Old 1st January 2013, 14:17   #641  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by Myrsloik View Post
And why do you hate empty strings in python? I'll apply the qfatal stuff with spaces tomorrow but the rest is rejected. The precedence of logic operators is also well defined so I don't intend to change it just to please a very high compiler warning level.
I think both gcc and clang warn about those empty strings, but they do the job anyway.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 1st January 2013, 22:39   #642  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Debugging help needed
I'm finally going completely crazy. I have narrowed down the python memory leak quite a bit but I just can't explain the last part. If anyone happens to be good at debugging python (perhaps you've even used cython too) memory leaks and want to help please contact me. I have a fairly simple case that can reproduce the issue but I simply don't know what triggers it in the first place.
Unless this bug is found it will never be possible to simply press F2 again and again in vdub to refresh a script.
Old 2nd January 2013, 18:56   #643  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
quick update for Waf version.
Index: bootstrap.py
--- bootstrap.py	(revision 405)
+++ bootstrap.py	(working copy)
@@ -2,7 +2,7 @@
 import os, stat, urllib2
-f = urllib2.urlopen('http://waf.googlecode.com/files/waf-1.7.6')
+f = urllib2.urlopen('http://waf.googlecode.com/files/waf-1.7.8')
 with open('waf', 'wb') as waf:
     waf.write(f.read())
BTW, Myrsloik, do you have a preferred method in which we send patches to you?
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 2nd January 2013, 19:17   #644  |  Link
Myrsloik
Myrsloik's Avatar
Index: bootstrap.py
@@ -2,7 +2,7 @@
     waf.write(f.read())
I'm not that picky but if you open an issue for it on the bug tracker and add it as an attachment I definitely won't miss it. I'm happy as long as it's in some kind of diff/patch format, really.
Anyway, applied.
Old 4th January 2013, 07:57   #645  |  Link
Adub
Adub's Avatar
Cleanup for some of the invert_example.c comments: https://gist.github.com/4450489
Site:Adubvideo
Old 4th January 2013, 17:50   #646  |  Link
Myrsloik
Myrsloik's Avatar
Applied. I've also finally managed to solve most of the evils of python so the next version will leak a lot less memory.
Old 4th January 2013, 22:49   #647  |  Link
Adub
Adub's Avatar
Excellent, good to hear. I've begun work on my CUDA environment. I'm getting used to the Waf build system and incorporating the CUDA compiler into the mix. It's almost up an ready for dev, but I've got a few CFLAGS issues to fix first.
Site:Adubvideo
Old 5th January 2013, 11:28   #648  |  Link
Myrsloik
Myrsloik's Avatar
Will the missing operator ^(power) in Expr be available in the next version as well?
I have no optimized code for it so just use exp and log to get the same result.
Old 5th January 2013, 21:38   #649  |  Link
Reel.Deel
I have no optimized code for it so use exp and log to get the same result.
For a RPN/LUT dummy like myself, how would I write this mt_lut expression using Expr?
mt_lut("x 128 - 1.49 * x 128 - 2 ^ x 128 - 2 ^ 9 + / * 128 +")
I also think it would be a good idea for existing mt_lut/x/y/z expressions to be compatible with Expr with no additional gimmicks.
Reel.Deel is offline   Reply With Quote
Old 5th January 2013, 23:09   #650  |  Link
Myrsloik
Myrsloik's Avatar
Well... theoretically I could add the ^ operator but it would do you no good since it's very slow just for squaring things. In this case x*x is much faster. So I give you this equivalent that doesn't even need ^ and removes some duplicate evaluation:
"x 128 - 1.49 * x 128 - dup * dup 9 + / * 128 +"
(warning, completely untested but should work and if it doesn't just tell me and I'll actually try it myself)
When you go from a lut to actually evaluating the expression for every pixel you have to be more careful about how you write it too or it could become slow.
