Old 1st September 2016, 06:12   #7961  |  Link
DoctorM
Anyone know if it's possible to use the re-author mode to add a subtitle track to a 3D BD without breaking things?
Old 5th September 2016, 05:07   #7962  |  Link
Ghred62
Can I import externally-created menus to multiAVCHD?
I'm a multiAVCHD newbie, admittedly, but no matter what I try, every attempt to create a BluRay menu fails. I've tried disabling the Top Menu (previously tried XMP, then Carousel type) and choosing only the title list menu, but it always fails due to the following error:
Failure to mux menu and to create playlist [00xxx.mpls]
Error muxing title-list menu page #1!
I'll post the whole log below, but my questions are:
  1. Is there a known solution to this problem?
  2. Else, can I create a menu in some external tool and import it into multiAVCHD instead? If so, how?
For the record, my system passed all MultiTests.
Here's the log:
[23:52:42] Checking for available space and drive types (FAT32/NTFS)...
[23:52:45] Destination [D:]: NTFS, 1129845.29 MiB (1103.365 GiB) free space
[23:52:45] Temp folder [D:]: NTFS, 1129845.29 MiB (1103.365 GiB) free space
[23:52:45] Log started for multiAVCHD v4.1 (build 771)
[23:52:45] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
[23:52:45] Processing 2 titles...
[23:52:45] Existing D:\NewBD Work\BRP1 Out\AVCHD\ cannot be used as destination folder!
[23:52:45] Output will be written to: D:\NewBD Work\BRP1 Out\AVCHD-20160904-235245
[23:52:50] Processing (D:\SourceVids - AC3\Test\Test Vid 1.mp4)...
[23:52:50] Pre-processing...
[23:52:50] Detected frame reference count: 2 (max:4).
[23:52:50] Detected video: ID#1:V_MPEG4/ISO/AVC 1920x1080, fps=30.000, ref=2
[23:52:50] Detected audio: ID#2:A_AC3 (48000Hz 16bit 2ch 128kbps) Language: unk
[23:52:50] Added audio: A_AC3, "D:\SourceVids - AC3\Test\Test Vid 1.mp4", track=2, lang=unk, timeshift=0ms
[23:52:50] M2TS stream split set at 99999MiB...
[23:52:50] Creating clip and playlist info (tsMuxeR)...
        tsMuxeR (Version 1.10.6) output:
Decoding H264 stream (track 1): Profile: High@4.1  ResolutioD: 1920:1080p  Frame rate: 30
H.264 stream does not contain fps field. Muxing fps=30
Decoding AC3 stream (track 2): Bitrate: 128Kbps Sample Rate: 48KHz Channels: 2
H264 bitstream changed: insert SPS/PPS units
Processed 501 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 0 sec
        tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000  --vbv-len=500
V_MPEG4/ISO/AVC, "D:\SourceVids - AC3\Test\Test Vid 1.mp4", insertSEI, contSPS, track=1, lang=eng, fps=30.000
[23:52:53] Media transfer: 00000 -> 00000.m2ts
[23:52:53] Processing playlist...
[23:52:53] Title #1 added: "Test Vid 1"
[23:52:53] Verifying title...
[23:52:56] Title has: 1 audio tracks and 0 subtitle tracks
[23:52:59] Processing (D:\SourceVids - AC3\Test\Test Vid 2.mp4)...
[23:52:59] Pre-processing...
[23:52:59] Detected frame reference count: 2 (max:4).
[23:52:59] Detected video: ID#1:V_MPEG4/ISO/AVC 1920x1080, fps=29.970, ref=2
[23:52:59] Detected audio: ID#2:A_AC3 (48000Hz 16bit 2ch 128kbps) Language: unk
[23:52:59] Added audio: A_AC3, "D:\SourceVids - AC3\Test\Test Vid 2.mp4", track=2, lang=unk, timeshift=0ms
[23:52:59] M2TS stream split set at 99999MiB...
[23:52:59] Creating clip and playlist info (tsMuxeR)...
Decoding H264 stream (track 1): Profile: High@4.1  ResolutioD: 1920:1080p  Frame rate: 29.97
H.264 stream does not contain fps field. Muxing fps=29.97
Processed 4840 video frames
Muxing time: 4 sec
        tsMuxeR meta:
V_MPEG4/ISO/AVC, "D:\SourceVids - AC3\Test\Test Vid 2.mp4", insertSEI, contSPS, track=1, lang=eng, fps=29.970
[23:53:04] Media transfer: 00000 -> 00001.m2ts
[23:53:04] Processing playlist...
[23:53:04] Title #2 added: "Test Vid 2"
[23:53:04] Verifying title...
[23:53:08] Title has: 1 audio tracks and 0 subtitle tracks
[23:53:08] Preparing authoring information...
[23:53:08] Authoring menu (NTSC).
[23:53:08] Creating title thumbnails for 2 titles (XMB)...
[23:53:11] Using 1 thumbnail/chapter links for title #1...
[23:53:11]  *** Extracting 1 chapter thumbnails...
