Old 17th April 2016, 18:25   #24101  |  Link
ggtop
I'm curious myself. Therefore I started another encode right away.
log:
[04.17.16] BD Rebuilder v0.50.15
[18:57:05] Source:  JUPITER_ASCENDING_00100
  - Input BD size: 33,75 GB
  - Approximate total content: [02:07:34.313]
  - Windows Version: 6.1 [7601]
  - Mode: xxx MP4 Container, 1920x1080, AutoGOP, AC3
  - Quality: Good (Very Fast)
[18:57:05] PHASE ONE, Encoding
 - [18:57:05] Processing: VID_00042 (1 of 1)
 - [18:57:05] Extracting A/V streams [VID_00042]
 - [19:13:30] Reencoding video [VID_00042]
   - Rate/Length: 23,976fps, 183.520 frames
 - [19:13:30] Reencoding: VID_00042, Pass 1 of 1
Profile:
caption=xxx MP4 Container, 1280x720, AutoGOP, AC3
vBitrate=2000
aBitrate=448
aType=0
vFormat=4
vKeyint=Auto
Sorry for the inconvience!!! Obviously the missing container type cType caused the stereo downmix. Copy & paste error in my custom profile.
I'm very sorry stealing your time. I will double-check handling errors on my side next time and hopefully avoid them.
AVS without cType specified:
#Created by BD Rebuilder - v0.50.15
LoadPlugin("C:\Users\xxx\Documents\Software\BD_Rebuilder_V05014\tools\nicaudio.dll")
audio=NicDTSSource("00042.track_4354.dts")
audio = (AudioChannels(audio) > 2) ? MixAudio(GetChannel(audio, 1, 2), GetChannel(audio, 3, 3), 0.5858, 0.4142) : audio
ConvertAudioTo16bit(ResampleAudio(audio, 48000))
AVS WITH cType specified:
audio = (AudioChannels(audio) > 6) ? GetChannel(audio,1,2,3,4,7,8) : audio
ggtop
Old 17th April 2016, 20:14   #24102  |  Link
Originally Posted by ggtop View Post
Sorry for the inconvience. Obviously the missing cType caused the Stereo downmix. Copy & paste error in my custom profile.
Yep. If you fail to specify a ctype it defaults to 0, which is iPod. Since the iPod only supports stereo output, all audio for that ctype is converted to stereo.
I should probably change the default to MKV.
Old 17th April 2016, 22:52   #24103  |  Link
wakko709
any word on mockingjay_2 now it happing with zero dark thirty
wakko709 is offline   Reply With Quote
Old 17th April 2016, 23:48   #24104  |  Link
gonca
@wakko709
At one point or another I have used BD_RB on Pacific Rim, Mocking jay 2, and Zero Dark Thirty with no issues.
Perhaps the issue is on your end
Logs and settings would help establish where the problem lies
Old 18th April 2016, 13:37   #24105  |  Link
I got it and tested it. No problems at all.
Old 18th April 2016, 17:43   #24106  |  Link
palburn
Quick Play menu not being created
Hi, have been on this forum for a number of years, butthis is my first post. Haved BD-Rebuilder prior to BD-RBV04904 and love the software. However, I have now got a problem, I cannot create a BD with Quick Play menus for tv series etc. I rarely use this feature but have done on occasions in the past with no problem. I am in process on converting to BDR a number of TV series but always fail on Menu creation. Currently running BD-RBV05014.
I attach log & ini. files. Have I missed something out of the config file or is this a bug? Any help would be gratefully recieved.
[Options]
VERSION=0.50.0.14
ENCODER=0
MODE=2
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_TWOPASSONLY=1
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_AMPLIFY=1.2
AUDIO_DRC=0
MENU_ACTIVE_COLOR=RED
DECODER=2
AVCHD=1
REMOVE_WORKFILES=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=23500
TARGET_SIZE=23500
MENU_BACKGROUND=E:\Software\DVD & Video\Blu Ray\BD Rebuilder\BD-RBV05014\BD_Rebuilder\Misc\menuback 2.jpg
MENU_AUDIO=E:\Software\DVD & Video\Blu Ray\BD Rebuilder\BD-RBV05014\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=0
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
[Paths]
WORKING_PATH=O:\THE--------- \BDR\
SOURCE_PATH=O:\THE----------- \BDR\IMPORTS\---------------\
log
[15:32:24] Importing: THE_-------------------
- [15:32:31] Importing video file: (1 of 6)
  - Collecting audio/video streams from source...
