Old 17th July 2016, 22:51   #24501  |  Link
soneca
Chevron, I know the rules, after all already participate in this forum a long time.
The AnyDVD settings do not apply to this extraction, I was testing this function and forgot to turn off.
I'm not demanding anything at all just asking to jdobbs that, please be sure to check this version because when I go back to the previous version these problems disappear.
Edit: jdobbs, I found that disabling multiprocessing BDRB back to function normally using DirectShow.
Old 20th July 2016, 14:09   #24502  |  Link
Please explain exactly what you experienced and how it could be repeated. I made the change below in v0.50.16, and it's possible it may have some unexpected consequence.
- Corrected an error in which attempting to
  encode using a combination of MULTIPROCESS
  and DirectshowSource() on an MPEG-2 source
  was not working properly.
Old 20th July 2016, 15:20   #24503  |  Link
musiclover
I'll look at it -- but I use that feature all the time on 25fps sources.
Just a note, though. It won't be converted until an encode is done. The pseudo-BD structure just holds the original intact video that was extracted during import.
I am interested to know if you succeeded converting a PAL dvd source to NTSC. I still cannot make it work.
Old 20th July 2016, 16:23   #24504  |  Link
Ch3vr0n
well with the latest version and MULTIPROCESS=1 on my 6700k no more than 1 instance gets launched of x264
Old 20th July 2016, 19:08   #24505  |  Link
soneca
Just multiprocessing be enabled, I tried with 3 discs (MPEG4 AVC).
It's happening on both pc's.
[07/20/16] BD Rebuilder v0.50.17
[14:40:15] Source:  O_P_T_III_O_LEGADO_00000
  - Input BD size: 15,65 GB
  - Approximate total content: [01:42:51.798]
  - Target BD size: 4,38 GB
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY mode enabled
  - Quality: Highest (Very Slow), Two Pass
  - Output folder: E:\VIDEOS\
  - Decoding/Frame serving: DirectShow [3-way]
[14:40:17] PHASE ONE, Encoding
 - [14:40:17] Processing: VID_00000 (1 of 1)
 - [14:40:17] Extracting A/V streams [VID_00000]
 - [14:43:51] Reencoding video [VID_00000]
   - Rate/Length: 29,970fps, 184.969 frames
   - Bitrate: 4.198 Kbs
 - [14:43:51] Reencoding: VID_00000, Pass 1 of 2
  - Encode failed.  Aborting.
- BD-Rebuilder v0.50.17
  - Working Path Free Space: 332,95GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - HAALI Splitter:  Isn't recommended version
  - FFDSHOW: 4515, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[14:54:52] Source:  MISTERIOS_DO_NILO_00000
  - Input BD size: 10,48 GB
  - Approximate total content: [00:47:38.814]
[14:54:53] PHASE ONE, Encoding
 - [14:54:53] Processing: VID_00000 (1 of 1)
 - [14:54:53] Extracting A/V streams [VID_00000]
 - [14:57:03] Reencoding video [VID_00000]
   - Rate/Length: 23,976fps, 68.543 frames
   - Bitrate: 11.466 Kbs
 - [14:57:03] Reencoding: VID_00000, Pass 1 of 2
  - Working Path Free Space: 334,63GB
  - FFDSHOW: 4515, Ok
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[Options]
VERSION=0.50.0.17
MOVIE_ONLY_LOOP=0
DOWNRESIZE=LanczosResize
HC_PROFILE=BEST
OUTPUT_FOLDER=E:\VIDEOS
REMOVE_WORKING=1
REMOVE_IMPORT=1
ALTCRF=18
MULTIPROCESS=3
ENCODER=0
MODE=3
ENCODE_QUALITY=3
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;por;
SUBS_TO_KEEP=por;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=1
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=4480
PRIORITY_CLASS=0
TARGET_SIZE=4480
MOVIEONLY_TYPE=0
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
[Paths]
WORKING_PATH=E:\BDREBUILDER_TEMP\
NeroAACPath=C:\Programas\Nero AAC Codec 1.5.4.0\win32\neroAacEnc.exe
SOURCE_PATH=D:\BLU_RAY\MISTERIOS DO NILO\
DGIndexNV=C:\Programas\DGDenNV 2051\DGIndexNV.exe
DGDecNV=C:\Programas\DGDenNV 2051\DGDecodeNV.dll
Old 21st July 2016, 02:10   #24506  |  Link
Lathe
Lathe's Avatar
Crap brain fart....
Now... was that an NTSC or a PAL Crap brain fart...???
