Old 21st January 2019, 17:21   #21  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Here's the one I used:
import vapoursynth as vs
core = vs.get_core()
orig = core.dgdecodenv.DGSource(r'O:\Testclips\test2.dgi', fulldepth=True)
orig = core.f3kdb.Deband(orig, preset="medium", output_depth=10)
clp = core.ffms2.Source(source=r'c:\x265\aq\aqmode3.hevc')
orig = core.resize.Bicubic(orig, width=3840, height=2160, filter_param_a=0, filter_param_b=0.5)
clp = core.resize.Bicubic(clp, width=3840, height=2160, filter_param_a=0, filter_param_b=0.5)
result = core.vmaf.VMAF(orig, clp, model=1, log_path="c:\x265\aq\clp1.log", log_fmt=0, pool=1, ci=True)
result.set_output()
I also noticed that there's no logfile written if I run that one through "vspipe script.vpy ."
Boulder is offline
Old 21st January 2019, 21:11   #22  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The process also hangs without returning to the command prompt. The values are output but I need to use CTRL+C to get the prompt back.
C:\>vspipe c:\x265\aq\compare.vpy .
Start calculating VMAF score...
Exec FPS: 0.501642
VMAF score (harmonic_mean) = 98.925030
The Exec FPS must be a wrong value, the clips are 1385 frames long and it only took a couple of seconds to produce that output. If I ran with the -p option, I got those out of memory errors quite soon.
Boulder is offline
Old 21st January 2019, 21:34   #23  |  Link
lansing
Exec FPS: 0.501642
Have you try running it with vs editor's benchmark? My 1000 frames 1080p anime took about a minute and 20 seconds, yours should be doubling or tripling my time comparing 4k clips.
lansing is offline
Old 21st January 2019, 21:40   #24  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Just tried - it crashed by vanishing without a warning almost right after it started. I raised the cache size to 2048 MB and it hung at frame 30 which it probably what happens with vspipe as well.
Boulder is offline
Old 21st January 2019, 23:03   #25  |  Link
lansing
I tried your script, mine stop moving about frame 14 too. I try lowering the resize resolution to 3000x2000, it was able to run with RAM usage jumping between 3.8G to 4.8G. So it should be an insufficient memory problem?
lansing is offline
Old 22nd January 2019, 02:23   #26  |  Link
ChaosKing
No problems here. Max ram usage was 10gb.
Maybe it is also a path problem? I used log_path=r"D:\test\clp1.log"
The x265 folder exists on c? Bcs if not vapoursynth can't create one without admin rights.
ChaosKing is offline
Old 22nd January 2019, 02:52   #27  |  Link
gonca
Did I understand correctly that model 0 should be used if the tested material is 1080p or less? At first I thought that it meant the viewing device but after reading the FAQ, it looks like it's the content itself.
Could someone expand on this.
Is it the device or video?
Does the video have to be resized?
gonca is offline
Old 22nd January 2019, 03:09   #28  |  Link
HolyWu
I also can't reproduce the issues you two encountered with a 2000 frames 1080p upscaled to 4K, no matter using vspipe or vsedit. And not prefixing the string containing a single backslash with r is always a bad idea.
HolyWu is offline
Old 22nd January 2019, 03:44   #29  |  Link
HolyWu
It's the viewing device. See https://github.com/Netflix/vmaf/blob...ible-artifacts.
HolyWu is offline
Old 22nd January 2019, 03:59   #30  |  Link
lansing
I did another test, my PC has 16G RAM and I start the benchmark with all my apps closed dropping total ram usage to 3.5G. And now the benchmark ran without chocking with RAM usage for the process peaks at 6G rarely.
And then I did another benchmark with starting ram usage at 8.4G, this time the process stopped after the first few frames with its ram usage start from 200MB -> 3GB -> 500MB.
So this seems like a not-enough-memory issue, but with 16G, I should still have 1G excessive memory to run the second benchmark.
lansing is offline
Old 22nd January 2019, 04:50   #31  |  Link
Boulder
Pig on the wing
Boulder's Avatar
And this seems to confirm that upscaling to that resolution is the way to go, although getting a VMAF score from an originally 1080p source on a 4K display is not optimal.
