Old 14th December 2012, 14:21   #21  |  Link
ney2x
Hoping for a ICL13 Lite Build. Thanks.
ney2x is offline   Reply With Quote
Old 14th December 2012, 14:51   #22  |  Link
Joniii
I got this to compile at last .
Wouldn't this be logical? When Playrate is increased or decreased, pressing play would reset the playrate, now you need extra button to reset it. So on a remote you got play button mapped but then it requires to map another button to continue play after rewind/forward.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards
MPC-HC (madVR, LAV Filters, XySubFilter)
Sony Bravia 85X950H/85XH95
Yamaha RX-V685
Yamaha Piano Black NS-777/555/C444/YST-SW315
Joniii is offline   Reply With Quote
Old 14th December 2012, 16:37   #23  |  Link
Armada
MPC-HC Developer
Makes sense to me, if you can implement a solution that doesn't affect Play/Pause I'll happily integrate it.
Armada is offline   Reply With Quote
Old 14th December 2012, 20:58   #24  |  Link
Joniii
MainFrm.cpp
void CMainFrame::OnPlayPlay()
if (GetPlaybackMode() == PM_FILE)
            if (m_fEndOfStream)
                SendMessage(WM_COMMAND, ID_PLAY_STOP);
			pMS->SetRate(m_dSpeedRate = 1.0);
            pMC->Run();
I't already worked on DVD, it was only broken on Blu-ray and other video files, this should fix it.
Is there some reason why BD fast forward won't go beyond 4X?
Yamaha RX-V685
Old 14th December 2012, 23:07   #25  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Look at pull requests in order to contribute code
Prolly not going to happen any time soon.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline   Reply With Quote
Old 15th December 2012, 00:47   #26  |  Link
Joniii
MainFrm.cpp
            if (m_fEndOfStream)
            pMC->Run();
There is one thing that needs fixing for this to work properly on the UI side. With the remote this works fine or when you map a keyboard button to play command. However, the UI buttons have an unusual behaviour that prevents pressing the play buttond when on increased speed. It should be allowed to be pressed again or set the increase speed button selected when on increased speed so that play button will be unselected and can be pressed again. Then remove the Shortcut code for reset rate as that wouldn't be needed anymore.
Ok.
Yamaha RX-V685
Old 15th December 2012, 00:49   #27  |  Link
dansrfe
Just wanted to say that I liked the change to the increase/decrease rate buttons that allowed .1 incremental increases in speed instead of the jump to 2.00x etc. I had to revert back to 1.6.5.6334 in order to get that functionality back as it seems the change was reverted in the later builds. Please consider putting that option back or adding a customization property in MPC-HC that allows the user to set the increment to increase/decrease by similar to how subtitle offset ms is customizable.
Also, if an option could be added to automatically add temporary chapter points for files that don't have chapters (including audio files) that would be spectacular. Thanks!
Old 15th December 2012, 11:12   #28  |  Link
Joniii
I think MPC-HC would need something like this fast.
Yamaha RX-V685
Old 15th December 2012, 13:51   #29  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Armada just polished that option with configuration option. Now you can choose which rate you want. It just landed into git head
Old 15th December 2012, 14:03   #30  |  Link
betaking
Fantasy Codecs writer
betaking's Avatar
S.Chinese update
http://www.mediafire.com/?9iognt40b85hjho
betaking is offline   Reply With Quote
Old 15th December 2012, 20:45   #31  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Originally Posted by betaking View Post
Thanks. Landed as 59639f72
Old 16th December 2012, 07:37   #32  |  Link
Superb
Originally Posted by clsid View Post
There is a subtitle selection bug in the latest builds. If both embedded and an external subtitle file is present, then Play>Subtitles shows the external subtitle track as selected (as it should), but the embedded one is actually shown. Changing the selection in Play>Subtitles twice results in the correct one being displayed.
Really annoying bug for those of us that use external subtitles when watching! :O
Verified on 1.6.5.6354 (c00d66a).
Probably happened here: https://github.com/mpc-hc/mpc-hc/com...0255744bd16736
Superb is offline   Reply With Quote
Old 16th December 2012, 09:08   #33  |  Link
Joniii
Is anyone planning to do similar theming options than in BE?
Yamaha RX-V685
Old 16th December 2012, 09:20   #34  |  Link
v0lt
I do not understand. Describe the bug details. Maybe there is a small sample?
Old 16th December 2012, 10:35   #35  |  Link
Reino
Reino's Avatar
What are your plans for (embedded) cue-sheet support?
My hobby website
Reino is offline   Reply With Quote
Old 16th December 2012, 11:28   #36  |  Link
Superb
Sent ya a small sample via PM.
Old 16th December 2012, 11:47   #37  |  Link
Joniii
Would it be possible to get an option to lock window borders with video?
Yamaha RX-V685
Old 16th December 2012, 12:16   #38  |  Link
betaking
betaking's Avatar
S.Chinese update
http://www.mediafire.com/?cbb07cng2d9taok
Old 16th December 2012, 12:20   #39  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
This should be fixed as of 0696a331
Yeah, Armada has plans to revamp the UI in near future.
Old 16th December 2012, 15:42   #40  |  Link
mrchisholm
firstly, appologies if it has been covered before but i have a problem when streaming from my DVB-apps to MPC-HC.
The problem is whenever you open the HTTP stream (http://127.0.0.1:2345 for example, from dvbviewer) MPC creates a temp file in C:\Users\XXX\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\(random letter/number labeled folder)\ called 127.0.0.1[1] as if it's storing the stream there as it is being fed .. so far so good but when the file reaches 4GB in size the stream stops and restarts from where u started it. I've tried several MPC-HC versions and even old MPC but all have the same problem, i've tried diffrent splitters/audio/video codecs and different renderes (yes i'm fumbling in the dark here) without success. since it seem to be an issue in all versions i guess it could be an external issue but i have no way of knowing, if i try to delete the file it say that it's in use by MPC. If i play the stream in VLC it works without problems.
Any ideas what could be causing this? I tried different dvb apps, dvbdream, dvbviewer and all express the same issue. i'm beginning to wonder if it's a DirectShow issue, but i would have thought this would be dealt with long ago if it was a common issue, i have a friend who have the same exact problem on his PC. Both use Win7 x64.
Thanks in advance.
MrC
mrchisholm is offline   Reply With Quote
dxva, media player classic, mpc, mpc-hc
