29th January 2021, 00:28 | #30370 | Link | |
If, however, you actually are getting 3840x2170, something is causing a resize -- and I'd need a lot more information in order to see what is happening. Last edited by jdobbs; 29th January 2021 at 00:31. |
30th January 2021, 17:57 | #30371 | Link | |
Banned
3840x2160
31st January 2021, 00:43 | #30374 | Link |
Elit Amans
Well, nothing wrong with that then. According to this thread it was solved with an system update of the Xbox.
If you want to look at the nVidia forum discussion it can be found here. Bottom line it is within specs and it is up to the decoder to show it properly on screen. There is no way around this with hardware encoding at the moment, as far as I know. //LD
Windows 11 Pro 64-bit, AMD Ryzen 9 5950X@3.40GHz, 32GB, NVIDIA RTX 2070 8GB, PIONEER BDR-S09XLT, ASUS BW-16D1HT, LG CX 65", Panasonic DP-UB820EB-K, Sony PS3 & PS5 |
1st February 2021, 18:20 | #30376 | Link | |
Banned
I want to thank you for the advice. I did the last update xbox one s green band still on image Anyway thanks to all very good forum Last edited by play12; 1st February 2021 at 18:22. |
3rd February 2021, 18:47 | #30377 | Link |
I've run into a weird issue converting UHD discs to BD25. I noticed after burning to disc that the disc wasn't full. So, I ran it again. I noticed this on a couple of other discs, but ignored it. Now I'll have to go back, but until there is a cure, rerunning the job won't accomplish anything.
The problem is that on this disc, two of the M2TS files are short: Code:
Frames/Is Length/Should Be Length 83198 - 18:30 - 57.83 83703 - 22:12 - 58:18 81013 - 56:21 - 56.32 Code:
[05:37:46] PHASE ONE, Encoding - [05:37:46] Processing: VID_00044 (1 of 3) - [05:37:46] Extracting A/V streams [VID_00044] - [05:41:22] Reencoding video [VID_00044] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 83,198 frames - Bitrate: 12,328 Kbs - [05:41:22] Reencoding: VID_00044, Pass 1 of 1 - [05:49:46] Video Encode complete - [05:49:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [05:49:46] Multiplexing M2TS - [05:50:54] Processing: VID_00045 (2 of 3) - [05:50:54] Extracting A/V streams [VID_00045] - [05:54:36] Reencoding video [VID_00045] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 83,703 frames - Bitrate: 11,190 Kbs - [05:54:36] Reencoding: VID_00045, Pass 1 of 1 - [06:10:59] Video Encode complete - [06:10:59] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4364 (eng): Keeping original audio - [06:10:59] Multiplexing M2TS - [06:12:14] Processing: VID_00046 (3 of 3) - [06:12:14] Extracting A/V streams [VID_00046] - [06:17:30] Reencoding video [VID_00046] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 81,018 frames - Bitrate: 3,682 Kbs - [06:17:30] Reencoding: VID_00046, Pass 1 of 1 - [06:35:13] Video Encode complete - [06:35:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - [06:35:13] Multiplexing M2TS [06:37:30]PHASE ONE complete I think I just made a boatload of coasters. Looking at disc 1 of the four discs, the three episodes on that disc last about 8 seconds, yet the log shows nothing wrong. I had the workfiles removed after the job completed. I'm rerunning the above disc, keeping the workfiles. |
3rd February 2021, 22:07 | #30378 | Link |
OK, the video workfiles end up having the same time length. This is a TV show with HDR. Three episodes.
I had to leave for a while, so I haven't checked all of the discs for all of the seasons. I did check a movie, HDR, and it was the correct length. |
4th February 2021, 14:48 | #30380 | Link | |
Any more info you can give, that might help pinpoint it, would be appreciated. Was the source from a BD, or were the episodes imported? If imported, is the episode the correct length in the PSEUDO structure? The bitrates shown are certainly suspicious. Two of the episodes are above 11Mbs, and the third one is only 3.6Mbs. That would lead one to believe that the original file for the third one was very small (bitrates are calculated based upon keeping the output size proportional to the input size as a percentage of the target). Last edited by jdobbs; 4th February 2021 at 15:13. |
