20th July 2010, 05:09 | #8861 | Link | |
20th July 2010, 15:12 | #8862 | Link |
Hello everyone. I seem to be having trouble backing up Hot Tub Time Machine. It contains a theatrical and unrated version, so uses seamless branching. The movie will play fine to start, but begins to have problems when it reaches a point where the branching is supposed to take place. Playback will freeze up for about a minute and jerk through before finally moving on and playing fine again until it reaches the next branch point.
I have tried 3 different backups (full disc, move only, and full disc again) but with the same problem on each. I have also tried to re-rip (AnyDVDHD) and process again before the last burn but same thing happens. Am I doing something wrong or is there something I'm not doing? Or is it a bug? Anyone else successfully backup this movie? Thanks for the help. Code:
Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: *Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: *Ok - WIN7 preferred VC-1 CODEC: *Ok - WIN7 preferred MPEG2 CODEC: *Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": *Ok - FFDSHOW AVC set to "libavcodec": *Ok - BD Rebuilder v0.34.0.5, Ok - X264: *Ok - AFTEN: *Ok - FAAC: *Ok - MP4BOX: *Ok - WAVI: *Ok - TSMUXER: *Ok [Status] LABEL=HOT_TUB_TIME_MACHINE VERSION=v0.34.05 (beta) SOURCE_SIZE=37026419461 SOURCE_VIDEO_SIZE=36543909888 TARGET_SIZE=24326963200 REDUCTION=.652487752407409 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=40 REBUILD_COMPLETE=1 [00990] AUDIO=1 PGS= M2TS_TARGET=7203966 NSIZE=749568 FLINK=0 MLINK=0 [00918] AUDIO=1 PGS= M2TS_TARGET=43764995 NSIZE=19943424 FLINK=0 MLINK=0 [00914] AUDIO=1 PGS= M2TS_TARGET=65621434 NSIZE=30738432 FLINK=0 MLINK=0 [00926] AUDIO=1 PGS= M2TS_TARGET=77070809 NSIZE=53164032 FLINK=0 MLINK=0 [00913] AUDIO=1 PGS= M2TS_TARGET=81127801 NSIZE=77752320 FLINK=0 MLINK=0 [00916] AUDIO=1 PGS= M2TS_TARGET=117263888 NSIZE=66539520 FLINK=0 MLINK=0 [00919] AUDIO=1 PGS= M2TS_TARGET=121617537 NSIZE=82280448 FLINK=0 MLINK=0 [00920] AUDIO=1 PGS= M2TS_TARGET=128312374 NSIZE=86403072 FLINK=0 MLINK=0 [00915] AUDIO=1 PGS= M2TS_TARGET=138527013 NSIZE=92547072 FLINK=0 MLINK=0 [00924] AUDIO=1 PGS= M2TS_TARGET=144893122 NSIZE=116748288 FLINK=0 MLINK=0 [00923] AUDIO=1 PGS= M2TS_TARGET=147707359 NSIZE=148531200 FLINK=0 MLINK=0 [00921] AUDIO=1 PGS= M2TS_TARGET=150501551 NSIZE=165064704 FLINK=0 MLINK=0 [00932] AUDIO=10 PGS=111 M2TS_TARGET=155847793 RATE=19896 NSIZE=150540288 FLINK=-1 MLINK=0 [00922] AUDIO=1 PGS= M2TS_TARGET=167067048 NSIZE=153962496 FLINK=0 MLINK=0 [00912] AUDIO=1 PGS= M2TS_TARGET=172968928 NSIZE=173328384 FLINK=0 MLINK=0 [00892] AUDIO=10 