1st July 2010, 14:29 | #8163 | Link |
Audio Delay Determination...
Hi Atak, thank you so much for this wonderful app!
I got a question though: It appears that +/- keys are disabled in the preview mode, is there a way to enable them so i can detect the amount of audio delay much easier? If it's not possible it'll be much appreciated if you could enable this feature. Thank you in advance for your assistance and have a great time! Last edited by Algamish; 1st July 2010 at 15:40. |
4th July 2010, 19:43 | #8166 | Link |
Quick question, I have a Blu Ray disc of a TV show (6 episodes on the disc). When ripbot analyzes the the disc it shows me three playlists. The 1st playlist is of the entire 6 episodes grouped together. The 2nd and 3rd playlist are of Episode #1 and #2. Any idea why a playlist is not showing for episode #3-6?
EDIT: OK, did a little more digging, I am wondering if it is a bug with eac3to? Using Clown_BD I only see the three playlists as well, but if I use MakeMKV I can see all 7 playlists (1 master playlist and 6 episode playlists). The other option I was thinking was to use MakeMKV to get an mkv of each episode, and then run the episode mkv through Ripbot
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
4th July 2010, 21:44 | #8167 | Link |
@dbone1026
send sample to author
6th July 2010, 05:56 | #8168 | Link |
Hi Atak,
I've got one movie can't demuxed completly, i have no audio on the project available for enconding. Code:
Général Nom complet : D:\Les 3 Royaumes.Partie.1.1080p.mkv Format : Matroska Taille du fichier : 17,4 Gio Durée : 2h 25mn Débit global moyen : 17,2 Mb/s Nom du film : Les.3.Royaumes.Partie.1.1080p Date d'encodage : UTC 2010-05-13 10:33:03 Application utilisée : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24 Bibliothèque utilisée : libebml v0.8.0 + libmatroska v0.9.0 Couverture : Yes Vidéo ID : 1 Format : AVC Format/Info : Advanced Video Codec Profil du format : High@L4.1 Paramètres du format, CABAC : Oui Paramètres du format, RefFrames : 4 images Type de muxing : Container profile=Unknown@4.1 Identifiant du codec : V_MPEG4/ISO/AVC Durée : 2h 25mn Débit : 13,8 Mb/s Largeur : 1 920 pixels Hauteur : 1 080 pixels Format à l'écran : 16/9 Images par seconde : 24,000 Im/s Résolution : 8 bits Colorimétrie : 4:2:0 Type d'image : Progressif Bits/(Pixel*Image) : 0.277 Taille du flux : 14,0 Gio (80%) Bibliothèque utilisée : x264 core 94 r1542M 5b86182 Paramètres d'encodage : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / open_gop=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=80 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / crf-max=0.0 / ip_ratio=1.40 / aq=1:0.70 / nal_hrd=none Langue : Anglais Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Identifiant du codec : A_DTS Durée : 2h 25mn Type de débit : Constant Débit : 1 510 Kbps Canaux : 6 canaux Position des cannaux : Front: L C R, Side: L R, LFE Echantillonnage : 48,0 KHz Résolution : 24 bits Delai par rapport Vidéo : 157ms Taille du flux : 1,53 Gio (9%) Titre : Gaulois DTS_5.1@1536Kbps Langue : Français Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Identifiant du codec : A_DTS Durée : 2h 25mn Type de débit : Constant Débit : 1 510 Kbps Canaux : 6 canaux Position des cannaux : Front: L C R, Side: L R, LFE Echantillonnage : 48,0 KHz Résolution : 24 bits Taille du flux : 1,53 Gio (9%) Titre : Chinois DTS_5.1@1536Kbps Langue : Chinois Texte #1 ID : 4 Format : UTF-8 Identifiant du codec : S_TEXT/UTF8 Identifiant du codec/Info : UTF-8 Plain Text Titre : SRT Français Forcés Langue : Français Texte #2 ID : 5 Format : UTF-8 Identifiant du codec : S_TEXT/UTF8 Identifiant du codec/Info : UTF-8 Plain Text Titre : SRT Français Langue : Français Menu 00:00:00.000 : en: 00:02:46.792 : en: 00:13:40.167 : en: 00:23:41.208 : en: 00:32:14.000 : en: 00:43:44.042 : en: 00:53:45.833 : en: 01:03:46.458 : en: 01:13:23.333 : en: 01:23:29.875 : en: 01:32:59.917 : en: 01:43:10.625 : en: 01:53:54.542 : en: 02:06:24.875 : en: 02:18:13.625 : en: http://www.mediafire.com/?dm2zdtqy0zv Thanks!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
6th July 2010, 17:24 | #8170 | Link | |
7th July 2010, 03:03 | #8171 | Link |
You've tested with the sample, i dont know why its works manually with tsmuxer GUi and not the command line.
Here some log informations: chapters.txt; Code:
(mkvextract) The file 'D:\--= Complete =--\Les 3 Royaumes.Edition.Integrale.OpenMatte.1080p.BluRay\Les 3 Royaumes.Partie.1.1080p.BluRay.Multi.mkv' could not be opened for reading (No error). Code:
"C:\Ripbot264\Tools\mkvtoolnix\mkvextract.exe" tracks "D:\--= Complete =--\Les 3 Royaumes.Edition.Integrale.OpenMatte.1080p.BluRay\Les 3 Royaumes.Partie.1.1080p.BluRay.Multi.mkv' " 2:"E:\Temp\RipBot264temp\job1\2_audio_French.dts" 3:"E:\Temp\RipBot264temp\job1\3_audio_Undetermined.dts" 4:"E:\Temp\RipBot264temp\job1\4_subtitles_French.srt" 5:"E:\Temp\RipBot264temp\job1\5_subtitles_French.srt" "C:\Ripbot264\Tools\mkvtoolnix\mkvextract.exe" chapters "D:\--= Complete =--\Les 3 Royaumes.Edition.Integrale.OpenMatte.1080p.BluRay\Les 3 Royaumes.Partie.1.1080p.BluRay.Multi.mkv' " -s > "E:\Temp\RipBot264temp\job1\chapters.txt"
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 7th July 2010 at 03:06. |
7th July 2010, 17:23 | #8174 | Link | |
Rename your folder from "D:\--= Complete =--\" to "D:\Complete\" and it will work! Last edited by stasi; 7th July 2010 at 17:34. |
8th July 2010, 02:13 | #8175 | Link |
Atak,
Just ran into a problem with a new Blu-ray rip(Girl with the dragon tattoo). No video or audio found. http://www.mediafire.com/?mgyzza4mmzw Thanks |
8th July 2010, 06:14 | #8178 | Link |
Just out of curiosity I tried the sample I uploaded and it worked just fine. If I pull the main m2ts file out of the stream folder everything is detected, but of course it doesn't have a playlist. It may be a bad rip, so I'm doing it again.
8th July 2010, 09:18 | #8180 | Link |
@prettyboy85712
make sure that you don't have any national characters in path! for example: c:\BD-RIP\ąćźńółż\