Old 21st July 2016, 06:09   #24507  |  Link
MrVideo
MrVideo's Avatar
You know full well that posting had nothing to do with NTSC, or PAL.
Old 21st July 2016, 06:15   #24508  |  Link
MrVideo
MrVideo's Avatar
I realized that my avs script was for converting 576i to 480i, but recoding to H.264. I haven't done any MPEG-2 standalone encoding in ages.
But, you never answered my question about what technological abilities your friend has in playing digital videos. I find it hard to believe that he can't play 576i videos on something he has.
Old 21st July 2016, 15:27   #24509  |  Link
@Ch3vr0n and soneca
Can you possibly provide your INI file? I just ran a couple tests using DirectShowSource with MULTIPROCESS=2 on an AVC source -- and it works with no problem. I'm getting 2 instances of X264 and they are encoding properly.
[Edit] I've tried it with MULTIPROCESS=3 as well -- and it is encoding properly with 3 instances of X264.
@Ch3vr0n
How long is the source you are attempting? BD-RB won't run multiple processes if splitting would make the individual segments less than 5000 frames. So if you are splitting 3 ways, the source must be a minimum of 15,000 frames.
Old 21st July 2016, 16:22   #24510  |  Link
Ch3vr0n
@jdobbs Full discs only, every time.
[07/21/16] BD Rebuilder v0.50.17
[17:03:16] Source: THE_REVENANT
- Input BD size: 42,70 GB
- Approximate total content: [03:43:55.962]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
[17:03:16] PHASE ONE, Encoding
- [17:03:16] Processing: VID_00191 (1 of 3)
- [17:03:16] Extracting A/V streams [VID_00191]
- [17:03:24] Reencoding video [VID_00191]
- Rate/Length: 23,976fps, 1*432 frames
- Bitrate: 9*694 Kbs
- [17:03:24] Reencoding: VID_00191, Pass 1 of 1
- [17:03:37] Video Encode complete
- [17:03:37] Processing audio tracks
- [17:03:37] Multiplexing M2TS
- [17:03:42] Processing: VID_00200 (2 of 3)
- [17:03:42] Extracting A/V streams [VID_00200]
- [17:04:31] Reencoding video [VID_00200]
- Rate/Length: 23,976fps, 63*408 frames
- Bitrate: 7*452 Kbs
- [17:04:31] Reencoding: VID_00200, Pass 1 of 1
- [17:11:48] Video Encode complete
- [17:11:48] Processing audio tracks
- [17:11:48] Multiplexing M2TS
- [17:12:20] Processing: VID_00800 (3 of 3)
- [17:12:20] Extracting A/V streams [VID_00800]
- [17:17:51] Reencoding video [VID_00800]
- Rate/Length: 23,976fps, 224*928 frames
- Bitrate: 11*500 Kbs
- [17:17:51] Reencoding: VID_00800, Pass 1 of 1
[17:20:00]PHASE ONE aborted by user request
No multiprocess
[Options]
#video settings
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=0
OPEN_GOP=0
MOVIE_ONLY_LOOP=1
USE_FILTERS=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=1
SD_TO_1080=0
CONVERT_WIDE=0
MOVIEONLY_TYPE=19
ALTCRF=20
ALT_TARGET=2048
ALTMETHOD=2
ALTAUTOCROP=0
WIDE_PERCENT=40
WIDE_OFFSET=.85
RESIZE_1440=0
RESIZE_720=0
OUTPUT_3D=1
IGNORE_3D=0
NEROAAC=0
DGDECNV=1
USE_LAVF=0
#audio settings
AUDIO_TO_KEEP=dut;eng;nld;und;
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
FULL_AVCHD=0
#subtitle settings
SUBS_TO_KEEP=dut;eng;nld;und;
#output settings
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
REMOVE_IMPORT=1
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23450
PRIORITY_CLASS=1
TARGET_SIZE=23500
AUTO_BURN=2
QUICK_EXTRAS=0
#General Settings
ENABLE_TEST=1
ENABLE_BLANKING=1
BLANK_THRESHOLD=60
MULTIPROCESS=1
MINIMIZE_TO_TRAY=1
SHUTDOWN_REBOOT=1
IMPORT_FOLDER=C:\TEMP
VERBOSE_STATUS=1
BDMV_CERT_ONLY=1
AUTO_BLANK=0
UNMASK_CHAPTER=1
VERSION=0.50.0.15
COMPLETION_BEEP=1
BEEP_SOUNDFILE=C:\Program Files (x86)\ImgBurn\Sounds\Success.wav
SD_PROGRESSIVE=1
MKV_CHAPTERS=1
SUPTITLE=0
OUTPUT_SBS=0
MENU_BACKGROUND=C:\Program Files (x86)\BD_Rebuilder\misc\menuback.jpg
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_PLAY_SEQUENTIAL=1
MENU_START_WITH_MENU=1
OUTPUT_FOLDER=D:\Blu-ray\Rebuilds\BDRB\
FRIMSOURCE=0
ENCODER=0
DGDECIM=0
DECODER=3
AUDIO_DRC=1
ALT_CRF_TARGET=2048
PGSTOSRT=1
[Paths]
WORKING_PATH=C:\TEMP\
SOURCE_PATH=G:\
DGIndexNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\DGDecodeNV.dll
using only LAV filters and DSS
Old 21st July 2016, 16:46   #24511  |  Link
soneca
jdobbs, when I set multiprocessing (MULTIPROCESS=1) to 1 log shows 4.