If, say, for a distorted video of 480 resolution, we still want to predict its quality viewing from 3 times the height (not 6.75), how can this be achieved?
    If the 480 distorted video comes with a source (reference) video of 1080 resolution, then the right way to do it is to upsample the 480 video to 1080, and calculate the VMAF at 1080, together with its 1080 source.
    If the 480 distorted video has only a 480 reference, then you can still upsample both distorted/reference to 1080, and calculate VMAF. A caveat is, since the VMAF model was not trained with upsampled references,
the prediction would not be as accurate as 1).
Boulder is offline
Old 22nd January 2019, 04:56   #32  |  Link
Boulder
Pig on the wing
Boulder's Avatar
When I first tested things, I didn't have any other big processes running and I had no cache size restrictions in the script. The memory usage jumped to around 8GB and still got the out of memory error. Task Manager showed that the total memory usage was around 65-70% when it happened, so there was still more memory available but maybe Vapoursynth restricted it.
It looks like I cannot run an encode simultaneously because it seems end abruptly quite often when the other VS process grabs hold of most of the memory on the computer. I'm getting 8GB more this week which is good for testing this issue.
Boulder is offline
Old 22nd January 2019, 23:38   #33  |  Link
gonca
Doing a test run
4K display, 4K sample
Using VDub2 64 bit for playback of script
So far it is slow and CPU is at near 100%
RAM for VDub2 is +/- 12 GB, but overall I see spikes to near 16GB overall, VDub2 has spiked to about 14GB on some occasions.
When this run is over I will try VSEditor
gonca is offline
Old 23rd January 2019, 00:17   #34  |  Link
gonca
VDub2 seems to run fine
Tried VSEditor and got the out of memory error early
Added one line and it seems to go through fine
Numbers (RAM) are about the same as VDub2
Original script
core.std.LoadPlugin("C:/Program Files (Portable)/dgdecnv/x64 Binaries/DGDecodeNV.dll")
core.std.LoadPlugin(r'C:\Users\LUIS\Desktop\VMAF-r2\plugins64\VMAF.dll')
orig = core.dgdecodenv.DGSource(r'I:\original.dgi', fieldop=0, fulldepth=True)
orig = core.resize.Point(orig, format=vs.YUV420P10)
dist = core.dgdecodenv.DGSource(r'I:\distorted.dgi', fieldop=0, fulldepth=True)
dist = core.resize.Point(dist, format=vs.YUV420P10)
result = core.vmaf.VMAF(orig, dist, model=1, log_path=r'I:\log.log', log_fmt=1, pool=1, ci=True)
result.set_output ()
Modified script
core.max_cache_size = 16384
Seems minimum amount of RAM for 4K is 16GB + all background processes
gonca is offline
Old 25th January 2019, 04:53   #35  |  Link
lansing
I'm wondering, right now with my machine I'm doing 12 fps on 1440x1080 clips with 3G ram usage. If I'm to upgrade to a faster machine that do 3 times this speed, will my ram usage also go up by 3 times?
lansing is offline
Old 25th January 2019, 06:47   #36  |  Link
HolyWu
I guess the ram usage should only be relevant to the video resolution, bit depth, and number of threads.
HolyWu is offline
Old 25th January 2019, 21:37   #37  |  Link
lansing
I did another test on this, I disabled the core in task manager and ran benchmark on 1 to 8 threads, speed rises as more threads were used, but the ram usage are the same on the all of them.
A side note, setting the thread number in the script doesn't work
core = vs.get_core(threads=1)
lansing is offline
Old 26th January 2019, 03:08   #38  |  Link
HolyWu
Ah, libvmaf uses pthreads for its internal multithreading, and I didn't set it according to core's number of threads but leave it at its default which uses all threads available. I'll fix it at the next release.
HolyWu is offline
Old 1st February 2019, 06:01   #39  |  Link
HolyWu
Update r3.
  • Update libvmaf to v1.3.13, which includes performance improvement.
  • Change default pool to 1.
  • Set libvmaf's threads according to core's number of worker threads.
HolyWu is offline
Old 1st February 2019, 19:28   #40  |  Link
lansing
I couldn't update it through vsrepo?
lansing is offline
