54. |
22nd February 2019, 19:46 | #54944 | Link |
I am sorry, if this question may be out of place and/or too "n00b" to be allowed - just tell me if that is the case and I'll remove it. :-)
I have Asperger and get anxiety if things are not done in the same way each time and I am not at home, so I can't check this and therefore I am turning to this forum. My HTPC is a Windows 7 Home Premium DELL desktop computer and the only programs I use on it are CCleaner, ReClock, MPC-HC with LAV Filters and madVR. (Yes, I know about CCleaner, but only use the right click option on the Recycle Bin to empty it and never enter the program itself.) When I want to watch something, I move it from either of the USB-hard drives connected to my router or from my NAS and place it on the Windows desktop of the HTPC. I then run CCleaner once, click the .mkv-file once and press Enter on the keyboard; ReClock, MPC-HC and madVR starts accordingly. When the program has come to it's end, ReClock, MPC-HC and madVR exits back to the Windows desktop, after which I drag the .mkv-file to the Recycle Bin, run CCleaner once from the right-click menu and then either shut the computer down, turn off the TV (to watch something later) or move a new .mkv-file to the desktop from either drive. With this in mind, I have two questions for you, the people, more knowledgeable than I: 1. The last program I watched before I left home, I think I might have forgotten the .mkv-file on the desktop, ran CCleaner from the right-click menu of the, empty, Recycle Bin and then shut down the computer. If that is the case and the computer is - next time - not turned on in the same state that it always is: With and empty Windows desktop and I the proceed to remove the file, can this in any way affect the performance and - most importantly - the picture quality of - primarily - madVR (and/or ReClock and MPC-HC)? 2. Additional question - please put it to me as bluntly as you can: I am "overdoing it", aren't I? |
22nd February 2019, 20:04 | #54945 | Link | |
It will definitely not affect picture quality. The ccleaner also has no impact in your current use-process. Theoretically if you wanted everything to remain identically in place, you would have to re-image the entire drive every time you used the computer. EVEN THEN, because of wear leveling on the ssd nand, the data will never be copied to the exact same place after imaging. There are analog elements to the entire computing process which one can not bring ORDER to. The very nature of Perception is a simplification/ modeling process, an approximation of what is.
Ghetto | 2500k 5Ghz |
22nd February 2019, 20:17 | #54946 | Link | |
22nd February 2019, 20:51 | #54947 | Link | |
1. I had the HTPC before I had any kind of external storage, so that would move me away from how I've always done it (the Asperger comes into play there) 2. In my head, that would be slower, no? Wouldn't the render and present times increase, running it not directly from the same hard drive where madVR is installed? |
23rd February 2019, 00:28 | #54949 | Link |
It does on very low spec machines. I've got a netbook that chokes if playing files over wifi, as the transfer and cpu overhead of the wireless eats into the rendertime. And some wireless cards also greatly increase dpc latency which can cause render time spikes as well.
23rd February 2019, 01:31 | #54950 | Link | |
this has nothing todo with madVr if the file doesn't get there in time.
this feature will never be fool proofed. |
23rd February 2019, 16:27 | #54952 | Link | |
What quantity of rendering time improvements are you guys seeing. I'm only seeing 0.4-0.6ms , that doesn't seem worth it. The Most demanding settings in madvr have differences of 10-30ms on cheaper cards, so that 0.4-0.6 saving may not help to cut the cheese anywhere. woah.. nm figured it out, didn't crop. 5-10ms on 1080p upscales... How does cropped profiles work Can i use (AR > 1.77) ?? so pretty much anything > 16:9 use a different profile ? if (variableAR) "VAR" else if (AR > 16:9) "AR" Does AR have to be input as a ratio ? Is there a way to crop horizontal bars only, but not crop vertical bars. ?
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 23rd February 2019 at 18:21. |
24th February 2019, 01:00 | #54954 | Link |
Why would you want to do that?
madVR options explained |
24th February 2019, 13:20 | #54955 | Link |
Because he seems quite mad.....he wrote most of that last post to himself over an hr.
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Pioneer VSX-534 | Philips 65PUS6703 - 65" |
24th February 2019, 13:52 | #54956 | Link |
I ain't gonna change anything but I am just curious.
Smooth motion blurs slightly the whole image,right? For example does NGU still looks like NGU with smooth motion enabled or it looks like a lower quality upscaler? |
24th February 2019, 15:16 | #54957 | Link | |
I got a few movies that have 2-3 pixel worth of vertical black bar, I'd rather have that Uncropped, because otherwise it goes from NGU to NGU + Lanczos. Why waste so much processing power over 2 lines. And not just the processing overhead, but how much is Lanczos messing with the already really good image from NGU.. If the detection could reject small quantities that would be good. But I would say rejecting vertical in general would cover nearly all cases, because if it's a wide screen movie, the vertical black bar I've seen are at most 10-20 pixels wide. For example the ghost in the shell anniversary bluray. Adding Lanczos on top of NGU could push it into the 40+ ms territory, without it , just NGU , it's in the 35ms territory, that's a huge difference. if we could crop horizontal and NOT vertical.
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 24th February 2019 at 15:18. |
24th February 2019, 15:22 | #54959 | Link | |
It smooths out judder for people who are very bothered by judder. I personally don't mind judder, because heck 24fps itself is almost a slideshow, why bother with judder removal.