Here is the .ini file.
[12:35:38] Source: MISTERIOS_DO_NILO_00000
- Target BD size: 4,36 GB
- Decoding/Frame serving: DirectShow [4-way]
[12:35:40] PHASE ONE, Encoding
- [12:35:40] Processing: VID_00000 (1 of 1)
- [12:35:40] Extracting A/V streams [VID_00000]
[12:36:08]PHASE ONE aborted by user request
Old 22nd July 2016, 00:54   #24512  |  Link
Lathe
Lathe's Avatar
Originally Posted by Ch3vr0n View Post
i'm loving this new rig. (atm non-overclocked) i7 6700k
1h 15 where on my Q9550 it could easily take 3-4h
Wow, that is fast!
If you don't mind my asking, and I don't mean this as a criticism at all, I'm just really curios. But. since you are taking a full Blu-ray at about 40 Gigs and compressing it almost in half using just the 'Good' ABR 1 pass setting, how does the resulting video quality look? Are you viewing it on a very large screen?
The reason why I am curious is because that film is HIGHLY visual and there is a lot of action. I guess I just can't imagine only using that fast and simple of a setting and compressing it that much that it would still look really good.
Do you mind just giving me your honest impressions of how the resulting encode looks?
Thanks!
Old 22nd July 2016, 01:47   #24513  |  Link
Ch3vr0n
I'm letting bdrb decide the best options for quality. So they're the same excellent quality as always, just in a lot less time. Viewing on standard 42'' hd TV flat screen.
Old 22nd July 2016, 02:04   #24514  |  Link
That's right. When you set it to 1, BD-RB chooses a count based upon your virtual (or actual) processors. Setting it to 0 (or deleting it) will disable multiprocessing (meaning you will use one instance). Setting it to any other number forces that many processes (instances).
Old 22nd July 2016, 02:14   #24515  |  Link
Ch3vr0n
Then why does my 6700k only do 1, doesn't seem right.
Old 22nd July 2016, 03:05   #24516  |  Link
Lathe
Lathe's Avatar
Thank you Ch3vr0n; that is what I THOUGHT you usually do, but you specified the 'Fast' option at one ABR pass, so I thought that you chose it deliberately.
So, you are seriously telling me that BDRB chose that fast of a speed and ONE pass when you were compressing a 40 Gig Blu-ray onto a BD-25...???
Seriously...?
Old 22nd July 2016, 03:11   #24517  |  Link
soneca
I did not know or remember that detail, had never set to 1.
Old 22nd July 2016, 03:22   #24518  |  Link
Ch3vr0n
Yup, I don't know exactly what makes bdrb decide the settings it decides, but it has never let me down. I didn't specify anything, I have it set to automatic. Bdrb does it's algorithm magic to decide the best quality. You also have to realize, if the original has 6 audio streams and I strip 4 away, there's less to compress so a less complicated algorithm can be used for the same quality.
Old 22nd July 2016, 06:41   #24519  |  Link
Sharc
@chevron:
I don't think that it really matters but I am just wondering about your thousands separators like , and * in your logfiles. Probably a matter of your local Windows settings.
Old 22nd July 2016, 07:29   #24520  |  Link
Lathe
Lathe's Avatar
Hmmm... quite interesting. I would have NEVER thought that BDRB would have chosen such a fast speed and only 1 pass for such an action packed, visually complex 40 Gig Blu-ray like that. I know that the encoding it chooses can be pretty liberal for my personal taste, but for this film I find that amazing!
Thanks Ch3vr0n!
