7th April 2020, 21:57 | #302 | Link | |
8th April 2020, 09:42 | #303 | Link | |
Acid fr0g
Not yet. I have a long restoration process that will finish in a day or two.
@turment on Telegram |
22nd April 2020, 18:16 | #304 | Link |
MP_Pipeline doesn't work with L-SMASH-Works until the .lwi file has already been successfully created. MPP .18 and .20 both do it.
This fails: Code:
LoadPlugin("C:\HDTV Tools\MP_Pipeline\x64\MP_Pipeline.dll") SetMemoryMax(1) MP_Pipeline(""" ### platform: win64 LoadPlugin("C:\HDTV Tools\L-SMASH-Works\x64\LSMASHSource.dll") LWLibavVideoSource("source.mkv") ### prefetch: 16, 8 ### ### """) It also fails to load from AVSmeter and x264. The .lwi file appears to only be partially created. It's smaller than when the source fully loads and the .lwi doesn't have a proper "footer" in it. This works: Code:
LoadPlugin("C:\HDTV Tools\L-SMASH-Works\x64\LSMASHSource.dll") LWLibavVideoSource("source.mkv") |
22nd April 2020, 23:36 | #305 | Link |
Also, MPP .20 is incompatible with the old x64 build of DGMPGDec from 2010 (I'm not aware of a newer x64 build). You basically just get a green screen as the output if used in a MPP segment. It works with MPP .18. The x64 build works outside of MPP .20.
FWIW, the 32bit version of DGMPGDec works with MPP .20. Last edited by Stereodude; 22nd April 2020 at 23:47. |
23rd April 2020, 00:02 | #306 | Link | |
See My Avisynth Stuff |
23rd April 2020, 05:44 | #308 | Link | |
23rd April 2020, 07:15 | #309 | Link | |
23rd April 2020, 15:04 | #311 | Link |
I see. During an initial handshake the host process can detect a "SLAVE_OK" message sent over stdout. If no "SLAVE_OK" is received then it assumes that something bad happened and starts collecting data sent over the stdout pipe and waits until the internal buffer size (1024 bytes) is full (or timeout). Then it exits and is showing us the text which is intended to be an Error text, but it is only the indexing log. This 1024 bytes is that you posted from VD log screen.
31st October 2020, 21:55 | #312 | Link |
Broadcast Encoder
I'm probably doing something wrong, but why this doesn't work?
MP_Pipeline(""" video1=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1220_001.MP4") ### export clip: video1 ### ### video2=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1226_001.MP4") ### export clip: video2 ### pass clip: video1 ### ### video1++video2 ### ### """) nor does this: Code:
MP_Pipeline(""" video1=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1220_001.MP4") ### export clip: video1 ### ### video2=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1226_001.MP4") ### export clip: video1, video2 ### ### video1++video2 ### ### """) nor does this Code:
MP_Pipeline(""" FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1220_001.MP4") ### ### video2=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1226_001.MP4") myvideo=last++video2 return myvideo ### ### """) while this clearly does: Code:
FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1220_001.MP4") video2=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1226_001.MP4") myvideo=last++video2 return myvideo |
1st November 2020, 14:55 | #313 | Link |
I think it's because you don't pass the variable 'last'.
That's how it works for me. Code:
MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "IMG_2563.MOV_x64.avs.mkv" SourceFile = Exist(SourceFile) ? SourceFile : "E:\Ablage\IMG_2563.MOV_x64.avs.mkv" ### inherit end ### LWLibavVideoSource(SourceFile, cache=False) ### ### v2=LWLibavVideoSource(SourceFile, cache=False) ### export clip: v2 ### ### v3=Tweak(v2, hue=0.0, sat=1.5, bright=0, cont=1.0, coring=True, sse=False, startHue=0, endHue=360, maxSat=150, minSat=0, interp=16) last+v3 ### ### return last """) Code:
MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "IMG_2563.MOV_x64.avs.mkv" SourceFile = Exist(SourceFile) ? SourceFile : "E:\Ablage\IMG_2563.MOV_x64.avs.mkv" ### inherit end ### LWLibavVideoSource(SourceFile, cache=False) ### ### video2=LWLibavVideoSource(SourceFile, cache=False) last++video2 ### ### return last """)
Live and let live Last edited by gispos; 1st November 2020 at 15:03. |
1st November 2020, 15:20 | #314 | Link |
Think there were several posts about that requirement for "return last", fairly recently, maybe within last 6 months. [not sure which thread]
EDIT: Here:- https://forum.doom9.org/showthread.p...07#post1914707 See several posts ahead of it too.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 1st November 2020 at 15:27. |
1st November 2020, 17:20 | #315 | Link |
Broadcast Encoder
Right... right...