PGS=111 M2TS_TARGET=173798874 RATE=20017 NSIZE=168271872 FLINK=-1 MLINK=0 [00942] AUDIO=10 PGS=111 M2TS_TARGET=190851199 RATE=19784 NSIZE=185051136 FLINK=-1 MLINK=0 [00934] AUDIO=10 PGS=111 M2TS_TARGET=204174904 NSIZE=111765504 FLINK=-1 MLINK=0 [00938] AUDIO=10 PGS=111 M2TS_TARGET=223340890 RATE=20069 NSIZE=216256512 FLINK=-1 MLINK=0 [00928] AUDIO=10 PGS=111 M2TS_TARGET=224830673 NSIZE=155068416 FLINK=-1 MLINK=0 [00112] AUDIO=1 PGS= M2TS_TARGET=232499993 NSIZE=189462528 FLINK=0 MLINK=0 [00925] AUDIO=1 PGS= M2TS_TARGET=235116296 NSIZE=175460352 FLINK=0 MLINK=0 [00927] AUDIO=1 PGS= M2TS_TARGET=235479558 NSIZE=264026112 FLINK=0 MLINK=0 [00936] AUDIO=10 PGS=111 M2TS_TARGET=249177397 NSIZE=184338432 FLINK=-1 MLINK=0 [00917] AUDIO=1 PGS= M2TS_TARGET=251116155 NSIZE=162871296 FLINK=0 MLINK=0 [00895] AUDIO=10 PGS=111 M2TS_TARGET=259109754 RATE=20393 NSIZE=249968640 FLINK=-1 MLINK=0 [00930] AUDIO=10 PGS=111 M2TS_TARGET=278688188 NSIZE=176836608 FLINK=-1 MLINK=0 [00944] AUDIO=10 PGS=111 M2TS_TARGET=284289127 NSIZE=180817920 FLINK=-1 MLINK=0 [00941] AUDIO=10 PGS=111 M2TS_TARGET=360112497 RATE=20626 NSIZE=348487680 FLINK=-1 MLINK=0 [00939] AUDIO=10 PGS=111 M2TS_TARGET=429982570 NSIZE=246183936 FLINK=-1 MLINK=0 [00933] AUDIO=10 PGS=111 M2TS_TARGET=498091655 RATE=21097 NSIZE=481837056 FLINK=-1 MLINK=0 [00937] AUDIO=10 PGS=111 M2TS_TARGET=517368702 RATE=20770 NSIZE=500951040 FLINK=-1 MLINK=0 [00946] AUDIO=10 PGS=111 M2TS_TARGET=562922291 RATE=20913 NSIZE=546207744 FLINK=-1 MLINK=0 [00947] AUDIO=10 PGS=111 M2TS_TARGET=594267790 NSIZE=307771392 FLINK=-1 MLINK=0 [00935] AUDIO=10 PGS=111 M2TS_TARGET=1197198285 RATE=21380 NSIZE=1155059712 FLINK=-1 MLINK=0 [00890] AUDIO=10 PGS=111 M2TS_TARGET=1501714413 RATE=21438 NSIZE=1450407936 FLINK=-1 MLINK=0 [00943] AUDIO=10 PGS=111 M2TS_TARGET=3312960155 RATE=21365 NSIZE=3191150592 FLINK=0 MLINK=0 [00940] AUDIO=10 PGS=111 M2TS_TARGET=3807353209 RATE=21727 NSIZE=3682652160 FLINK=-1 MLINK=0 [00945] AUDIO=10 PGS=111 M2TS_TARGET=3878040827 RATE=22225 NSIZE=3753523200 FLINK=-1 MLINK=0 [00929] AUDIO=10 PGS=111 M2TS_TARGET=4341732603 RATE=22996 NSIZE=4184248320 FLINK=-1 MLINK=0 Last edited by jdobbs; 20th July 2010 at 19:04. |
20th July 2010, 20:10 | #8867 | Link | |
1. Open GOPs. 2. The "--qpfile" addition in 0.34.05. The first one could theoretically have made chapter changes slower -- but I didn't experience it on my Sony 360. The second one placed I frames at the chapter points, and should have corrected any possible affect of the first one. |
20th July 2010, 20:45 | #8868 | Link |
Thanks jdobbs. Once you get it, the first time it happens is a little past the 7:00 mark of the movie.