  - Integrating into pseudo-BD structure...
- [15:36:45] Importing video file: (2 of 6)
- [15:41:04] Importing video file: (3 of 6)
- [15:45:20] Importing video file: (4 of 6)
- [15:49:41] Importing video file: (5 of 6)
- [15:53:52] Importing video file: (6 of 6)
- [15:58:16] Creating Quick-Play Menu...
   - Encoding menu background...
   - Building menu structure...
[15:58:23] Video import completed successfully.
[04/16/16] BD Rebuilder v0.50.14
[15:59:11] Source:  THE_-------------------
  - Input BD size: 27.64 GB
  - Approximate total content: [05:38:56.542]
  - Target BD size: 22.95 GB
  - Quick-Play Reauthoring mode enabled
  - Quality: High Quality (Default), Two Pass
[15:59:11] PHASE ONE, Encoding
 - [15:59:11] Processing: VID_00001 (1 of 6)
 - [15:59:11] Extracting A/V streams [VID_00001]
 - [16:02:47] Reencoding video [VID_00001]
   - Rate/Length: 25.000fps, 85,498 frames
   - Bitrate: 7,369 Kbs
 - [16:02:47] Reencoding: VID_00001, Pass 1 of 2
 - [16:21:10] Reencoding: VID_00001, Pass 2 of 2
 - [17:08:25] Video Encode complete
 - [17:08:25] Processing audio tracks
   - Track 4352 (und): Keeping original audio
 - [17:08:25] Multiplexing M2TS
 - [17:10:14] Processing: VID_00002 (2 of 6)
 - [17:10:14] Extracting A/V streams [VID_00002]
 - [17:13:36] Reencoding video [VID_00002]
   - Rate/Length: 25.000fps, 80,693 frames
   - Bitrate: 7,800 Kbs
 - [17:13:36] Reencoding: VID_00002, Pass 1 of 2
 - [17:31:42] Reencoding: VID_00002, Pass 2 of 2
 - [18:19:48] Video Encode complete
 - [18:19:48] Processing audio tracks
 - [18:19:48] Multiplexing M2TS
 - [18:21:36] Processing: VID_00003 (3 of 6)
 - [18:21:36] Extracting A/V streams [VID_00003]
 - [18:24:42] Reencoding video [VID_00003]
   - Rate/Length: 25.000fps, 85,125 frames
   - Bitrate: 7,303 Kbs
 - [18:24:42] Reencoding: VID_00003, Pass 1 of 2
 - [18:43:27] Reencoding: VID_00003, Pass 2 of 2
 - [19:31:36] Video Encode complete
 - [19:31:36] Processing audio tracks
 - [19:31:36] Multiplexing M2TS
 - [19:33:40] Processing: VID_00004 (4 of 6)
 - [19:33:40] Extracting A/V streams [VID_00004]
 - [19:37:11] Reencoding video [VID_00004]
   - Bitrate: 7,308 Kbs
 - [19:37:11] Reencoding: VID_00004, Pass 1 of 2
 - [19:55:42] Reencoding: VID_00004, Pass 2 of 2
 - [20:46:18] Video Encode complete
 - [20:46:18] Processing audio tracks
 - [20:46:18] Multiplexing M2TS
 - [20:48:03] Processing: VID_00005 (5 of 6)
 - [20:48:03] Extracting A/V streams [VID_00005]
 - [20:51:23] Reencoding video [VID_00005]
   - Rate/Length: 25.000fps, 84,079 frames
   - Bitrate: 7,426 Kbs
 - [20:51:24] Reencoding: VID_00005, Pass 1 of 2
 - [21:08:45] Reencoding: VID_00005, Pass 2 of 2
 - [22:00:10] Video Encode complete
 - [22:00:10] Processing audio tracks
 - [22:00:10] Multiplexing M2TS
 - [22:01:51] Processing: VID_00006 (6 of 6)
 - [22:01:51] Extracting A/V streams [VID_00006]
 - [22:05:27] Reencoding video [VID_00006]
   - Rate/Length: 25.000fps, 87,880 frames
   - Bitrate: 7,043 Kbs
 - [22:05:27] Reencoding: VID_00006, Pass 1 of 2
 - [22:25:51] Reencoding: VID_00006, Pass 2 of 2
 - [23:19:39] Video Encode complete
 - [23:19:39] Processing audio tracks
 - [23:19:39] Multiplexing M2TS
[23:21:31]PHASE ONE complete
[23:21:31]PHASE TWO - Rebuild Started
 - [23:21:31] Rebuilding BD file Structure
 - [23:21:32] Creating Quick-Play Menu...