I forgot about return last, but it didn't help as this failed: Code:
MP_Pipeline(""" video1=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1220_001.MP4") ### export clip: video1 ### ### video2=FFVideoSource("I:\temp\Raw Canon EOS R\20190806_1226_001.MP4") ### export clip: video1, video2 ### ### video1++video2++video3 return last """) Code:
MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "20190806_1220_001.MP4" SourceFile = Exist(SourceFile) ? SourceFile : "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" ### inherit end ### FFVideoSource(SourceFile, cache=False) ### ### video2=FFVideoSource(SourceFile, cache=False) last++video2 ### ### return last """) but here is the thing, as I tried adding more and more SourceFile, it broke. This code is still working: Code:
MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "20190806_1220_001.MP4" SourceFile = Exist(SourceFile) ? SourceFile : "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" SourceFile2 = String(ScriptDir()) + "20190806_1226_001.MP4" SourceFile2 = Exist(SourceFile2) ? SourceFile2 : "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4" SourceFile3 = String(ScriptDir()) + "20190807_2005_001.MP4" SourceFile3 = Exist(SourceFile3) ? SourceFile3 : "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4" ### inherit end ### FFVideoSource(SourceFile, cache=False) ### ### video2=FFVideoSource(SourceFile2, cache=False) last++video2 ### ### video3=FFVideoSource(SourceFile3, cache=False) last++video3 ### ### return last """) Code:
MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "20190806_1220_001.MP4" SourceFile = Exist(SourceFile) ? SourceFile : "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" SourceFile2 = String(ScriptDir()) + "20190806_1226_001.MP4" SourceFile2 = Exist(SourceFile2) ? SourceFile2 : "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4" SourceFile3 = String(ScriptDir()) + "20190807_2005_001.MP4" SourceFile3 = Exist(SourceFile3) ? SourceFile3 : "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4" SourceFile4 = String(ScriptDir()) + "20190807_2011_001.MP4" SourceFile4 = Exist(SourceFile4) ? SourceFile4 : "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4" ### inherit end ### FFVideoSource(SourceFile, cache=False) ### ### video2=FFVideoSource(SourceFile2, cache=False) last++video2 ### ### video3=FFVideoSource(SourceFile3, cache=False) last++video3 ### ### video4=FFVideoSource(SourceFile4, cache=False) last++video4 ### ### return last """) Code:
MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "20190806_1220_001.MP4" SourceFile = Exist(SourceFile) ? SourceFile : "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" SourceFile4 = String(ScriptDir()) + "20190807_2011_001.MP4" SourceFile4 = Exist(SourceFile4) ? SourceFile4 : "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4" ### inherit end ### FFVideoSource(SourceFile, cache=False) ### ### ### ### video4=FFVideoSource(SourceFile4, cache=False) last++video4 ### ### return last """) I also tried with: Code:
