Old 11th October 2018, 22:53   #53141  |  Link
Some people seem to think that replying to any post means you need to quote the entire thing or have no idea they can alter it. I'd guess about 25% of this thread is pointless quoting. Just mention it whenever it becomes a problem, I'd think some have learned as I've mentioned it multiple times. Would be nice if there was a mod here but it's not a huge problem, not a lot of newcomers so things should improve.
Old 11th October 2018, 23:28   #53142  |  Link
madVr doesn't support proper interlanced output.
the RGB conversation is enough to ruin it so it is not really possible to test Tv deinterlancer with it.
on the other hand YADIf will not "win" against a frame addptive deinterlanced that is used in GPU hardware deinterlancer.
while software deinterlancing has the "best" deinterlancer "QTGMC" which is hard to do in real time hardware deinterlancer are consider to be the part of the better ones.
edit: fixed major typo
Old 12th October 2018, 00:48   #53143  |  Link
SamuriHL
SamuriHL's Avatar
The only real issue right now is that madvr can't deinterlace with the D3D11 decoder....at least not yet. Once it can, it'll be a good option.
Old 12th October 2018, 06:29   #53144  |  Link
x7007
Something weird that happened ...
All this time I used Nvidia Output Dynamic Range - FULL - TV was set Black level - HIGH , MADVR was set to 0-255 . now suddenly when I watch a movie I see crushed blacks ... it didn't happen before 1809 I think or with other nvidia drivers. I am not sure when it was working fine . I usually watch HDR so it's limited there but I will also check this... what this setting needs to be with HDR in MADVR ?
Do we need to set 16-235 always now in MADVR even with OLED FULL Range support ?
LG OLED E6 5.30.30 ISF Dark Movie profile - Black Level - AUTO (HIGH)
Windows 10 1809 17763.55
Nvidia 1080 416.16 set to FULL and Use Default color settings
x7007 is offline   Reply With Quote
Old 12th October 2018, 06:41   #53145  |  Link
jandari
HDR is working again with nVidia 416.34 drivers
jandari is offline   Reply With Quote
Old 12th October 2018, 06:43   #53146  |  Link
x7007
but it also worked 416.16 ... with hdr what do you set Madvr ? 16-235 or 0-255 ?
Weird,,,, HDR works fine with 0-255.... why SDR doesn't work now , I am sure it works fine before....
Anyone notice this also or something else ?? it really crush the black ( picture ) and it didn't do before, it just made it look better , making the washed up white light thing ...
If someone knows something or can check it please write ,,, I have no idea what's wrong . is that how it suppose to be ? If I choose for example
Nvidia - Limited . TV - LOW Madvr 0-255 ? would it work or I get also crash ? I mean it worked fine like this also before.
******* NEVER MIND I've found the issue, some of the potplayer settings has been change maybe some shortcuts I accidently clicked ..... rofl..........
some numbers with the bars has been somehow moved ... so I reverted them to 50%
Old 12th October 2018, 10:27   #53147  |  Link
austonrush
Hey Guys, I've got a repeated frames glitch when starting a video file. The audio plays in the background but, the video portion initially freezes. This started after the latest windows 10 and nvidia upgrade, never had it before. It can freeze for up to 10 seconds sometimes. Anyone else seeing this? It is not exclusive to any one video.
https://imgur.com/a/t8eGSZZ on average it repeats about 900 frames before the video kicks in.
Once the video eventually begins playing I have no other issues for the remainder of playback.
MPC-HC 64 bit (tried both 1.7 and 1.8 builds)
External Lav (latest night build 73.0-1)
MADVR 92.17 (CPU Queue Size 16 and GPU Queue of 12)
If I use EVR custom Presenter instead of madvr I get Instant playback. I've tried uninstalling and reinstalling madvr as well.
- toggling between options for fullscreen exclusive mode and Direct3D 11 for Presentation had no effect.
austonrush is offline   Reply With Quote
Old 12th October 2018, 10:35   #53148  |  Link
I already had a similar issue under Windows 7 in MPC-HC with madVR when any other application using DirectX 11 functions (e.g. a 3D game) is already running.