[23:21:37]ERROR: Failed quick menu creation. No menus.
[23:21:37] - Encode and Rebuild complete
 - WORKFILES folder removed.
[23:21:38] JOB: THE_---------------------- finished.
[04/17/16] Checking System Settings
- BD-Rebuilder v0.50.14
- Working Path Free Space: 686.33GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[04/17/16] Systems Settings Check complete
palburn is offline   Reply With Quote
Old 18th April 2016, 17:59   #24107  |  Link
It failed in trying to encode the file below into an AVC stream:
Are you sure it exists and it is a legal JPG file?
Old 18th April 2016, 19:19   #24108  |  Link
palburn
Absolutely sure and the path is correct. All I did was remove the default menu to a different folder tempoarily and substituted my own custom .jpg. I was wondering if this line from the config was the cause of the problem: MENU_AUTO_BACKGROUND=0. Should this be changed to "1" ?
Thanks JD for your quick reply.
Old 18th April 2016, 19:22   #24109  |  Link
RowanM
There is a space a between "menuback" and the "2", is that correct?
If so then try putting quotes around the complete filename and that might help it.
Like:
"E:\Software\DVD & Video\Blu Ray\BD Rebuilder\BD-RBV05014\BD_Rebuilder\Misc\menuback 2.jpg"
RowanM is offline   Reply With Quote
Old 18th April 2016, 19:50   #24110  |  Link
palburn
Cheers Rowan, will try that as well, as I'm following a suggestion from JD and changing the location of menu images to close to the root of a drive
I have just created a new folder at the root of the drive for backgound images for menus:BD Backgrounds as I wondered if the required .jpg was 6 levels down from the root, thus causing the problem.
Old 18th April 2016, 20:33   #24111  |  Link
Like:
BD-RB does that automatically. I'm confident the menu system works correctly -- it's probably the feature I used most these days.
Old 18th April 2016, 22:24   #24112  |  Link
mparade
@jdobbs
Would it be possible to insert --frame-packing 4 in the X264 command line when creating TAB 3D output? This would help my new media tank to automatically recognize my 3D contents.
It would be really appreciated.
Old 18th April 2016, 22:49   #24113  |  Link
@jdobbs
No problem. I'll get it into the next release.
Old 18th April 2016, 23:48   #24114  |  Link
mparade
Thank you very much.
Old 19th April 2016, 02:22   #24115  |  Link
Lathe
Lathe's Avatar
I don't know if this is relevant to your situation, but whenever I use the Quick-Play deal, every time it goes to 'encode menu background' I get a prompt telling me something like an action is being called without the proper permission, or something like that. I just hit "ok" and it continues just fine. I also notice a similar prompt every time Avisynth is called. I THINK that it has something to do with the locations of the .exe's, but I honestly don't know...
Old 19th April 2016, 02:29   #24116  |  Link
Hmm... I use this feature all the time and I've never gotten that. Can you capture the screen the next time you see it and let me see what it looks like?
Old 19th April 2016, 02:54   #24117  |  Link
Lathe
Lathe's Avatar
Sho-nuff boss, will do it...
Old 20th April 2016, 01:55   #24118  |  Link
Lathe
Lathe's Avatar
Here it is...
Okay, here is the prompt I always get when I either use the Quick-Play import function (right after it says 'encoding menu background') or when Avisynth is called during encodes (resizing, etc...) I have no idea why and it doesn't really affect me much as long as I click 'ok' when the prompt occurs so that the program can continue.
Old 20th April 2016, 02:38   #24119  |  Link
Interesting. Are sure you're using the version of X264 that is included with BD-RB?