MP_Pipeline(""" ### inherit start ### video1 = "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" video2 = "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4" video3 = "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4" video4 = "I:\temp\Raw Canon EOS R\20190807_2008_001.MP4" video5 = "I:\temp\Raw Canon EOS R\20190807_2010_001.MP4" video6 = "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4" video7 = "I:\temp\Raw Canon EOS R\20190807_2013_001.MP4" video8 = "I:\temp\Raw Canon EOS R\20190808_1014_001.MP4" video9 = "I:\temp\Raw Canon EOS R\20190808_1015_001.MP4" video10 = "I:\temp\Raw Canon EOS R\20190808_1016_001.MP4" video11 = "I:\temp\Raw Canon EOS R\20190808_1531_002.MP4" video12 = "I:\temp\Raw Canon EOS R\20190808_1619_001.MP4" video13 = "I:\temp\Raw Canon EOS R\20190808_1620_001.MP4" video14 = "I:\temp\Raw Canon EOS R\20190808_1621_001.MP4" video15 = "I:\temp\Raw Canon EOS R\20190812_1400_001.MP4" video16 = "I:\temp\Raw Canon EOS R\20190812_1947_001.MP4" video17 = "I:\temp\Raw Canon EOS R\20190812_1948_001.MP4" video18 = "I:\temp\Raw Canon EOS R\20190812_2006_001.MP4" ### inherit end ### FFVideoSource(video1, cache=False) ### ### v2=FFVideoSource(video2, cache=False) last=last++v2 return last ### ### v3=FFVideoSource(video3, cache=False) last=last++v3 return last """) same goes for this one: Code:
MP_Pipeline(""" ### inherit start ### video1 = "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" video2 = "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4" video3 = "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4" video4 = "I:\temp\Raw Canon EOS R\20190807_2008_001.MP4" video5 = "I:\temp\Raw Canon EOS R\20190807_2010_001.MP4" video6 = "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4" video7 = "I:\temp\Raw Canon EOS R\20190807_2013_001.MP4" video8 = "I:\temp\Raw Canon EOS R\20190808_1014_001.MP4" video9 = "I:\temp\Raw Canon EOS R\20190808_1015_001.MP4" video10 = "I:\temp\Raw Canon EOS R\20190808_1016_001.MP4" video11 = "I:\temp\Raw Canon EOS R\20190808_1531_002.MP4" video12 = "I:\temp\Raw Canon EOS R\20190808_1619_001.MP4" video13 = "I:\temp\Raw Canon EOS R\20190808_1620_001.MP4" video14 = "I:\temp\Raw Canon EOS R\20190808_1621_001.MP4" video15 = "I:\temp\Raw Canon EOS R\20190812_1400_001.MP4" video16 = "I:\temp\Raw Canon EOS R\20190812_1947_001.MP4" video17 = "I:\temp\Raw Canon EOS R\20190812_1948_001.MP4" video18 = "I:\temp\Raw Canon EOS R\20190812_2006_001.MP4" ### inherit end ### FFVideoSource(video1, cache=False) ### ### mysource2=FFVideoSource(video2, cache=False) last++mysource2 ### ### mysource3=FFVideoSource(video3, cache=False) last++mysource3 return last """) I know that the compiler is always right, but... what is it trying to tell me this time? and... by the way, I'm not mad, files are there and are not corrupted and have been indexed correctly, so... why? Last edited by FranceBB; 1st November 2020 at 17:30. |
1st November 2020, 17:49 | #316 | Link |
Unhandled C++ execption is a dll error, not your fault.
No idea bout the rest of it, tis a mystery to me [mp_pipeline thingy].
1st November 2020, 18:34 | #318 | Link | |
You make a mistake at the end of MP_Pipeline. Please compare. Code:
MP_Pipeline(""" ### inherit start ### video1 = "E:\Ablage\IMG_2563.MOV_x64.avs.mkv" ### inherit end ### LWLibavVideoSource(video1, cache=False) ### ### mysource2=LWLibavVideoSource(video1, cache=False) last++mysource2 ### ### mysource3=LWLibavVideoSource(video1, cache=False) last++mysource3 ### ### (note this line) return last """) And MP_Pipeline can only access what is written in 'inherit start'. For me it usually looks like this. Code:
### ### audio=LWLibavAudioSource(SourceFile, cache=False) audioDub(last, audio) return last """)
Live and let live Last edited by gispos; 1st November 2020 at 19:02. |
1st November 2020, 20:29 | #319 | Link | ||
Broadcast Encoder
This returns unhandled C++ exception: Code:
