Old 2nd July 2017, 16:36   #2241  |  Link
XP1
XP1
XP1's Avatar
How do I cut the audio? When I cut the video using preview, the video gets cut, but the audio doesn't get cut. It remains the same.
_
XP1 is offline   Reply With Quote
Old 2nd July 2017, 17:51   #2242  |  Link
stax76
stax76's Avatar
I still get wrong frame rate display for 29.76fps and 23.976fps (displays 23.976023fps) files using latest StaxRip build under windows 7.
It's fine, the value is returned from avs/vs, if there is something wrong then it's the source filter or another filter in your script.
signature, log file
Old 2nd July 2017, 18:23   #2243  |  Link
fredlkrue
The issue is the display, but the end encoded file is fine, its not a big deal, thanks.
fredlkrue is offline   Reply With Quote
Old 2nd July 2017, 18:26   #2244  |  Link
stax76
stax76's Avatar
The display is fine too, avs/vs/vfw use num/denum 24000/1001, staxrip uses system.double and truncates after 6 decimal digits and mediainfo truncates after 3 decimal digits.
Old 2nd July 2017, 20:53   #2245  |  Link
Zetti
x264 r2851 is released.
Old 2nd July 2017, 22:53   #2246  |  Link
stax76
stax76's Avatar
Thanks, next built has it included.
Old 2nd July 2017, 23:50   #2247  |  Link
XP1
XP1
XP1's Avatar
signature, log file
I think I figured it out. It was because I was using split and manually editing the cutting filter instead of setting cut start and end in the preview.
_
Old 5th July 2017, 14:47   #2248  |  Link
mcjordan
NVEncC 3.14
CPU usage reduction etc. It may be suppressed considerably less when decoding HW.
[NVEnc.auo / NVEncC common]
- Reduce CPU utilization. Especially, CPU usage rate when using HW decoder is greatly reduced.
- Added option to specify CUDA scheduling mode. (-cuda-schedule <string>)
Mainly determines the behavior of the CPU when waiting for GPU task completion. The default is sync.
- auto - Leave the mode decision to the driver of CUDA.
- spin - Always run the CPU and monitor the end of the GPU task. The latency of restoration is the smallest, it is the fastest, but always uses the CPU usage for one core.
- yield - Basically it is the same as spin, but it gives over to other threads if there is one.
- sync - leep thread until GPU task is finished. Instead of slightly degrading performance, especially when using HW decoding, greatly reduce CPU usage.
- Adjust the way to synchronize CPU / GPU.
- Display the CUDA version at runtime in the log.
[NVEncC]
- Fixed the place where help display was wrong.
- Progress display garbage should not remain at the end of encoding.
- Use NVML to get information such as GPU usage rate. Only x64 version.
mcjordan is offline   Reply With Quote
Old 5th July 2017, 17:13   #2249  |  Link
ENiGMA59
Problem muxing mp4
Muxing using MP4Box 0.7.2-DEV-rev37 x64
"C:\Program Files\Staxrip\Apps\MP4Box\MP4Box.exe" -add "C:\Users\ENiGMA59\Desktop\RS 2\rs.2_temp\rs.2_new_out.h264#video" -add "C:\Users\ENiGMA59\Desktop\RS 2\rs.2_temp\rs.2_out1.ac3#audio:lang=fre:name=French DTS 1509kbps" -add "C:\Users\ENiGMA59\Desktop\RS 2\rs.2_temp\rs.2 ID4 French French.srt:lang=fre:name= " -chap "C:\Users\ENiGMA59\Desktop\RS 2\rs.2_temp\rs.2_chapters.xml" -itags encoder="StaxRip 1.5.0.0" -new "C:\Users\ENiGMA59\Desktop\RS 2\rs.2_new.mp4"
[avc-h264] Possible Variable Frame Rate: VUI "fixed_frame_rate_flag" absent.
AVC-H264 import - frame size 1280 x 528 at 23.976 FPS
AVC Import results: 153963 samples (157820 NALUs) - Slices: 2152 I 47621 P 104190 B - 1 SEI - 1928 IDR
Stream uses forward prediction - stream CTS offset: 2 frames
AC3 import - sample rate 48000 - 5.1 channels
Timed Text (SRT) import - text track 1280 x 528, font Serif (size 18)
Error Muxing using MP4Box 0.7.2-DEV-rev37 x64
Muxing using MP4Box 0.7.2-DEV-rev37 x64 failed with exit code: -1073741819 (0xC0000005)
The exit code might be a system error code: L'instruction à 0xp emploie l'adresse mémoire 0xp. L'état de la mémoire ne peut pas être s.
Start: 17:55:13
End: 17:55:13
Duration: 00:00:00
Help me please , thanx in adcance
ENiGMA59 is offline   Reply With Quote
Old 5th July 2017, 19:27   #2250  |  Link
stax76
stax76's Avatar
@mcjordan
Thanks, I'll update it.
