1st February 2020, 01:07 | #18322 | Link | |
Grumpy Old Man.
But, alas, I can't find any actual scripts... I have MD1, MD2, MD3 & MD4, in Custom Filters, with different thSAD numbers. I got great results using MD3 thSAD 800 on "The Fifth Element". I have several other older movies that will need to same treatment, it takes a long time, that's for sure, but the end result is definitely worth waiting for.
1st February 2020, 12:03 | #18323 | Link |
CLI options to add job...
Atak, would it be possible that you add the possibility of adding a job in command line mode, of the style: ripbot264.exe <FileIn>
this would generate a job in the working folder of RipBot264 that would go well with the '/ start' option existing since v1.17.1 |
1st February 2020, 12:50 | #18324 | Link | |
1st February 2020, 13:31 | #18325 | Link | |
that would save me from having to manipulate RipBot264 windows |
1st February 2020, 16:19 | #18326 | Link | |
ByteShare
Sure, here is a pretty reasonable starting point IMO:
SMDegrain(video,tr=3,thSAD=400,thSADC=150,refinemotion=false,contrasharp=true,plane=4,pel=2, prefilter=4,Truemotion=False,chroma=true,hpad=32,vpad=32,str=2,amp=1) More info here: http://avisynth.nl/index.php/SMDegrain Parameters Code:
SMDegrain (clip input, int "tr", int "thSAD", int "thSADC", bool "RefineMotion", val "contrasharp", clip "CClip", bool "interlaced", int "plane", int "Globals", int "pel", int "subpixel", val "prefilter", clip "mfilter", int "blksize", int "overlap", int "search", bool "truemotion", int "limit", int "limitc", int "thSCD1", int "thSCD2", bool "chroma", int "hpad", int "vpad", bool "lsb", bool "lsb_in", bool "lsb_out", int "mode", val "Show", float "Str", float "Amp") Quote:
If there was a way to have more than one folder watched or something in the filename to dictate which settings to use that would be great, because I don't want the same settings for all of my files. I can understand those that do want the same settings for all of their videos or if the vast majority of the files they are processing are going to use the same settings...I'm just not one of those, and even when ~80% of my videos are one setting it doesn't seem like much of a stretch for me to just add those last manually in batch. |
1st February 2020, 16:37 | #18327 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 1st February 2020 at 18:14. |
1st February 2020, 18:44 | #18328 | Link | |
and then the rest Code:
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
1st February 2020, 21:10 | #18329 | Link | |
ByteShare
OH!? I never tried to add a second folder. My fault for assuming.
Loadplugin("*path*.dll") Import("*path*.avsi/avi") Code:
Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\DCTFilter.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\Deblock.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\Deblockx64.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\dfttest.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\dither.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\FrameRateConverterx64.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\MedianBlur2.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Custom\SmoothAdjust.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\DGTonemap\x64\DGTonemap.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\ffms\x64\ffms2.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\flash3kyuu_deband\flash3kyuu_deband.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\hqdn3d\hqdn3d.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\masktools\masktools2.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\mvtools\mvtools2.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\NicAudio\NicAudio.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\nnedi3\nnedi3.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Plugins_JPSDR\Plugins_JPSDR.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\RawSourcePlus\RawSourcePlus.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\RgTools\RgTools.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\TIVTC\TIVTC.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\VSFilter\VSFilter.dll") LoadPlugin("C:\RipBot\Tools\AviSynth plugins\KNLMeansCL\KNLMeansCL.dll") Loadplugin("C:\RipBot\Tools\AviSynth plugins\Yadif\yadif.dll") Import("C:\RipBot\Tools\AviSynth plugins\ffms\FFMS2.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\Deblock_QED_MT2Mod.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\dither.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\FrameRateConverter.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\HQDeringmod_v1.8.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\LSFmod.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\proToon.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Custom\SeeSaw.avs") Import("C:\RipBot\Tools\AviSynth plugins\Custom\SMDegrain.avsi") Import("C:\RipBot\Tools\AviSynth plugins\Scripts\QTGMC.avs") video=SMDegrain(video,tr=3,thSAD=400,thSADC=150,refinemotion=false,contrasharp=true,plane=4,pel=2,prefilter=4,Truemotion=False,chroma=true,hpad=32,vpad=32,str=2,amp=1) |
2nd February 2020, 14:11 | #18330 | Link | |
too much complex ? |
6th February 2020, 17:10 | #18331 | Link | |
ByteShare
Please wait... Combining chunks...
At the end of a job things got stuck:
I'm on core 2020.01.17 (v1.25.1) I stopped the job and started it, and all of the chunks had to start over? Encoding it again, will be ~12hrs until I get another result. |
7th February 2020, 02:41 | #18332 | Link |
Yeah I had similar occur on a few occasions now. I'm on v1.25.1. The chunks get combined to make video.264 but encoding client doesn't close and muxing can't start. I just end up running the mux.cmd to finish the job. I tried to just close encoding client but sometimes it's no longer in the processes list of taskmanager so I usually just terminate Ripbot264.
7th February 2020, 09:07 | #18333 | Link | |
Run CombineAllChunks.cmd and then run jobX_MuxFiles.cmd Open the program, remove the job and continue
7th February 2020, 22:14 | #18335 | Link | |
Then go to #18333
8th February 2020, 01:02 | #18336 | Link |
ByteShare
I've done this before. I didn't expect the temp encoded chunks to get restarted when I aborted and started again, that was the main issue to me. I thought (incorrectly) that I would stop it and then RB would see all of the chunks are done so it would try to mux again
9th February 2020, 01:36 | #18337 | Link |
Grumpy Old Man.
Another "sneaky" auto-update..
Hey guys,
A reasonably significant auto update... Core 2020-02-08 ffmpeg lsmash matroska splitter (new, but not really) mkvtoolnix mpc
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 10th February 2020 at 00:31. |
9th February 2020, 14:07 | #18338 | Link |
I just updated to new core, 02-08, Using distributed encode, after every encode finishes, but before the encoding client exits.... it hangs. Chunks don't combine back and when I try to "Abort" nothing happens. I have to kill encoding client using task manager again. Then manually combine chunks and mux files using cmds in temp folder.
9th February 2020, 14:20 | #18339 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 9th February 2020 at 14:55. |
10th February 2020, 00:31 | #18340 | Link |
So I've done more testing today and the hangings seem to be cause by the servers going to sleep. I've noticed this because as soon as there's no more chunks to encode, the chunkless servers are being put to sleep, causing the hang in EncodingClient. If none of them go to sleep (of the 10 servers) then everything works fine. Is there something in rip bot putting servers to sleep? I know 100% all servers are set to not sleep in windows settings.