MP_Pipeline(""" ### inherit start ### video1 = "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" video2 = "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4" video3 = "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4" video4 = "I:\temp\Raw Canon EOS R\20190807_2008_001.MP4" video5 = "I:\temp\Raw Canon EOS R\20190807_2010_001.MP4" video6 = "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4" video7 = "I:\temp\Raw Canon EOS R\20190807_2013_001.MP4" video8 = "I:\temp\Raw Canon EOS R\20190808_1014_001.MP4" video9 = "I:\temp\Raw Canon EOS R\20190808_1015_001.MP4" video10 = "I:\temp\Raw Canon EOS R\20190808_1016_001.MP4" video11 = "I:\temp\Raw Canon EOS R\20190808_1531_002.MP4" video12 = "I:\temp\Raw Canon EOS R\20190808_1619_001.MP4" video13 = "I:\temp\Raw Canon EOS R\20190808_1620_001.MP4" video14 = "I:\temp\Raw Canon EOS R\20190808_1621_001.MP4" video15 = "I:\temp\Raw Canon EOS R\20190812_1400_001.MP4" video16 = "I:\temp\Raw Canon EOS R\20190812_1947_001.MP4" video17 = "I:\temp\Raw Canon EOS R\20190812_1948_001.MP4" video18 = "I:\temp\Raw Canon EOS R\20190812_2006_001.MP4" ### inherit end ### FFVideoSource(video1, cache=False) ### ### mysource2=FFVideoSource(video2, cache=False) last++mysource2 ### ### mysource3=FFVideoSource(video3, cache=False) last++mysource3 return last """) Code:
MP_Pipeline(""" ### inherit start ### video1 = "I:\temp\Raw Canon EOS R\20190806_1220_001.MP4" video2 = "I:\temp\Raw Canon EOS R\20190806_1226_001.MP4" video3 = "I:\temp\Raw Canon EOS R\20190807_2005_001.MP4" video4 = "I:\temp\Raw Canon EOS R\20190807_2008_001.MP4" video5 = "I:\temp\Raw Canon EOS R\20190807_2010_001.MP4" video6 = "I:\temp\Raw Canon EOS R\20190807_2011_001.MP4" video7 = "I:\temp\Raw Canon EOS R\20190807_2013_001.MP4" video8 = "I:\temp\Raw Canon EOS R\20190808_1014_001.MP4" video9 = "I:\temp\Raw Canon EOS R\20190808_1015_001.MP4" video10 = "I:\temp\Raw Canon EOS R\20190808_1016_001.MP4" video11 = "I:\temp\Raw Canon EOS R\20190808_1531_002.MP4" video12 = "I:\temp\Raw Canon EOS R\20190808_1619_001.MP4" video13 = "I:\temp\Raw Canon EOS R\20190808_1620_001.MP4" video14 = "I:\temp\Raw Canon EOS R\20190808_1621_001.MP4" video15 = "I:\temp\Raw Canon EOS R\20190812_1400_001.MP4" video16 = "I:\temp\Raw Canon EOS R\20190812_1947_001.MP4" video17 = "I:\temp\Raw Canon EOS R\20190812_1948_001.MP4" video18 = "I:\temp\Raw Canon EOS R\20190812_2006_001.MP4" ### inherit end ### FFVideoSource(video1, cache=False) ### ### mysource2=FFVideoSource(video2, cache=False) last++mysource2 ### ### mysource3=FFVideoSource(video3, cache=False) last++mysource3 ### ### return last """) Quote:
Ah, Ferenc is here. I'm running Avisynth+ 3.6.1 r3300 on x86 under Windows XP with PAE turned on and 32 GB of RAM. Output from AVSMeter: Code:
Operating system: Windows XP (x86) Service Pack 3.0 (Build 2600) CPU: Intel(R) Xeon(R) CPU X5482 @ 3.20GHz / Xeon (Harpertown) MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1 4 physical cores / 4 logical cores [Avisynth info] VersionString: AviSynth+ 3.6.1 (r3300, 3.6, i386) VersionNumber: 2.60 File / Product version: 3.6.1.0 / 3.6.1.0 Interface Version: 8 Multi-threading support: Yes Avisynth.dll location: C:\WINDOWS\system32\avisynth.dll Avisynth.dll time stamp: 2020-06-19, 20:44:24 (UTC) PluginDir2_5 (HKLM, x86): C:\Programmi\AviSynth\plugins PluginDir+ (HKLM, x86): C:\Programmi\AviSynth+\plugins+ The output of AVSMeter doesn't really show anything either: |
1st November 2020, 21:06 | #320 | Link | |
The filename comes from 'inherit' and the last clip variable (mysource3) is created in the main thread.
Live and let live |
avisynth, multi-process, pipeline |