Old 20th April 2016, 19:11   #24120  |  Link
Flanker-B
Originally Posted by GodZZial View Post
Hello Everybody,
Does anyone know how to bypass this error? Or what the problem is. I saw that skylab has the same problem on page 328. But no one had respond to him.
The problem is that at the end of bd rebuilder. There occurs an error. "CopyDirStructure"
I poste the log with this message
Thanks in Advance,
Ronald
[13:18:41] BD Rebuilder v0.31.06 (beta)
- Source: BOURNE_ULTIMATUM_BLURAY
- Input BD size: 40,65 GB
- Approximate total content: [03:21:51.841]
- Target BD size: 22,46 GB
- Windows Version: 6.0 [6002]
[13:18:41] PHASE ONE, Encoding
- [13:18:41] Extracting A/V streams [VID_00082]
- [13:18:45] Reencoding: VID_00082 (1 of 21)
- [13:19:30] Extracting A/V streams [VID_00080]
- [13:19:35] Reencoding: VID_00080 (2 of 21)
- [13:20:25] Extracting A/V streams [VID_00113]
- [13:20:29] Reencoding: VID_00113 (3 of 21)
- [13:21:23] Extracting A/V streams [VID_00116]
- [13:21:28] Reencoding: VID_00116 (4 of 21)
- [13:22:25] Extracting A/V streams [VID_00118]
- [13:22:31] Reencoding: VID_00118 (5 of 21)
- [13:23:29] Extracting A/V streams [VID_00117]
- [13:23:35] Reencoding: VID_00117 (6 of 21)
- [13:24:45] Extracting A/V streams [VID_00112]
- [13:24:53] Reencoding: VID_00112 (7 of 21)
- [13:26:28] Extracting A/V streams [VID_00111]
- [13:26:36] Reencoding: VID_00111 (8 of 21)
- [13:28:28] Extracting A/V streams [VID_00119]
- [13:28:38] Reencoding: VID_00119 (9 of 21)
- [13:30:10] Extracting A/V streams [VID_00115]
- [13:30:18] Reencoding: VID_00115 (10 of 21)
- [13:31:44] Extracting A/V streams [VID_00114]
- [13:31:58] Reencoding: VID_00114 (11 of 21)
- [13:34:20] Extracting A/V streams [VID_00010]
- [13:34:35] Reencoding: VID_00010 (12 of 21)
- [13:37:00] Extracting A/V streams [VID_00395]
- [13:37:20] Reencoding: VID_00395 (13 of 21)
- [13:39:52] Extracting A/V streams [VID_00394]
- [13:40:13] Reencoding: VID_00394 (14 of 21)
- [13:42:48] Extracting A/V streams [VID_00399]
- [13:43:11] Reencoding: VID_00399 (15 of 21)
- [13:46:07] Extracting A/V streams [VID_00401]
- [13:46:31] Reencoding: VID_00401 (16 of 21)
- [13:49:20] Extracting A/V streams [VID_00400]
- [13:49:43] Reencoding: VID_00400 (17 of 21)
- [13:52:39] Extracting A/V streams [VID_00396]
- [13:53:02] Reencoding: VID_00396 (18 of 21)
- [13:56:09] Extracting A/V streams [VID_00397]
- [13:56:39] Reencoding: VID_00397 (19 of 21)
- [13:59:54] Extracting A/V streams [VID_00398]
- [14:00:20] Reencoding: VID_00398 (20 of 21)
- [14:03:45] Extracting A/V streams [VID_00009]
- [14:31:55] Reencoding: VID_00009 (21 of 21)
- [14:31:55] Reencoding secondary video [TRK_02]
- [15:01:49] Reencoding secondary video [TRK_03]
[03:11:30]PHASE ONE complete
[03:11:30]PHASE TWO - Rebuild Started
- [03:11:30] Rebuilding BD file Structure
- [03:11:30] CopyDirStructure() 00076 1200
- [07:54:10] CopyDirStructure() 00076 1200
- [07:54:11] CopyDirStructure() 00076 1200
- [07:54:12] CopyDirStructure() 00076 1200
[07:54:13] - Aborted at user request
This error happens to me since the last update, the only thing it happens only once and the gap is short!
Flanker-B is offline   Reply With Quote