@ENiGMA59
The newest staxrip test build has a newer mp4box build, I hope that it was fixed meanwhile.
https://github.com/stax76/staxrip/bl.../test-build.md
Old 5th July 2017, 20:17   #2251  |  Link
XP1
XP1
XP1's Avatar
I'm getting a crash on ArgumentOutOfRangeException.
Log: https://pastebin.com/dhS07HZC
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
   at StaxRip.MainForm.ProcessJob() in D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 2493
   at StaxRip.GlobalClass.ProcessJobs() in D:\Projekte\VS\VB\StaxRip\General\GlobalClass.vb:line 37
_
Old 6th July 2017, 13:44   #2252  |  Link
craigpro
It's simple I believe, first you setup your empty project and then you add the source files in file batch mode, it then creates a job for every source file.
sorry just wanted to say a thank you for this - I've always used folders and batch encoded every file in there - adding files is actually much easier (but not obvious).
craigpro is offline   Reply With Quote
Old 6th July 2017, 17:22   #2253  |  Link
stax76
stax76's Avatar
@XP1
Did that happen once or can you reproduce it? It's a problem with the exception handling of the threads for the new parallel processing. I've made a change but without knowing exactly what went wrong it might not yet be fixed.
@craigpro
You're welcome, glad it works.
Old 6th July 2017, 19:28   #2254  |  Link
XP1
XP1
XP1's Avatar
@XP1
Yes, reproducible.
I think the problem has something to do with an empty sub file. When StaxRip is trying to cut a sub for a duration that has no subs (or maybe the sub is corrupt?), it creates an empty "..._cut_.sub" file (0 bytes).
If I disable the sub, it works fine. When I enable the sub again, it causes the crash. Something to do with processing an empty sub file? Crash occurs before mkvmerge stage.
_
Old 7th July 2017, 16:01   #2255  |  Link
stax76
stax76's Avatar
That's it exactly, good catch! I also found out why the exception handling didn't provide better information.
Old 7th July 2017, 16:16   #2256  |  Link
stax76
stax76's Avatar
Requirements
.NET 4.7 is required on systems prior Windows 10 Version 1703 (Creators Update)
https://www.microsoft.com/en-us/down....aspx?id=55170
Download
https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM
https://onedrive.live.com/redir?resi...nt=folder%2c7z
1.5.1.9 unstable test build
  • new: context help is now implemented for all video encoders, a right-click on any label, menu or checkbox will show the help for the option, for nvenc, qsvenc and vceenc a new help browser was developed with powershell look and feel
  • new: UT Video added for ffmpeg video encoder GUI with options for: -pred (None Left Gradient Median) -pix_fmt (YUV420P YUV422P YUV444P RGB24 RGBA)
  • new: help improved for Tags in mp4box container options dialog, the help is runtime generated using the output from mp4box -tag-list
  • new: ffmpeg muxing formats menu and profiles added for: asf avi flv ismv mkv mov mp4 mpg mxf nut ogg ts webm wmv
  • new: audio target format W64 added with 16/24 bit depth option
  • new: nvenc options --cuda-schedule, --perf-monitor, --perf-monitor-interval
  • fix: cmd.exe is now used directly without batch files, this improves foreign/special character support in particular on Windows 7
  • fix: Jobs Processing window popping up while job processing even when staxrip was previously minimized
  • fix: tray icons not cleaned up
  • fix: in a few dialogs the help dialog was shown four times instead once
  • fix: broken scaling on DPI change using a multi-monitor setup with different DPI values, virtual scaling is used in that case now
  • fix: crash when cutting empty subtitles
  • change: all classes made public for powershell usage
  • update: x264 0.150.2851
  • update: nvenc 3.14
Old 10th July 2017, 09:45   #2257  |  Link
burfadel
I have found the Job processing window disappears when moving on to the next project. I still have it in the memory, it's still processing, but the Staxrip icon isn't showing in the tray or task bar.
Old 10th July 2017, 10:11   #2258  |  Link
lotnybartek
Can someone enlighten me the difference between: LA-VBR vs LA-HRD-VBR in terms of picture quality? Form Intel's docs: "With HRD compliance, the Coded Picture Buffer should neither overflow nor underflow. This rate control is recommended in storage transcoding solutions and streaming scenarios, where low latency is not a major requirement." - so in other word, subjective image quality should be better, because encoder is distributing bits more effectively (no buffer overflow nor underflow)? I'm lost.
lotnybartek is offline   Reply With Quote
Old 10th July 2017, 10:18   #2259  |  Link
stax76
stax76's Avatar
@burfadel
I had this also but often it appeared after a short time, it's a bit difficult to test because with small files it usually cannot be reproduced and testing large files takes much time, maybe the source filters are sluggish sometimes, one thing that is a issue is that l-smash don't report progress while indexing. I'll run some tests before I upload the next build.
Old 10th July 2017, 11:06   #2260  |  Link
stax76
stax76's Avatar
@burfadel
There is a issue with l-smash, it loads slow even if there is already a index file, every time you open the preview it loads slow, it does not happen with ffms2, this causes staxrip to be hidden while l-smash loads, there was some discussion about l-smash a megui thread, I don't know if it relates.
