6th March 2020, 18:55 | #1441 | Link |
You're welcome. Next build includes a check for it.
7th March 2020, 09:21 | #1442 | Link |
App Digger
HE-AAC audio in mp4 demuxed to an mka format
While remuxing an AAC audio stream via stream copy with a re-encoded HEVC video stream to an mp4 file, I found this weird behavior of StaxRip (2.0.7.4 Beta): it demuxes the HE-AAC audio stream (via MP4Box) to an mka format while demuxing the AAC-LC audio stream to an m4a format (as expected).
This produces a false warning that remuxing the original AAC(HE-AAC) audio stream via stream copy to an mp4 format is not appropriate, which is inappropriate itself. On the other hand, this warning does not appear in the case of an AAC-LC audio stream, as a matter of course. Well, is there any reason why an HE-AAC stream is demuxed to an mka format? Thanks in advance. |
7th March 2020, 09:54 | #1443 | Link |
2.0.7.5 Beta ------------ - fix: when the cut feature was used and afterwards the preview was opened from the code editor then the cut settings got damaged - fix: when AviSynthShader was used StaxRip did not show a warning in case DirectX 9 is not installed - fix: HE-AAC as demuxed as mka - new: setting that allows to define how many frames are used for auto cropping - new: some default settings were changed - new: the buttons in the preview dialog look much better now, also flicker was eleminated and the button and trackbar size was increased, standard buttons were used, I don't know how it looks on Win 7... - new: the csv file content in the apps dialog was improved - new: auto crop feature in crop dialog finally shows progress - new: the avisynth and vapoursynth code editor has a new 'Advanced > Advanced Info' feature, it offers the following info: avs2pipemod info, avsmeter info, avsmeter benchmark and vspipe info https://1drv.ms/u/s!ArwKS_ZUR01g0kH4...3GaKe?e=qbOfGS
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 7th March 2020 at 10:15. |
8th March 2020, 00:04 | #1445 | Link |
Please post either a link to the error message or post the error message.
8th March 2020, 00:34 | #1446 | Link |
StaxRip.ErrorAbortException: Index LWLibav failed with exit code: -1073741515 (0xC0000135)
C:\Users\gouck\AppData\Local\Programs\VapourSynth\core\vspipe.exe "D:\****1080p_temp\ ****1080p_new.vpy" NUL -i at StaxRip.Proc.Start() in D:\Projekte\VB\staxrip\General\Proc.vb:line 342 at StaxRip.MainForm.Indexing() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 3193 at StaxRip.VideoScript.Synchronize(Boolean convertToRGB, Boolean comparePath, Boolean flipVertical) in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 237 at StaxRip.VideoScript.GetInfo() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 444 at StaxRip.VideoScript.GetFrameCount() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 458 at StaxRip.GlobalClass.IsValidSource(Boolean warn) in D:\Projekte\VB\staxrip\General\GlobalClass.vb:line 701 at StaxRip.MainForm.AviSynthListView_ScriptChanged() in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 5223 at StaxRip.FiltersListView.OnChanged() in D:\Projekte\VB\staxrip\Controls\FiltersListView.vb:line 271 at StaxRip.FiltersListView._Lambda$__14-0(VideoScript script) in D:\Projekte\VB\staxrip\Controls\FiltersListView.vb:line 30 at StaxRip.VideoScript.RaiseChanged() in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 22 at StaxRip.VideoScript.SetFilter(Int32 index, VideoFilter filter) in D:\Projekte\VB\staxrip\General\VideoScript.vb:line 92 at StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Projekte\VB\staxrip\Forms\MainForm.vb:line 2069 Last edited by Spunkmeyer; 8th March 2020 at 00:38. |
8th March 2020, 01:10 | #1447 | Link |
Apparently my diagnostic code failed on multiple levels, 0xC0000135 should be STATUS_DLL_NOT_FOUND, try this:
Main Menu > Apps > Manage > type 'visual' in search field and install some VC++ Redist x64, also please post the generated vpy vapoursynth script, so I can fix the requirement detection as well as the exit code analysis. edit: Is there a _staxrip.log file?
