Old 15th March 2019, 02:22   #4581  |  Link
goorawin
It's a function. It does a similar and I think, a slightly better job to
ColorMatrix(mode="Rec.709->Rec.601")
goorawin is offline
Old 15th March 2019, 02:28   #4582  |  Link
manolito
manolito's Avatar
I think he is talking about the HDRMatrix plugin from VideoArtifact:
https://www.videoartifact.com/hdr/
manolito is offline
Old 15th March 2019, 06:27   #4583  |  Link
goorawin
Yes that is correct, it uses HDRMatrix
goorawin is offline
Old 15th March 2019, 11:07   #4584  |  Link
StainlessS
StainlessS's Avatar
Hi P, as you seem to have been missing for a few days (Thanks for RemoveDirt mod), thought you may have missed this:- https://forum.doom9.org/showthread.php?t=176193
See comments in script and purple subtitles for 32 bit YV16.
I sometimes post sober.
StainlessS is offline
Old 15th March 2019, 11:12   #4585  |  Link
pinterf
Thanks, noticed too and fixed on git last month.
https://github.com/pinterf/AviSynthP...68aa367ffbaacb
Busy times, not released yet.
pinterf is offline
Old 16th March 2019, 13:47   #4586  |  Link
StainlessS
StainlessS's Avatar
see Comment in blue here:- https://forum.doom9.org/showthread.p...06#post1869006
Quote by StainlessS
EDIT:
Looks like CR_IsReallyFloatOld(InDAR) is a missing RaffRiff42 avsi function,
and it will only work as intended on v2.58, not v2.60+,
In v2.60+, Float args where user supplied as Int, they are forcibly converted to Float by Avisynth, and so that function has no purpose in v2.60 or Avs+.
Due to this forcible conversion, you cannot tell whether or not user called with float or int arg.
[I would have been happier if had been left as it was originally]
EDIT:
Function test(float "f") {
    S = (f.Defined) ? "Defined" : "NOT Defined"
    f=Default(f,42)
    s = S + " F="+String(f) + "\n"
    Return S
S0=VersionString+"\n"
S1=Test()
S2=Test(1)
S3=Test(2.0)
S= S0 + S1 + S2 + S3
BlankClip(width=240,Height=100)
Subtitle(S,lsp=0)
Avs v2.58
Avs 2.60(+)
EDIT: In v2.60+, if the guy that wrote the script function supplied the default arg as an int, then can still produce problems and so the original fix conversion to float arg
still dont work ideally, ie maybe should also convert Defaulted args to Float where the formal arg type (think thats what its called) is of eg type float.
If this was done, then I would be happier.
Old 17th March 2019, 18:14   #4587  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Does Avisynth+ include the audio quality improvements of TimeStretchPlugin natively? (compared to the TimeStretch of AVS 2.6)
MysteryX is offline
Old 18th March 2019, 04:47   #4588  |  Link
manolito
manolito's Avatar
Yes, I believe it does...
v2.61 Updated SoundTouch library to 1.9.2. Fixes multichannel issues
manolito is offline
Old 18th March 2019, 12:11   #4589  |  Link
tebasuna51
tebasuna51's Avatar
Just to be clear, correct me if I am wrong.
- TimeStretchPlugin is a old (2015) plugin by Wilbert to improve the TimeStretch internal function of AviSynth 2.58 to add support for multichannel audio.
- Like manolito say AviSynth v2.61 update the TimeStretch internal function to SoundTouch library 1.9.2. Then TimeStretchPlugin is not needed for v2.61, only for v2.58.
- From the begining AviSynth+ have the TimeStretch function in a external plugin TimeStretch.dll (with SoundTouch library 1.9.2) supplied with AviSynth+
- BTW the SoundTouch library version is now 2.1.1. I don't know if the the last TimeStretch.dll from Avs+ is updated.
tebasuna51 is offline
Old 18th March 2019, 13:19   #4590  |  Link
manolito
manolito's Avatar
TimeStretch history as far as I remember:
AVS 2.60 internal TimeStretch function (forgot the SoundTouch version) only supports stereo audio, multichannel not supported.
Next was the TimeStretch Plugin by Wilbert:
changelog:
* version: 2.5.8.0 (requires AviSynth v2.58)
* filter is named to TimeStretchPlugin
* multichannel support
* updated SoundTouch library to 1.8.0
This version did support multichannel audio sources.
Then AVS 2.61 Alpha had an even newer internal TimeStretch version:
Update to SoundTouch 1.9.0(Wilbert+IanB).
For AVS+ the docs are really not very informative. In the AVS Wiki the Timestretch version info says:
Since classic AVS was not updated for years I suppose that this info applies to AVS+. But I could not find any info in the AVS+ docs about the current TimeStretch version. And the DLL itself does not have any embedded version info.
manolito is offline
Old 18th March 2019, 13:30   #4591  |  Link
Groucho2004
https://github.com/pinterf/AviSynthP...uch/whence.txt
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 18th March 2019, 13:51   #4592  |  Link
tebasuna51
tebasuna51's Avatar
Thanks Groucho2004, I can't remember where I read the Avs+ SoundTouch version but seems my memory still work a little.
