Old 4th November 2017, 16:47   #2701  |  Link
foxace
Originally Posted by foxace View Post
Hello,
how to convert 4k HDR movies with NVencC and preserve the HDR metadata ?
thanks for help me
Hello
Can someone help me please ?
thank
foxace is offline   Reply With Quote
Old 5th November 2017, 12:33   #2702  |  Link
Yanak
Hello
thank
Hi, i don't have HDR sources nor the display needed for HDR and don't use Nvencc either but last test version of Staxrip added an option to keep HDR metaData :
new: option added to the options dialog on the video tab to import VUI metadata like HDR from the source file to the video encoder, this is applied when the source loads like before and since this build additionally everytime a video encoder profile is loaded
This 1.7.0.4 test version of Staxrip can be found here : https://github.com/stax76/staxrip/bl...r/changelog.md
Can't help more than this sorry :/
Yanak is offline   Reply With Quote
Old 5th November 2017, 14:37   #2703  |  Link
foxace
thanks for you answer, but this do not work on NvenCc.
Old 5th November 2017, 15:34   #2704  |  Link
Yanak
Arg :/
Not using HDR or having Nvidia GPU i could not even test, Stax is probably the only one that could answer this then, he did not login since a couple of weeks i think, hope he's fine tho.
Old 9th November 2017, 03:44   #2705  |  Link
IbrahimKh
how to enable this demux option on newest version?
IbrahimKh is offline   Reply With Quote
Old 9th November 2017, 19:34   #2706  |  Link
Yanak
Hi, Not sure if it's what you want but should be this, in Options :
(tied to each templates so you will need to save the template after setting this option to be set for the next times too I think)
Old 12th November 2017, 12:40   #2707  |  Link
foxace
for the HDR with nvencc
https://github.com/SK-Hardwired/nv_hevc_hdr_patcher
this work very well
Old 15th November 2017, 16:35   #2708  |  Link
ircopdd
this work very well
how to get HDR metadata?
ircopdd is offline   Reply With Quote
Old 15th November 2017, 17:54   #2709  |  Link
foxace
with media info
Old 17th November 2017, 10:31   #2710  |  Link
ircopdd
with media info
MasteringDisplay_ColorPrimaries :
R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
I do not know what to do
G(0.265000,0.690000) ???
Old 17th November 2017, 13:27   #2711  |  Link
sneaker_ger
You have to multiply with specific factors to get from one value to the other. You can find them in the x265 documentation along with an example:
http://x265.readthedocs.io/en/defaul...master-display
0.265 / 0.00002 = 13250
0.69 / 0.00002 = 34500
BTW:
1.7.0.4 unstable test build
Old 18th November 2017, 03:50   #2712  |  Link
ircopdd
BTW:
thanks you
but VUI metadata no work for nvenc
Old 18th November 2017, 10:33   #2713  |  Link
Magik Mark
Hi Stax!
Any update on HDR -> SDR conversion script?
Old 19th November 2017, 15:10   #2714  |  Link
Zetti
eac3to v3.33 is released.
MKVToolNix v18.0.0 is released.
Old 20th November 2017, 08:37   #2715  |  Link
Zetti
eac3to v3.34 is released.
Old 21st November 2017, 19:51   #2716  |  Link
Cyberavater
@stax76 Replace ur f3kdb plugin with this one
https://onedrive.live.com/?authkey=%...&action=locate
the one u added doesn't work check it if ya like.
Also Plz add FineDehalo filter I'm having problem adding it manually.
Cyberavater is offline   Reply With Quote
Old 22nd November 2017, 10:33   #2717  |  Link
craigpro
hi all, been offline for a while due to my chipset 1155 motherboard failing and couldn't afford a replacement for a while.. anyways - is there still the issue with the recent nvidia driver and nvencc encoding? If yes, which previous nvidia driver should I downgrade to please? thank you.
craigpro is offline   Reply With Quote
Old 22nd November 2017, 12:43   #2718  |  Link
daberti
(Noob, please help) Compressibility check: how to? :confused:
I'm using StaxRip 1.7 and I'm investigating Intel H264 VBR encoding, with max size being assigned.
On the GUI appear Quality and Compressibility, both at 0, point is: how to run compressibility check?
TIA
daberti is offline   Reply With Quote
Old 23rd November 2017, 06:18   #2719  |  Link
JohnLai
Pascal = weighted-P is not working with driver 387.92 and current 388.13
Get drivers older than 387.92 if you want weighted-P for HEVC encoding.
JohnLai is offline   Reply With Quote
Old 24th November 2017, 07:04   #2720  |  Link
craigpro
thanks JohnLai! I'll try 385.69
from memory the weighted option resulted in a lot smaller file size but I've been without a PC for a month so I've forgotten what I was testing.
EDIT: yes 385.69 works fine. I'd need to do testing to see the file difference with the weighted-p option but from memory it was about 10%?
