11th June 2017, 03:44 | #25981 | Link | |
Hell, I don't even think that Adobe Premiere allows field stepping. It never did when i was using it way back when. And what makes you think that you do not have misconceptions? |
11th June 2017, 05:01 | #25982 | Link |
Then why point to it again?
I decided to use IVTC_1080i=1 because I wanted to confirm something for myself. Weird stuff and all that is possible. I disabled all SUP. This is what happened. Code:
[06/10/17] BD Rebuilder v0.50.23 [16:12:38] Source: MONTY_PYTHON_D2 - Input BD size: 42.62 GB - Approximate total content: [04:05:23.675] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [16:12:40] PHASE ONE, Encoding - [16:12:40] Processing: VID_00000 (1 of 39) - [16:12:40] Extracting A/V streams [VID_00000] - [16:14:56] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 97,163 frames - Inverse Telecining in effect (IVTC) - Bitrate: 11,287 Kbs - [16:14:56] Reencoding: VID_00000, Pass 1 of 2 - [16:14:56] Reencoding: VID_00000, Pass 2 of 2 - [16:48:26] Video Encode complete - [16:48:26] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Keeping original audio - [16:48:31] Multiplexing M2TS - [16:49:39] Processing: VID_00001 (2 of 39) - [16:49:39] Extracting A/V streams [VID_00001] - [16:52:05] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 90,158 frames - Inverse Telecining in effect (IVTC) - Bitrate: 11,302 Kbs - [16:52:05] Reencoding: VID_00001, Pass 1 of 2 - [16:52:05] Reencoding: VID_00001, Pass 2 of 2 - [17:21:13] Video Encode complete - [17:21:13] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Keeping original audio - [17:21:19] Multiplexing M2TS [...] - [19:09:50] Processing: VID_00083 (39 of 39) - [19:09:50] Extracting A/V streams [VID_00083] - [19:09:55] Reencoding video [VID_00083] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 98 frames - Inverse Telecining in effect (IVTC) - Bitrate: 1,895 Kbs - [19:09:55] Reencoding: VID_00083, Pass 1 of 2 - [19:09:55] Reencoding: VID_00083, Pass 2 of 2 - [19:09:58] Video Encode complete - [19:09:58] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - [19:09:58] Multiplexing M2TS [19:10:02]PHASE ONE complete [19:10:02]PHASE TWO - Rebuild Started - [19:10:02] Rebuilding BD file Structure [19:10:05] - Encode and Rebuild complete [19:10:05] JOB: MONTY_PYTHON_D2 finished. Code:
[06/10/17] BD Rebuilder v0.50.23 [20:23:17] Source: MONTY_PYTHON_D2 - Input BD size: 42.62 GB - Approximate total content: [04:05:23.675] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - MOVIE and MENUS mode enabled - Quality: High-Speed Option (BD-25+), Two Pass - Decoding/Frame serving: DGDecNV [3-way] - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [20:23:19] PHASE ONE, Encoding - [20:23:19] Processing: VID_00000 (1 of 39) - [20:23:19] Extracting A/V streams [VID_00000] - [20:25:35] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 97,163 frames - Inverse Telecining in effect (IVTC) - Bitrate: 11,287 Kbs - [20:25:35] Reencoding: VID_00000, Pass 1 of 2 - [20:25:36] Reencoding: VID_00000, Pass 2 of 2 - [20:58:59] Video Encode complete - [20:58:59] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (eng): Keeping original audio - [20:59:05] Multiplexing M2TS - [20:59:05] CreateBDFiles() 00063 2004 [20:59:23]PHASE ONE aborted by user request
11th June 2017, 08:40 | #25983 | Link | |
Anyway, I understand when you run BD RB with its default settings all is ok, right? As a sidenote, if the BBC original was produced as 25i there is actually no need to convert it to 29.97i because 25i is perfectly blu-ray compliant even when upscaled to 1080i. So I wonder how the movie "benefited" from this unnecessary framerate conversion. But apparently the industry still locks some blu-ray players from playing 25 fps material. Oh well ..... |
11th June 2017, 11:14 | #25985 | Link |
Just to mention shekh's VirtualDub FilterMod based on 1.10.5 with some very useful extensions, e.g. wrt. video formats
https://sourceforge.net/projects/vdfiltermod/ |
11th June 2017, 12:41 | #25986 | Link | |
TFM() Code:
telecide() Code:
DGTelecide() Last edited by Sharc; 11th June 2017 at 12:53. |
11th June 2017, 15:47 | #25987 | Link | |
I do not know of any Blu-ray players that are locked from playing 25 fps material. That said, I've not researched it either. I buy Samsung players. There are some monitors that do not, so that can cause an issue. But, pretty much anything these days will handle 25 fps material. That still doesn't stop the companies that release material that was originally 25 fps as 29.97 fps for the U.S. That is why I buy the U.K. releases so that I can keep the original frame rate. |
11th June 2017, 16:01 | #25989 | Link |
Thanks, I've downloaded it. I hoping it can deal with H.264/4.2.2 video. CBS/CW network is now in the process of changing over their network feeds from MPEG2/4.2.2 to H.264/4.2.2. I can view the video with VLC, but can't currently edit and convert to H.264/4.2.0.
11th June 2017, 16:19 | #25991 | Link | ||
Useful n00b
11th June 2017, 19:58 | #25995 | Link | ||
This means the satellite transmission from NY to the affiliates. I receive those feeds on my 12' BUD. Yes, it has a limited scope of users. Quote:
