Old 17th September 2018, 06:44   #3161  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
Originally Posted by hydra3333 View Post
will there also be a portable VSRepo equivalent without an installer ?
commit 46da486 had added vsrepo to the portable package
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 17th September 2018, 09:39   #3162  |  Link
ChaosKing
@hydra VSRepo is not tightly bundled with VS (it can run independently). Btw You can also just download the git version.
Portable mode with custom folders could look like this:
.\vsrepo.py -p upgrade-all -b vapoursynth64\plugins -s ..\Scripts
Old 17th September 2018, 10:54   #3163  |  Link
hydra3333
Ah, that is great news. Cheers !
hydra3333 is offline   Reply With Quote
Old 22nd September 2018, 20:09   #3164  |  Link
rekweom
Could somebody help me configure Lut2 so that it works the same way as Avisynth's Overlay function in SoftLight mode? Or maybe there is a better way to do it with some other function? I have a hard time figuring this out.
rekweom is offline   Reply With Quote
Old 23rd September 2018, 09:21   #3165  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Here's an interesting concept for an optimizer tool for Avisynth, and I asked about future VS compatibility. The tool has some prerequisites, could someone take a look and guide the author? Thank you
https://forum.doom9.org/showthread.p...83#post1852583
Old 27th September 2018, 20:23   #3166  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
R45-RC1
Go test it. I plan to do more VSRepo integration in R46.
Changes:
r45:
updated to zimg v2.8
updated visual studio runtimes in installer
avfs now uses utf8 filename support when available in avs+
avfs now prints the used mount point
windows binaries now use python 3.7
removed accept_lowecase setting from the python bindings
fixed frame duration calculation in clipinfo (dubhater)
fixed bug that prevented adding vertical margins in subtext (dubhater)
documentation updates
Old 28th September 2018, 07:27   #3167  |  Link
amayra
Quality Checker
amayra's Avatar
thank you Myrsloik finally i can say goodbye to filename problem and update my python setup
I love Doom9
Old 30th September 2018, 20:31   #3168  |  Link
ca18
Can you please post VS Portable R45 64bit for Python 3.7 64bit Windows?
ca18 is offline   Reply With Quote
Old 30th September 2018, 21:37   #3169  |  Link
There is no Release 45 yet. Only a first candidate (RC1 = "Release Candidate 1"). Patience, young padawan.
Old 30th September 2018, 22:29   #3170  |  Link
ca18
Extracted with uniextract2 now ...
Old 30th September 2018, 22:30   #3171  |  Link
Myrsloik
Myrsloik's Avatar
Final release will be in a day or two. Just have to actually test the avfs changes properly so I didn't break everything.
Old 30th September 2018, 22:52   #3172  |  Link
ca18
NP m8, thank you, great job as always! Need to get rid of this python 3.6 + 3.7 mess ASAP, everyone's been waiting for VS with 3.7 so time to finally bury 3.6
Old 17th October 2018, 18:13   #3173  |  Link
Revan654
Revan654's Avatar
Any update on the Final Release? I assume something broke since there no R45 release yet.
Revan654 is offline   Reply With Quote
Old 17th October 2018, 23:11   #3174  |  Link
DJATOM
DJATOM's Avatar
I have RC1 installed, no issues on my side.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 17th October 2018, 23:51   #3175  |  Link
Myrsloik
Myrsloik's Avatar
Life happened. I'll stop dragging and simply release it tomorrow. It's always tomorrow...
Old 18th October 2018, 09:26   #3176  |  Link
hydra3333
great to hear you have a life
Old 19th October 2018, 02:06   #3177  |  Link
Revan654
Revan654's Avatar
Just wondering, Something broke my search path. Nothing in vs is working currently without crashing. I want to uninstall everything and re-install everything and try to get it working again.
Python Path: C:\ProgramData
VS Path: C:\Program Files (x86)
Encoder: Desktop
Old 20th October 2018, 23:58   #3178  |  Link
Myrsloik
Myrsloik's Avatar
R45 finally released. Maintenance and ironically avs+ improvements to avfs so unicode filenames are used.
VSRepo is bundled too but not particularly well integrated.
Changes:
r45:
Old 21st October 2018, 00:57   #3179  |  Link
hydra3333
Originally Posted by myrsloik View Post
changes:
Thank you.
Was that 3.7.0 or 3.7.1 ?
Old 21st October 2018, 02:48   #3180  |  Link
amichaelt
Thank you.
Wasn't 3.7.1 only just released a few hours ago?
speed, vaporware, vapoursynth