Old 18th March 2019, 14:31   #4593  |  Link
manolito
manolito's Avatar
ColorMatrix and alternatives under AVS+ MT
After many more tests using my Thinkpad Core i5 3rd generation (2 physical cores plus Hyperthreading) I think I know quite well what's going on here:
The good old tritical Colormatrix works well without crashes using the modifications suggested by almosely:
https://forum.doom9.org/showthread.p...79#post1865279
Colormatrix followed by RequestLinear, both in MT_SERIALIZED mode. I could not detect any artifacts of the kind described by PDR.
z_ConvertFormat uses MT_MULTI_INSTANCE through the SetMTMode.avsi (this is also the AVS+ default, no need to explicitly specify it). This might work for the z_Resizers, but if the matrix parameters are used, the script will crash. It needs MT_SERIALIZED for the matrix params.
For the HDRMatrix plugin the SetMTMode.avsi calls for MT_NICE_FILTER. This causes a crash immediately after starting the conversion. Specifying MT_MULTI_INSTANCE runs stable, but at a very low speed.
For me the old ColorMatrix plugin is the best so far. It is faster than the competition, and I did not detect any quality issues so far.
(I did not test DitherTools as suggested by Groucho. Way too complicated for me...)
Cheers
manolito
manolito is offline
Old 18th March 2019, 14:34   #4594  |  Link
pinterf
Changed
I've updated SoundTouch with current git version (2.1.3) (today's achievement, exists only on my git, not released)
pinterf is offline
Old 19th March 2019, 19:01   #4595  |  Link
GhostAFRippEr
FoReVeR MoViE
GhostAFRippEr's Avatar
i have not activeted MT how to i add .avs script ?
GhostAFRippEr is offline
Old 19th March 2019, 19:12   #4596  |  Link
How to use multi-threading in AviSynth+?
Read: Avisynth Wiki – AviSynth+: 3. MT Notes
LigH is offline
Old 22nd March 2019, 00:09   #4597  |  Link
qyot27
qyot27's Avatar
It's been quite a while since the last time we tried this, so here's a GCC build of AviSynth+:
AviSynth+ (GCC) r2831-g316b54aa-20190321
And a corresponding pair of FFmpeg and mpv builds that include builds capable of handling otherwise-difficult 32-bit GCC builds of AviSynth+:
FFmpeg r93433+7
mpv r46865+11
Unlike the previous GCC build of AviSynth+, it now will not interfere with your existing plugin folders. There is a separate registry entry and plugin folder path GCC builds look for, plugins+gcc. Examples below - change the path accordingly for where AviSynth+ is installed, but the point is that the plugins folder for GCC builds of AviSynth+ should be separate from the folder(s) for normal MSVC builds.
64-bit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth]
@="E:\\Programs\\AviSynth+"
"plugindir2_5"="E:\\Programs\\AviSynth+\\plugins64"
"plugindir+"="E:\\Programs\\AviSynth+\\plugins64+"
"plugin+gcc"="E:\\Programs\\AviSynth+\\plugins64_gcc"
32-bit:
"plugindir2_5"="E:\\Programs\\AviSynth+\\plugins"
"plugindir+"="E:\\Programs\\AviSynth+\\plugins+"
"plugindir+gcc"="E:\\Programs\\AviSynth+\\plugins_gcc"
C-plugins should work with the GCC builds (the FFMS2 C-plugin definitely works). C++ plugins will not (excepting possibly if they were built with g++, but I've not tried this yet).
For those not wanting duplicate copies of FFMS2-C floating around, symbolic links should work fine.
qyot27 is offline
Old 23rd March 2019, 00:56   #4598  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Help please - I'm trying to track down a bug but my lack of understanding of smart pointers is causing me a headache. The bug occurs if I use the following code in GetFrame:
	PVideoFrame tmp = child2->GetFrame(n, env);
	PVideoFrame src = child->GetFrame(n, env);
        return src
In the constructor, the filter does something along these lines:
        if ([condition]) child2 = env->Invoke(...); else child2 = child;
So child2 may, or may not, be the same clip (literally the same pointer) as child. When they are the same, I get unexpected behaviour, so I'm guessing there is something bad about calling GetFrame twice on the same clip.
So my question: is straight copying of a PClip like this an unambiguously wrong thing to do (I'm guessing it is), and if so, what's the correct thing to do?
wonkey_monkey is offline
Old 23rd March 2019, 10:39   #4599  |  Link
pinterf
There is nothing wrong with copying PClips. In the above example, is tmp unused deliberately?
pinterf is offline
Old 23rd March 2019, 10:53   #4600  |  Link
jpsdr
Is there MT mode used ? In that case, maybe affecting child2 in constructor is not compatible with MT_NICE ?
My github.
jpsdr is offline
