17th February 2019, 22:22 | #4501 | Link | |
IsRGB() - Returns true for all RGB color spaces IsRGB24(), IsRGB32, IsRGB48, IsRGB64 - Self-explanatory
Groucho's Avisynth Stuff |
17th February 2019, 23:35 | #4503 | Link | |
Formerly davidh*****
Edit: oh, I think you meant if we already knew it was RGB. True, but IsRGB24() and IsRGB32() work as expected anyway, it's the wiki that's wrong. |
18th February 2019, 00:58 | #4504 | Link | ||
Same thing for the IsYUV thing.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th February 2019 at 01:01. |
18th February 2019, 11:01 | #4505 | Link |
since there are no way to get avs+ version I made AvsPlusVersionNumber() function to use it in avs scripting, the 1st one (IsAvsPlus) from the wiki but with some edit since there are no need for lower case and other things for all avs+ versions I seen
function IsAvsPlus() { FindStr(VersionString, "AviSynth+") != 0 } function AvsPlusVersionNumber() { IsAvsPlus ? eval(MidStr(VersionString(),17,4)) : 0 } Subtitle(String(AvsPlusVersionNumber)) tested with r1576 and above and all fine but let hope nothing will change to make it break in future
See My Avisynth Stuff |
18th February 2019, 11:24 | #4507 | Link | |
18th February 2019, 11:24 | #4508 | Link | |
same script and folder work ok with x264 alone
See My Avisynth Stuff Last edited by real.finder; 18th February 2019 at 11:29. |
18th February 2019, 11:28 | #4509 | Link |
that can used too, but as I said those work already since the begin of avs+, and they look nicer than any other methods
See My Avisynth Stuff Last edited by real.finder; 18th February 2019 at 11:36. |
18th February 2019, 11:38 | #4510 | Link |
Out of curiosity - Under what circumstances would you need the revision number?
18th February 2019, 11:49 | #4511 | Link |
A check with AddAutoloadDir whould detect Avisynth Neo also as Avisynth+ (it basically is avs+ with cuda stuff) while AvsPlusVersionNumber returns 0. VersionString() returns on avs neo: "Avisynth Neo 0.1 (r2882, Neo, i386)"
It this case a check with AddAutoloadDir would be prefered. https://github.com/nekopanda/AviSynthPlus/releases
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 18th February 2019 at 11:54. |
18th February 2019, 12:00 | #4512 | Link |
same circumstances that old VersionNumber be used, like keep support for some older versions
18th February 2019, 12:04 | #4513 | Link |
Arrrgh. Yet another version. Let's confuse the crap out of the average user.
18th February 2019, 12:05 | #4514 | Link |
What support? Can you be more specific? Maybe a couple of examples?
18th February 2019, 12:10 | #4515 | Link | |
18th February 2019, 12:15 | #4516 | Link |
support older avs+ in some scripts, like the old 1576 and so, since there are new functions added every time in avs+
18th February 2019, 12:19 | #4517 | Link | |
@pinterf See above. Edit: Or maybe a few simple utility functions which return true/false such as IsHighBitDepth() (HasHighBitDepth() ?), IsMultiThreaded(), etc. Just thinking out loud...
Groucho's Avisynth Stuff Last edited by Groucho2004; 18th February 2019 at 12:34. |
18th February 2019, 12:24 | #4518 | Link |
maybe but I like use it like vanilla AviSynth VersionNumber(), with < or >, simple and nice
18th February 2019, 12:24 | #4519 | Link |
From RT_Stats function list thing,
AviSynth+_0.1_(r2772,_MT,_i386)_ORDERED_Function_List FunctionExists "s"
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th February 2019 at 12:26. |
18th February 2019, 12:28 | #4520 | Link |
