Old 14th November 2009, 02:32   #41  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Flash is a broken piece of crap. This is somehow news?
Old 14th November 2009, 02:33   #42  |  Link
CruNcher
CruNcher's Avatar
CpT your site doesn't seem to work with firefox 3.7a1 ? i see only a white screen with no video playing strange
The Problems don't occur with the 50 second here but already start @ the 6 second and appear some frame then some frame are clear and then you see them (black blocks) again totally unwatchable Mobile this way
PS: I hope TI is gonna fix this weightp problem in their current CX64+ DSP Decoder fast, and i wonder if current Tegra has also issues with it (Zune HD, Samsung YP-M1)
It is about Time
Old 14th November 2009, 02:41   #43  |  Link
CpT
/signed! Its a royal pain that's for sure.
@Cruncher
Sound like that version of ff is borked. I don't test with/for pre-release or beta versions of anything. By the time it comes out the whole thing will have been rewritten 100 times over. And tbh I don't give a crap about Mobile viewing.
Sorry for getting OT.
CpT is offline   Reply With Quote
Old 14th November 2009, 09:32   #44  |  Link
Astrophizz
You said it works perfectly with flash and now you say the fact that it doesn't work isn't news? So you changed your stance?
Astrophizz is offline   Reply With Quote
Old 14th November 2009, 09:41   #45  |  Link
jmartinr
jmartinr's Avatar
@CpT
This one: http://vizmu.com/movie-trailers/812/129863/ shows corruption too at 1:10.
Roelofs Coaching
jmartinr is offline   Reply With Quote
Old 14th November 2009, 10:06   #46  |  Link
CpT
@jmartinr
Yea I'm sure there's quite a few. I ran a bunch of tests but checked emm all in vlc. -apparently was a mistake on my part.
I'm re-encoding that one as I type this. When I get a chance I'll search for more. Thanks for finding it.
Old 14th November 2009, 10:21   #47  |  Link
Dark Shikari
x264 developer
"Changed my stance"? What, is this a political issue or something?
I saw evidence that it was broken and concluded that it was broken. What else is there to it?
Old 14th November 2009, 11:18   #48  |  Link
Astrophizz
I worded that wrong, sorry. I just thought it was odd that your first time you said that flash had problems with weightp you said it as though it wasn't anything new.
Old 14th November 2009, 11:32   #49  |  Link
Dark Shikari
x264 developer
Flash having problems period isn't anything new
Old 14th November 2009, 11:33   #50  |  Link
Astrophizz
True
Old 14th November 2009, 13:00   #51  |  Link
CruNcher
CruNcher's Avatar
But it's not only flash Mainconcepts Decoder that is affected here. ON which Hardware STB solutions did you evaluated it, is there a list of Chips that are working ?
It is about Time
Old 14th November 2009, 13:01   #52  |  Link
plonk420
amd & h.264 fanboy
plonk420's Avatar
just wanted to report --weightp 2 works on PS3 (like 10 refs)
plonk420 is offline   Reply With Quote
Old 14th November 2009, 13:02   #53  |  Link
Dark Shikari
x264 developer
How about a list of chips that are not working?
The likelihood of a hardware decoder failing to abide by the specification is rather low given the relative thoroughness that ASIC developers give to following the specification.
Old 14th November 2009, 13:05   #54  |  Link
CruNcher
CruNcher's Avatar
Ok so in case of TIs Omap 3440 Decoder currently used on their DSP it's a Software Implementation bug, i wonder if it's also failing on the new Motorala Droid i guess it uses the same Decoder Core from TI or one of TI's partner my guess somehow is the Decoder is Inginients one
It is about Time
Old 14th November 2009, 20:22   #55  |  Link
Dark Shikari
x264 developer
IIRC the iPhone 3GS uses the OMAP and it decodes things just fine.
Old 14th November 2009, 21:37   #56  |  Link
CruNcher
CruNcher's Avatar
Nope it uses Samsung S5PC100 Chip (though also Cortex A8 based) and their Decoder Research as seen here http://www.youtube.com/watch?v=tSrsGPgIsEQ and here http://www.youtube.com/watch?v=zEWrV8LuX04
Hopefully we gonna see CoreCodecs own implementation running on the A8 or even better on the A8 + on the CX64+ beagleboard way
It is about Time
Old 15th November 2009, 21:52   #57  |  Link
Dark Shikari
x264 developer
It turns out that at least one of the problematic streams (not the "2012" trailer though) contained invalid offsets due to at least one, if not two, bugs in weightp's analysis. This means that most of the problematic decoders probably work just fine.
A fix will be incoming as soon as I can get a hold of Dylan.
Old 15th November 2009, 21:58   #58  |  Link
Chengbin
So after this fix the problematic decoders, like CoreAVC 1.9.5 and Archos PMPs, can play streams with weightp 2 without problems?
Chengbin is offline   Reply With Quote
Old 15th November 2009, 22:00   #59  |  Link
Dark Shikari
x264 developer
Not all, just some. Flash and CoreAVC 1.9.5 are still broken.
Old 15th November 2009, 22:03   #60  |  Link
poisondeathray
Has Adobe been notified RE: flash and recent x264 changes?
Lots of websites use x264 e.g. vimeo, youtube etc... , maybe not the most recent builds, but it could cause issues soon...
artifacts, coreavc, corruption, weightp
