24th December 2011, 12:38 | #10361 | Link |
are you trying to load something what does not exist? next two lines will also give an error message.
27th December 2011, 17:40 | #10363 | Link |
Carlos Martinez
Please forgive my question, if it's already a known issue.
I just installed RipBot264, and when I run it claims to need having Ffdshow 32 bit installed. AFAIK it is installed (I just checked my directory), so why is it not seeing it? How should I proceed? Last edited by carlmart; 27th December 2011 at 18:18. |
29th December 2011, 14:52 | #10366 | Link |
Does anyone have a small guide how I can use the InterFrame script inside ripbot? I want encode my 25fps video to 50 fps...
I have downloaded and put the files under RipBot264v1.16.5\Tools\AviSynth plugins\InterFrame\ |
29th December 2011, 20:12 | #10367 | Link |
@Hobbe
Is very easy to CUT frames but it is impossible put in place or to increase frames after their cutting Anyway try this: http://www.spirton.com/interframe/ and http://www.spirton.com/convert-videos-to-60fps/ I didn't try it , but I presume it is smth forced or faked... |
30th December 2011, 08:49 | #10368 | Link |
@benjyv
Thats the avisynth script i'm trying to use. I paste this line in ripbot: InterFrame(FlowPath="C:\Bin\RipBot264v1.16.5\Tools\AviSynth plugins\InterFrame") All Interframe dll's are in that folder... When I try to preview the script it just say: Script error: there is no function named "Interframe" |
30th December 2011, 11:01 | #10369 | Link |
Pasar 1920x1080-25p a 1920x1080-50i
Muchas Gracias por este maravilloso programa, llevo 2 años utilizándolo y es de lo mejor que he encontrado, aunque lo normal es hacer lo contrario yo necesito pasar un video de 1920x1080-25p a 1920x1080-50i, sin que este ultimo no sea un falso entrelazado, necesito vuestra ayuda, gracias.
30th December 2011, 12:17 | #10370 | Link |
no hablo espanol amigo.
31st December 2011, 04:12 | #10371 | Link | |
31st December 2011, 04:15 | #10372 | Link |
eac3to v3.24
command line: "C:\Users\Zenophobe\Downloads\RipBot264v1.16.5\Tools\eac3to\eac3to.exe" "F:\" 1) 2: "D:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "D:\temp\RipBot264temp\job1\audio_English.thd.w64" -down16 1: "D:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="D:\temp\RipBot264temp\job1\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 1 audio track, 1:20:38, 24p /1.001 1: Chapters, 13 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 7.1 channels, 48kHz (embedded: AC3, 5.1 channels, 640kbps, 48kHz) Creating file "D:\temp\RipBot264temp\job1\chapters.txt"... [v02] Extracting video track number 2... [v02] Muxing video to Matroska... [a03] Extracting audio track number 3... [a03] Extracting TrueHD stream... [a03] Decoding with libav/ffmpeg... [a03] Remapping channels... [a03] Reducing depth from 24 to 16 bits... [a03] Writing W64... [a03] The libav decoder reported error -1 while decoding. <ERROR> i don't know where to begin.. I've re-installed 3 times now... I have an 120GB SSD as my OS drive and some programs.. the ripbot264 is running off of this drive as well as all add-ons are installed on this drive.. I have a 500GB second HDD that i store larger files and programs on.. Is this an issue? PC Specs: Windows 7 Ultimate 64bit Intel i7-980 OC 4.26GHz nVidia GTX 580 3GB 24GB DDR3 1600MHZ Ram OCZ Vertex 3 120GB 500GB RAID 0 HDD CoolerMaster HAF-X Case EVGA Classified 3 MB ABS 1050 PSU Last edited by Zenophobe; 31st December 2011 at 04:26. Reason: added info |
1st January 2012, 23:47 | #10374 | Link |
French Love
Hi Atak and good work,
Ripbot264 v1.17.0 request ffdshow 32 rev4200 and last available version is rev3984_20110922_clsid.exe (4.6 MB) Thank's
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial Demo for MVC Player Free: Trailer 3D 3DBD's Free - v0.0.0.0005.exe Old Programing free for all. |
2nd January 2012, 05:01 | #10376 | Link |
I'm really excited about the distributed encoding capabilities of this new version, what a great idea! I've been trying to get it working with no luck. I've watched the tutorial and edited the INI properly but ripbot won't start the client portion when I click start. It loads the server when run but encodes the blu-ray as usual in its own window. I am on a domain so I've shared the temp folder (D:\Temp\RipBot264temp in my case) but don't have the security option to check under network settings as in the video. Any help would be appreciated!
Here is my ini: [settings] // TEMP=uses System temp ; C , D ... uses specific partition StoreTempFilesin=D KeepJobsQueue=1 --------------------- DefaultProfile=[HIGH 4.0] HD . Progressive DefaultEncodingMode=CQ DefaultModeValue=18 --------------------- //Directory must exists!!! D:\movies\ is correct but D:\movies is incorrect! DefaultOutputPath=D:\DVD\ --------------------- // allowed values are mp4 , mkv , bluray , mkv-divxhd DefaultContainer=mp4 --------------------- // in GiB (1GiB=1024 MiB) , 0 = no splitting SplitM2TS=0 --------------------- FastFirstPassin2passMode=1 --------------------- //AnyDVD DVD/HD-DVD/Blu-Ray decryptor will be automatically activated with RipBot264 ExecuteAnyDVD=0 --------------------- //Blu-ray subtitles will be converted to SUB/IDX format for .mkv container. Smaller size and better compatibility with some players. ConvertSUPtoSUB=1 --------------------- x264LowPriority=1 --------------------- // it will use 64bit version of x264 on 64bit Windows. up to 10% faster encoding speed. Usex264x64=1 --------------------- // Only for DVD / HD-DVD / BD sources! UseDistributedEncoding=1 |
2nd January 2012, 05:35 | #10377 | Link |
Ok, got a little further. It now starts the encoding client and connects to both the localhost and a remote server I have set up. Unfortunately both of them flip back and forth between encoding and idle. The status flips back and forth between Starting... and Queue (about twice a second). If I open the server it flashes Encoding Terminated... over and over...
2nd January 2012, 06:33 | #10378 | Link |
The Black Reaper
Distributed encoding looks awesome but I don't think I should bother trying it with my 2600k desktop with my c2d laptop, doubt the speed difference will be significant.
Pretty excited about the batch feature, it's what everyone has been waiting for. Shall try it out when I have the time. |
2nd January 2012, 14:58 | #10380 | Link | |
Thanks for the new version