[23:53:15] Using 1 thumbnail/chapter links for title #2...
[23:53:15]  *** Extracting 1 chapter thumbnails...
[23:53:19] Image processing for XMB menu completed!
[23:53:19] Preparing menu pages...
[23:53:19] Encoding Title List menu page [1/1].
[23:53:24] Failure to mux menu and to create playlist [00254.mpls]
[23:53:24] Error muxing title-list menu page #1!
[23:53:25] Setting main menu for 2 titles...
[23:53:25] Loop mode after last title.
[23:53:25] Playback will start with title #1 (Test Vid 1).
[23:53:25] Setting menu properties...
[23:53:25] Selected TV system: [NTSC]
[23:53:25] Processing clip (CPI/CLPI) files...
[23:53:25] Completed.
[23:53:25] Setting Blu-ray format...
[23:53:26] Done!
[23:53:26] Saving multiAVCHD quick-load project (mpf):
[23:53:26] D:\NewBD Work\BRP1 Out\AVCHD-20160904-235245\multiAVCHD.mpf (OK!)
        Compilation summary:
        Format: Blu-ray player (BD-R/BD-RE disc)
        1. Test Vid 1                               [00:00:16]
        2. Test Vid 2                               [00:02:41]
        Overall duration : 00:02:58
        Output size      : 413 MiB (0.403 GiB)
[23:53:26] D:\NewBD Work\BRP1 Out\AVCHD-20160904-235245 folder created (AVCHD/Blu-ray output)!
[23:53:26] Burn its CONTENTS to BD-R/RE UDF 2.50/2.60 disc!
[23:53:27] You may now remove temp folder (D:\NewBD Work\TEMP\multiTEMP-20160904\).
[23:53:27] Your compilation contains 0hrs 2min 58sec of video material.
[23:53:27] multiAVCHD finished in 41.855 seconds (00:00:41.854)!
[23:53:27] End of log.
Any help will be greatly appreciated!
Ghred62 is offline   Reply With Quote
Old 5th September 2016, 09:25   #7963  |  Link
Szymszel
My Blu-ray player recognize burned multiAVCHD's project as DATA DISC.
Hi.
First, sorry for may English.
This is not my first multiAVCHD's project burned on BD-R disc via ImgBurn application but first project recognized as DATA DISC.
I've checked folder structure and it's OK.
I don't know where is the cause.
I'm and .
Please HELP!
Szymszel is offline   Reply With Quote
Old 7th September 2016, 08:57   #7964  |  Link
Music Fan
If you burn the folders created by multiAVCHD in UDF 2.50, it should be ok.
Music Fan is offline   Reply With Quote
Old 20th September 2016, 18:14   #7965  |  Link
Miro72
multiAVCHD and Dolby Atmos
Hi all, first of all I want to apologize for my poor English.
I'm new here and I have to you just such a question. Or multiAVCHD can also work from Dolby Atmos audio. I have a blu-ray movie and have English audio Dolby Atmos, and I would like there will add other audio and subtitles, and create your own bluray. Thank you for your advice and help.
Miro72 is offline   Reply With Quote
Old 21st September 2016, 21:42   #7966  |  Link
Music Fan
I don't know if multiAVCHD support Atmos but you can do it with TSMuxer (without menus).
Old 30th September 2016, 21:47   #7967  |  Link
Miro72
Hello, Music Pop, so I tried Dolby Atmos in multiAVCHD menu without menu and I must say that it multiAVCHD mastered brilliantly. Super the software. As far as I know tsMuxeR of Dolby Atmos can not handle. Well thank you!
Old 1st October 2016, 09:07   #7968  |  Link
Music Fan
Hello, Music Pop
Music Fan
Yes it does, and anyway multiAVCHD uses tsMuxeR for multiplexing in m2ts.
Old 5th October 2016, 15:36   #7969  |  Link
Szymszel
Next project burned properly. Probably my player has a problem with reading the UDF 2.60. But I'm not sure. With UDF 2.50 is OK.
Old 5th October 2016, 15:49   #7970  |  Link
Szymszel
Upper subtitles in project. Possible?
I want to create a project with additional upper subtitles in the same language as the lower subs. Many Blu-rays has upper subtitles appear from time to time, instead of the lower subtitle.
Does anyone know how to do it? I created 2 sup's with lower and upper subs. What's next?
Old 10th October 2016, 14:26   #7971  |  Link
Miro72
Audio
When you want to insert your own audio multiAvchd: Menu-Advanced-background audio so that the audio cracking. You do not know what's wrong? Sorry for my English.
Old 6th November 2016, 08:25   #7972  |  Link
Sylontack
Working with episodes, possibly replacing video streams
Obligatory "clearly made an account just to ask this one question because I'm in over my damn head" post here. Forgive the size, I'm super wordy and I've been trying to sort this out for quite some time so I've a lot of talk piled up in my brain on the matter.
So I've used MultiAVCHD a couple of times to add audio and subtitle tracks to BDMVs and it's mostly worked out pretty well after some trial and error.
