3rd October 2019, 18:45 | #3442 | Link |
Wouldn't that make it more prevalent over a range of files instead of a single batch? Dumping file info in case it helps.
SW: Windows 10 MPC-HC (latest) LAV Video, Audio, Splitter madVR, EVR (CP), ... XYsub, ASS, VobSub, ... HW: i7-6700HQ @ 2.60 GHz GTX 960M (4 GB) 16 GB DDR4 RAM 1TB HDD + 128GB SSD |
3rd October 2019, 19:28 | #3443 | Link |
That video has an uncommon resolution. Plus the encoding settings of the video can be very different between files.
Start by updating to the latest version of MPC-HC. Then update the NVIDIA driver. |
3rd October 2019, 22:21 | #3444 | Link | |
21st July 2020, 13:23 | #3446 | Link |
Video blinks (black frames?) when not on top (with MPC Video Renderer)
This is not happening on every video.
It does not happen with EVR-CP. This is my current setup: Code:
MPC-HC (Nightly, 64-bit) Build information: Version: 1.9.6.28 (e518e401c) Compiler: MSVC v19.26.28806 Build date: Jul 10 2020 LAV Filters: LAV Splitter: 0.74.1.64 LAV Video: 0.74.1.64 LAV Audio: 0.74.1.64 FFmpeg compiler: MinGW-w64 GCC 9.3.0 Operating system: Name: Windows NT 10.0 (build 20170) Version: 10.0 (64-bit) Hardware: CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz GPU: Intel(R) HD Graphics 620 (driver version: 27.20.100.8425) Here's one file it happens with: Code:
Format : Matroska Format version : Version 4 File size : 1.91 GiB Duration : 30 min 7 s Overall bit rate mode : Variable Overall bit rate : 9 054 kb/s Encoded date : UTC 2020-07-20 04:01:56 Writing application : mkvmerge v48.0.0 ('Fortress Around Your Heart') 64-bit Writing library : libebml v1.4.0 + libmatroska v1.6.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 30 min 7 s Bit rate mode : Variable Bit rate : 8 668 kb/s Maximum bit rate : 12.4 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.139 Stream size : 1.82 GiB (96%) Language : English Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 30 min 7 s Bit rate mode : Constant Bit rate : 384 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 82.8 MiB (4%) Language : English Service kind : Complete Main Default : Yes Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 29 min 47 s Bit rate : 129 b/s Count of elements : 1150 Stream size : 28.2 KiB (0%) Title : English (SDH) Language : English Default : No Forced : No Last edited by Faiakes; 21st July 2020 at 22:11. |
21st July 2020, 15:34 | #3447 | Link |
For MPC Video Renderer bugs you need to go here:
https://github.com/Aleksoid1978/VideoRenderer |
2nd April 2021, 21:50 | #3452 | Link |
From page1 (13th December 2012), some questions never get old it seems.
Current mpc-hc development: https://github.com/clsid2/mpc-hc
bShaders: realtime Effects/filters for video players |
2nd April 2021, 22:32 | #3453 | Link |
Also read on: MPC-HC 1.9.x+
22nd February 2024, 14:25 | #3454 | Link |
Hi, could you tell me the cause of the slowdowns when I go to check my MP3? I leave you an explanatory video. HI
https://www.mediafire.com/file/jm3ki...e_mp3.mp4/file |
dxva, media player classic, mpc, mpc-hc |