Old 12th October 2018, 10:39   #53149  |  Link
austonrush
game bar and game recording are disabled on my pc and I'm not running any gpu monitoring software. Nothing else running in the background, games etc.
Old 12th October 2018, 11:03   #53150  |  Link
Sunset1982
had this problem too, after I updated Win10 to 1809. Did a restore to 1803 and everything is good again. The update also destroyed my ati driver panel. Did not have the tab to change RGB values after the update.
Maybe you should try a clean Install of Win10 1809 with latest nvidia drivers.
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 12th October 2018, 11:16   #53151  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
+1 for "add grain" as separate feature instead of being "upscale refinement".
When I use SVP, I don't know how to hack the scripts to include AddGrain for FFDShow. And FFDShow's own filter is nowhere near nice enough as AVS AddGrain.
Even at 4, it doesn't seem to do as much as what AddGrain AVS can do.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 12th October 2018, 16:30   #53152  |  Link
SamuriHL
SamuriHL's Avatar
Indeed it is. To clarify this means in windowed mode not just FSE.
Old 12th October 2018, 16:48   #53153  |  Link
brazen1
I can confirm nVidia 416.34 are switching HDR in FSW and FSE again. Same with 3D which is a first for my system.
Old 12th October 2018, 19:54   #53154  |  Link
ajp_anton
ajp_anton's Avatar
100% view is the screen as it appear in the media player. The encoded video size is the original pixel count of the source. I haven't tried the second option, but I think that is what it means.
Nope, for me xxx% view always creates a screenshot that is xxx% of the encoded video, no matter how much I've zoomed. So "100% view" is always identical to "encoded video size".
ajp_anton is offline   Reply With Quote
Old 12th October 2018, 21:39   #53155  |  Link
did you try an anamorphic video. the view and encoded size should be different on these.
Old 13th October 2018, 00:07   #53156  |  Link
famasfilms
Latest Nvidia drivers have fixed HDR, but now the madvr display mode switching doesn't toggle my LG OLED from "PC" mode to "Home Theatre" and my calibrated picture settings.
Ever since I got the TV and the calibration done it's been set to PC mode (because I use it for other stuff), and madvr has been setup to switch display modes - the change of display mode would automatically change the TV to "home theatre" which is where the calibrated "night" setting was
famasfilms is offline   Reply With Quote
Old 13th October 2018, 02:41   #53157  |  Link
mkohman
Hey guys thanks to @Onkyoman, I have now created two profiles for HDR and SDR within madVR for slight saturation boost for HDR content..
On my JVC projector I have also created 2 profiles.. First one is HDR to SDR and the second one is just SDR..
Is there anyway that when I am playing a bluray (1080p) upscaled to 4K via madVR using REC709 on the JVC's SDR custom setting I created, is there any way to get madVR to get the projector to detect that it's playing an SDR movie and to change it to the SDR profile on the JVC and visa versa? rather than me doing it via the projectors remote control? Thank you guys in advance..
Sent from my moto g(6) using Tapatalk
mkohman is offline   Reply With Quote
Old 13th October 2018, 03:28   #53158  |  Link
try the send bt 2020 option under calibration.
not sure how your device exsactly handles this but if you have it by default in bt 709 mode and add this bt 2020 option to the HDR profile it should switch if it understand this setting.
Old 13th October 2018, 07:45   #53159  |  Link
blaubart
Wow Nvidia was listening to my laments! 416.34 (still in W10 1809) and madVR switching HDR again. AND switching it to correct black/white clipping, yeah!
During all my posts I had to switch HDR manually through Windows Display settings -> aha and if I do that now madVR still shows wrong black/white clipping. So seems to be a Windows>Display settings>HDR bug or bad YCbCr cooperation with madVR.
blaubart is offline   Reply With Quote
Old 13th October 2018, 11:56   #53160  |  Link
pantagruel68
Hey Guys.
Can someone explain me why when I watch a movie when chosing 1080p resolution I get very close To 23.976 ( about 23.9758) with my gtx 1060 but when selecting 2160p I get 23.978?
pantagruel68 is offline   Reply With Quote
