13th July 2004, 12:55 | #21 | Link |
Pig on the wing
You may also want to point out that CNR2 has finally been fixed thanks to tritical; the latest working version is now 2.61.
http://forum.doom9.org/showthread.php?s=&threadid=78905
14th July 2004, 20:45 | #22 | Link | |
Excellent guide, thanks to all who contributed. The info on PAR is very nice. I did find an error in Section 16.5.1, the last paragraph step 1 is --
I also have another question regarding resizing. It seems there are 3 methods to use - 1. PAR method from section 16 (always works, great!) 2. Sections 4.4 and 5.6(same as 4.4), method 1 3. Sections 4.4 and 5.6(same as 4.4), method 2 I have figured out how to apply scaling factors for using method 1 when you have cropped all black borders from a source but I'm having difficulty using method 2 to do this. Any hints? Please try the example in section 16.5.1,example 2 for instance. One last observation regarding method 1 is that it seems to work no matter what you capture at. As long as you know your source capture H and V pixels and the capture width of your source, you can just resize it to maintain the aspect ratio and then pad the H or V value to get the target format size. I've done all the examples in the PAR section using this method and it never fails. tyee Last edited by tyee; 14th July 2004 at 20:48. |
15th July 2004, 08:21 | #23 | Link | ||
Alias fragger
But basically, method 1 and 2 are quick and simple methods to do resizing calcs provided you don't do any extra cropping beforehand or do a PAL to NTSC conversion or something like that. So they don't cover all situations but have the advantage of being simple. |
16th July 2004, 03:46 | #24 | Link | |
budala
If you want to do different than your destination we could modify it. As a method #2.B example: 1. 768x576 my that's big. 2. svcd is 53.333 3. BTWincap PAL is 52.03 4. 52.03/53.333 * 480 = 468 4.B Resize from your cap size 768x576 to 468x576 5. Add 6 pixels on each side to get 480x576 6. You already resized so don't do it again. The 'simple' methods are really intended for TV watching where you don't care about the edges because you wont see them. AKA, you almost always have to pad. Last edited by trevlac; 16th July 2004 at 13:21. |
16th July 2004, 05:21 | #25 | Link |
Thanks guys for the info. I'll keep reading the guide. It will take a while to get through it.
BTW, I downloaded the .chm file which is great. What software would you guys recommend that's easy to use to make .chm files from HTML or from anything else for that matter? |
16th July 2004, 21:56 | #26 | Link |
Compiling chm files:
1) Download and install Microsoft HTML Workshop here: http://download.microsoft.com/downlo...S/HTMLHELP.EXE 2) Open it one time to ensure that .hhp files are associated with this program. 2b) hhp = project file, hhc = contents file. 3) Open it: File -> New -> Project (... and give it a name). 4) In the project tab: a) Upper left button "change project options". Here you can change: a1) general tab: language a2) files tab: name and path of compiled (chm) file a3) compiler tab: check 'Compile full text search info' to include search possibilities in chm file. b) Second button (add/remove topic files): include all the html files. In the case of cap guide, only start.html is sufficient, because every other html page is linked to this. 5) If you want to include a Contents file (like we did for AviSynth: Table of Contents.hhc), click on the Contents tab. Now you can make a contents file. I suggest you to open the project file of AviSynth (english.hhp), to see how the contents file is made. The project/contents file of AviSynth are included in the documentation. 6) Under the File tab, select Compile to make the chm file. I hope this is enough info to get you started |
19th August 2004, 13:05 | #28 | Link |
> A compiled chm file (4.2 MB) can be found here:
> http://www.geocities.com/wilbertdijkhof/ACG40.zip Is that chm link valid? Yahoo says it's not. Jeff |
20th August 2004, 16:48 | #31 | Link |
Where to get ACG40.zip
The geocities link is not working for me, I tried yesterday and today.
Can anybody upload the file to a more reliable server or something? By the way, is it the last version or the HTML one is more updated? |
24th August 2004, 20:03 | #34 | Link | |
AviSynth plugger
O.K., I see some improvements
Descratch part is added. But DeSpot part is still obsolete (version 1.0 was used probably). Quote:
Some new motion option was added in v.3. And DeSpot has reached version 3.2 recently
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
9th September 2004, 08:45 | #35 | Link | |
Newbie Forum Mod
cheers kr stefan
Search the forum, read the forum rules once more and use the search function on doom9.org before posting! oh btw my amazon.de wishlist Last edited by killingspree; 26th December 2004 at 14:56. |
11th October 2004, 22:11 | #38 | Link |
Too pro for Capture FAQ
Hia there.
<<Angry drivel removed by moderator, per Rules 4 and 16>> ... I'm sending you a sample of a capture done under their parameters, wanna see some professional results over a vcd for tv broadcasting? check this out: www.canalrcn.com Last edited by jggimi; 11th October 2004 at 23:14. |
11th October 2004, 22:32 | #40 | Link | |
AviSynth plugger
I read this chapter:
7.2.1 Determine cuts in VirtualdubMod: Quote:
BTW, VDMOD has bug with converting framesets to TRIMs (end frame must be less by 1).
guide |
