Old 12th November 2018, 05:22   #1221  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Originally Posted by Selur View Post
Which would require 2pass encoding and a fixed gop structue (in regard to the gop sizes), iirc 2nd pass normally should be able to overwrite GOP to archive vbv limits (not totally sure).
I'm totally fine with that. I usually use 2pass anyway. And, of course, I meant I wish they had it as an option.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 12th November 2018, 12:47   #1222  |  Link
@ Nintendo Maniac 64:
Even AMD Athlon64/Phenom (K8-K10 arch.) support some SSE3; but x264/x265 does not use it, considers their implementation as "too slow", I believe.
Old 12th November 2018, 23:16   #1223  |  Link
marcomsousa
SSE3-optimised av1_nn_predict
https://aomedia.googlesource.com/aom...6f313f27b1c501
I have developed a SIMD-optimised neural network implementation using
SSE3. I have also added functional equivalence tests between this and
the original implementation. I added aom_clear_system_state() to a few
places where FPU operations are used after av1_nn_predict.
Speed-ups over the original C implementation for various network shapes:
10x64x16: 1.72x
12x12x1: 2.72x
12x24x1: 2.35x
12x32x1: 3.34x
18x24x4: 0.94x
18x32x4: 0.93x
4x16x1: 2.01x
8x16x1: 1.89x
8x16x4: 2.02x
8x24x1: 2.77x
8x32x1: 2.98x
8x64x1: 3.76x
9x32x3: 1.08x
4x8x4: 1.66x
A few awkwardly-shaped networks are slightly slower: these could be
padded to more convenient sizes to use the SIMD kernels.
I also wrote an AVX/AVX2 implementation but on these relatively small
networks it was barely faster than the SSE3 code.
AV1 win64 VS2019 builds
Last build here
marcomsousa is offline   Reply With Quote
Old 12th November 2018, 23:23   #1224  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
...but this is exactly what I alluded to?
Athlon 64 CPUs are available on socket 754, 939, and AM2; 754 and 939 used DDR1 memory while AM2 used DDR2, and all AM2 CPUs support SSE3.
(there are some socket 754 and 939 CPUs that support SSE3, though it's kind of hit and miss).
Phenom for reference requires at least DDR2.
Nintendo Maniac 64 is offline   Reply With Quote
Old 13th November 2018, 08:50   #1225  |  Link
I'm sorry, I don't know socket numbers... - so we looked at the same topic from different angles.
Old 13th November 2018, 19:26   #1226  |  Link
v0lt
Originally Posted by Wolfberry View Post
I ran the same test as above and get 16/38/46 fps.
What is the CPU you use for testing?
It might be related to the AVX2 code used in dav1d.
Intel i5-3570k (SSE4.1, SSE4.2, AVX), Windows 7 Sp1 x64.
Old 15th November 2018, 00:29   #1227  |  Link
SmilingWolf
I am maddo saientisto!
SmilingWolf's Avatar
Status report!
Previous edition: http://forum.doom9.org/showthread.ph...49#post1852449
Whatever paragraph I don't repeat here can be assumed to be the same as in the aforementioned post
First of all: graphs! Click to enlarge
Y axis: chosen metric
X axis: bits per pixel
720p:
1080p:
BD rates for 720p:
x264 -> rav1e (yeah you read that right!)
        RATE (%)  DSNR (dB)
 MSSSIM -0.736889 0.0375593
PSNRHVS -5.5274   0.375081
rav1e -> x265
        RATE (%) DSNR (dB)
 MSSSIM -26.5291 1.29942
PSNRHVS -27.1134 1.70509
x265 -> libaom
        RATE (%) DSNR (dB)
 MSSSIM -18.9088 0.7852
PSNRHVS -15.3123 0.761791
BD rates for 1080p:
x264 -> rav1e (yeah you read that right again!)
        RATE (%) DSNR (dB)
 MSSSIM -4.92009 0.235151
PSNRHVS -7.23088 0.473125
rav1e -> x265
        RATE (%) DSNR (dB)
 MSSSIM -26.7063 1.16103
PSNRHVS -28.0007 1.53902
x265 -> libaom
        RATE (%) DSNR (dB)
 MSSSIM -26.486  0.938124
PSNRHVS -21.7431 0.905916
Encoders:
x264 157-2935-545de2f
x265 2.9-4-471726d3a046
rav1e 0.1.0-702-ab4d23e2
libaom 1.0.0-908-g3a607f7b0
Cmdlines:
x264 --preset veryslow --tune ssim --crf 16 -o test.x264.crf16.264 orig.i420.y4m
x265 --preset veryslow --tune ssim --crf 16 -o test.x265.crf16.hevc orig.i420.y4m
rav1e --low_latency false -o test.rav1e.cq80.ivf --quantizer 80 -s 2 --tune psnr orig.i420.y4m
aomenc --frame-parallel=0 --tile-columns=3 --auto-alt-ref=1 --cpu-used=4 --tune=psnr --passes=2 --threads=2 --end-usage=q --cq-level=20 --test-decode=fatal -o test.av1.cq20.webm orig.i420.y4m
Notes:
So as you can see, the rav1e and aomenc cmdlines have been slightly adjusted to take advantage of the bugfixes and updates from the last months.
In particular, rav1e has been gifted by Frank Bossen the ability to create a B-pyramid, which almost single handedly decreed rav1e's advantage over x264.
