26th June 2013, 23:51 | #17521 | Link |
@wakko709
Do you have coreAVC or any other AVC codecs installed? Last time I saw a similar message was when I was using BD_RB as a stress tester to check my O.C. The message I recall seeing, if I remember correctly, said "x264 or x264.exe" has stopped working. Note that it referred to x264 not h264. Last edited by gonca; 26th June 2013 at 23:54. |
28th June 2013, 04:52 | #17522 | Link | |
I now understand why I was seeing a slight "jerky" video with "The Mentalist" S1 D1 Ep1.. In Alternate MP4 (iPad) AAC...the DVD Episode isn't being rerendered to 23.976. None of the Hidden Options I've used or combinations are creating a 23.976 MP4. To verify it's possible I used HandBrake to create a smooth 23.976 Detelecined MP4. Is there something broken in that Alternate Output, perhaps? Oh, I meant to let you know is seems it Is possible to have PGSs within an MP4, it's just that iPad (2)'s software doesn't know how to deal with it so it display...only. No turning it off. Hah! A recent version of HandBrake created the file. I saw PGS was selectable, so I played. Do you really think 0 is ODD?? PULLDOWN_720=n n = 0/1 - 0=ODD (default) - if set to "1", use pulldown for 29.97->59.94 conversion on 720p
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 28th June 2013 at 04:56. |
28th June 2013, 14:52 | #17525 | Link | |
TWEAK_PASS_ONE=--opencl TWEAK_PASS_TWO=--opencl Last edited by jdobbs; 28th June 2013 at 14:57. |
28th June 2013, 15:15 | #17526 | Link | |
TWEAK_PASS_ONE=--opencl TWEAK_PASS_TWO=--opencl in bdrebuilder.ini correct? Last edited by lauguru; 28th June 2013 at 15:30. |
28th June 2013, 15:31 | #17527 | Link |
I'm not sure LAVF selection is required. Someone else may be able to give more info on its internal workings. But I can say that turning it on with Directshow enabled is actually much slower than Directshow alone when I try it with my Nvidia card.
28th June 2013, 15:54 | #17528 | Link | |
true! works now, turning to what I've said many thanks jdobbs |
28th June 2013, 16:03 | #17529 | Link |
I just checked, that the first pass has run ati stream, but the 2 pass I see that the graphics card does not process, single processor
which could be the problem? [Options] VERSION=0.44.0.14 MODE=0 TWEAK_PASS_ONE=--opencl TWEAK_PASS_TWO=--opencl THREADS=12 DVD_IMPORT_THRESHOLD=5 FORCE_ENCODE=1 DEFAULT_LANG=spa B_PYRAMID=1 MIN_M2TS_SIZE=1 MIN_PLAYLIST_MINS=1 WEIGHTP =1 DTSX_ENABLE=1 AUTO_BIAS=3 BLANK_THRESHOLD=1 ENABLE_TEST=1 ONEPASS_ENCODING=0 MULTIPROCESS=1 AUTO_QUALITY=0 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=1 DEINTERLACER_TYPE=3 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=24900 ENABLE_BLANKING=1 TARGET_SIZE=24900 OUTPUT_3D=0 PRIORITY_CLASS=1 RESIZE_1440=0 ENCODE_QUALITY=4 MOVIEONLY_TYPE=29 ALTCRF=20 ALT_TARGET=28000 ALTMETHOD=2 ALTAUTOCROP=1 RESIZE_720=0 NEROAAC=0 Last edited by lauguru; 28th June 2013 at 16:16. |
29th June 2013, 12:10 | #17530 | Link |
Hi!
Thank you for you work. I like the simplicity of your application, but unfortunately most of the times i can't use it. I have a sound delaying problem, which i don't know what causes. The inspect exe says everything is OK and i use the recommended ffdshow version. Last time i tried (version 0.44.14), i picked the high quality setting CRF, and targeted BD25 option. There were no audio reencode, i kept the HD audio too. What do you suggest? Thanks! |
29th June 2013, 13:43 | #17531 | Link |
@jdobbs
For the past few versions of BD Rebuilder, I haven't been able to do BD to DVD conversions when I include subtitles. When no subtitles are present, everything works fine. I've tried it with 4-5 different BDs and I always get the same error at the very end. This is what the log looks like. This was for 'James and the Giant Peach' but I also got the same behabior a few days ago with 'Silver Linings Playbook'. [06-22-13] BD Rebuilder v0.44.14 (beta) [11:41:45] Source: JAMESANDTHEGIANTPEACH_00100 - Input BD size: 24,21 GB - Approximate total content: [01:19:25.051] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: DVD-5, 720x480/576, AC3 Audio - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [11:41:46] PHASE ONE, Encoding - [11:41:46] Processing: VID_00066 (1 of 1) - [11:41:46] Extracting A/V streams [VID_00066] - [12:00:53] Reencoding video [VID_00066] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 114 247 frames - Bitrate: 6 687 Kbs - [12:00:53] Reencoding: VID_00066 - [13:05:46] Video Encode complete - [13:05:46] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - Track 4353 (fra): Reencoding audio to AC3... [13:09:42]PHASE ONE complete [13:09:42]PHASE TWO - Rebuild Started - [13:09:42] Building ALTERNATE OUTPUT Structure - [13:09:42] Converting 3 subtitles to DVD format. - [13:10:50] Starting MPLEX. - [13:12:58] Multiplexing 3 subtitles into stream. - WARNING: Failed to integrate Subtitle_01 - WARNING: Failed to integrate Subtitle_02 - WARNING: Failed to integrate Subtitle_03 - [13:13:06] Building DVD File Structure. - ERROR in attempt to create DVD structure (DVDAUTHOR) [13:13:06] - Failed to REBUILD The Inspect tool output looks fine too : - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.44.0.14, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - WAVI: Ok - TSMUXER: Ok Any idea ? Thanks !! |
29th June 2013, 14:26 | #17532 | Link | |
29th June 2013, 14:27 | #17533 | Link | |
29th June 2013, 15:10 | #17534 | Link | ||
My problem is more precisely is that all of the soundtracks are delayed by a couple of seconds. What kind of log would be helpful? The one that is displayed by bd_rebuilder at the end of the job? inspect.exe: Quote:
29th June 2013, 15:31 | #17537 | Link | |
It means i can't get help with my problem regarding bd rebuilder? |
29th June 2013, 15:32 | #17538 | Link |
I think you are mistaken. They both work. I tested it after your original post. You should be able to open the file LASTCMD.TXT in the installation folder and see the actual command line used for encoding.
29th June 2013, 15:34 | #17539 | Link |
Sorry, but I only support bug reports that are against original BDs. It's almost impossible to debug an issue that is the result of preprocessing. I have no idea whether the source is good. In my experience I have found that most issues (actually almost all) reported on preprocessed sources are the result of the preprocessing rather than a bug in BD-RB.
29th June 2013, 15:42 | #17540 | Link |
@ tiamat911
I just did a DVD-5 conversion from BD using a test disc -- and it worked correctly. I don't have "James and the Giant Peach" -- so I'll do another test against "Silver Linings Playbook". But so far it seems everything is executing as it should. You may want to try removing BD-RB, AVISYNTH, HAALI, and FFDSHOW and reinstall them all from scratch. |