Bonus material by jfs, the original expression in readable form:
(x-128)*1.49 * (((x-128)^2) / ((x-128)^2 + 9)) + 128
Old 6th January 2013, 02:44   #651  |  Link
Reel.Deel
Expr expression works as expected, the only only thing is that mt_lut by default only processes the luma. So I read the Expr documentation and added the following and now the results look identical.
avs = core.avs.mt_lut(c1=src, expr="x 128 - 1.49 * x 128 - 2 ^ x 128 - 2 ^ 9 + / * 128 +", Y=3, U=1, V=1)
vs =  core.std.Expr(clips=[src], expr=["x 128 - 1.49 * x 128 - dup * dup 9 + / * 128 +", "", ""])
Thanks for the bonus material. Much easier to understand.
Old 7th January 2013, 00:37   #652  |  Link
wOxxOm
Oz of the zOo
What about "something 1.05 ^"?
What about "something something ^"?
Also the calculation is done only once while building lut table, so the overhead may safely be neglected.
Absolutely.
There are lots of useful scripts with very complex expressions.
wOxxOm is offline   Reply With Quote
Old 7th January 2013, 00:56   #653  |  Link
pie
pie's Avatar
I'm not too sure with RPN, but something like this?
something log 1.05 * exp
For a^b
a log b * exp
--> e^(ln(a)*b)
pie is offline   Reply With Quote
Old 7th January 2013, 00:58   #654  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by wOxxOm View Post
what about "something 1.05 ^"?
Absolutely.
There are lots of useful scripts using very complex expressions.
Then you have to remember from school that a^x = e^(x*ln(a))
so you rewrite it to:
a log x * exp (or something log 1.05 * exp)
And I have to reiterate that just copying and pasting expressions is kind of a bad idea for performance reasons. Just take the one I changed around above as an example.
Old 7th January 2013, 10:57   #655  |  Link
wOxxOm
Oz of the zOo
What performance?
This is not something one learns at school, I guess, but still it's obvious.
Old 7th January 2013, 12:17   #656  |  Link
Chikuzen
typo lover
Chikuzen's Avatar
lutxyz requires at least about 16MiB(256*256*256*1byte).
Since a huge table is not settled in CPU cache, it may need very very slow memory access each time.
Therefore, runtime calcuration is often faster than LUT.
my repositories
Chikuzen is offline   Reply With Quote
Old 7th January 2013, 13:44   #657  |  Link
wOxxOm
Oz of the zOo
Chikuzen, is this somehow related to my remarks about the majority of lut scripts, taking in account that lutxyz should be avoided at all costs and thankfully not commonly used anyway? Also, don't forget that memory access penalty during building of that 16MB table is *nothing* compared with memory penalty during processing of lots of actual video frames.
Old 7th January 2013, 14:13   #658  |  Link
StainlessS
StainlessS's Avatar
It is lut access during processing of video frames that will have a heavy cache miss penalty.
I sometimes post sober.
Old 7th January 2013, 14:27   #659  |  Link
wOxxOm
Oz of the zOo
StainlessS, I wrote about the same earlier, and to reiterate my point I'll rephrase: having a cpu-heavy instructions in expressions (like "^" - power) takes only an insignificant amount of overall processing time (it's calculated only one time, not each frame) so there's no need to exclude those in favour of non-practical 'performance gains' while degrading substantially ease of porting for existing lut-scripts.
Old 7th January 2013, 14:31   #660  |  Link
TheFluff
Excessively jovial fellow
expr() in Vapoursynth doesn't use a LUT, it re-evaluates the expression for each pixel, hence Myrsloik's comments about how you should be careful with your RPN expressions. It's done that way because building LUT's for high bitdepth video is a really stupid idea.
People who like faith-based optimizations may note that expr() isn't really any significantly slower than mt_lutxy[z] in many cases; for simple expressions it can even be faster than mt_lutxy.
TheFluff is offline   Reply With Quote
speed, vaporware, vapoursynth