A word of warning on this last point: it's still kind of a mixed bag. In very flat, static scenes like PresageFlowerWalk x264 still rules by quite a margin, while rav1e takes the crown in clips like F.Y.C and PresageFlowerFight
F.Y.C, x264 -> rav1e:
        RATE (%) DSNR (dB)
 MSSSIM -18.451  1.01281
PSNRHVS -25.7463 2.03419
PresageFlowerFight, x264 -> rav1e:
        RATE (%) DSNR (dB)
 MSSSIM -31.4953 1.80761
PSNRHVS -31.0827 2.27546
PresageFlowerWalk, x264 -> rav1e:
        RATE (%) DSNR (dB)
 MSSSIM 66.2264 -1.70084
PSNRHVS 70.8208 -2.28853
(as always, a negative BD rate means improvement, positive means regression)
Considerations about times with libaom:
I'm using my desktop PC to run all the encodes. It is also my main study/work PC, so the times can come quite off. Plus, I run multiple encodes in parallel, which further messes up timings.
HOWEVER, between annoying bugs and a lot of stuff, the first report did cost me nearly a week of time (this includes having to re-run some encodes because sh*t happened) ONLY to encode with libaom.
Taking advantage of the recent bugfixes and improvements I have been able to rework my workflow and bring down that time to a couple days only, WITHOUT having to touch the --cpu-used parameter and no night time encoding.
All in all, I am pretty satisfied.
This concludes my (bi-monthly?) report.
As always, I'm open to any kind of feedback to improve my comparisons and my encodes.
SmilingWolf is offline   Reply With Quote
Old 16th November 2018, 19:53   #1228  |  Link
benwaggoner
So, what's everyone's favorite AV1 decoder app on Windows? Chrome looks to be not converting from video to PC range correctly (blacks are washed out, contrast is low, etcetera). Is there a nightly of something that does AV! correctly for apples-apples?
Ben Waggoner
My Compression Book
Old 16th November 2018, 22:45   #1229  |  Link
SmilingWolf
VLC 3.0.5 (Nightly). I fixed my nVidia settings just today because I had that same problem while playing back the ToS fragment I use for the tests. Plays out correctly now.
In alternative, ffplay for quick stuff when I already have a bunch of command prompts open in the right path.
Old 16th November 2018, 23:27   #1230  |  Link
I use almost only MPC-HC. Which uses LAV Filters with a direct API. It was able to play AV1 clips from the YouTube beta playlist and some tiny own encodes (I don't have powerful CPU's available). So, only a limited experience, yet, but it appears to work.
Old 18th November 2018, 12:40   #1231  |  Link
SmilingWolf
32/64bits binaries (GCC 9.0):
av1-1.0.0-941-gd2a592e1c: https://mega.nz/#!F5Am2KyK!9aQ6_7mM2...6_OaZahvKCHPWQ
Old 19th November 2018, 10:51   #1232  |  Link
mandarinka
mandarinka's Avatar
Originally Posted by Mystery Keeper View Post
I wish aomenc/vpxenc had GOP-level parallelism. When each thread is encoding one GOP, and then they are stitched together. That would make use of all CPU power without compromising quality/compression.
You could get the same results by splitting manually into X parts end encode them separately at once. I'm not sure how much does libvpx/libaom count with that. It works great with x264 and x265 (using raw output at least).
Old 19th November 2018, 10:58   #1233  |  Link
mandarinka
mandarinka's Avatar
SSE3 is not particularly useful for multimedia and it's just a few instructions introduced in Presscot P4 and Venice 90nm K8.
You probably mean SSSE3 (SSS instead of SS) aka "Suplemental SSE3" which is a confusing and dumb name. Probably should have been SSE4 but got renamed for marketing reasons. Or SSE3 was not supposed to be SSE3 originally.
SSSE3 is very useful for encoding and decoding, but only comes on Core 2 chips, and Bobcat/Bulldozer and later cores from AMD. K10 and K8 end at the not-so-important SSE3.
(Note that x265 actually needs SSSE3 + SSE4 to be useful, you are barred from most of assembly optimization if you only have SSSE3, like with 65nm Core 2s or pre-Sandy Bridge Pentium/Celeron).
Old 19th November 2018, 13:09   #1234  |  Link
Thanks, mandarinka, that explains a bit. I meant SSE3 of 2004 (a.k.a. "Prescott New Instructions" PNI, according to Wikipedia), originally. SSSE3 of 2006 did not arrive in AMD CPUs before the "Cat" (Fusion APU) and "Heavy Equipment" series, so Athlon64/Phenom are clearly out of business.
Old 20th November 2018, 01:08   #1235  |  Link
benwaggoner
Naïve Split-and-stich risks violating VBV at the stitch boundaries and/or reducing quality at those boundaries in order to ensure VBV.
Not that VBV is being used in any AV1 testing I've seen so far.
Ben Waggoner
My Compression Book
Old 20th November 2018, 04:13   #1236  |  Link
utack
So I am not entirely sure about what the stats file from first pass includes.
When using pure "q" mode for constant quality, is there a benefit to doing a first pass, or does the first pass only determine how to distribute bitrate when a target bitrate and vbr is specified?
utack is offline   Reply With Quote
Old 20th November 2018, 16:37   #1237  |  Link
marcomsousa
Building Modern Web Media Experiences: AV1 (Chrome Dev Summit 2018)
https://youtu.be/iTC3mfe0DwE?t=612
Last build here
Old 21st November 2018, 11:24   #1238  |  Link
uneedme
Hi all
Still, anywhere could find the detail explained parameter functions and arguments range?
forgive my poor wording...
high-end spree means nothing...
uneedme is offline   Reply With Quote
Old 22nd November 2018, 00:09   #1239  |  Link
utack
dav1d is doing well
http://www.jbkempf.com/blog/post/201...-first-release
Old 22nd November 2018, 11:48   #1240  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
64-bit GCC 8.2.0 binaries: av1-1.0.0-962-1468e60d7
AVX2 ver of highbd dr predictions Z1,Z3
perfromance increase 1.22x-20x depending on input params
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