Edit. By the way, I forgot to mention that my backups are all to BD25's Last edited by bluestarCVO; 20th July 2010 at 20:49. |
20th July 2010, 21:49 | #8869 | Link | |
@jdobbs
BTW, what I'm referring to is specifically when using the remote to select the "NEXT" chapter... |
21st July 2010, 00:22 | #8872 | Link |
@jdobbs;
Just curious, but I have a couple of Universal titles that I would like to do a full backup to BD9. Both titles have PiP with DTS Express secondary audio. In the past, I have PROCESS_SECONDARY=0 set, and the backups experience the no audio for main title on playback on my S360. You mentioned, at least the no audio heard issue, is a Sony player problem. So, could this be related to the PiP? Would there be an advantage to changing to PROCESS_SECONDARY=1? ( I was not sure if AVCHD BD5/9 was compatible with PiP ) I don't really care to keep the PiP on BD5/9 full backups, especially if there will be no secondary audio available. But if it affects the playback capabilities on my Sony, maybe it should be kept. If it is kept, will PiP work if full backup is to BD9? |
21st July 2010, 01:07 | #8873 | Link | |
I just did "Scorpion King" to BD-9, as I think that's one of the problem discs. I haven't played it back yet on BD-9 or BD-35, I'll let you know what I find. |
21st July 2010, 01:35 | #8874 | Link | |
OK, I will test my next one, and will keep PiP. I will let you know the results. I think I remember reading you had success with BD9 full movie backups with PiP, playing back on your Sony? |
21st July 2010, 04:28 | #8875 | Link |
I can now report my test of Green Zone, full movie backup to BD5 ( burned to DVD+RW for testing/avoiding a coaster! ), keeping PiP but no secondary audio since it is DTS Express. Playback on Sony S360.
I have run into the no audio for the main movie again. Also, there is no PiP displayed on playback. ( The PiP does work when played back with TMT3 though ) Also, there is deleted scenes with PiP, and there is no audio heard for this as well, and this also does not display the PiP with my Sony, but does work properly with TMT3. |
22nd July 2010, 21:00 | #8876 | Link |
BD-Rebuilder v.0.34.05 successfully backed up my copy of Avatar decrypted by MakeMKV v.1.5.8. I used all the defaults in BD-Rebuilder and used Mode full disc to DVD-9. When I put the ImgBurned disc into my player (Philips BDP7200/F7) I get and error code "BD-J Error 0001" I don't get an error code with the original BD in the player and my firmware is updated to the latest version 1.113. Is this my player being lame or something else? I'm doing a BD-Rebuilder movie only run now to see if that makes a difference.
22nd July 2010, 21:36 | #8877 | Link | |
My second question would be whether MakeMKV can handle that disc? I have Avatar, I'll do a full backup to BD-9 using AnyDVD HD and see how it goes. As seem to remember it working... but I'm not positive I did BD-9. Last edited by jdobbs; 22nd July 2010 at 21:38. |
22nd July 2010, 23:10 | #8878 | Link | |
@jdobbs
Hi! Quote:
On that date, I used MakeMKV to first make a full disc backup of "Avatar". I then used that full backup as my source for BD-RB to create both a DVD9 full backup and a DVD9 movie only backup - both of which function properly on my SONY BDP-S360 standalone player and on my PC, using PowerDVD v.7.3... |
22nd July 2010, 23:27 | #8879 | Link | |
MakeMKV seemed to work as I can play the resultant files on the puter. |
23rd July 2010, 02:41 | #8880 | Link | |
All players should play BD-J on a BD-25. But some won't do so on a BD-5/9 (since BD-J isn't allowed in AVCHD). I'd be careful with LTH, though, as lots of players have issues with those. |