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 8th March 2020 at 02:11. |
8th March 2020, 12:36 | #1448 | Link |
In version 2.0.7.5 the chapters are not set automatically. You have to search and select the xml file via Container Options -> Options -> Chapters for each film. If you do not do this, the line in Chapters remains empty.
8th March 2020, 13:37 | #1449 | Link | |
8th March 2020, 17:39 | #1451 | Link |
I hope it's getting more stable because I really want to get that 2.0.8.0 stable release out, please help to test.
2.0.7.6 ------- - fix: format compatibility was improved with an automated test - fix: in the preview dialog the start position for mpc and mpv was incorrect when cut ranges were active - fix: chapter file not being picked up - fix: in the filter setup profiles dialog a exception could happen and loading a filter setup from the menu could fail - fix: the filter parameter menu in the code editor was adding parameters even if they were already existing with different casing - fix: cutting could cause an error where staxrip generates a chapter file without containing a ChapterAtom - new: the logic to create and edit cut sections in the preview dialog is now smarter and more flexible - new: the assistant tells in case of a script error that the full error can be shown by clicking the preview button - new: MiniDeen avs filter added - new: Advanced Info in the code editor was moved to the top level menu and AviSynth Info() can be shown directly from the Advanced Info without adding Info() to the script, staxrip generates the script with perfect font size and shows it with mpv (paused, no osc, no osd) https://1drv.ms/u/s!ArwKS_ZUR01g0kH4...3GaKe?e=qbOfGS
8th March 2020, 18:33 | #1452 | Link |
For your next version ALL rigaya's HW transcoders have new versions:
NVenc v4.68 QSVenc v3.33 VCEenc v5.04
8th March 2020, 19:44 | #1453 | Link |
@NikosD
I've updated it locally.
8th March 2020, 20:22 | #1455 | Link |
App Digger
And Subtitle Edit was updated to 3.5.14 yesterday:
https://github.com/SubtitleEdit/subt...ses/tag/3.5.14 BTW, I noticed a sub-folder name change in the StaxRip\Apps\Plugins folder: Both ⇒ Dual Well, just for you guys who just overwrite the whole folders/files. |
8th March 2020, 20:47 | #1456 | Link | |
Another option has been added for QSVEnc: --vpp-colorspace |
8th March 2020, 20:55 | #1457 | Link |
@Spunkmeyer
Look for a file that ends with _staxrip.log @JKyle I've updated it.
8th March 2020, 20:58 | #1458 | Link |
Starfish
I tried 2.0.7.6 and it's not usable. I open a new video file with source "automatic". Demuxing is working, but then the program fails and I get the error message, that AviSynth+ was not found even so I installed 3.5 prior. Code:
------------------------- Error opening source ------------------------- AviSynth+ installation cannot be found LoadPlugin("D:\_Programme\_Portable\StaxRip-x64-2.0.7.6-beta\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("D:\Video\Der Film_temp\Der Film.mkv", colorspace = "YV12", \ cachefile = "D:\Video\Der Film_temp\Kim Possible - Der Film.ffindex") I use both versions as portable installations with the settings folder in each portable folder. I reverted AviSynth+ to the previous version but 2.0.6.0 keeps on failing. Code:
------------------------- Error opening source ------------------------- FFVideoSource: The index does not match the source file (D:\Video\Billy the Kid_temp\Billy the Kid_source.avs, line 3) LoadPlugin("D:\_Programme\_Portable\StaxRip-x64-2.0.6.0-stable\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("D:\Video\Billy the Kid_temp\Billy the Kid.mkv", colorspace = "YV12", \ cachefile = "D:\Video\Billy the Kid_temp\Billy the Kid.ffindex") |
8th March 2020, 21:12 | #1459 | Link | |
https://github.com/staxrip/staxrip/b...eneral/Test.vb https://github.com/staxrip/staxrip/b...QSVEnc.vb#L116
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 8th March 2020 at 21:16. |
8th March 2020, 21:21 | #1460 | Link |
@FreaQ
Post one screenshot of the AviSynth page in the apps dialog and one screenshot of your Windows Uninstall dialog showing your AviSynth+ 3.5 x64 installation.
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