My next few intended projects are TV Series BDs instead of movies and those ones are a bit more complex authoring-wise for me. So I understand from the first page which I've gone over lots of times over the last year or so on various projects that series and multiple cuts are harder to work with, and the tutorial doesn't actually apply to the way the discs I'm working with are authored (neither have individual playlists for each episode for example). I've come to the conclusion that the most painless way to achieve what I'm after is to just mux the new audio and subtitle tracks into each m2ts stream file and replace the originals.
Of course I'm also aware that just muxing the new stuff in will result in a disc that won't play. I know that I need to work with the IN and OUT times in some way but I've never found a good explanation of how those work that made any sense to me (I've seen lots of people just say what to do with them, but if I don't understand what they are or how they work I can't adapt it to my project).
Basically to disregard all this context I've given; is there a simple and painless way to just completely replace the video streams with almost identical files while still keeping the disc otherwise unchanged? Alternatively is there a way to use MultiAVCHD to add streams to the video files themselves rather than the playlists? As some of my discs only have the master playlist with all episodes at once, and some have multiple playlists for one episode (despite only having one m2ts file for the episode), I fear it'll be too complicated to work off the playlists.
I'd also be interested in editing the menu to read in English and add options for my new audio/subs but I fear that'll get way too messy so I'm not very fussed about that.
So if anyone here is familiar with achieving what I want (basically anyone who works with Anime series BDs will probably know exactly what my issues are), any help would be seriously appreciated. I've been trying to get this going for quite some time now and I've given up on trying to learn on my own.
Sylontack is offline   Reply With Quote
Old 6th November 2016, 10:40   #7973  |  Link
Music Fan
I don't know if MultiAVCHD can help you for this but I read several times that BDedit could help a lot. Unfortunately, there is no complete tutorial over its skills but only some partial tutorials over specific cases ;
http://forum.doom9.org/showthread.php?t=152952
http://forum.doom9.org/showthread.php?t=150511
As you see, that's not simple.
Old 6th November 2016, 12:43   #7974  |  Link
Sylontack
Thanks, I'll give it another go next weekend after going over these a couple of times, unfortunately the IN and OUT time still throws me for a loop but maybe if I do a bit of trial and error with that I might figure it out because that seems to specifically be where I'm falling short.
Old 21st December 2016, 15:52   #7975  |  Link
Ghitulescu
Ghitulescu's Avatar
"Error converting subtitles (java?)"
This question has been asked once in this forum, some 250 posts ago , in the good old times when the author still answered questions, but never answered (there were two questions and only the last one has been treated). Actually it has been asked a second time, but being related to "pirated material" it wasn't answered.
Finding that error line in the log of multiAVCHD I thought that BDSubToSup has problems with java. Found that tool in its directory and double-clicked onto it - it started and worked with no problems. Not even the addition of the java and java/bin directories in the PATH variable changed something.
I am not really 100% sure but it worked once, however I do not remember if I carried out any modifications to the system apart from installing new software.
So, has anyone any idea what exactly this error message means and/or how to prevent its occurrence?
Born in the USB (not USA)
Old 16th January 2017, 10:16   #7976  |  Link
thetrooper23
Ok, i hope in the good section, hi every one and sorry for my poor (very poor) english. i hope i'll be clear.
i'm working with multivachd, and i try to use the others menus include with the installer (templates/menu) but where in the soft i can choose other one ? i don't know i can use the tree picts in the Appleseed menu, i can choose only one jpeg...
but i want to use the three images (BG/SetUP/Static)... if i choose only one, it will be update automatic for the set-up and co ?
how to import MMT file in the 4.1 Version of Multiavchd.
thanks in advance
very friendly
thetrooper23 is offline   Reply With Quote
Old 26th March 2017, 08:44   #7977  |  Link
alimao
Title movie search movie database offiline ? Any possible solution ?
alimao is offline   Reply With Quote
Old 28th April 2017, 19:43   #7978  |  Link
detroit1
in the past I used multiavchd many times successfully. Now, it is failing me almost every time. It makes the folders and they look normal but when I burn to disc using imgburn, the disc does not play on my recentl blu-ray players
I have used tsmuxer on the same exact file and that usually works but multiavchd can handle putting in multiple files with different bit rates, etc so that is why I need to get it working on my windows 10 computer
If you use multiple files on tsmuxer, you have to join them during the process and that usually causes the audio and video to get out of sync
Has anyone else noticed this ? also, is there a way to make the avchd or blu-ray folder structure and then just add videos to it an then burn ?
I'm not sure what has happened with multiavchd
detroit1 is offline   Reply With Quote
Old 28th April 2017, 19:45   #7979  |  Link
rs008f
Another reason for me to never upgrade to Windows 10.
rs008f is offline   Reply With Quote
Old 23rd May 2017, 05:50   #7980  |  Link
rs008f
Is it possible to burn HDV M2T files (1440x1080) to Bluray using multiavchd? Which other Bluray authoring software supports HDV files?
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
